[PATCH] bsps/shared/ofw: Added and Documented RTEMS OFW interface
Niteesh G. S.
niteesh.gs at gmail.com
Wed Aug 12 16:19:32 UTC 2020
Hello,
I have resent the patches onto the mailing list as per Gedare's suggestion
in the IRC.
The current implementation is not 100% OF compliant. I have avoided a few
functions
like OF_call, OF_write etc since these don't have a valid implementation in
the FDT
implementation of OF interface.
Once we agree upon the interface implementing it becomes easier since I can
use the
code from ofw_fdt.c (BSD-2 licensed)
The implementation will go in ofw.c in RTEMS. And the OF interface will be
provided
through defines to make it libBSD compatible.
For eg:
#define OF_finddevice rtems_ofw_finddevice
This is as per Gedare's suggestion to avoid namespace pollution.
Thanks,
Niteesh.
On Wed, Aug 12, 2020 at 9:41 PM G S Niteesh Babu <niteesh.gs at gmail.com>
wrote:
> bsps/shared/dev/ofw/ofw.c | 0
> bsps/shared/dev/ofw/ofw.h | 437 ++++++++++++++++++++++++++++++++++++++
> 2 files changed, 437 insertions(+)
> create mode 100644 bsps/shared/dev/ofw/ofw.c
> create mode 100644 bsps/shared/dev/ofw/ofw.h
> diff --git a/bsps/shared/dev/ofw/ofw.c b/bsps/shared/dev/ofw/ofw.c
> new file mode 100644
> index 0000000000..e69de29bb2
> diff --git a/bsps/shared/dev/ofw/ofw.h b/bsps/shared/dev/ofw/ofw.h
> index 0000000000..5a8526c892
> --- /dev/null
> +++ b/bsps/shared/dev/ofw/ofw.h
> @@ -0,0 +1,437 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup ofw
> + * RTEMS FDT implementation of OpenFirmWare Interface.
> + * Copyright (C) <2020> Niteesh Babu G S <niteesh.gs at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _OFW_H
> +#define _OFW_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#include <stdint.h>
> +#include <stddef.h>
> +typedef uint32_t ihandle_t;
> +typedef uint32_t pcell_t;
> +typedef uint32_t phandle_t;
> + * @brief Gets the node that is next to @a node.
> + * @param[in] node Node offset
> + * @retval Peer node offset Successful operation.
> + * @retval 0 No peer node or invalid node handle
> +phandle_t rtems_ofw_peer(
> + phandle_t node
> + * @brief Gets the node that is the child of @a node.
> + * @retval child node offset Successful operation.
> + * @retval 0 No child node or invalid node handle
> +phandle_t rtems_ofw_child(
> + phandle_t node
> + * @brief Gets the node that is the parent of @a node.
> +phandle_t rtems_ofw_parent(
> + phandle_t node
> + * @brief Gets the length of the property mentioned in @a propname.
> + * @param[in] prop Property name
> + * @retval -1 Invalid node or property
> + * @retval Length of property on successful operation
> +size_t rtems_ofw_getproplen(
> + phandle_t node,
> + const char *propname
> + * @brief Gets the value of property mentioned in @a propname.
> + * @param[out] buf The property value gets stored in this buffer
> (Pre-allocated)
> + * @param[in] len Length of the buffer
> +size_t rtems_ofw_getprop(
> + phandle_t node,
> + const char *propname,
> + void *buf,
> + size_t len
> + * Gets the value of property of @a node and converts the value into the
> host's
> + * endiannes.
> buffer(Pre-allocated)
> + * after converted to the host's endiannes
> +size_t rtems_ofw_getencprop(
> + phandle_t node,
> + const char *prop,
> + pcell_t *buf,
> + size_t len
> + * @brief Checks if the property @a propname is present in @a node.
> + * @param[in] propname Property name
> + * @retval 0 Property not present.
> + * @retval 1 Property is present.
> +int rtems_ofw_hasprop(
> + phandle_t node,
> + * @brief Searches for property @a propname in @a node.
> + * Searches the node and its parent recursively for the property and
> fills the
> + * buffer with the first found value.
> (Pre-allocated)
> + * @retval Length of the property if property is found.
> + * @retval -1 Property is not found.
> +size_t rtems_ofw_searchprop(
> + phandle_t node,
> + void *buf,
> + size_t len
> fills the
> + * buffer with the first value found after converting it to the endiannes
> of the
> + * host.
> +size_t rtems_ofw_searchencprop(
> + phandle_t node,
> + pcell_t *buf,
> + size_t len
> + * Same as rtems_ofw_getprop, but the @a buf is allocated in this routine
> and
> + * the user is responsible for freeing it.
> + * @param[out] buf The buffer is allocated in this routine and user is
> + * responsible for freeing.
> +size_t rtems_ofw_getprop_alloc(
> + phandle_t node,
> + void **buf
> + * @brief Gets multiple values of the property @a propname.
> + * Same as rtems_ofw_getprop_alloc but it can read properties with
> multiple
> + * values.
> + * For eg: reg = <0x1000 0x10 0x2000 0x20>
> + * @param[in] elsz Size of the single value
> + * @retval Number of values read.
> +size_t rtems_ofw_getprop_alloc_multi(
> + phandle_t node,
> + int elsz,
> + void **buf
> + * Same as rtems_ofw_getprop_alloc but the value stored in the buffer is
> + * converted into the host's endiannes.
> +size_t rtems_ofw_getencprop_alloc(
> + phandle_t node,
> + void **buf
> + * Same as rtems_ofw_getprop_alloc_multi but the values stored in the
> buffer
> + * are converted to the host's endiannes.
> +size_t rtems_ofw_getencprop_alloc_multi(
> + phandle_t node,
> + int elsz,
> + void **buf
> + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc functions.
> + * @param[in] buf Buffer to be freed
> +void rtems_ofw_prop_free(
> + void *buf
> + * @brief Finds the next property of @a node.
> + * Finds the next property of the node and when @a propname is NULL it
> returns
> + * the value in the first property.
> + * @param[out] buf The value of the next property gets stored in this
> buffer
> + * (Pre-allocated)
> + * @retval -1 node or previous property does not exist
> + * @retval 0 no more properties
> + * @retval 1 success
> +int rtems_ofw_nextprop(
> + phandle_t node,
> + char *buf,
> + size_t len
> + * @brief Sets the property @name of @a node to @a buf.
> + * @param[in] name Property name
> + * @param[in] buf Buffer containes the value to be set.
> + * @retval -1 node does not exist
> + * @retval 0 on success
> + * @retval libFDT error codes on unsuccessful setting operation
> +int rtems_ofw_setprop(
> + phandle_t node,
> + const char *name,
> + const void *buf,
> + size_t len
> + * @brief Converts a device specifier to a fully qualified path name.
> + * @param[in] dev device specifier
> + * @param[out] buf The path is filled into the buffer(Pre-allocated)
> + * @param[in] length of the buffer
> + * @retval -1 always. Unimplemented.
> +size_t rtems_ofw_canon(
> + const char *dev,
> + char *buf,
> + size_t len
> + * @brief Finds the node at the given path
> + * @param[in] path to the node from root
> + * @retval node handle on success
> +phandle_t rtems_ofw_finddevice(
> + const char *path
> + * @brief This routine converts effective phandle of @a node to node
> offset.
> + * @param[in] xref Node phandle
> + * @retval Node offset on success
> + * @retval Node phandle on failure
> +phandle_t rtems_ofw_node_from_xref(
> + phandle_t xref
> + * @brief This routine converts node offset to effective phandle of @a
> node.
> + * @retval Node phandle on success
> + * @retval Node offset on failure
> +phandle_t rtems_ofw_xref_from_node(
> + phandle_t node
> + * instance handles(ihandle_t) as same as phandles in the FDT
> implementation
> + * of OF interface.
> + * @brief Converts @a instance handle to phandle.
> + * instance are same as node offsets in FDT.
> + * @param[in] instance Node offset
> + * @retval phandle of node on success.
> + * @retval instance of node on failure.
> +phandle_t rtems_ofw_instance_to_package(
> + ihandle_t instance
> + * @brief Find the node's path from phandle.
> + * @param[out] buf Path is filled into this buffer(Pre-allocated).
> + * @param[in] len Length of the buffer.
> +size_t rtems_ofw_package_to_path(
> + phandle_t node,
> + char *buf,
> + size_t len
> + * @brief Find the node's path from ihandle.
> +size_t rtems_ofw_instance_to_path(
> + ihandle_t instance,
> + char *buf,
> + size_t len
> +#ifdef __cplusplus
> +#endif
> +#endif /* _OFW_H */
> \ No newline at end of file
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200812/0ede2272/attachment-0001.html>
