[PATCH 1/2] user: Remove RSB sb-builder command
chrisj at rtems.org
chrisj at rtems.org
Tue Aug 11 02:52:16 UTC 2020
Updates #4045
user/rsb/commands.rst | 40 -------------------------------
user/rsb/configuration.rst | 49 +++++++++++---------------------------
2 files changed, 14 insertions(+), 75 deletions(-)
diff --git a/user/rsb/commands.rst b/user/rsb/commands.rst
index b4787aa..04d3cea 100644
--- a/user/rsb/commands.rst
+++ b/user/rsb/commands.rst
@@ -295,43 +295,3 @@ The ``arguments`` are a list of build sets to build.
``--list-deps``:
Print a list of dependent files used by a build set. Dependent files have a
``dep[?]` prefix where ``?`` is a number. The files are listed alphabetically.
-Set Builder (sb-builder)
-This command builds a configuration as described in a configuration
-file. Configuration files have the extension of ``.cfg``:
-.. code-block:: none
- $ ./source-builder/sb-builder --help
- sb-builder: [options] [args]
- RTEMS Source Builder, an RTEMS Tools Project (c) 2012 Chris Johns
- Options and arguments:
- --force : Force the build to proceed
- --quiet : Quiet output (not used)
- --trace : Trace the execution
- --dry-run : Do everything but actually run the build
- --warn-all : Generate warnings
- --no-clean : Do not clean up the build tree
- --always-clean : Always clean the build tree, even with an error
- --jobs : Run with specified number of jobs, default: num CPUs.
- --host : Set the host triplet
- --build : Set the build triplet
- --target : Set the target triplet
- --prefix path : Tools build prefix, ie where they are installed
- --topdir path : Top of the build tree, default is $PWD
- --configdir path : Path to the configuration directory, default: ./config
- --builddir path : Path to the build directory, default: ./build
- --sourcedir path : Path to the source directory, default: ./source
- --patchdir path : Path to the patches directory, default: ./patches
- --tmppath path : Path to the temp directory, default: ./tmp
- --macros file[,[file] : Macro format files to load after the defaults
- --log file : Log file where all build out is written too
- --url url[,url] : URL to look for source
- --targetcflags flags : List of C flags for the target code
- --targetcxxflags flags : List of C++ flags for the target code
- --libstdcxxflags flags : List of C++ flags to build the target libstdc++ code
- --with-<label> : Add the --with-<label> to the build
- --without-<label> : Add the --without-<label> to the build
- --list-configs : List available configurations
diff --git a/user/rsb/configuration.rst b/user/rsb/configuration.rst
index e31d1bb..1403c4f 100644
--- a/user/rsb/configuration.rst
+++ b/user/rsb/configuration.rst
@@ -40,8 +40,7 @@ The configuration search path is a macro variable and is reference as
Build set files have the file extension ``.bset`` and the package build
configuration files have the file extension of ``.cfg``. The ``sb-set-builder``
-command will search for *build sets* and the ``sb-builder`` commands works with
-package build configuration files.
+command will search for *build sets*.
Both types of configuration files use the ``#`` character as a comment
character. Anything after this character on the line is ignored. There is no
@@ -450,13 +449,12 @@ tools.
File naming provides configuration management. A specific version of a package
is captured in a specific set of configuration files. The top level
-configuration file referenced in a *build set* or passed to the ``sb-builder``
-command relates to a specific configuration of the package being built. For
-example the RTEMS configuration file ``rtems-gcc-4.7.2-newlib-2.0.0-1.cfg``
-creates an RTEMS GCC and Newlib package where the GCC version is 4.7.2, the
-Newlib version is 2.0.0, plus any RTEMS specific patches that related to this
-version. The configuration defines the version numbers of the various parts
-that make up this package:
+configuration file referenced in a *build set* relates to a specific
+configuration of the package being built. For example the RTEMS configuration
+file ``rtems-gcc-4.7.2-newlib-2.0.0-1.cfg`` creates an RTEMS GCC and Newlib
+package where the GCC version is 4.7.2, the Newlib version is 2.0.0, plus any
+RTEMS specific patches that related to this version. The configuration defines
+the version numbers of the various parts that make up this package:
.. code-block:: spec
@@ -736,28 +734,11 @@ Finally there is an optional clean section. The RSB will run this section if
``--no-clean`` has not been provided on the command line. The RSB does clean up
for you.
-Once we have the configuration files we can execute the build using the
-``sb-builder`` command. The command will perform the build and create a tar file
-in the ``tar`` directory:
- $ ../source-builder/sb-builder --prefix=/usr/local \
- --log=log_dtc devel/dtc-1.2.0
- RTEMS Source Builder, Package Builder v0.2.0
- config: devel/dtc-1.2.0
- package: dtc-1.2.0-x86_64-freebsd9.1-1
- download: https://www.kernel.org/pub/software/utils/dtc/dtc-v1.2.0.tgz -> sources/dtc-v1.2.0.tgz
- building: dtc-1.2.0-x86_64-freebsd9.1-1
- $ ls tar
- dtc-1.2.0-x86_64-freebsd9.1-1.tar.bz2
-If you want to have the package installed automatically you need to create a
-build set. A build set can build one or more packages from their configurations
-at once to create a single package. For example the GNU tools is typically seen
-as binutils, GCC and GDB and a build set will build each of these packages and
-create a single build set tar file or install the tools on the host into the
-prefix path.
+To have a package installed automatically create a build set. A build set can
+build one or more packages from their configurations at once to create a
+single package. For example the GNU tools is typically seen as binutils, GCC
+and GDB and a build set will build each of these packages and create a single
+build set tar file or install the tools on the host into the prefix path.
The DTC build set file is called ``dtc.bset`` and contains:
@@ -1591,12 +1572,10 @@ The ``%endif`` macro ends a conditional logic block.
The ``%bconf_with`` macro provides a way to test if the user has passed a
-specific option on the command line with the ``--with-<label>`` option. This
-option is only available with the ``sb-builder`` command.
+specific option on the command line with the ``--with-<label>`` option.
%bconf_without
The ``%bconf_without`` macro provides a way to test if the user has passed a
-specific option on the command line with the ``--without-<label>`` option. This
+specific option on the command line with the ``--without-<label>`` option.
2.24.1
