[PATCH 2/2] user, eclipse: Remove RSB sb-bootstrap command
chrisj at rtems.org chrisj at rtems.org
Tue Aug 11 02:52:17 UTC 2020
Update #4046
 eclipse/rtems.rst               | 2 +-
 user/installation/developer.rst | 6 +++---
 user/installation/kernel.rst    | 6 +++---
 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/eclipse/rtems.rst b/eclipse/rtems.rst
index 4459749..3db2e7b 100644
--- a/eclipse/rtems.rst
+++ b/eclipse/rtems.rst
@@ -44,7 +44,7 @@ Now run the `bootstrap` command:
   $ ./bootstrap
 Sit back, this can take a while. The Getting Started Guide talks about using
-the RSB's `sb-bootstrap` to run the bootstrap process in parallel on all
+the `rtems-bootstrap` to run the bootstrap process in parallel on all
 available cores. The output of the bootstrap has not been copied into this
 documentment.
diff --git a/user/installation/developer.rst b/user/installation/developer.rst
index ff7eefe..1b2b785 100644
--- a/user/installation/developer.rst
+++ b/user/installation/developer.rst
@@ -576,12 +576,12 @@ Then we generate the pre-install header file automake make files:
   Generating ./cpukit/zlib/preinstall.am
    /c/opt/rtems/kernel/rtems
-Finally we run the RSB's parallel ``bootstrap`` command:
+Finally we run the parallel ``bootstrap`` command:
 .. code-block:: none
-  $ /c/opt/rtems/rsb/source-builder/sb-bootstrap
-  RTEMS Source Builder - RTEMS Bootstrap, 4.11 (76188ee494dd)
+  $ ./rtems-bootstrap
+  RTEMS Bootstrap, 4.11 (76188ee494dd)
     1/139: autoreconf: configure.ac
     2/139: autoreconf: c/configure.ac
     3/139: autoreconf: c/src/configure.ac
diff --git a/user/installation/kernel.rst b/user/installation/kernel.rst
index f8c3c6f..fca4ed7 100644
--- a/user/installation/kernel.rst
+++ b/user/installation/kernel.rst
@@ -57,18 +57,18 @@ The developers version of the code from git requires we ``bootstrap`` the
 source code. This is an ``autoconf`` and ``automake`` bootstrap to create the
 various files generated by ``autoconf`` and ``automake``. RTEMS does not keep
 these generated files under version control. The bootstrap process is slow so
-to speed it up the RSB provides a command that can perform the bootstrap in
+to speed it up we provide a command that can perform the bootstrap in
 parallel using your available cores. We need to enter the cloned source
 directory then run the bootstrap commands:
   $ cd rtems
-  $ ./bootstrap -c && $HOME/development/rtems/rsb/source-builder/sb-bootstrap
+  $ ./bootstrap -c && ./rtems-bootstrap
   removing automake generated Makefile.in files
   removing configure files
   removing aclocal.m4 files
-  RTEMS Source Builder - RTEMS Bootstrap, 5 (089327b5dcf9)
+  RTEMS Bootstrap, 5 (089327b5dcf9)
     2/139: autoreconf: cpukit/configure.ac
     3/139: autoreconf: tools/cpu/configure.ac
2.24.1
