[PATCH 5] shell: Only clear std handles when the shell task exits
Sat Aug 8 14:10:39 UTC 2020
it should be applied with the doco patch from sebastian
On Sat, Aug 8, 2020 at 2:13 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Clearing the std file handles when the main loop exited crashes
> telnetd as it reuses its session threads.
> Closes #3859
>  cpukit/libmisc/shell/shell.c | 26 ++++++++++++++++++++++----
>  1 file changed, 22 insertions(+), 4 deletions(-)
> diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
> index 0b06e8b4d1..13ae411f9c 100644
> --- a/cpukit/libmisc/shell/shell.c
> +++ b/cpukit/libmisc/shell/shell.c
> @@ -234,12 +234,16 @@ static void rtems_shell_clear_shell_env(void)
>    eno = pthread_setspecific(rtems_shell_current_env_key, NULL);
>    if (eno != 0)
>      rtems_error(0, "pthread_setspecific(shell_current_env_key): clear");
> -   * Clear stdin and stdout file pointers of they will be closed
> + * Clear stdin, stdout and stderr file pointers so they will not be closed.
> +static void rtems_shell_clear_shell_std_handles(void)
>    stdin = NULL;
>    stdout = NULL;
> +  stderr = NULL;
> @@ -775,6 +779,7 @@ void rtems_shell_print_env(
>    if ( !shell_env ) {
>      printk( "shell_env is NULL\n" );
>      return;
>    printk( "shell_env=%p\n"
> @@ -797,6 +802,7 @@ static rtems_task rtems_shell_task(rtems_task_argument task_argument)
>    rtems_shell_env_t *shell_env = (rtems_shell_env_t*) task_argument;
>    rtems_id           wake_on_end = shell_env->wake_on_end;
>    rtems_shell_main_loop( shell_env );
> +  rtems_shell_clear_shell_std_handles();
>    if (wake_on_end != RTEMS_INVALID_ID)
>      rtems_event_send (wake_on_end, RTEMS_EVENT_1);
>    rtems_task_exit();
> @@ -872,6 +878,11 @@ bool rtems_shell_main_loop(
>      else
>        stdout = stderr;
>    } else if (strcmp(shell_env->output, "/dev/null") == 0) {
> +    if (stdout == NULL) {
> +      fprintf(stderr, "shell: stdout is NULLs\n");
> +      rtems_shell_clear_shell_env();
> +      return false;
>      fclose (stdout);
>    } else {
>      FILE *output = fopen(shell_env->output,
> @@ -906,6 +917,13 @@ bool rtems_shell_main_loop(
>    if (!input_file) {
> +    if (stdin == NULL) {
> +      fprintf(stderr, "shell: stdin is NULLs\n");
> +      if (stdoutToClose != NULL)
> +        fclose(stdoutToClose);
> +      return false;
>      /* Make a raw terminal, Linux Manuals */
>      if (tcgetattr(fileno(stdin), &previous_term) >= 0) {
>        term = previous_term;
> @@ -967,7 +985,7 @@ bool rtems_shell_main_loop(
>           *  keep on trucking.
>          if (shell_env->login_check != NULL) {
> -          result = rtems_shell_login(shell_env, stdin,stdout);
> +          result = rtems_shell_login(shell_env, stdin, stdout);
>          } else {
>            setuid(shell_env->uid);
>            setgid(shell_env->gid);
> 2.19.1
> devel mailing list
> devel at rtems.org
