[PATCH 2/2] user, eclipse: Remove RSB sb-bootstrap command
Wed Aug 12 00:31:25 UTC 2020
On 11/8/20 11:35 pm, Gedare Bloom wrote:
> On Mon, Aug 10, 2020 at 8:52 PM <chrisj at rtems.org> wrote:
>> From: Chris Johns <chrisj at rtems.org>
>> Update #4046
>>  eclipse/rtems.rst               | 2 +-
>>  user/installation/developer.rst | 6 +++---
>>  user/installation/kernel.rst    | 6 +++---
>>  3 files changed, 7 insertions(+), 7 deletions(-)
>> diff --git a/eclipse/rtems.rst b/eclipse/rtems.rst
>> index 4459749..3db2e7b 100644
>> --- a/eclipse/rtems.rst
>> +++ b/eclipse/rtems.rst
>> @@ -44,7 +44,7 @@ Now run the `bootstrap` command:
>>    $ ./bootstrap
>>  Sit back, this can take a while. The Getting Started Guide talks about using
>> -the RSB's `sb-bootstrap` to run the bootstrap process in parallel on all
>> +the `rtems-bootstrap` to run the bootstrap process in parallel on all
>>  available cores. The output of the bootstrap has not been copied into this
>>  documentment.
> unrelated, can you fix this existing typo: 'document'
Yes I will.
> rest of this doco set looks good besides what I noted about the virtualenv one.
Thanks for the review.
