[PATCH] bsps/shared/ofw: Added and Documented RTEMS OFW interface
G S Niteesh Babu
niteesh.gs at gmail.com
Wed Aug 12 16:10:54 UTC 2020
bsps/shared/dev/ofw/ofw.c | 0
bsps/shared/dev/ofw/ofw.h | 437 ++++++++++++++++++++++++++++++++++++++
2 files changed, 437 insertions(+)
create mode 100644 bsps/shared/dev/ofw/ofw.c
create mode 100644 bsps/shared/dev/ofw/ofw.h
diff --git a/bsps/shared/dev/ofw/ofw.c b/bsps/shared/dev/ofw/ofw.c
new file mode 100644
index 0000000000..e69de29bb2
diff --git a/bsps/shared/dev/ofw/ofw.h b/bsps/shared/dev/ofw/ofw.h
index 0000000000..5a8526c892
--- /dev/null
+++ b/bsps/shared/dev/ofw/ofw.h
@@ -0,0 +1,437 @@
+ * @file
+ * @ingroup ofw
+ * RTEMS FDT implementation of OpenFirmWare Interface.
+ * Copyright (C) <2020> Niteesh Babu G S <niteesh.gs at gmail.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _OFW_H
+#define _OFW_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <stdint.h>
+#include <stddef.h>
+typedef uint32_t ihandle_t;
+typedef uint32_t pcell_t;
+typedef uint32_t phandle_t;
+ * @brief Gets the node that is next to @a node.
+ * @param[in] node Node offset
+ * @retval Peer node offset Successful operation.
+ * @retval 0 No peer node or invalid node handle
+phandle_t rtems_ofw_peer(
+ phandle_t node
+ * @brief Gets the node that is the child of @a node.
+ * @retval child node offset Successful operation.
+ * @retval 0 No child node or invalid node handle
+phandle_t rtems_ofw_child(
+ phandle_t node
+ * @brief Gets the node that is the parent of @a node.
+phandle_t rtems_ofw_parent(
+ phandle_t node
+ * @brief Gets the length of the property mentioned in @a propname.
+ * @param[in] prop Property name
+ * @retval -1 Invalid node or property
+ * @retval Length of property on successful operation
+size_t rtems_ofw_getproplen(
+ phandle_t node,
+ const char *propname
+ * @brief Gets the value of property mentioned in @a propname.
+ * @param[out] buf The property value gets stored in this buffer (Pre-allocated)
+ * @param[in] len Length of the buffer
+size_t rtems_ofw_getprop(
+ phandle_t node,
+ const char *propname,
+ void *buf,
+ size_t len
+ * Gets the value of property of @a node and converts the value into the host's
+ * endiannes.
+ * @param[out] buf The property value gets stored in this buffer(Pre-allocated)
+ * after converted to the host's endiannes
+size_t rtems_ofw_getencprop(
+ phandle_t node,
+ const char *prop,
+ pcell_t *buf,
+ size_t len
+ * @brief Checks if the property @a propname is present in @a node.
+ * @param[in] propname Property name
+ * @retval 0 Property not present.
+ * @retval 1 Property is present.
+int rtems_ofw_hasprop(
+ phandle_t node,
+ * @brief Searches for property @a propname in @a node.
+ * Searches the node and its parent recursively for the property and fills the
+ * buffer with the first found value.
+ * @retval Length of the property if property is found.
+ * @retval -1 Property is not found.
+size_t rtems_ofw_searchprop(
+ phandle_t node,
+ void *buf,
+ size_t len
+ * buffer with the first value found after converting it to the endiannes of the
+ * host.
+size_t rtems_ofw_searchencprop(
+ phandle_t node,
+ pcell_t *buf,
+ size_t len
+ * Same as rtems_ofw_getprop, but the @a buf is allocated in this routine and
+ * the user is responsible for freeing it.
+ * @param[out] buf The buffer is allocated in this routine and user is
+ * responsible for freeing.
+size_t rtems_ofw_getprop_alloc(
+ phandle_t node,
+ void **buf
+ * @brief Gets multiple values of the property @a propname.
+ * Same as rtems_ofw_getprop_alloc but it can read properties with multiple
+ * values.
+ * For eg: reg = <0x1000 0x10 0x2000 0x20>
+ * @param[in] elsz Size of the single value
+ * @retval Number of values read.
+size_t rtems_ofw_getprop_alloc_multi(
+ phandle_t node,
+ int elsz,
+ void **buf
+ * Same as rtems_ofw_getprop_alloc but the value stored in the buffer is
+ * converted into the host's endiannes.
+size_t rtems_ofw_getencprop_alloc(
+ phandle_t node,
+ void **buf
+ * Same as rtems_ofw_getprop_alloc_multi but the values stored in the buffer
+ * are converted to the host's endiannes.
+size_t rtems_ofw_getencprop_alloc_multi(
+ phandle_t node,
+ int elsz,
+ void **buf
+ * @brief Free's the buffers allocated by the rtems_ofw_*_alloc functions.
+ * @param[in] buf Buffer to be freed
+void rtems_ofw_prop_free(
+ void *buf
+ * @brief Finds the next property of @a node.
+ * Finds the next property of the node and when @a propname is NULL it returns
+ * the value in the first property.
+ * @param[out] buf The value of the next property gets stored in this buffer
+ * (Pre-allocated)
+ * @retval -1 node or previous property does not exist
+ * @retval 0 no more properties
+ * @retval 1 success
+int rtems_ofw_nextprop(
+ phandle_t node,
+ char *buf,
+ size_t len
+ * @brief Sets the property @name of @a node to @a buf.
+ * @param[in] name Property name
+ * @param[in] buf Buffer containes the value to be set.
+ * @retval -1 node does not exist
+ * @retval 0 on success
+ * @retval libFDT error codes on unsuccessful setting operation
+int rtems_ofw_setprop(
+ phandle_t node,
+ const char *name,
+ const void *buf,
+ size_t len
+ * @brief Converts a device specifier to a fully qualified path name.
+ * @param[in] dev device specifier
+ * @param[out] buf The path is filled into the buffer(Pre-allocated)
+ * @param[in] length of the buffer
+ * @retval -1 always. Unimplemented.
+size_t rtems_ofw_canon(
+ const char *dev,
+ char *buf,
+ size_t len
+ * @brief Finds the node at the given path
+ * @param[in] path to the node from root
+ * @retval node handle on success
+phandle_t rtems_ofw_finddevice(
+ const char *path
+ * @brief This routine converts effective phandle of @a node to node offset.
+ * @param[in] xref Node phandle
+ * @retval Node offset on success
+ * @retval Node phandle on failure
+phandle_t rtems_ofw_node_from_xref(
+ phandle_t xref
+ * @brief This routine converts node offset to effective phandle of @a node.
+ * @retval Node phandle on success
+ * @retval Node offset on failure
+phandle_t rtems_ofw_xref_from_node(
+ phandle_t node
+ * instance handles(ihandle_t) as same as phandles in the FDT implementation
+ * of OF interface.
+ * @brief Converts @a instance handle to phandle.
+ * instance are same as node offsets in FDT.
+ * @param[in] instance Node offset
+ * @retval phandle of node on success.
+ * @retval instance of node on failure.
+phandle_t rtems_ofw_instance_to_package(
+ ihandle_t instance
+ * @brief Find the node's path from phandle.
+ * @param[out] buf Path is filled into this buffer(Pre-allocated).
+ * @param[in] len Length of the buffer.
+size_t rtems_ofw_package_to_path(
+ phandle_t node,
+ char *buf,
+ size_t len
+ * @brief Find the node's path from ihandle.
+size_t rtems_ofw_instance_to_path(
+ ihandle_t instance,
+ char *buf,
+ size_t len
+#ifdef __cplusplus
+#endif
+#endif /* _OFW_H */
\ No newline at end of file
2.17.1
