[GSoC 2020] : BSP Buildset for EPICS (next steps)
Wed Aug 12 15:42:24 UTC 2020
On Wed, Aug 12, 2020 at 9:20 AM Mritunjay Sharma
<mritunjaysharma394 at gmail.com> wrote:
> Thank you so much Heinz and Gedare for the suggestion of using sed instead of patches.
> The good news is that I worked with them and EPICS 7 was built successfully
> for "xilinx_zynq_a9_qemu" using RSB recipe.
> The changes I made were  as follows:
> ```diff --git a/source-builder/config/epics-7-1.cfg b/source-builder/config/epics-7-1.cfg
> index 2398cacf..f51c6582 100644
> --- a/source-builder/config/epics-7-1.cfg
> +++ b/source-builder/config/epics-7-1.cfg
> @@ -31,10 +31,20 @@ URL:  https://epics.mpg.de/
>    source_dir_epics="epics-base-%{epics_version}"
>    %source setup epics -q -n epics-base-%{epics_version}
> -  %patch setup epics -p1
> +# Changing the RTEMS Version in epics-base/configure/os/CONFIG_SITE.Common.RTEMS
> +sed -i 's/RTEMS_VERSION = .*/RTEMS_VERSION = 5/g' configure/os/CONFIG_SITE.Common.RTEMS
> +# Changing the RTEMS Base in epics-base/configure/os/CONFIG_SITE.Common.RTEMS
> +sed -i "s/^RTEMS_BASE .*/RTEMS_BASE = \/home\/mritunjay\/development\/rtems\/\$\(RTEMS_VERSION\)\-arm/g" configure/os/CONFIG_SITE.Common.RTEMS
>    cd ${build_top}
>  %build
>    build_top=$(pwd)
> The changes can be observed from here as well: https://github.com/RTEMS/rtems-source-builder/commit/1e7d7d4237a479dce564711b1080a9b3225e9e9a
> One issue that remains is that even after adding sha512 has for epics-base-7.0.tar.gz, I am getting "no hash found"  warning.
> However, the build is running successfully.
> Now that it is seen that sed can be used, the next step, in my opinion, is to develop a logic for making these changes use-oriented as even now,
> I have to specify my directory in the scripts, the only difference is that I am using sed instead of patch.
sed is not cross-platform. you need to find something in Python you can use.
> Thank you again, Heinz and Gedare for introducing me to sed and making me revise some regex as well!
> Thanks
> Mritunjay Sharma
> On Wed, Aug 12, 2020 at 7:07 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Wed, Aug 12, 2020 at 1:58 AM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
>> > I think you should not make a patch for these two changes but a
>> > simple replacement with e.g. sed.
>> > like
>> > sed -i ’s/^RTEMS_BASE/RTEMS_BASE = \/home\/mritunjay\/development\/rtems/\$\(RTEMS_VERSION\)-arm\/g’ configure/os/CONFIG_SITE.Common.RTEMS
>> > oder so ;-)
>> Yes, great, that was something I think I mentioned before--the patches
>> are fine to get things hacked, but we should script the configuration
>> if we can from RSB. A cross-platform python-based approach must be
>> used.
>> > Viele Grüße
>> > Heinz Junkes
>> > Experience directly varies with equipment ruined.
>> > > On 12. Aug 2020, at 02:13, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
>> > > Hello Heinz and everyone!
>> > > Thank you so much for this update. I started to work first by building EPICS by hand
>> > > for "xilinx_zynq_a9_qemu". Till the time, you gave https://gitlab.fhi.mpg.de/junkes/epics-base.git,
>> > > I had to struggle with lot of errors which cloning into this repo solved.
>> > > So I started by building "xilinx_zynq_a9_qemu" BSP for RTEMS5 using my own blog with only difference being
>> > > that  I used '--disable-networking' to use libbsd.
>> > > After that, I used this blog https://rmeena840.github.io/Fourth-Post/ of a GSoC 19 Student to build and install rtems-libbsd
>> > > Everything worked perfectly fine till now. Now I entered the 'epics-base' directory and made
>> > > the changes in configure/os/CONFIG_SITE.Common.RTEMS as:
>> > > # FHI:
>> > > RTEMS_SERIES = 5
>> > > RTEMS_VERSION = 5
>> > > RTEMS_BASE = /home/mritunjay/development/rtems/$(RTEMS_VERSION)-arm
>> > > Also made the change in configure/CONFIG_SITE:
>> > > CROSS_COMPILER_TARGET_ARCHS=RTEMS-xilinx_zynq_a9_qemu
>> > > After this I used 'make' command and it worked fine.
>> > > So, I can say that there were just two changes which I had to make then the previous one.
>> > > The successful build by hand enabled me to work on the RSB recipe.
>> > > I worked on them and it can be found here https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support-zynq.
>> > > The patch I am applying can be found here: https://raw.githubusercontent.com/mritunjaysharma394/epics-mritunjay/master/patches/0001-Added-support-for-RTEMS-xilinx_zynq_a9_qemu.patch
>> > > However, the problem I am facing is that while building the recipe using:
>> > > ```.../source-builder/sb-builder --log=log_epics epics-7-1```,
>> > > the build is failing because it seems that Patch setup in configure file is not getting applied there. I followed the same steps as done for pc
>> > > but this time the patch is not getting applied.
>> > > It will be really helpful if you can guide where did I went wrong thist time.
>> > > I am attaching the log and report file for reference.
>> > > Thanks
>> > > Mritunjay
>> > > On Mon, Aug 10, 2020 at 8:56 PM junkes <junkes at fhi-berlin.mpg.de> wrote:
>> > > Hello Mritunjay,
>> > > I have now finished an EPICS variant that works with libbsd so far. DHCP and NFS work. NTP I added a primitive reader. This is sufficient for testing.
>> > > You can find the development here:
>> > > It's not perfect yet. The adaptation to the legacy stack and the processing of the environment variables from the flash (u-boot etc.) is still missing.
>> > > [h1 at earth QtC-epics-base (7.0 *+)]$ ./startQemu softIoc
>> > > Script name: ./startQemu
>> > > qemu-system-aarch64: warning: nic cadence_gem.1 has no peer
>> > > WARNING: OS Clock time was read before being set.
>> > > Using 1990-01-02 00:00:00.000000 UTC
>> > > initConsole --- Info ---
>> > > stdin: fileno: 0, ttyname: /dev/ttyS1
>> > > stdout: fileno: 1, ttyname: /dev/ttyS1
>> > > stderr: fileno: 2, ttyname: /dev/ttyS1
>> > > tcsetattr failed: I/O error
>> > > time set to : 04/14/14 07:30:06.000055589 UTC
>> > > Startup.
>> > > epicsThreadSetPriority called by non epics thread
>> > > ***** RTEMS Version: rtems-5.0.0-m2003 (ARM/ARMv4/xilinx_zynq_a9_qemu) *****
>> > > ***** Initializing network (dhcp) *****
>> > > nexus0: <RTEMS Nexus device>
>> > > zy7_slcr0: <Zynq-7000 slcr block> on nexus0
>> > > cgem0: <Cadence CGEM Gigabit Ethernet Interface> on nexus0
>> > > miibus0: <MII bus> on cgem0
>> > > e1000phy0: <Marvell 88E1111 Gigabit PHY> PHY 0 on miibus0
>> > > e1000phy0:  none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT-FDX, 1000baseT-FDX-master, auto
>> > > e1000phy1: <Marvell 88E1111 Gigabit PHY> PHY 23 on miibus0
>> > > e1000phy1:  none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT-FDX, 1000baseT-FDX-master, auto
>> > > info: cgem0: Ethernet address: 52:54:00:12:34:56
>> > > info: lo0: link state changed to UP
>> > > ---- Wait for DHCP done ...
>> > > dhcpcd: unknown option -- pv4only
>> > > info: version 6.2.1 starting
>> > > cgem0: cgem_mediachange: could not set ref clk0 to 25000000.
>> > > info: cgem0: link state changed to UP
>> > > debug: cgem0: executing `ioc boot' PREINIT
>> > > ***** Primary Network interface : cgem0 *****
>> > > debug: cgem0: executing `ioc boot' CARRIER
>> > > info: DUID 00:01:00:01:1a:de:4a:fe:52:54:00:12:34:56
>> > > info: cgem0: IAID 00:12:34:56
>> > > info: cgem0: soliciting an IPv6 router
>> > > debug: cgem0: delaying Router Solicitation for LL address
>> > > debug: cgem0: using ClientID 00:46:48:49:20:74:65:73:74:20:63:6c:69:65:6e:74
>> > > info: cgem0: soliciting a DHCP lease
>> > > debug: cgem0: sending DISCOVER (xid 0x86686938), next in %0.1f seconds
>> > > info: cgem0: carrier lost
>> > > debug: cgem0: executing `ioc boot' NOCARRIER
>> > > info: cgem0: carrier acquired
>> > > debug: cgem0: sending DISCOVER (xid 0x441a0d89), next in %0.1f seconds
>> > > debug: cgem0: wrong xid 0x86686938 (expecting 0x441a0d89) from 10.1.0.1
>> > > info: cgem0: offered 10.1.0.104 from 10.1.0.1
>> > > debug: cgem0: sending REQUEST (xid 0x441a0d89), next in %0.1f seconds
>> > > debug: cgem0: acknowledged 10.1.0.104 from 10.1.0.1
>> > > debug: cgem0: checking for 10.1.0.104
>> > > debug: cgem0: sending ARP probe (1 of 3), next in %0.1f seconds
>> > > debug: cgem0: sending ARP probe (2 of 3), next in %0.1f seconds
>> > > debug: cgem0: sending ARP probe (3 of 3), next in %0.1f seconds
>> > > info: cgem0: leased 10.1.0.104 for 6000 seconds
>> > > debug: cgem0: renew in 3000 seconds, rebind in 5250 seconds
>> > > debug: cgem0: adding IP address 10.1.0.104/24
>> > > info: cgem0: adding host route to 10.1.0.104 via 127.0.0.1
>> > > err: cgem0: ipv4_addroute: File exists
>> > > info: cgem0: adding route to 10.1.0.0/24
>> > > info: cgem0: adding default route via 10.1.0.1
>> > > debug: cgem0: writing lease `/var/db/dhcpcd-cgem0.lease'
>> > > debug: cgem0: executing `ioc boot' BOUND
>> > > Interface TGP bounded
>> > > rtems_bsdnet_bootp_server_name : 1001.1001 at 10.1.0.1:/Volumes/Epics
>> > > rtems_bsdnet_bootp_boot_file_name : /Volumes/Epics/myExample/bin/RTEMS-xilinx_zynq_a9_qemu/myExample.boot
>> > > rtems_bsdnet_bootp_cmdline : /Volumes/Epics/myExample/iocBoot/iocmyExample/st.cmd
>> > > debug: cgem0: sending ARP announce (1 of 2), next in 2.0 seconds
>> > > -------------- IFCONFIG -----------------
>> > > cgem0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
>> > >        options=80008<VLAN_MTU,LINKSTATE>
>> > >        ether 52:54:00:12:34:56
>> > >        inet6 fe80::5054:ff:fe12:3456%cgem0 prefixlen 64 scopeid 0x1
>> > >        inet 10.1.0.104 netmask 0xffffff00 broadcast 10.1.0.255
>> > >        nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
>> > >        media: Ethernet autoselect (100baseTX <full-duplex>)
>> > >        status: active
>> > > lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
>> > >        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
>> > >        inet 127.0.0.1 netmask 0xffffff00
>> > >        inet6 ::1 prefixlen 128
>> > >        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
>> > >        groups: lo
>> > > -------------- NETSTAT ------------------
>> > > Routing tables
>> > > Internet:
>> > > Destination        Gateway            Flags     Netif Expire
>> > > default            10.1.0.1           UGS       cgem0
>> > > 10.1.0.0/24        link#1             U         cgem0
>> > > 10.1.0.104         link#1             UHS         lo0
>> > > 127.0.0.1          link#2             UH          lo0
>> > > Internet6:
>> > > ::1                               link#2                        UH          lo0
>> > > fe80::%cgem0/64                   link#1                        U         cgem0
>> > > fe80::5054:ff:fe12:3456%cgem0     link#1                        UHS         lo0
>> > > fe80::%lo0/64                     link#2                        U           lo0
>> > > fe80::1%lo0                       link#2                        UHS         lo0
>> > > ***** Until now no NTP support in RTEMS 5 with rtems-libbsd *****
>> > > ***** Ask ntp server once... *****
>> > > time from ntp : 08/10/20 15:08:41.000055589 UTC
>> > > ***** Setting up file system *****
>> > > ***** Initializing NFS *****
>> > > rtems_bootp_server_name: 1001.1001 at 10.1.0.1:/Volumes/Epics
>> > > nfsMount("1001.1001 at 10.1.0.1", "/Volumes/Epics", "/Volumes/Epics")
>> > > Mount 1001.1001 at 10.1.0.1:/Volumes/Epics on /Volumes/Epics
>> > > Warning: EPICS_TIMEZONE (CST6CDT,M3.2.0/2,M11.1.0/2) unrecognizable -- times will be displayed as GMT.
>> > > check for time registered , C++ initialization ...
>> > > ***** Preparing EPICS application *****
>> > > chdir("/Volumes/Epics/myExample/iocBoot/iocmyExample/")
>> > > ***** Starting EPICS application *****
>> > > dbLoadDatabase("../../dbd/softIoc.dbd")
>> > > Can't register 'system' command -- no command interpreter available.
>> > > softIoc_registerRecordDeviceDriver(pdbbase)
>> > > # Begin /Volumes/Epics/myExample/iocBoot/iocmyExample/st.cmd
>> > > iocInit()
>> > > Starting iocInit
>> > > ## EPICS R7.0.3.2-DEV
>> > > ## Rev. R7.0.3.1-105-ge597f8104c18ec7b9fc5-dirty
>> > > debug: cgem0: sending ARP announce (2 of 2)
>> > > Warning: RSRV has empty beacon address list
>> > > epicsThreadRealtimeLock Warning: Unable to lock the virtual address space.
>> > > VM page faults may harm real-time performance. errno=22
>> > > iocRun: All initialization complete
>> > > # End /Volumes/Epics/myExample/iocBoot/iocmyExample/st.cmd
>> > > On 2020-08-08 21:58, Mritunjay Sharma wrote:
>> > >> On Sat, Aug 8, 2020 at 11:10 PM Gedare Bloom <gedare at rtems.org> wrote:
>> > >> On Sat, Aug 8, 2020 at 11:08 AM Mritunjay Sharma
>> > >> > On Sat, Aug 8, 2020 at 9:46 PM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
>> > >> >> Hallo Mritunjay,
>> > >> >> everything looks pretty good. I'm commenting on the text. I also send this mail
>> > >> >> to two EPICS experts (Andrew Johnson and Michael Davidsaver). Maybe they also have some ideas.
>> > >> > Thank you so much Heinz! It will be really a great help!
>> > >> >> > Current Status:
>> > >> >> > 1) Successfully built EPICS7 with RTEMS5 by hand for pc-386
>> > >> >> > 2) Worked for RSB recipe.
>> > >> >> >    In its due process, I Wrote:
>> > >> >> >     i) rsb/rtems/config/epics/epics-7-1.cfg
>> > >> >> >     ii)rsb/rtems/config/epics/epics-base.bset
>> > >> >> >     iii)rsb/source-builder/config/epics-7-1.cfg
>> > >> >> > 3) Added Patch for RTEMS-pc-386 support which made the above recipe work successfully.
>> > >> >> > 4) Therefore, Successully built EPICS7 with RTEMS5 by using RSB recipe as well for pc-386 as of now.
>> > >> >> > 5) Sent 4 Patches for review of the same.
>> > >> >> > What problems are in the next steps?
>> > >> >> > 1) How to make it work across different architectures?
>> > >> >> > 2) Exisiting EPICS works on the old legacy network stack.
>> > >> >> > 3) I am not using EPICS upstream branch. It is being built
>> > >> >> > by Heinz's epics playground.
>> > >> >> > 4) Doubts in how to start with testing.
>> > >> >> > My Resarch work for the Problem no: 1
>> > >> >> > I have gone through the EPICS developer guide from here
>> > >> >> > exhaustively in the past couple of day and here are few interesting things
>> > >> >> > that I found which can help:
>> > >> >> > 1) "The main ingredients of the build system are:
>> > >> >> > • A set of configuration files and tools provided in the EPICS base/configure directory
>> > >> >> > • A corresponding set of configuration files in the <top>/configure directory of a non-base <top> directory
>> > >> >> > structure to be built. The makeBaseApp.pl and makeBaseExt.pl scripts create these configuration files. Many of
>> > >> >> > these files just include a file of the same name from the base/configure directory.
>> > >> >> > • Makefiles in each directory of the <top> directory structure to be built
>> > >> >> > • User created configuration files in build created $(INSTALL_LOCATION)/cfg directories.
>> > >> >> > Remarks: Now since it is also mentioned in the guide that "makeBaseApp.pl
>> > >> >> > creates directories and then copies template files into the newly created directories
>> > >> >> > while expanding macros in the template files. EPICS base provides two sets of template files: simple and example."
>> > >> >> > Can we think of using makeBaseApp.pl to that end? Making the user allow
>> > >> >> > to change the configurations from the terminal?
>> > >> >> I don't think that makeBaseApp.pl will help you. This is intended to build an example IOC. It takes the settings from the above mentioned configuration files.
>> > >> >> You "only" need to specify the location of the RTEMS installation in configure/os/CONFIG_SITE.Common.RTEMS.
>> > >> >> RTEMS_VERSION =
>> > >> >> RTEMS_BASE =
>> > >> >> Then you have to define the target in configure/CONFIG_SITE:
>> > >> >> # Which target architectures to cross-compile for.
>> > >> >> #  Definitions in configure/os/CONFIG_SITE.<host>.Common
>> > >> >> #  may override this setting.
>> > >> >> e.g. "CROSS_COMPILER_TARGET_ARCHS=RTEMS-xilinx_zynq_a9_qemu"
>> > >> >> And for each target there must be a file in configure/os:
>> > >> >> e.g. CONFIG_Common.RTEMS-xilinx_zynq_a9_qemu
>> > >> >> If it is not provided by EPICS, the RSB should install it there (adapted to the target to be used by epics make).
>> > >> Probably they should be provided by EPICS for known-to-work
>> > >> configurations. If they are not, we should push upstream.
>> > >> > Yes, Heinz. I followed the above steps and created a patch which I applied in the configuration files of RSB recipe.
>> > >> > The problem with it is that it's made only for pc-386 and I have to hardcode there about location of the RTEMS installation in
>> > >> > configure/os/CONFIG_SITE.Common.RTEMS. My doubt is how to modify the patch that can it offer user-specific location of the RTEMS
>> > >> > installation and bsp?
>> > >> I still think this should be done through some kind of pre-processing
>> > >> (scripting) over these configuration files for a given target, using
>> > >> some fixed pattern, rather than by patching. A patch is fine for
>> > >> proof-of-concept, but I don't think we want to have x patches for x
>> > >> BSP targets of EPICS.  Maybe it is fine, there aren't that many BSP
>> > >> targets right now, but I can see this kind of patch-based
>> > >> configuration getting a little unwieldy.
>> > >> If you proceed with the patch-based approach, you need to figure out
>> > >> how to pick the right patch to apply based on the target/bsp build. So
>> > >> that would be your next step. Create a patch for the zynq, and see if
>> > >> you can dynamically determine which one to apply (zynq or pc386) based
>> > >> on RSB internal state/variables.
>> > >> Thank you for the suggestions. I will start working on creating the patch for zynq and will see if
>> > >> something can be done to dynamically determine them.
>> > >> >> > 2) "The startup directory in EPICS base contains a perl script, EpicsHostArch.pl, which can be used to define
>> > >> >> > EPICS_HOST_ARCH. This script can be invoked with a command line parameter defining the alternate compiler (e.g.
>> > >> >> > if invoking EpicsHostArch.pl yields solaris-sparc, then invoking EpicsHostArch.pl gnu will yield
>> > >> >> > solaris-sparc-gnu).
>> > >> >> > The startup directory also contains scripts to help users set the path and other environment variables"
>> > >> >> This has nothing to do with 2)
>> > >> > I am sorry for the misunderstanding. All the 4 points mentioned here are my observations only for the Problem No.1
>> > >> > `1) How to make it work across different architectures?`
>> > >> >> There's no need to adjust anything here. The EPICS make recognizes the architecture on which it is started.
>> > >> >> > Remarks: As EPICS_HOST_ARCH, can we do something similar for CROSS_COMPILER_TARGET_ARCHS?
>> > >> >> > 3) ") The following is a summary of targets that can be specified for gnumake:
>> > >> >> > • <action>
>> > >> >> > • <arch>
>> > >> >> > • <action>.<arch>
>> > >> >> > • <dir>
>> > >> >> > • <dir>.<action>
>> > >> >> > • <dir>.<arch>
>> > >> >> > • <dir>.<action>.<arch>
>> > >> >> > where:
>> > >> >> > <arch> is an architecture such as solaris-sparc, vxWorks-68040, win32-x86, etc.
>> > >> >> > <action> is help, clean, realclean, distclean, inc, install, build, rebuild, buildInstall, realuninstall, or uninstall"
>> > >> >> > Remarks: Now similar to the above stated, can we work for Cross Compiler target Architecture?
>> > >> >> But this does not refer to 3) ?
>> > >> > No no, this remark is also for the problem 1 only as told above. Slight misunderstanding here :)
>> > >> >> 3) You have to take "my" repo at the moment, because the adaptations to RTEMS5 are not yet included in the official epics-base. This is a hen-and-egg problem because RTEMS is only now in the release phase, so my changes have not been implemented yet.
>> > >> > Ok, I hope Dr. Gedare and Chris can help you with that.
>> > >> We just need to be ready for when RTEMS 5.1 is officially released.
>> > >> Hopefully soon, but I don't have a timeline. Releases are mostly
>> > >> volunteer time, so they happen when they happen. We're trying to get
>> > >> better about that, but it is hard (due to lack of incentives).
>> > >> I think that makes it clear, Heinz.
>> > >> >> 2) I'm just about to figure out in the Epics Makefiles whether the target was built with the legacy-stack or libbsd-stack. It's working already.
>> > >> >> Now I also have to adjust the rtems_init.c accordingly. Here I have to clean up a little bit. But I hope to have this finished by the middle of the week.
>> > >> > Thank you so much for the update!
>> > >> > So I would like to ask my other mentors - what can I do for the time being? What should be the next steps for this week?
>> > >> Prepare the zynq patch and try to work out the logic of how to select
>> > >> the right patch to apply.
>> > >> Then similar logic might be usable to script the configuration changes
>> > >> of EPICS so we don't need patches.
>> > >> Sure, I will do and update soon.
>> > >> > And yes how to begin the testing part?
>> > >> This was suggested by Heinz earlier to look at the CI test scripts
>> > >> that EPICS maintainers use.
>> > >> Yes, it slipped out of my mind. Will check and revert.
>> > >> Thanks
>> > >> Mritunjay Sharma
>> > >> > I have tried to find some resources but I think it will be
>> > >> > better if you can help somewhere to look at.
>> > >> > Thanks
>> > >> > Mritunjay Sharma
>> > >> >> > These were the little doubts that originated from the research work I did.
>> > >> >> > I will like the opinion of mentors that what can be the optimal way now to approach the
>> > >> >> > project after this? What can be some resources for better research work of the
>> > >> >> > above problems?
>> > >> >> > Also, for the reference:
>> > >> >> > Link to the changes in commits of rsb can be found here: https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support
>> > >> >> > The patch for epics can be found here: https://github.com/mritunjaysharma394/epics-mritunjay/tree/master/patches
>> > >> >> > Thanks
>> > >> >> > Mritunjay Sharma
>> > >> >> Heinz
>> > > <rsb-report-epics-base-7.0-x86_64-linux-gnu-1.txt><log_epics>
