[PATCH] common: Remove probably superfluous import
Mon Aug 10 08:48:16 UTC 2020
On 10/08/2020 10:41, Chris Johns wrote:
> On 8/7/20 2:33 pm, Sebastian Huber wrote:
>> On 08/07/2020 03:11, Chris Johns wrote:
>>> On 7/7/20 3:29 pm, Sebastian Huber wrote:
>>>> The purpose of this import is unclear.
>>>> This import caused the following error with Sphinx 3.0:
>>>> Extension error:
>>>> Could not import extension rtemsdomain (exception: cannot import name 'l_')
>>>>    common/rtemsdomain.py | 1 -
>>>>    1 file changed, 1 deletion(-)
>>>> diff --git a/common/rtemsdomain.py b/common/rtemsdomain.py
>>>> index 49d0728..9b092a3 100644
>>>> --- a/common/rtemsdomain.py
>>>> +++ b/common/rtemsdomain.py
>>>> @@ -3,7 +3,6 @@ from docutils.parsers.rst import directives
>>>>      from sphinx import addnodes
>>>>    from sphinx.roles import XRefRole
>>>> -from sphinx.locale import l_, _
>>> Is this backwards compatible?
>> It seems to work also with Sphinx 2.4. I didn't find uses of "l_" and "_" in the
>> file.
> Please push.
It is already pushed to the master. Do you want it also on another branch?
