[PATCH] sb/track: Add a command to track build sets.
Chris Johns
chrisj at rtems.org
Mon Aug 10 06:16:15 UTC 2020
On 10/8/20 4:12 pm, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Process a build set for a range of hosts and output a dependency
> tree, the used build set and configuration files.
> - Output the configuration files that are no referenced
> Closes #4044
This should be #4036 and #4044 will be closed as a duplicate.
