[PATCH] common: Remove probably superfluous import
Mon Aug 10 08:41:57 UTC 2020
On 8/7/20 2:33 pm, Sebastian Huber wrote:
> On 08/07/2020 03:11, Chris Johns wrote:
>> On 7/7/20 3:29 pm, Sebastian Huber wrote:
>>> The purpose of this import is unclear.
>>> This import caused the following error with Sphinx 3.0:
>>> Extension error:
>>> Could not import extension rtemsdomain (exception: cannot import name 'l_')
>>>   common/rtemsdomain.py | 1 -
>>>   1 file changed, 1 deletion(-)
>>> diff --git a/common/rtemsdomain.py b/common/rtemsdomain.py
>>> index 49d0728..9b092a3 100644
>>> --- a/common/rtemsdomain.py
>>> +++ b/common/rtemsdomain.py
>>> @@ -3,7 +3,6 @@ from docutils.parsers.rst import directives
>>>     from sphinx import addnodes
>>>   from sphinx.roles import XRefRole
>>> -from sphinx.locale import l_, _
>> Is this backwards compatible?
> It seems to work also with Sphinx 2.4. I didn't find uses of "l_" and "_" in the
> file.
Please push.
Thanks
