[PATCH v2] Move 5 build sets to 6
chrisj at rtems.org chrisj at rtems.org
Thu Aug 13 01:55:31 UTC 2020
- Move 5/bsps/* to bsps/*
- Update package build references from 5 to 6
- Remove 5 build sets.
Update #4048
 rtems/config/5/bsps/atsamv.bset               | 10 -----
 rtems/config/5/bsps/imx7.bset                 | 10 -----
 rtems/config/5/bsps/qoriq_e500.bset           | 10 -----
 rtems/config/5/bsps/qoriq_e6500_32.bset       | 10 -----
 rtems/config/5/bsps/qoriq_e6500_64.bset       | 10 -----
 rtems/config/5/rtems-aarch64.bset             |  4 --
 rtems/config/5/rtems-all.bset                 | 19 ---------
 rtems/config/5/rtems-arm.bset                 |  4 --
 rtems/config/5/rtems-autotools-base.bset      | 23 -----------
 rtems/config/5/rtems-autotools-internal.bset  | 13 -------
 rtems/config/5/rtems-autotools.bset           | 27 -------------
 rtems/config/5/rtems-bfin.bset                |  3 --
 rtems/config/5/rtems-default.bset             | 22 -----------
 rtems/config/5/rtems-epiphany.bset            | 39 -------------------
 rtems/config/5/rtems-i386.bset                |  4 --
 rtems/config/5/rtems-lm32.bset                | 10 -----
 rtems/config/5/rtems-m68k.bset                |  3 --
 rtems/config/5/rtems-microblaze.bset          |  3 --
 rtems/config/5/rtems-mips.bset                |  6 ---
 rtems/config/5/rtems-moxie.bset               | 12 ------
 rtems/config/5/rtems-nios2.bset               |  3 --
 rtems/config/5/rtems-or1k.bset                | 15 -------
 rtems/config/5/rtems-powerpc.bset             |  8 ----
 rtems/config/5/rtems-riscv.bset               | 17 --------
 rtems/config/5/rtems-sh.bset                  |  6 ---
 rtems/config/5/rtems-sparc.bset               |  6 ---
 rtems/config/5/rtems-sparc64.bset             |  3 --
 rtems/config/5/rtems-tier-1.bset              |  5 ---
 rtems/config/5/rtems-tier-2.bset              |  3 --
 rtems/config/5/rtems-tier-3.bset              | 17 --------
 rtems/config/5/rtems-tier-4.bset              | 10 -----
 rtems/config/5/rtems-v850.bset                |  3 --
 rtems/config/5/rtems-x86_64.bset              | 13 -------
 rtems/config/6/rtems-default.bset             |  3 ++
 rtems/config/{5 => 6}/rtems-kernel.bset       |  2 +-
 rtems/config/{5 => 6}/rtems-libbsd.bset       |  2 +-
 rtems/config/{5 => 6}/rtems-llvm.bset         |  0
 rtems/config/{5 => 6}/rtems-packages.bset     |  0
 rtems/config/{5 => 6}/rtems-tools.bset        |  4 +-
 rtems/config/bsps/atsamv.bset                 | 10 +++++
 .../config/{5 => }/bsps/beagleboneblack.bset  | 10 ++---
 rtems/config/{5 => }/bsps/erc32.bset          | 10 ++---
 rtems/config/{5 => }/bsps/gr712rc.bset        |  6 +--
 rtems/config/{5 => }/bsps/gr740.bset          |  6 +--
 rtems/config/bsps/imx7.bset                   | 10 +++++
 rtems/config/{5 => }/bsps/pc.bset             | 10 ++---
 rtems/config/bsps/qoriq_e500.bset             | 10 +++++
 rtems/config/bsps/qoriq_e6500_32.bset         | 10 +++++
 rtems/config/bsps/qoriq_e6500_64.bset         | 10 +++++
 rtems/config/{5 => }/bsps/raspberrypi2.bset   | 10 ++---
 .../{5 => }/bsps/xilinx_zynq_zc702.bset       | 10 ++---
 .../{5 => }/bsps/xilinx_zynq_zc706.bset       | 10 ++---
 .../{5 => }/bsps/xilinx_zynq_zedboard.bset    | 10 ++---
 rtems/config/ftp/curl.bset                    |  5 ---
 rtems/config/net-mgmt/net-snmp.bset           |  5 ---
 rtems/config/tools/rtems-kernel-5.cfg         | 12 ------
 rtems/config/tools/rtems-kernel-6.cfg         | 12 ++++++
 rtems/config/tools/rtems-kernel-common.cfg    |  3 +-
 ...{rtems-libbsd-5.cfg => rtems-libbsd-6.cfg} |  7 ++--
 59 files changed, 115 insertions(+), 423 deletions(-)
 delete mode 100644 rtems/config/5/bsps/atsamv.bset
 delete mode 100644 rtems/config/5/bsps/imx7.bset
 delete mode 100644 rtems/config/5/bsps/qoriq_e500.bset
 delete mode 100644 rtems/config/5/bsps/qoriq_e6500_32.bset
 delete mode 100644 rtems/config/5/bsps/qoriq_e6500_64.bset
 delete mode 100644 rtems/config/5/rtems-aarch64.bset
 delete mode 100644 rtems/config/5/rtems-all.bset
 delete mode 100644 rtems/config/5/rtems-arm.bset
 delete mode 100644 rtems/config/5/rtems-autotools-base.bset
 delete mode 100644 rtems/config/5/rtems-autotools-internal.bset
 delete mode 100644 rtems/config/5/rtems-autotools.bset
 delete mode 100644 rtems/config/5/rtems-bfin.bset
 delete mode 100644 rtems/config/5/rtems-default.bset
 delete mode 100644 rtems/config/5/rtems-epiphany.bset
 delete mode 100644 rtems/config/5/rtems-i386.bset
 delete mode 100644 rtems/config/5/rtems-lm32.bset
 delete mode 100644 rtems/config/5/rtems-m68k.bset
 delete mode 100644 rtems/config/5/rtems-microblaze.bset
 delete mode 100644 rtems/config/5/rtems-mips.bset
 delete mode 100644 rtems/config/5/rtems-moxie.bset
 delete mode 100644 rtems/config/5/rtems-nios2.bset
 delete mode 100644 rtems/config/5/rtems-or1k.bset
 delete mode 100644 rtems/config/5/rtems-powerpc.bset
 delete mode 100644 rtems/config/5/rtems-riscv.bset
 delete mode 100644 rtems/config/5/rtems-sh.bset
 delete mode 100644 rtems/config/5/rtems-sparc.bset
 delete mode 100644 rtems/config/5/rtems-sparc64.bset
 delete mode 100644 rtems/config/5/rtems-tier-1.bset
 delete mode 100644 rtems/config/5/rtems-tier-2.bset
 delete mode 100644 rtems/config/5/rtems-tier-3.bset
 delete mode 100644 rtems/config/5/rtems-tier-4.bset
 delete mode 100644 rtems/config/5/rtems-v850.bset
 delete mode 100644 rtems/config/5/rtems-x86_64.bset
 rename rtems/config/{5 => 6}/rtems-kernel.bset (88%)
 rename rtems/config/{5 => 6}/rtems-libbsd.bset (77%)
 rename rtems/config/{5 => 6}/rtems-llvm.bset (100%)
 rename rtems/config/{5 => 6}/rtems-packages.bset (100%)
 rename rtems/config/{5 => 6}/rtems-tools.bset (74%)
 create mode 100644 rtems/config/bsps/atsamv.bset
 rename rtems/config/{5 => }/bsps/beagleboneblack.bset (68%)
 rename rtems/config/{5 => }/bsps/erc32.bset (65%)
 rename rtems/config/{5 => }/bsps/gr712rc.bset (55%)
 rename rtems/config/{5 => }/bsps/gr740.bset (55%)
 create mode 100644 rtems/config/bsps/imx7.bset
 rename rtems/config/{5 => }/bsps/pc.bset (65%)
 create mode 100644 rtems/config/bsps/qoriq_e500.bset
 create mode 100644 rtems/config/bsps/qoriq_e6500_32.bset
 create mode 100644 rtems/config/bsps/qoriq_e6500_64.bset
 rename rtems/config/{5 => }/bsps/raspberrypi2.bset (67%)
 rename rtems/config/{5 => }/bsps/xilinx_zynq_zc702.bset (68%)
 rename rtems/config/{5 => }/bsps/xilinx_zynq_zc706.bset (68%)
 rename rtems/config/{5 => }/bsps/xilinx_zynq_zedboard.bset (69%)
 delete mode 100644 rtems/config/tools/rtems-kernel-5.cfg
 create mode 100644 rtems/config/tools/rtems-kernel-6.cfg
 rename rtems/config/tools/{rtems-libbsd-5.cfg => rtems-libbsd-6.cfg} (63%)
diff --git a/rtems/config/5/bsps/atsamv.bset b/rtems/config/5/bsps/atsamv.bset
deleted file mode 100644
index 4bde317..0000000
--- a/rtems/config/5/bsps/atsamv.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define mail_single_report 1
-%define with_rtems_bsp atsamv
-%define rtems_target   arm-rtems5
-%define rtems_host     %{rtems_target}
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/5/bsps/imx7.bset b/rtems/config/5/bsps/imx7.bset
index c48a526..0000000
--- a/rtems/config/5/bsps/imx7.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define with_rtems_bsp imx7
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/5/bsps/qoriq_e500.bset b/rtems/config/5/bsps/qoriq_e500.bset
index 4390e72..0000000
--- a/rtems/config/5/bsps/qoriq_e500.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define with_rtems_bsp qoriq_e500
-%define rtems_target   powerpc-rtems5
-5/rtems-powerpc
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/5/bsps/qoriq_e6500_32.bset b/rtems/config/5/bsps/qoriq_e6500_32.bset
index ddd2055..0000000
--- a/rtems/config/5/bsps/qoriq_e6500_32.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define with_rtems_bsp qoriq_e6500_32
-5/rtems-powerpc
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/5/bsps/qoriq_e6500_64.bset b/rtems/config/5/bsps/qoriq_e6500_64.bset
index 9869b40..0000000
--- a/rtems/config/5/bsps/qoriq_e6500_64.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define with_rtems_bsp qoriq_e6500_64
-5/rtems-powerpc
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/5/rtems-aarch64.bset b/rtems/config/5/rtems-aarch64.bset
index f38aff3..0000000
--- a/rtems/config/5/rtems-aarch64.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch aarch64
-%define with_libgomp
-%include 5/rtems-default.bset
diff --git a/rtems/config/5/rtems-all.bset b/rtems/config/5/rtems-all.bset
index 00ccfae..0000000
--- a/rtems/config/5/rtems-all.bset
+++ /dev/null
@@ -1,19 +0,0 @@
-5/rtems-aarch64
-5/rtems-arm
-5/rtems-bfin
-5/rtems-epiphany
-5/rtems-i386
-5/rtems-lm32
-5/rtems-m68k
-5/rtems-microblaze
-5/rtems-mips
-5/rtems-moxie
-5/rtems-nios2
-5/rtems-or1k
-5/rtems-powerpc
-5/rtems-riscv
-5/rtems-sh
-5/rtems-sparc
-5/rtems-sparc64
-5/rtems-v850
-5/rtems-x86_64
diff --git a/rtems/config/5/rtems-arm.bset b/rtems/config/5/rtems-arm.bset
index 896c534..0000000
--- a/rtems/config/5/rtems-arm.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch arm
diff --git a/rtems/config/5/rtems-autotools-base.bset b/rtems/config/5/rtems-autotools-base.bset
index 12ebffa..0000000
--- a/rtems/config/5/rtems-autotools-base.bset
+++ /dev/null
@@ -1,23 +0,0 @@
-# Tools Set for RTEMS 5 Internal Autotools Stable
-%define release 1
-%define rtems_arch none
-# The RTEMS base defines.
-%include rtems-base.bset
-# The autotools package.
-package: rtems-%{rtems_version}-autotools-%{_host}-%{release}
-# Tools configuration.
-tools/rtems-autoconf-2.69-1
-tools/rtems-automake-1.12.6-1
diff --git a/rtems/config/5/rtems-autotools-internal.bset b/rtems/config/5/rtems-autotools-internal.bset
index 67dae0d..0000000
--- a/rtems/config/5/rtems-autotools-internal.bset
+++ /dev/null
@@ -1,13 +0,0 @@
-# Do not use via the command line.
-%define _internal_autotools yes
-%define _disable_collecting yes
-%define _disable_packaging  yes
-%define _disable_reporting  yes
-%define _disable_installing yes
-%include 5/rtems-autotools-base.bset
diff --git a/rtems/config/5/rtems-autotools.bset b/rtems/config/5/rtems-autotools.bset
index c50f988..0000000
--- a/rtems/config/5/rtems-autotools.bset
+++ /dev/null
@@ -1,27 +0,0 @@
-# Tools Set for RTEMS 5 Autotools Stable
-# Autoconf and automake are not relocatable and cannot be cross-compiled.
-# RTEMS uses autoconf and automake and building RTEMS in the RSB requires
-# bootstrapping and this requires a current autoconf and automake. The RSB
-# provides to support by:
-#  1. Building and installing autoconf and automake with a prefix to a
-#     temporary internal path.
-#  2. Using the temporary internal build, build and install another copy
-#     using the final prefix location.
-# A magic internal path that would break if changes in the defaults.mc
-# macro file are made.
-%define _internal_autotools_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
-# Disable emailing reports of this building for RTEMS.
-%define mail_disable
-5/rtems-autotools-internal
-5/rtems-autotools-base
diff --git a/rtems/config/5/rtems-bfin.bset b/rtems/config/5/rtems-bfin.bset
index ae30324..0000000
--- a/rtems/config/5/rtems-bfin.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch bfin
diff --git a/rtems/config/5/rtems-default.bset b/rtems/config/5/rtems-default.bset
index 3f4e6ab..0000000
--- a/rtems/config/5/rtems-default.bset
+++ /dev/null
@@ -1,22 +0,0 @@
-# Default tools configuration.
-5/rtems-autotools
-# Build gdb first to raise the Python install error as early as possible.
-# GDB needs expat so it needs to be built before.
-devel/expat-2.1.0-1
-tools/rtems-gdb-9.1-1
-tools/rtems-binutils-2.34
-tools/rtems-gcc-7.5.0-newlib-7947581
-tools/rtems-tools-5-1
diff --git a/rtems/config/5/rtems-epiphany.bset b/rtems/config/5/rtems-epiphany.bset
index e54a8ea..0000000
--- a/rtems/config/5/rtems-epiphany.bset
+++ /dev/null
@@ -1,39 +0,0 @@
-# Tools Set for RTEMS Epiphany 5 Stable
-%define release 1
-%define rtems_arch epiphany
-# Get GNU tools from external repositories.
-%define gdb_external 1
-# Expanded names of the GNU tools
-%define gdb_expand_name epiphany-binutils-gdb-f05996c7c42e6b2781946acbab153a481ce3fd0b
-# Fetch GNU tools from external repos (temporarly).
-%define epiphany_gdb_version f05996c7c42e6b2781946acbab153a481ce3fd0b
-%source set gdb --rsb-file=gdb-f05996c7c42e6b2781946acbab153a481ce3fd0b.zip https://github.com/adapteva/epiphany-binutils-gdb/archive/f05996c7c42e6b2781946acbab153a481ce3fd0b.zip
-%hash sha256 gdb-f05996c7c42e6b2781946acbab153a481ce3fd0b.zip 2b2034fd12f2fd5108205ade66400c175ede8cef8141a38ae03fc78bf2d65325
-5/rtems-autotools
-tools/rtems-gdb-7.8.1-1
diff --git a/rtems/config/5/rtems-i386.bset b/rtems/config/5/rtems-i386.bset
index 7fd0313..0000000
--- a/rtems/config/5/rtems-i386.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch i386
diff --git a/rtems/config/5/rtems-lm32.bset b/rtems/config/5/rtems-lm32.bset
index e54ad34..0000000
--- a/rtems/config/5/rtems-lm32.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define release 1
-%define rtems_arch lm32
-# Fix the simulator UART interface.
-%patch add gdb https://devel.rtems.org/raw-attachment/ticket/3030/gdb-7.9-lm32uart-2.diff
-%hash  sha256 gdb-7.9-lm32uart-2.diff 7a266c1800829dcb5e493073ef98ad7d7f38a69715b93154dfaaffd34073dff3
diff --git a/rtems/config/5/rtems-m68k.bset b/rtems/config/5/rtems-m68k.bset
index 6ed64eb..0000000
--- a/rtems/config/5/rtems-m68k.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch m68k
diff --git a/rtems/config/5/rtems-microblaze.bset b/rtems/config/5/rtems-microblaze.bset
index e5c23af..0000000
--- a/rtems/config/5/rtems-microblaze.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch microblaze
diff --git a/rtems/config/5/rtems-mips.bset b/rtems/config/5/rtems-mips.bset
index bb6e4d1..0000000
--- a/rtems/config/5/rtems-mips.bset
+++ /dev/null
@@ -1,6 +0,0 @@
-%define release 1
-%define rtems_arch mips
-%define gdb-sim-options --enable-sim-hardware
-%define win32-gdb-disable-sim
-tools/rtems-mipstx39-gdb-8.0.1-1
diff --git a/rtems/config/5/rtems-moxie.bset b/rtems/config/5/rtems-moxie.bset
index 0e01f7f..0000000
--- a/rtems/config/5/rtems-moxie.bset
+++ /dev/null
@@ -1,12 +0,0 @@
-# Tools Set for RTEMS Moxie 5 Stable
-%define release 1
-%define rtems_arch moxie
-# Moxie needs dtc to build gdb, then pick up the rest of the set
-devel/dtc-1.6.0-1
diff --git a/rtems/config/5/rtems-nios2.bset b/rtems/config/5/rtems-nios2.bset
index 4a20854..0000000
--- a/rtems/config/5/rtems-nios2.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch nios2
diff --git a/rtems/config/5/rtems-or1k.bset b/rtems/config/5/rtems-or1k.bset
index 75e0eb8..0000000
--- a/rtems/config/5/rtems-or1k.bset
+++ /dev/null
@@ -1,15 +0,0 @@
-# or1k architecture
-%define release 1
-%define rtems_arch or1k
-5/rtems-autotools
-tools/rtems-gdb-8.2.1-1
-tools/rtems-gcc-9.3.0-newlib-7947581
diff --git a/rtems/config/5/rtems-powerpc.bset b/rtems/config/5/rtems-powerpc.bset
index 25e0ae2..0000000
--- a/rtems/config/5/rtems-powerpc.bset
+++ /dev/null
@@ -1,8 +0,0 @@
-# PowerPC architecture
-%define release 1
-%define rtems_arch powerpc
diff --git a/rtems/config/5/rtems-riscv.bset b/rtems/config/5/rtems-riscv.bset
index bf5874b..0000000
--- a/rtems/config/5/rtems-riscv.bset
+++ /dev/null
@@ -1,17 +0,0 @@
-# RISC-V architecture
-%define release 1
-%define rtems_arch riscv
-5/rtems-autotools
-tools/rtems-gdb-8.3-1
-devel/sis-2-1
diff --git a/rtems/config/5/rtems-sh.bset b/rtems/config/5/rtems-sh.bset
index 5a14c87..0000000
--- a/rtems/config/5/rtems-sh.bset
+++ /dev/null
@@ -1,6 +0,0 @@
-# SH architecture
-%define release 1
-%define rtems_arch sh
diff --git a/rtems/config/5/rtems-sparc.bset b/rtems/config/5/rtems-sparc.bset
index ccb3e10..0000000
--- a/rtems/config/5/rtems-sparc.bset
+++ /dev/null
@@ -1,6 +0,0 @@
-%define release 1
-%define rtems_arch sparc
-%define gdb-disable-sim 1
-devel/sis-2-1
diff --git a/rtems/config/5/rtems-sparc64.bset b/rtems/config/5/rtems-sparc64.bset
index a56ad71..0000000
--- a/rtems/config/5/rtems-sparc64.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch sparc64
diff --git a/rtems/config/5/rtems-tier-1.bset b/rtems/config/5/rtems-tier-1.bset
index 3e2dbe6..0000000
--- a/rtems/config/5/rtems-tier-1.bset
+++ /dev/null
@@ -1,5 +0,0 @@
-# Tier 1 architectures. Must build.
-5/rtems-arm
-5/rtems-i386
diff --git a/rtems/config/5/rtems-tier-2.bset b/rtems/config/5/rtems-tier-2.bset
index d2dfa31..0000000
--- a/rtems/config/5/rtems-tier-2.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-# Tier 2 architectures. Must build.
diff --git a/rtems/config/5/rtems-tier-3.bset b/rtems/config/5/rtems-tier-3.bset
index 0fb7622..0000000
--- a/rtems/config/5/rtems-tier-3.bset
+++ /dev/null
@@ -1,17 +0,0 @@
-# Tier 3 architectures. Must build.
-5/rtems-arm
-5/rtems-bfin
-5/rtems-i386
-5/rtems-lm32
-5/rtems-m68k
-5/rtems-mips
-5/rtems-moxie
-5/rtems-nios2
-5/rtems-or1k
-5/rtems-powerpc
-5/rtems-sh
-5/rtems-sparc
-5/rtems-sparc64
-5/rtems-v850
diff --git a/rtems/config/5/rtems-tier-4.bset b/rtems/config/5/rtems-tier-4.bset
index 2820fda..0000000
--- a/rtems/config/5/rtems-tier-4.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-# Tier 4 architectures. Do not need to build.
-# Tools listed here may not have a BSP in the kernel and are here to support
-# anyone working on adding a BSP.
-5/rtems-epiphany
-5/rtems-microblaze
-5/rtems-riscv32
-5/rtems-x86_64
diff --git a/rtems/config/5/rtems-v850.bset b/rtems/config/5/rtems-v850.bset
index e09bc4f..0000000
--- a/rtems/config/5/rtems-v850.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch v850
diff --git a/rtems/config/5/rtems-x86_64.bset b/rtems/config/5/rtems-x86_64.bset
index b414908..0000000
--- a/rtems/config/5/rtems-x86_64.bset
+++ /dev/null
@@ -1,13 +0,0 @@
-%define release 1
-%define rtems_arch x86_64
-5/rtems-autotools
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 9b09e8e..0dc2e77 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -1,3 +1,6 @@
+# Default tools configuration.
 %include 6/rtems-base.bset
 6/rtems-autotools
diff --git a/rtems/config/5/rtems-kernel.bset b/rtems/config/6/rtems-kernel.bset
similarity index 88%
rename from rtems/config/5/rtems-kernel.bset
rename to rtems/config/6/rtems-kernel.bset
index 080af0b..e3402f6 100644
--- a/rtems/config/5/rtems-kernel.bset
+++ b/rtems/config/6/rtems-kernel.bset
@@ -12,4 +12,4 @@
 # Build the kernel.
-tools/rtems-kernel-5
+tools/rtems-kernel-6
diff --git a/rtems/config/5/rtems-libbsd.bset b/rtems/config/6/rtems-libbsd.bset
similarity index 77%
rename from rtems/config/5/rtems-libbsd.bset
rename to rtems/config/6/rtems-libbsd.bset
index 2b84cf8..3d779bc 100644
--- a/rtems/config/5/rtems-libbsd.bset
+++ b/rtems/config/6/rtems-libbsd.bset
@@ -5,4 +5,4 @@
 # Build the BSD library for RTEMS.
-tools/rtems-libbsd-5
+tools/rtems-libbsd-6
diff --git a/rtems/config/5/rtems-llvm.bset b/rtems/config/6/rtems-llvm.bset
similarity index 100%
rename from rtems/config/5/rtems-llvm.bset
rename to rtems/config/6/rtems-llvm.bset
diff --git a/rtems/config/5/rtems-packages.bset b/rtems/config/6/rtems-packages.bset
rename from rtems/config/5/rtems-packages.bset
rename to rtems/config/6/rtems-packages.bset
diff --git a/rtems/config/5/rtems-tools.bset b/rtems/config/6/rtems-tools.bset
similarity index 74%
rename from rtems/config/5/rtems-tools.bset
rename to rtems/config/6/rtems-tools.bset
index 12a3302..d0be01a 100644
--- a/rtems/config/5/rtems-tools.bset
+++ b/rtems/config/6/rtems-tools.bset
@@ -1,5 +1,5 @@
-# Tools Set for RTEMS 5 Tools Stable
+# Tools Set for RTEMS 6 Tools Stable
 %define release 1
@@ -14,4 +14,4 @@
+tools/rtems-tools-6-1
diff --git a/rtems/config/bsps/atsamv.bset b/rtems/config/bsps/atsamv.bset
new file mode 100644
index 0000000..6b2dcf5
--- /dev/null
+++ b/rtems/config/bsps/atsamv.bset
@@ -0,0 +1,10 @@
+%define mail_single_report 1
+%define with_rtems_bsp atsamv
+%define rtems_target   arm-rtems%{rtems_version}
+%define rtems_host     %{rtems_target}
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/beagleboneblack.bset b/rtems/config/bsps/beagleboneblack.bset
similarity index 68%
rename from rtems/config/5/bsps/beagleboneblack.bset
rename to rtems/config/bsps/beagleboneblack.bset
index 41a06f6..33954d8 100644
--- a/rtems/config/5/bsps/beagleboneblack.bset
+++ b/rtems/config/bsps/beagleboneblack.bset
@@ -12,10 +12,10 @@
 %define with_rtems_bsp beagleboneblack
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/erc32.bset b/rtems/config/bsps/erc32.bset
similarity index 65%
rename from rtems/config/5/bsps/erc32.bset
rename to rtems/config/bsps/erc32.bset
index 276b061..bd27833 100644
--- a/rtems/config/5/bsps/erc32.bset
+++ b/rtems/config/bsps/erc32.bset
@@ -12,10 +12,10 @@
 %define with_rtems_bsp erc32
-%define rtems_target   sparc-rtems5
+%define rtems_target   sparc-rtems%{rtems_version}
-5/rtems-sparc
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-sparc
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/gr712rc.bset b/rtems/config/bsps/gr712rc.bset
similarity index 55%
rename from rtems/config/5/bsps/gr712rc.bset
rename to rtems/config/bsps/gr712rc.bset
index e997905..e74a984 100644
--- a/rtems/config/5/bsps/gr712rc.bset
+++ b/rtems/config/bsps/gr712rc.bset
@@ -1,8 +1,8 @@
 %define with_rtems_bsp gr712rc
-5/rtems-sparc
-5/rtems-kernel
+6/rtems-sparc
+6/rtems-kernel
diff --git a/rtems/config/5/bsps/gr740.bset b/rtems/config/bsps/gr740.bset
rename from rtems/config/5/bsps/gr740.bset
rename to rtems/config/bsps/gr740.bset
index 2e02c54..79b8ef1 100644
--- a/rtems/config/5/bsps/gr740.bset
+++ b/rtems/config/bsps/gr740.bset
@@ -1,8 +1,8 @@
 %define with_rtems_bsp gr740
-5/rtems-sparc
-5/rtems-kernel
+6/rtems-sparc
+6/rtems-kernel
diff --git a/rtems/config/bsps/imx7.bset b/rtems/config/bsps/imx7.bset
index 0000000..e49e979
--- /dev/null
+++ b/rtems/config/bsps/imx7.bset
@@ -0,0 +1,10 @@
+%define with_rtems_bsp imx7
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/pc.bset b/rtems/config/bsps/pc.bset
rename from rtems/config/5/bsps/pc.bset
rename to rtems/config/bsps/pc.bset
index e096fc9..57212f6 100644
--- a/rtems/config/5/bsps/pc.bset
+++ b/rtems/config/bsps/pc.bset
@@ -12,10 +12,10 @@
 %define with_rtems_bsp pc686
-%define rtems_target   i386-rtems5
+%define rtems_target   i386-rtems%{rtems_version}
-5/rtems-i386
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-i386
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/bsps/qoriq_e500.bset b/rtems/config/bsps/qoriq_e500.bset
index 0000000..2011d75
--- /dev/null
+++ b/rtems/config/bsps/qoriq_e500.bset
@@ -0,0 +1,10 @@
+%define with_rtems_bsp qoriq_e500
+%define rtems_target   powerpc-rtems%{rtems_version}
+6/rtems-powerpc
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/bsps/qoriq_e6500_32.bset b/rtems/config/bsps/qoriq_e6500_32.bset
index 0000000..419f334
--- /dev/null
+++ b/rtems/config/bsps/qoriq_e6500_32.bset
@@ -0,0 +1,10 @@
+%define with_rtems_bsp qoriq_e6500_32
+6/rtems-powerpc
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/bsps/qoriq_e6500_64.bset b/rtems/config/bsps/qoriq_e6500_64.bset
index 0000000..2d02b26
--- /dev/null
+++ b/rtems/config/bsps/qoriq_e6500_64.bset
@@ -0,0 +1,10 @@
+%define with_rtems_bsp qoriq_e6500_64
+6/rtems-powerpc
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/raspberrypi2.bset b/rtems/config/bsps/raspberrypi2.bset
similarity index 67%
rename from rtems/config/5/bsps/raspberrypi2.bset
rename to rtems/config/bsps/raspberrypi2.bset
index a7e51a3..83b12ea 100644
--- a/rtems/config/5/bsps/raspberrypi2.bset
+++ b/rtems/config/bsps/raspberrypi2.bset
@@ -12,10 +12,10 @@
 %define with_rtems_bsp raspberrypi2
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/xilinx_zynq_zc702.bset b/rtems/config/bsps/xilinx_zynq_zc702.bset
rename from rtems/config/5/bsps/xilinx_zynq_zc702.bset
rename to rtems/config/bsps/xilinx_zynq_zc702.bset
index 01177d7..295c841 100644
--- a/rtems/config/5/bsps/xilinx_zynq_zc702.bset
+++ b/rtems/config/bsps/xilinx_zynq_zc702.bset
@@ -12,10 +12,10 @@
 %define with_rtems_bsp xilinx_zynq_zc702
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/xilinx_zynq_zc706.bset b/rtems/config/bsps/xilinx_zynq_zc706.bset
rename from rtems/config/5/bsps/xilinx_zynq_zc706.bset
rename to rtems/config/bsps/xilinx_zynq_zc706.bset
index 1865b09..8b493cf 100644
--- a/rtems/config/5/bsps/xilinx_zynq_zc706.bset
+++ b/rtems/config/bsps/xilinx_zynq_zc706.bset
@@ -12,10 +12,10 @@
 %define with_rtems_bsp xilinx_zynq_zc706
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/xilinx_zynq_zedboard.bset b/rtems/config/bsps/xilinx_zynq_zedboard.bset
similarity index 69%
rename from rtems/config/5/bsps/xilinx_zynq_zedboard.bset
rename to rtems/config/bsps/xilinx_zynq_zedboard.bset
index b1fc65c..801c6c9 100644
--- a/rtems/config/5/bsps/xilinx_zynq_zedboard.bset
+++ b/rtems/config/bsps/xilinx_zynq_zedboard.bset
@@ -12,10 +12,10 @@
 %define with_rtems_bsp xilinx_zynq_zedboard
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/ftp/curl.bset b/rtems/config/ftp/curl.bset
index 84cac39..e0c58e4 100644
--- a/rtems/config/ftp/curl.bset
+++ b/rtems/config/ftp/curl.bset
@@ -4,11 +4,6 @@
 %define release 1
-# RTEMS Version
-%define rtems_version 5
 # The RTEMS URL paths.
diff --git a/rtems/config/net-mgmt/net-snmp.bset b/rtems/config/net-mgmt/net-snmp.bset
index 667acaa..07c2721 100644
--- a/rtems/config/net-mgmt/net-snmp.bset
+++ b/rtems/config/net-mgmt/net-snmp.bset
@@ -4,11 +4,6 @@
 %define release 1
-# RTEMS Version
-%define rtems_version 4.11
diff --git a/rtems/config/tools/rtems-kernel-5.cfg b/rtems/config/tools/rtems-kernel-5.cfg
index ef63205..0000000
--- a/rtems/config/tools/rtems-kernel-5.cfg
+++ /dev/null
@@ -1,12 +0,0 @@
-# RTEMS 5
-%define rtems_kernel_version 46c23871813618e7a16050068041b3d33551cd0d
-%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
-              CoTpxkjoEXVITsFBDFJReE4AbOYdgXFI1U3eCazd3dzi3B8R0n4L2qx5wSbzxajN7RzzTJZkbRMttRcB7Xh0lg==
-# The RTEMS build instructions.
-%include tools/rtems-kernel-common.cfg
diff --git a/rtems/config/tools/rtems-kernel-6.cfg b/rtems/config/tools/rtems-kernel-6.cfg
index 0000000..f1d0990
--- /dev/null
+++ b/rtems/config/tools/rtems-kernel-6.cfg
@@ -0,0 +1,12 @@
+# RTEMS 5
+%define rtems_kernel_version 3ec5f20484cc4201e1d7b87844505644533b6148
+%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
+              BjMKrf5n1YR6IpiZrY5TUEzKATPRJxA2/6m6f833DdRu+RyLxccXqA4gHRdVUqFelFNQ3o0XdG4o1naBKYfhkQ==
+# The RTEMS build instructions.
+%include tools/rtems-kernel-common.cfg
diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
index 3a17a28..157c7a4 100644
--- a/rtems/config/tools/rtems-kernel-common.cfg
+++ b/rtems/config/tools/rtems-kernel-common.cfg
@@ -214,8 +214,7 @@ URL: 	 https://www.rtems.org/
       export PATH="%{_internal_autotools_path}/bin:${PATH}"
     %endif
     ./bootstrap -c
-    %{_sbdir}/sb-bootstrap --preinstall
+    ./rtems-bootstrap
   %endif
   cd ..
diff --git a/rtems/config/tools/rtems-libbsd-5.cfg b/rtems/config/tools/rtems-libbsd-6.cfg
similarity index 63%
rename from rtems/config/tools/rtems-libbsd-5.cfg
rename to rtems/config/tools/rtems-libbsd-6.cfg
index f2c0e3d..1657096 100644
--- a/rtems/config/tools/rtems-libbsd-5.cfg
+++ b/rtems/config/tools/rtems-libbsd-6.cfg
@@ -1,10 +1,11 @@
-# RTEMS 5 LibBSD
+# RTEMS 6 LibBSD
-%define rtems_libbsd_version b96abfd647154f10ea8f7fac68e25676636eded5
+#  branch: 6-freebsd-12
+%define rtems_libbsd_version d964a6703c705cc92fd053bcefc08bb3b6baa0e2
 %hash sha512 rtems-libbsd-%{rtems_libbsd_version}.tar.bz2 \
-              /v2tsVlOL/ggpH8GMQib21tgEWaGKpjXdp44Ss/dDBgxxgbuc5mZ3DTlkjpOA72HeQ8HujGCdSX7QP9tjDkfMQ==
+              wEy8HtzSezKJtA3Vob7wM/D5qaG3ZVTDoNkK1yeTju04ov4IfL6IXWEtrNkOFsu9LdV1OPAOKSSYyAQ13sQqvg==
 %define rtems_waf_version ad08908c452c6a9bbb3bf7bbbcc9fc03fe46cc7f
 %hash sha512 rtems-waf-%{rtems_waf_version}.tar.bz2 \
               EyuEit0DsAR1gK9Ki1sjl416PFgFe7dcggH3H/hmdAPmMjEIIdX7TVOTDgOIK1Pt0DW6lZ9NcW7O87GZFyy8hg==
2.24.1
