[PATCH] sb/builder: Remove sb-builder command
chrisj at rtems.org
chrisj at rtems.org
Mon Aug 10 06:50:51 UTC 2020
Closes #4045
source-builder/sb-builder | 27 ---------------------------
source-builder/sb/cmd-builder.py | 29 -----------------------------
2 files changed, 56 deletions(-)
delete mode 100755 source-builder/sb-builder
delete mode 100755 source-builder/sb/cmd-builder.py
diff --git a/source-builder/sb-builder b/source-builder/sb-builder
deleted file mode 100755
index be3d205..0000000
--- a/source-builder/sb-builder
+++ /dev/null
@@ -1,27 +0,0 @@
-#! /bin/sh
-# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2018 Chris Johns (chrisj at rtems.org)
-# All rights reserved.
-# This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Permission to use, copy, modify, and/or distribute this software for any
-# purpose with or without fee is hereby granted, provided that the above
-# copyright notice and this permission notice appear in all copies.
-# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
-# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
-# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
-# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
-# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
-# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
-# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-builder.py
-if test -f ${base}/sb/python-wrapper.sh; then
- . ${base}/sb/python-wrapper.sh
-fi
-echo "error: python wrapper not found"
diff --git a/source-builder/sb/cmd-builder.py b/source-builder/sb/cmd-builder.py
index 437b81a..0000000
--- a/source-builder/sb/cmd-builder.py
+++ /dev/null
@@ -1,29 +0,0 @@
-# Copyright 2010-2012 Chris Johns (chrisj at rtems.org)
-from __future__ import print_function
-import sys, os
-try:
- import build
- build.run(sys.argv)
-except ImportError:
- print("Incorrect Source Builder installation", file = sys.stderr)
- sys.exit(1)
2.27.0
