[PATCH 0/8] Test Framework: Support Fixture Test Plans
Sebastian Huber
Thu Aug 13 10:11:25 UTC 2020
The functions T_push_fixture() and T_pop_fixture() were added to support
nested fixtures. This enables test building blocks. The patch set adds
fixture-specific test plans to allow the use of test plans with nested
fixtures.
Sebastian Huber (8):
libtest: Change fixture scope method
libtest: Add output buffer drain and fill
libtest: Add T_do_is_runner()
libtest: Add T_puts()
libtest: Use line buffer in T_check()
libtest: Add T_check_steps()
libtest: Add fixture steps
libtest: Change T_step() and T_assert_step()
cpukit/include/rtems/test.h | 31 +-
cpukit/libtest/t-test.c | 480 +++++++++++-------
testsuites/libtests/ttest01/init.c | 2 +-
testsuites/libtests/ttest01/test-destructor.c | 2 +-
testsuites/libtests/ttest01/test-fixture.c | 42 +-
testsuites/libtests/ttest01/test-plan.c | 6 +-
testsuites/libtests/ttest02/init.c | 7 +-
testsuites/smptests/smpmulticast01/init.c | 16 +-
8 files changed, 371 insertions(+), 215 deletions(-)
2.26.2
