[GSoC 2020] : BSP Buildset for EPICS (next steps)
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Wed Aug 12 15:20:22 UTC 2020
Thank you so much Heinz and Gedare for the suggestion of using sed instead
of patches.
The good news is that I worked with them and EPICS 7 was built successfully
for "xilinx_zynq_a9_qemu" using RSB recipe.
The changes I made were as follows:
```diff --git a/source-builder/config/epics-7-1.cfg
b/source-builder/config/epics-7-1.cfg
index 2398cacf..f51c6582 100644
--- a/source-builder/config/epics-7-1.cfg
+++ b/source-builder/config/epics-7-1.cfg
@@ -31,10 +31,20 @@ URL: https://epics.mpg.de/
source_dir_epics="epics-base-%{epics_version}"
%source setup epics -q -n epics-base-%{epics_version}
- %patch setup epics -p1
+# Changing the RTEMS Version in
epics-base/configure/os/CONFIG_SITE.Common.RTEMS
+sed -i 's/RTEMS_VERSION = .*/RTEMS_VERSION = 5/g'
+# Changing the RTEMS Base in epics-base/configure/os/CONFIG_SITE.Common.RTEMS
+sed -i "s/^RTEMS_BASE .*/RTEMS_BASE =
\/home\/mritunjay\/development\/rtems\/\$\(RTEMS_VERSION\)\-arm/g"
cd ${build_top}
%build
build_top=$(pwd)
The changes can be observed from here as well:
https://github.com/RTEMS/rtems-source-builder/commit/1e7d7d4237a479dce564711b1080a9b3225e9e9a
One issue that remains is that even after adding sha512 has for
epics-base-7.0.tar.gz, I am getting "no hash found" warning.
However, the build is running successfully.
Now that it is seen that sed can be used, the next step, in my opinion, is
to develop a logic for making these changes use-oriented as even now,
I have to specify my directory in the scripts, the only difference is that
I am using sed instead of patch.
Thank you again, Heinz and Gedare for introducing me to sed and making me
revise some regex as well!
Thanks
Mritunjay Sharma
On Wed, Aug 12, 2020 at 7:07 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Aug 12, 2020 at 1:58 AM Heinz Junkes <junkes at fhi-berlin.mpg.de>
> wrote:
> > I think you should not make a patch for these two changes but a
> > simple replacement with e.g. sed.
> > like
> > sed -i ’s/^RTEMS_BASE/RTEMS_BASE =
> \/home\/mritunjay\/development\/rtems/\$\(RTEMS_VERSION\)-arm\/g’
> > oder so ;-)
> Yes, great, that was something I think I mentioned before--the patches
> are fine to get things hacked, but we should script the configuration
> if we can from RSB. A cross-platform python-based approach must be
> used.
> > Viele Grüße
> > Heinz Junkes
> > Experience directly varies with equipment ruined.
> > > On 12. Aug 2020, at 02:13, Mritunjay Sharma <
> mritunjaysharma394 at gmail.com> wrote:
> > > Hello Heinz and everyone!
> > > Thank you so much for this update. I started to work first by building
> EPICS by hand
> > > for "xilinx_zynq_a9_qemu". Till the time, you gave
> https://gitlab.fhi.mpg.de/junkes/epics-base.git,
> > > I had to struggle with lot of errors which cloning into this repo
> solved.
> > > So I started by building "xilinx_zynq_a9_qemu" BSP for RTEMS5 using my
> own blog with only difference being
> > > that I used '--disable-networking' to use libbsd.
> > > After that, I used this blog https://rmeena840.github.io/Fourth-Post/
> of a GSoC 19 Student to build and install rtems-libbsd
> > > Everything worked perfectly fine till now. Now I entered the
> 'epics-base' directory and made
> > > the changes in configure/os/CONFIG_SITE.Common.RTEMS as:
> > > # FHI:
> > > RTEMS_SERIES = 5
> > > RTEMS_VERSION = 5
> > > RTEMS_BASE = /home/mritunjay/development/rtems/$(RTEMS_VERSION)-arm
> > > Also made the change in configure/CONFIG_SITE:
> > > CROSS_COMPILER_TARGET_ARCHS=RTEMS-xilinx_zynq_a9_qemu
> > > After this I used 'make' command and it worked fine.
> > > So, I can say that there were just two changes which I had to make
> then the previous one.
> > > The successful build by hand enabled me to work on the RSB recipe.
> > > I worked on them and it can be found here
> https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support-zynq
> > > The patch I am applying can be found here:
> https://raw.githubusercontent.com/mritunjaysharma394/epics-mritunjay/master/patches/0001-Added-support-for-RTEMS-xilinx_zynq_a9_qemu.patch
> > > However, the problem I am facing is that while building the recipe
> using:
> > > ```.../source-builder/sb-builder --log=log_epics epics-7-1```,
> > > the build is failing because it seems that Patch setup in configure
> file is not getting applied there. I followed the same steps as done for pc
> > > but this time the patch is not getting applied.
> > > It will be really helpful if you can guide where did I went wrong
> thist time.
> > > I am attaching the log and report file for reference.
> > > Thanks
> > > Mritunjay
> > > On Mon, Aug 10, 2020 at 8:56 PM junkes <junkes at fhi-berlin.mpg.de>
> wrote:
> > > Hello Mritunjay,
> > > I have now finished an EPICS variant that works with libbsd so far.
> DHCP and NFS work. NTP I added a primitive reader. This is sufficient for
> testing.
> > > You can find the development here:
> > > It's not perfect yet. The adaptation to the legacy stack and the
> processing of the environment variables from the flash (u-boot etc.) is
> still missing.
> > > [h1 at earth QtC-epics-base (7.0 *+)]$ ./startQemu softIoc
> > > Script name: ./startQemu
> > > qemu-system-aarch64: warning: nic cadence_gem.1 has no peer
> > > WARNING: OS Clock time was read before being set.
> > > Using 1990-01-02 00:00:00.000000 UTC
> > > initConsole --- Info ---
> > > stdin: fileno: 0, ttyname: /dev/ttyS1
> > > stdout: fileno: 1, ttyname: /dev/ttyS1
> > > stderr: fileno: 2, ttyname: /dev/ttyS1
> > > tcsetattr failed: I/O error
> > > time set to : 04/14/14 07:30:06.000055589 UTC
> > > Startup.
> > > epicsThreadSetPriority called by non epics thread
> > > ***** RTEMS Version: rtems-5.0.0-m2003 (ARM/ARMv4/xilinx_zynq_a9_qemu)
> > > ***** Initializing network (dhcp) *****
> > > nexus0: <RTEMS Nexus device>
> > > zy7_slcr0: <Zynq-7000 slcr block> on nexus0
> > > cgem0: <Cadence CGEM Gigabit Ethernet Interface> on nexus0
> > > miibus0: <MII bus> on cgem0
> > > e1000phy0: <Marvell 88E1111 Gigabit PHY> PHY 0 on miibus0
> > > e1000phy0: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX,
> 1000baseT-FDX, 1000baseT-FDX-master, auto
> > > e1000phy1: <Marvell 88E1111 Gigabit PHY> PHY 23 on miibus0
> > > e1000phy1: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX,
> > > info: cgem0: Ethernet address: 52:54:00:12:34:56
> > > info: lo0: link state changed to UP
> > > ---- Wait for DHCP done ...
> > > dhcpcd: unknown option -- pv4only
> > > info: version 6.2.1 starting
> > > cgem0: cgem_mediachange: could not set ref clk0 to 25000000.
> > > info: cgem0: link state changed to UP
> > > debug: cgem0: executing `ioc boot' PREINIT
> > > ***** Primary Network interface : cgem0 *****
> > > debug: cgem0: executing `ioc boot' CARRIER
> > > info: DUID 00:01:00:01:1a:de:4a:fe:52:54:00:12:34:56
> > > info: cgem0: IAID 00:12:34:56
> > > info: cgem0: soliciting an IPv6 router
> > > debug: cgem0: delaying Router Solicitation for LL address
> > > debug: cgem0: using ClientID
> 00:46:48:49:20:74:65:73:74:20:63:6c:69:65:6e:74
> > > info: cgem0: soliciting a DHCP lease
> > > debug: cgem0: sending DISCOVER (xid 0x86686938), next in %0.1f seconds
> > > info: cgem0: carrier lost
> > > debug: cgem0: executing `ioc boot' NOCARRIER
> > > info: cgem0: carrier acquired
> > > debug: cgem0: sending DISCOVER (xid 0x441a0d89), next in %0.1f seconds
> > > debug: cgem0: wrong xid 0x86686938 (expecting 0x441a0d89) from 10.1.0.1
> > > info: cgem0: offered 10.1.0.104 from 10.1.0.1
> > > debug: cgem0: sending REQUEST (xid 0x441a0d89), next in %0.1f seconds
> > > debug: cgem0: acknowledged 10.1.0.104 from 10.1.0.1
> > > debug: cgem0: checking for 10.1.0.104
> > > debug: cgem0: sending ARP probe (1 of 3), next in %0.1f seconds
> > > debug: cgem0: sending ARP probe (2 of 3), next in %0.1f seconds
> > > debug: cgem0: sending ARP probe (3 of 3), next in %0.1f seconds
> > > info: cgem0: leased 10.1.0.104 for 6000 seconds
> > > debug: cgem0: renew in 3000 seconds, rebind in 5250 seconds
> > > debug: cgem0: adding IP address 10.1.0.104/24
> > > info: cgem0: adding host route to 10.1.0.104 via 127.0.0.1
> > > err: cgem0: ipv4_addroute: File exists
> > > info: cgem0: adding route to 10.1.0.0/24
> > > info: cgem0: adding default route via 10.1.0.1
> > > debug: cgem0: writing lease `/var/db/dhcpcd-cgem0.lease'
> > > debug: cgem0: executing `ioc boot' BOUND
> > > Interface TGP bounded
> > > rtems_bsdnet_bootp_server_name : 1001.1001 at 10.1.0.1:/Volumes/Epics
> > > rtems_bsdnet_bootp_boot_file_name :
> /Volumes/Epics/myExample/bin/RTEMS-xilinx_zynq_a9_qemu/myExample.boot
> > > rtems_bsdnet_bootp_cmdline :
> /Volumes/Epics/myExample/iocBoot/iocmyExample/st.cmd
> > > debug: cgem0: sending ARP announce (1 of 2), next in 2.0 seconds
> > > -------------- IFCONFIG -----------------
> > > cgem0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu
> 1500
> > > options=80008<VLAN_MTU,LINKSTATE>
> > > ether 52:54:00:12:34:56
> > > inet6 fe80::5054:ff:fe12:3456%cgem0 prefixlen 64 scopeid 0x1
> > > inet 10.1.0.104 netmask 0xffffff00 broadcast 10.1.0.255
> > > nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
> > > media: Ethernet autoselect (100baseTX <full-duplex>)
> > > status: active
> > > lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
> > > options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
> > > inet 127.0.0.1 netmask 0xffffff00
> > > inet6 ::1 prefixlen 128
> > > inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
> > > groups: lo
> > > -------------- NETSTAT ------------------
> > > Routing tables
> > > Internet:
> > > Destination Gateway Flags Netif Expire
> > > default 10.1.0.1 UGS cgem0
> > > 10.1.0.0/24 link#1 U cgem0
> > > 10.1.0.104 link#1 UHS lo0
> > > 127.0.0.1 link#2 UH lo0
> > > Internet6:
> Netif Expire
> > > ::1 link#2 UH
> lo0
> > > fe80::%cgem0/64 link#1 U
> cgem0
> > > fe80::5054:ff:fe12:3456%cgem0 link#1 UHS
> lo0
> > > fe80::%lo0/64 link#2 U
> lo0
> > > fe80::1%lo0 link#2 UHS
> lo0
> > > ***** Until now no NTP support in RTEMS 5 with rtems-libbsd *****
> > > ***** Ask ntp server once... *****
> > > time from ntp : 08/10/20 15:08:41.000055589 UTC
> > > ***** Setting up file system *****
> > > ***** Initializing NFS *****
> > > rtems_bootp_server_name: 1001.1001 at 10.1.0.1:/Volumes/Epics
> > > nfsMount("1001.1001 at 10.1.0.1", "/Volumes/Epics", "/Volumes/Epics")
> > > Mount 1001.1001 at 10.1.0.1:/Volumes/Epics on /Volumes/Epics
> > > Warning: EPICS_TIMEZONE (CST6CDT,M3.2.0/2,M11.1.0/2) unrecognizable --
> times will be displayed as GMT.
> > > check for time registered , C++ initialization ...
> > > ***** Preparing EPICS application *****
> > > chdir("/Volumes/Epics/myExample/iocBoot/iocmyExample/")
> > > ***** Starting EPICS application *****
> > > dbLoadDatabase("../../dbd/softIoc.dbd")
> > > Can't register 'system' command -- no command interpreter available.
> > > softIoc_registerRecordDeviceDriver(pdbbase)
> > > # Begin /Volumes/Epics/myExample/iocBoot/iocmyExample/st.cmd
> > > iocInit()
> > > Starting iocInit
> > > ## EPICS R7.0.3.2-DEV
> > > ## Rev. R7.0.3.1-105-ge597f8104c18ec7b9fc5-dirty
> > > debug: cgem0: sending ARP announce (2 of 2)
> > > Warning: RSRV has empty beacon address list
> > > epicsThreadRealtimeLock Warning: Unable to lock the virtual address
> space.
> > > VM page faults may harm real-time performance. errno=22
> > > iocRun: All initialization complete
> > > # End /Volumes/Epics/myExample/iocBoot/iocmyExample/st.cmd
> > > On 2020-08-08 21:58, Mritunjay Sharma wrote:
> > >> On Sat, Aug 8, 2020 at 11:10 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> > >> On Sat, Aug 8, 2020 at 11:08 AM Mritunjay Sharma
> > >> <mritunjaysharma394 at gmail.com> wrote:
> > >> > On Sat, Aug 8, 2020 at 9:46 PM Heinz Junkes <
> junkes at fhi-berlin.mpg.de> wrote:
> > >> >> Hallo Mritunjay,
> > >> >> everything looks pretty good. I'm commenting on the text. I also
> send this mail
> > >> >> to two EPICS experts (Andrew Johnson and Michael Davidsaver).
> Maybe they also have some ideas.
> > >> > Thank you so much Heinz! It will be really a great help!
> > >> >> > Current Status:
> > >> >> > 1) Successfully built EPICS7 with RTEMS5 by hand for pc-386
> > >> >> > 2) Worked for RSB recipe.
> > >> >> > In its due process, I Wrote:
> > >> >> > i) rsb/rtems/config/epics/epics-7-1.cfg
> > >> >> > ii)rsb/rtems/config/epics/epics-base.bset
> > >> >> > iii)rsb/source-builder/config/epics-7-1.cfg
> > >> >> > 3) Added Patch for RTEMS-pc-386 support which made the above
> recipe work successfully.
> > >> >> > 4) Therefore, Successully built EPICS7 with RTEMS5 by using RSB
> recipe as well for pc-386 as of now.
> > >> >> > 5) Sent 4 Patches for review of the same.
> > >> >> > What problems are in the next steps?
> > >> >> > 1) How to make it work across different architectures?
> > >> >> > 2) Exisiting EPICS works on the old legacy network stack.
> > >> >> > 3) I am not using EPICS upstream branch. It is being built
> > >> >> > by Heinz's epics playground.
> > >> >> > 4) Doubts in how to start with testing.
> > >> >> > My Resarch work for the Problem no: 1
> > >> >> > I have gone through the EPICS developer guide from here
> > >> >> > exhaustively in the past couple of day and here are few
> interesting things
> > >> >> > that I found which can help:
> > >> >> > 1) "The main ingredients of the build system are:
> > >> >> > • A set of configuration files and tools provided in the EPICS
> base/configure directory
> > >> >> > • A corresponding set of configuration files in the
> <top>/configure directory of a non-base <top> directory
> > >> >> > structure to be built. The makeBaseApp.pl and makeBaseExt.pl
> scripts create these configuration files. Many of
> > >> >> > these files just include a file of the same name from the
> base/configure directory.
> > >> >> > • Makefiles in each directory of the <top> directory structure
> to be built
> > >> >> > • User created configuration files in build created
> $(INSTALL_LOCATION)/cfg directories.
> > >> >> > Remarks: Now since it is also mentioned in the guide that
> "makeBaseApp.pl
> > >> >> > creates directories and then copies template files into the
> newly created directories
> > >> >> > while expanding macros in the template files. EPICS base
> provides two sets of template files: simple and example."
> > >> >> > Can we think of using makeBaseApp.pl to that end? Making the
> user allow
> > >> >> > to change the configurations from the terminal?
> > >> >> I don't think that makeBaseApp.pl will help you. This is intended
> to build an example IOC. It takes the settings from the above mentioned
> > >> >> You "only" need to specify the location of the RTEMS installation
> in configure/os/CONFIG_SITE.Common.RTEMS.
> > >> >> RTEMS_VERSION =
> > >> >> RTEMS_BASE =
> > >> >> Then you have to define the target in configure/CONFIG_SITE:
> > >> >> # Which target architectures to cross-compile for.
> > >> >> # Definitions in configure/os/CONFIG_SITE.<host>.Common
> > >> >> # may override this setting.
> > >> >> e.g. "CROSS_COMPILER_TARGET_ARCHS=RTEMS-xilinx_zynq_a9_qemu"
> > >> >> And for each target there must be a file in configure/os:
> > >> >> e.g. CONFIG_Common.RTEMS-xilinx_zynq_a9_qemu
> > >> >> If it is not provided by EPICS, the RSB should install it there
> (adapted to the target to be used by epics make).
> > >> Probably they should be provided by EPICS for known-to-work
> > >> configurations. If they are not, we should push upstream.
> > >> > Yes, Heinz. I followed the above steps and created a patch which I
> applied in the configuration files of RSB recipe.
> > >> > The problem with it is that it's made only for pc-386 and I have to
> hardcode there about location of the RTEMS installation in
> > >> > configure/os/CONFIG_SITE.Common.RTEMS. My doubt is how to modify
> the patch that can it offer user-specific location of the RTEMS
> > >> > installation and bsp?
> > >> I still think this should be done through some kind of pre-processing
> > >> (scripting) over these configuration files for a given target, using
> > >> some fixed pattern, rather than by patching. A patch is fine for
> > >> proof-of-concept, but I don't think we want to have x patches for x
> > >> BSP targets of EPICS. Maybe it is fine, there aren't that many BSP
> > >> targets right now, but I can see this kind of patch-based
> > >> configuration getting a little unwieldy.
> > >> If you proceed with the patch-based approach, you need to figure out
> > >> how to pick the right patch to apply based on the target/bsp build. So
> > >> that would be your next step. Create a patch for the zynq, and see if
> > >> you can dynamically determine which one to apply (zynq or pc386) based
> > >> on RSB internal state/variables.
> > >> Thank you for the suggestions. I will start working on creating the
> patch for zynq and will see if
> > >> something can be done to dynamically determine them.
> > >> >> > 2) "The startup directory in EPICS base contains a perl script,
> EpicsHostArch.pl, which can be used to define
> > >> >> > EPICS_HOST_ARCH. This script can be invoked with a command line
> parameter defining the alternate compiler (e.g.
> > >> >> > if invoking EpicsHostArch.pl yields solaris-sparc, then invoking
> EpicsHostArch.pl gnu will yield
> > >> >> > solaris-sparc-gnu).
> > >> >> > The startup directory also contains scripts to help users set
> the path and other environment variables"
> > >> >> This has nothing to do with 2)
> > >> > I am sorry for the misunderstanding. All the 4 points mentioned
> here are my observations only for the Problem No.1
> > >> > `1) How to make it work across different architectures?`
> > >> >> There's no need to adjust anything here. The EPICS make recognizes
> the architecture on which it is started.
> > >> >> > Remarks: As EPICS_HOST_ARCH, can we do something similar for
> CROSS_COMPILER_TARGET_ARCHS?
> > >> >> > 3) ") The following is a summary of targets that can be
> specified for gnumake:
> > >> >> > • <action>
> > >> >> > • <arch>
> > >> >> > • <action>.<arch>
> > >> >> > • <dir>
> > >> >> > • <dir>.<action>
> > >> >> > • <dir>.<arch>
> > >> >> > • <dir>.<action>.<arch>
> > >> >> > where:
> > >> >> > <arch> is an architecture such as solaris-sparc, vxWorks-68040,
> win32-x86, etc.
> > >> >> > <action> is help, clean, realclean, distclean, inc, install,
> build, rebuild, buildInstall, realuninstall, or uninstall"
> > >> >> > Remarks: Now similar to the above stated, can we work for Cross
> Compiler target Architecture?
> > >> >> But this does not refer to 3) ?
> > >> > No no, this remark is also for the problem 1 only as told above.
> Slight misunderstanding here :)
> > >> >> 3) You have to take "my" repo at the moment, because the
> adaptations to RTEMS5 are not yet included in the official epics-base. This
> is a hen-and-egg problem because RTEMS is only now in the release phase, so
> my changes have not been implemented yet.
> > >> > Ok, I hope Dr. Gedare and Chris can help you with that.
> > >> We just need to be ready for when RTEMS 5.1 is officially released.
> > >> Hopefully soon, but I don't have a timeline. Releases are mostly
> > >> volunteer time, so they happen when they happen. We're trying to get
> > >> better about that, but it is hard (due to lack of incentives).
> > >> I think that makes it clear, Heinz.
> > >> >> 2) I'm just about to figure out in the Epics Makefiles whether the
> target was built with the legacy-stack or libbsd-stack. It's working
> already.
> > >> >> Now I also have to adjust the rtems_init.c accordingly. Here I
> have to clean up a little bit. But I hope to have this finished by the
> middle of the week.
> > >> > Thank you so much for the update!
> > >> > So I would like to ask my other mentors - what can I do for the
> time being? What should be the next steps for this week?
> > >> Prepare the zynq patch and try to work out the logic of how to select
> > >> the right patch to apply.
> > >> Then similar logic might be usable to script the configuration changes
> > >> of EPICS so we don't need patches.
> > >> Sure, I will do and update soon.
> > >> > And yes how to begin the testing part?
> > >> This was suggested by Heinz earlier to look at the CI test scripts
> > >> that EPICS maintainers use.
> > >> Yes, it slipped out of my mind. Will check and revert.
> > >> Thanks
> > >> Mritunjay Sharma
> > >> > I have tried to find some resources but I think it will be
> > >> > better if you can help somewhere to look at.
> > >> > Thanks
> > >> > Mritunjay Sharma
> > >> >> > These were the little doubts that originated from the research
> work I did.
> > >> >> > I will like the opinion of mentors that what can be the optimal
> way now to approach the
> > >> >> > project after this? What can be some resources for better
> research work of the
> > >> >> > above problems?
> > >> >> > Also, for the reference:
> > >> >> > Link to the changes in commits of rsb can be found here:
> > >> >> > The patch for epics can be found here:
> https://github.com/mritunjaysharma394/epics-mritunjay/tree/master/patches
> > >> >> > Thanks
> > >> >> > Mritunjay Sharma
> > >> >> Heinz
> > > <rsb-report-epics-base-7.0-x86_64-linux-gnu-1.txt><log_epics>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200812/c617b752/attachment-0001.html>
