[PATCH] sb/bootstrap: Remove the sb-bootsrap command
    chrisj at rtems.org
    chrisj at rtems.org
    Mon Aug 10 06:53:32 UTC 2020
Closes #4046
 source-builder/sb-bootstrap        |  27 ---
 source-builder/sb/bootstrap.py     | 273 -----------------------------
 source-builder/sb/cmd-bootstrap.py |  29 ---
 3 files changed, 329 deletions(-)
 delete mode 100755 source-builder/sb-bootstrap
 delete mode 100644 source-builder/sb/bootstrap.py
 delete mode 100755 source-builder/sb/cmd-bootstrap.py
diff --git a/source-builder/sb-bootstrap b/source-builder/sb-bootstrap
deleted file mode 100755
index 618e2bb..0000000
--- a/source-builder/sb-bootstrap
+++ /dev/null
@@ -1,27 +0,0 @@
-#! /bin/sh
-# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2018 Chris Johns (chrisj at rtems.org)
-# All rights reserved.
-# This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Permission to use, copy, modify, and/or distribute this software for any
-# purpose with or without fee is hereby granted, provided that the above
-# copyright notice and this permission notice appear in all copies.
-# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
-# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
-# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
-# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
-# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
-# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
-# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-bootstrap.py
-if test -f ${base}/sb/python-wrapper.sh; then
-  . ${base}/sb/python-wrapper.sh
-fi
-echo "error: python wrapper not found"
diff --git a/source-builder/sb/bootstrap.py b/source-builder/sb/bootstrap.py
deleted file mode 100644
index ec7d7c3..0000000
--- a/source-builder/sb/bootstrap.py
+++ /dev/null
@@ -1,273 +0,0 @@
-# Copyright 2013-2016 Chris Johns (chrisj at rtems.org)
-from __future__ import print_function
-import datetime
-import operator
-import os
-import re
-import sys
-import threading
-import time
-import error
-import log
-import options
-import path
-import version
-def _collect(path_, file):
-    confs = []
-    for root, dirs, files in os.walk(path.host(path_), topdown = True):
-        for f in files:
-            if f == file:
-                confs += [path.shell(path.join(root, f))]
-    return confs
-def _grep(file, pattern):
-    rege = re.compile(pattern)
-    try:
-        f = open(path.host(file), 'r')
-        matches = [rege.match(l) != None for l in f.readlines()]
-        f.close()
-    except IOError as err:
-        raise error.general('reading: %s' % (file))
-    return True in matches
-class command:
-    def __init__(self, cmd, cwd):
-        self.exit_code = 0
-        self.thread = None
-        self.output = None
-        self.cmd = cmd
-        self.cwd = cwd
-        self.result = None
-    def runner(self):
-        import subprocess
-        # Support Python 2.6
-        if "check_output" not in dir(subprocess):
-            def f(*popenargs, **kwargs):
-                if 'stdout' in kwargs:
-                    raise ValueError('stdout argument not allowed, it will be overridden.')
-                process = subprocess.Popen(stdout=subprocess.PIPE, *popenargs, **kwargs)
-                output, unused_err = process.communicate()
-                retcode = process.poll()
-                if retcode:
-                    cmd = kwargs.get("args")
-                    if cmd is None:
-                        cmd = popenargs[0]
-                    raise subprocess.CalledProcessError(retcode, cmd)
-                return output
-            subprocess.check_output = f
-        self.start_time = datetime.datetime.now()
-        try:
-            try:
-                if os.name == 'nt':
-                    cmd = ['sh', '-c'] + self.cmd
-                else:
-                    cmd = self.cmd
-                self.output = subprocess.check_output(cmd, cwd = path.host(self.cwd))
-            except subprocess.CalledProcessError as cpe:
-                self.exit_code = cpe.returncode
-                self.output = cpe.output
-            except OSError as ose:
-                raise error.general('bootstrap failed: %s in %s: %s' % \
-                                        (' '.join(cmd), path.host(self.cwd), (str(ose))))
-            except KeyboardInterrupt:
-                pass
-            except:
-                raise
-        except:
-            self.result = sys.exc_info()
-        self.end_time = datetime.datetime.now()
-    def run(self):
-        self.thread = threading.Thread(target = self.runner)
-        self.thread.start()
-    def is_alive(self):
-        return self.thread and self.thread.is_alive()
-    def reraise(self):
-        if self.result is not None:
-            raise self.result[0](self.result[1])
-class autoreconf:
-    def __init__(self, topdir, configure):
-        self.topdir = topdir
-        self.configure = configure
-        self.cwd = path.dirname(self.configure)
-        self.command = command(['autoreconf', '-i', '--no-recursive'], self.cwd)
-        self.command.run()
-        return self.command.is_alive()
-    def post_process(self):
-        if self.command is not None:
-            self.command.reraise()
-            if self.command.exit_code != 0:
-                raise error.general('error: autoreconf: %s' % (' '.join(self.command.cmd)))
-            makefile = path.join(self.cwd, 'Makefile.am')
-            if path.exists(makefile):
-                if _grep(makefile, 'stamp-h\.in'):
-                    stamp_h = path.join(self.cwd, 'stamp-h.in')
-                    try:
-                        t = open(path.host(stamp_h), 'w')
-                        t.write('timestamp')
-                        t.close()
-                        raise error.general('writing: %s' % (stamp_h))
-def generate(topdir, jobs):
-    if type(jobs) is str:
-        jobs = int(jobs)
-    start_time = datetime.datetime.now()
-    confs = _collect(topdir, 'configure.ac')
-    next = 0
-    autoreconfs = []
-    while next < len(confs) or len(autoreconfs) > 0:
-        if next < len(confs) and len(autoreconfs) < jobs:
-            log.notice('%3d/%3d: autoreconf: %s' % \
-                           (next + 1, len(confs), confs[next][len(topdir) + 1:]))
-            autoreconfs += [autoreconf(topdir, confs[next])]
-            next += 1
-        else:
-            for ac in autoreconfs:
-                if not ac.is_alive():
-                    ac.post_process()
-                    autoreconfs.remove(ac)
-                    del ac
-            if len(autoreconfs) >= jobs:
-                time.sleep(1)
-    end_time = datetime.datetime.now()
-    log.notice('Bootstrap time: %s' % (str(end_time - start_time)))
-class ampolish3:
-    def __init__(self, topdir, makefile):
-        self.makefile = makefile
-        self.preinstall = path.join(path.dirname(makefile), 'preinstall.am')
-        self.command = command([path.join(topdir, 'ampolish3'), makefile], self.topdir)
-                raise error.general('error: ampolish3: %s' % (' '.join(self.command.cmd)))
-            try:
-                p = open(path.host(self.preinstall), 'w')
-                for l in self.command.output:
-                    p.write(l)
-                p.close()
-                raise error.general('writing: %s' % (self.preinstall))
-def preinstall(topdir, jobs):
-        jobs = int(jobs)
-    makes = []
-    for am in _collect(topdir, 'Makefile.am'):
-        if _grep(am, 'include .*/preinstall\.am'):
-            makes += [am]
-    next = 0
-    ampolish3s = []
-    while next < len(makes) or len(ampolish3s) > 0:
-        if next < len(makes) and len(ampolish3s) < jobs:
-            log.notice('%3d/%3d: ampolish3: %s' % \
-                           (next + 1, len(makes), makes[next][len(topdir) + 1:]))
-            ampolish3s += [ampolish3(topdir, makes[next])]
-            next += 1
-        else:
-            for ap in ampolish3s:
-                if not ap.is_alive():
-                    ap.post_process()
-                    ampolish3s.remove(ap)
-                    del ap
-            if len(ampolish3s) >= jobs:
-                time.sleep(1)
-    log.notice('Preinstall time: %s' % (str(end_time - start_time)))
-def run(args):
-    try:
-        # On Windows MSYS2 prepends a path to itself to the environment
-        # path. This means the RTEMS specific automake is not found and which
-        # breaks the bootstrap. We need to remove the prepended path. Also
-        # remove any ACLOCAL paths from the environment.
-            cspath = os.environ['PATH'].split(os.pathsep)
-            if 'msys' in cspath[0] and cspath[0].endswith('bin'):
-                os.environ['PATH'] = os.pathsep.join(cspath[1:])
-            if 'ACLOCAL_PATH' in os.environ:
-                # The clear fails on a current MSYS2 python (Feb 2016). Delete
-                # the entry if the clear fails.
-                try:
-                    os.environ['ACLOCAL_PATH'].clear()
-                except:
-                    del os.environ['ACLOCAL_PATH']
-        optargs = { '--rtems':       'The RTEMS source directory',
-                    '--preinstall':  'Preinstall AM generation' }
-        log.notice('RTEMS Source Builder - RTEMS Bootstrap, %s' % (version.string()))
-        opts = options.load(sys.argv, optargs, logfile = False)
-        if opts.get_arg('--rtems'):
-            topdir = opts.get_arg('--rtems')
-        else:
-            topdir = os.getcwd()
-        if opts.get_arg('--preinstall'):
-            preinstall(topdir, opts.jobs(opts.defaults['_ncpus']))
-        else:
-            generate(topdir, opts.jobs(opts.defaults['_ncpus']))
-    except error.general as gerr:
-        print(gerr)
-        print('Bootstrap FAILED', file = sys.stderr)
-        sys.exit(1)
-    except error.internal as ierr:
-        print(ierr)
-        sys.exit(1)
-    except error.exit as eerr:
-        pass
-        log.notice('abort: user terminated')
-        sys.exit(1)
-    sys.exit(0)
-if __name__ == "__main__":
-    run(sys.argv)
diff --git a/source-builder/sb/cmd-bootstrap.py b/source-builder/sb/cmd-bootstrap.py
index 0243237..0000000
--- a/source-builder/sb/cmd-bootstrap.py
+++ /dev/null
@@ -1,29 +0,0 @@
-# Copyright 2013 Chris Johns (chrisj at rtems.org)
-import sys, os
-try:
-    import bootstrap
-    bootstrap.run(sys.argv)
-except ImportError:
-    print("Incorrect Source Builder installation", file = sys.stderr)
-    sys.exit(1)
2.27.0
