Name of the primary network interface, how to find in bsp header files?
Heinz Junkes
junkes at fhi-berlin.mpg.de
Sat Aug 8 11:58:41 UTC 2020
Hallo Chris,
I think there's been a misunderstanding.
I have implemented the following in the EPICS rtems_init.c :
sc = rtems_bsd_initialize();
assert (sc == RTEMS_SUCCESSFUL)
/* Let the callout timer allocate its resources */
sc = rtems_task_wake_after(2);
rtems_bsd_ifconfig_lo0();
/* lookup primary network interface */
char ifnamebuf[IF_NAMESIZE];
char *prim_ifname;
prim_ifname = if_indextoname(1, &ifnamebuf[0]);
assert(prim_ifname != NULL);
Heinz
> On 8. Aug 2020, at 03:50, Chris Johns <chrisj at rtems.org> wrote:
> On 8/8/20 5:12 am, Heinz Junkes wrote:
>> it works great with the libbsd-stack.
> I do not think it is a good idea rely on the RTEMS_BSP_NETWORK_DRIVER_NAME
> setting in libbsd. I have not questioned it before now as it has been used
> internally in the tests but exporting it as an interface is something else. It
> works for a specific case of target but it does not for others, for example the
> Xilinx Zynq has 2 MACs (cgem0, cgem1), a PC has a wide range of interfaces.
>> That is then also definitely the way to go.
> How would cgem1 on a Zynq be specified if RTEMS_BSP_NETWORK_DRIVER_NAME is
> cgem0? Also there is nothing stopping me changing RTEMS_BSP_NETWORK_DRIVER_NAME
> to cgem1 so how does that get handled?
> After 25 years doing this I have learnt to be careful about what we export and
> depend on.
>> I just remembered in the legacy stack that the network driver name
>> was set in some BSPs. But this was probably not continuous. And with the new ones, it is no longer possible.
> As a default it may be OK however it would be nice or important to allow this to
> be changed.
> How does an EPICS build for Linux on a PC deal with this given there is a large
> number of possible interface names?
> Chris
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200808/1ffea475/attachment.bin>
