[PATCH 5] shell: Only clear std handles when the shell task exits
chrisj at rtems.org
chrisj at rtems.org
Sat Aug 8 08:13:20 UTC 2020
Clearing the std file handles when the main loop exited crashes
telnetd as it reuses its session threads.
Closes #3859
cpukit/libmisc/shell/shell.c | 26 ++++++++++++++++++++++----
1 file changed, 22 insertions(+), 4 deletions(-)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 0b06e8b4d1..13ae411f9c 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -234,12 +234,16 @@ static void rtems_shell_clear_shell_env(void)
eno = pthread_setspecific(rtems_shell_current_env_key, NULL);
if (eno != 0)
rtems_error(0, "pthread_setspecific(shell_current_env_key): clear");
- * Clear stdin and stdout file pointers of they will be closed
+ * Clear stdin, stdout and stderr file pointers so they will not be closed.
+static void rtems_shell_clear_shell_std_handles(void)
stdin = NULL;
stdout = NULL;
+ stderr = NULL;
@@ -775,6 +779,7 @@ void rtems_shell_print_env(
if ( !shell_env ) {
printk( "shell_env is NULL\n" );
return;
printk( "shell_env=%p\n"
@@ -797,6 +802,7 @@ static rtems_task rtems_shell_task(rtems_task_argument task_argument)
rtems_shell_env_t *shell_env = (rtems_shell_env_t*) task_argument;
rtems_id wake_on_end = shell_env->wake_on_end;
rtems_shell_main_loop( shell_env );
+ rtems_shell_clear_shell_std_handles();
if (wake_on_end != RTEMS_INVALID_ID)
rtems_event_send (wake_on_end, RTEMS_EVENT_1);
rtems_task_exit();
@@ -872,6 +878,11 @@ bool rtems_shell_main_loop(
else
stdout = stderr;
} else if (strcmp(shell_env->output, "/dev/null") == 0) {
+ if (stdout == NULL) {
+ fprintf(stderr, "shell: stdout is NULLs\n");
+ rtems_shell_clear_shell_env();
+ return false;
fclose (stdout);
} else {
FILE *output = fopen(shell_env->output,
@@ -906,6 +917,13 @@ bool rtems_shell_main_loop(
if (!input_file) {
+ if (stdin == NULL) {
+ fprintf(stderr, "shell: stdin is NULLs\n");
+ if (stdoutToClose != NULL)
+ fclose(stdoutToClose);
+ return false;
/* Make a raw terminal, Linux Manuals */
if (tcgetattr(fileno(stdin), &previous_term) >= 0) {
term = previous_term;
@@ -967,7 +985,7 @@ bool rtems_shell_main_loop(
* keep on trucking.
if (shell_env->login_check != NULL) {
- result = rtems_shell_login(shell_env, stdin,stdout);
+ result = rtems_shell_login(shell_env, stdin, stdout);
} else {
setuid(shell_env->uid);
setgid(shell_env->gid);
2.19.1
