[PATCH 2/8] libtest: Add output buffer drain and fill
Sebastian Huber
Thu Aug 13 10:11:27 UTC 2020
Update #3199.
cpukit/libtest/t-test.c | 60 ++++++++++++++++++++++++-----------------
1 file changed, 35 insertions(+), 25 deletions(-)
diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
index b1b5253bb5..e8d0542c31 100644
--- a/cpukit/libtest/t-test.c
+++ b/cpukit/libtest/t-test.c
@@ -143,15 +143,12 @@ T_snprintf(char *s, size_t n, char const *fmt, ...)
return len;
-static int
-T_vprintf_direct(char const *fmt, va_list ap)
+static void
+T_output_buffer_drain(T_context *ctx)
- T_context *ctx;
unsigned int head;
unsigned int tail;
- ctx = &T_instance;
head = atomic_load_explicit(&ctx->buf_head, memory_order_acquire);
tail = atomic_load_explicit(&ctx->buf_tail, memory_order_relaxed);
@@ -161,32 +158,16 @@ T_vprintf_direct(char const *fmt, va_list ap)
atomic_store_explicit(&ctx->buf_tail, tail, memory_order_relaxed);
- return _IO_Vprintf(ctx->putchar, ctx->putchar_arg, fmt, ap);
-static int
-T_vprintf_buffered(char const *fmt, va_list ap)
+static unsigned int
+T_output_buffer_fill(T_context *ctx, const char *buf, unsigned int len)
- unsigned int len;
- T_context *ctx;
- char buf[T_LINE_SIZE];
- T_putchar_string_context sctx = {
- .s = buf,
- .n = sizeof(buf)
unsigned int head;
unsigned int tail;
unsigned int mask;
unsigned int capacity;
- len = (unsigned int)_IO_Vprintf(T_putchar_string, &sctx, fmt, ap);
- if (len >= sizeof(buf)) {
- len = sizeof(buf) - 1;
pthread_spin_lock(&ctx->lock);
head = atomic_load_explicit(&ctx->buf_head, memory_order_relaxed);
@@ -195,7 +176,7 @@ T_vprintf_buffered(char const *fmt, va_list ap)
if (len <= capacity) {
unsigned int todo;
- char *c;
+ const char *c;
todo = len;
c = buf;
@@ -215,7 +196,36 @@ T_vprintf_buffered(char const *fmt, va_list ap)
pthread_spin_unlock(&ctx->lock);
- return (int)len;
+ return len;
+static int
+T_vprintf_direct(char const *fmt, va_list ap)
+ T_context *ctx;
+ ctx = &T_instance;
+ T_output_buffer_drain(ctx);
+ return _IO_Vprintf(ctx->putchar, ctx->putchar_arg, fmt, ap);
+static int
+T_vprintf_buffered(char const *fmt, va_list ap)
+ char buf[T_LINE_SIZE];
+ T_putchar_string_context sctx = {
+ .s = buf,
+ .n = sizeof(buf)
+ unsigned int len;
+ len = (unsigned int)_IO_Vprintf(T_putchar_string, &sctx, fmt, ap);
+ if (len >= sizeof(buf)) {
+ len = sizeof(buf) - 1;
+ return (int)T_output_buffer_fill(&T_instance, buf, len);
int
2.26.2
