[PATCH 2/2] user, eclipse: Remove RSB sb-bootstrap command
Tue Aug 11 13:35:52 UTC 2020
On Mon, Aug 10, 2020 at 8:52 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Update #4046
>  eclipse/rtems.rst               | 2 +-
>  user/installation/developer.rst | 6 +++---
>  user/installation/kernel.rst    | 6 +++---
>  3 files changed, 7 insertions(+), 7 deletions(-)
> diff --git a/eclipse/rtems.rst b/eclipse/rtems.rst
> index 4459749..3db2e7b 100644
> --- a/eclipse/rtems.rst
> +++ b/eclipse/rtems.rst
> @@ -44,7 +44,7 @@ Now run the `bootstrap` command:
>    $ ./bootstrap
>  Sit back, this can take a while. The Getting Started Guide talks about using
> -the RSB's `sb-bootstrap` to run the bootstrap process in parallel on all
> +the `rtems-bootstrap` to run the bootstrap process in parallel on all
>  available cores. The output of the bootstrap has not been copied into this
>  documentment.
unrelated, can you fix this existing typo: 'document'
rest of this doco set looks good besides what I noted about the virtualenv one.
> diff --git a/user/installation/developer.rst b/user/installation/developer.rst
> index ff7eefe..1b2b785 100644
> --- a/user/installation/developer.rst
> +++ b/user/installation/developer.rst
> @@ -576,12 +576,12 @@ Then we generate the pre-install header file automake make files:
>    Generating ./cpukit/zlib/preinstall.am
>     /c/opt/rtems/kernel/rtems
> -Finally we run the RSB's parallel ``bootstrap`` command:
> +Finally we run the parallel ``bootstrap`` command:
>  .. code-block:: none
> -  $ /c/opt/rtems/rsb/source-builder/sb-bootstrap
> -  RTEMS Source Builder - RTEMS Bootstrap, 4.11 (76188ee494dd)
> +  $ ./rtems-bootstrap
> +  RTEMS Bootstrap, 4.11 (76188ee494dd)
>      1/139: autoreconf: configure.ac
>      2/139: autoreconf: c/configure.ac
>      3/139: autoreconf: c/src/configure.ac
> diff --git a/user/installation/kernel.rst b/user/installation/kernel.rst
> index f8c3c6f..fca4ed7 100644
> --- a/user/installation/kernel.rst
> +++ b/user/installation/kernel.rst
> @@ -57,18 +57,18 @@ The developers version of the code from git requires we ``bootstrap`` the
>  source code. This is an ``autoconf`` and ``automake`` bootstrap to create the
>  various files generated by ``autoconf`` and ``automake``. RTEMS does not keep
>  these generated files under version control. The bootstrap process is slow so
> -to speed it up the RSB provides a command that can perform the bootstrap in
> +to speed it up we provide a command that can perform the bootstrap in
>  parallel using your available cores. We need to enter the cloned source
>  directory then run the bootstrap commands:
>    $ cd rtems
> -  $ ./bootstrap -c && $HOME/development/rtems/rsb/source-builder/sb-bootstrap
> +  $ ./bootstrap -c && ./rtems-bootstrap
>    removing automake generated Makefile.in files
>    removing configure files
>    removing aclocal.m4 files
> -  RTEMS Source Builder - RTEMS Bootstrap, 5 (089327b5dcf9)
> +  RTEMS Bootstrap, 5 (089327b5dcf9)
>      2/139: autoreconf: cpukit/configure.ac
>      3/139: autoreconf: tools/cpu/configure.ac
> 2.24.1
> devel mailing list
> devel at rtems.org
