[PATCH 1/8] libtest: Change fixture scope method
Sebastian Huber
Thu Aug 13 10:11:26 UTC 2020
Return the produced character count. There is no need for a NUL
termination.
Update #3199.
cpukit/include/rtems/test.h | 9 +-
cpukit/libtest/t-test.c | 136 ++++++++++++---------
testsuites/libtests/ttest01/test-fixture.c | 8 +-
3 files changed, 86 insertions(+), 67 deletions(-)
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index 18aafbcf7c..a3900c1285 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -62,7 +62,7 @@ typedef struct T_fixture {
void (*setup)(void *);
void (*stop)(void *);
void (*teardown)(void *);
- void (*scope)(void *, char *, size_t);
+ size_t (*scope)(void *, char *, size_t);
void *initial_context;
} T_fixture;
@@ -2324,14 +2324,19 @@ T_NO_RETURN void T_stop(void);
* @param second_indices is an array of indices defining which descriptive
* string is used for each entry in the description table.
+ * @return Returns the characters consumed from the buffer for the produced
+ * scope.
-void T_get_scope(
+size_t T_get_scope(
const char * const * const *desc,
char *buf,
size_t n,
const size_t *second_indices
+size_t T_str_copy(char *, const char *, size_t);
#ifdef __rtems__
#define T_TEST_CASE_FIXTURE(name, fixture) \
void T_case_body_##name(void); \
diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
index 999b8770d0..b1b5253bb5 100644
--- a/cpukit/libtest/t-test.c
+++ b/cpukit/libtest/t-test.c
@@ -244,9 +244,26 @@ T_cpu(void)
#endif
+size_t
+T_str_copy(char *dst, const char *src, size_t n)
+ size_t i;
+ i = 0;
+ while (*src != '\0' && i < n) {
+ *dst = *src;
+ ++dst;
+ ++src;
+ ++i;
+ return i;
#if defined(__rtems__)
-static const char *
-T_object_name_to_string(Objects_Name name, char *buf)
+static size_t
+T_object_name_to_string(char *dst, Objects_Name name, size_t n)
uint32_t on;
size_t i;
@@ -260,18 +277,18 @@ T_object_name_to_string(Objects_Name name, char *buf)
c = (unsigned char)(on >> s);
- if (c >= '!' && c <= '~') {
- buf[i] = (char)c;
+ if (c >= '!' && c <= '~' && i < n) {
+ *dst = (char)c;
+ ++dst;
++i;
- buf[i] = '\0';
- return buf;
+ return i;
-T_thread_name(const Thread_Control *th, char *buf)
+static size_t
+T_thread_name(char *dst, const Thread_Control *th, size_t n)
if (th != NULL) {
const char *name;
@@ -279,23 +296,21 @@ T_thread_name(const Thread_Control *th, char *buf)
name = th->Join_queue.Queue.name;
if (name != NULL && name[0] != '\0') {
- return name;
- } else {
- return T_object_name_to_string(th->Object.name, buf);
+ return T_str_copy(dst, name, n);
- } else {
- buf[0] = '?';
- buf[1] = '\0';
- return buf;
+ return T_object_name_to_string(dst, th->Object.name, n);
+ return T_str_copy(dst, "?", n);
#endif
-T_scope(T_context *ctx, char *buf)
+static size_t
+T_scope(T_context *ctx, char *dst, size_t n)
- const char *r;
T_fixture_node *node;
+ size_t len;
ISR_Level level;
@@ -309,31 +324,26 @@ T_scope(T_context *ctx, char *buf)
executing = _Per_CPU_Get_executing(cpu_self);
_ISR_Local_enable(level);
- r = T_thread_name(executing, buf);
+ len = T_thread_name(dst, executing, n);
} else {
- buf[0] = 'I';
- buf[1] = 'S';
- buf[2] = 'R';
- buf[3] = '\0';
- r = buf;
+ len = T_str_copy(dst, "ISR", n);
#elif defined(__linux__)
static __thread char name[128];
- (void)buf;
if (name[0] == '\0') {
pthread_getname_np(pthread_self(), name, sizeof(name));
- r = &name[0];
+ len = T_str_copy(dst, name, n);
#else
- buf[0] = '?';
- buf[1] = '\0';
- r = buf;
+ len = T_str_copy(dst, "?", n);
#endif
+ dst += len;
+ n -= len;
node = &ctx->case_fixture;
do {
@@ -342,17 +352,18 @@ T_scope(T_context *ctx, char *buf)
fixture = node->fixture;
if (fixture != NULL && fixture->scope != NULL) {
- size_t n;
+ size_t m;
- n = strlen(r);
- (*fixture->scope)(node->context, buf + n,
- T_SCOPE_SIZE - n);
+ m = (*fixture->scope)(node->context, dst, n);
+ dst += m;
+ n -= m;
+ len += m;
node = node->previous;
} while (node != NULL);
- return r;
+ return len;
static void
@@ -541,6 +552,7 @@ T_check(const T_check_context *t, bool ok, ...)
T_context *ctx;
va_list ap;
char scope[T_SCOPE_SIZE];
+ size_t len;
unsigned int step;
ctx = &T_instance;
@@ -551,27 +563,28 @@ T_check(const T_check_context *t, bool ok, ...)
step = UINT_MAX;
+ len = T_scope(ctx, scope, sizeof(scope) - 1);
+ scope[len] = '\0';
if ((t->flags & T_CHECK_STEP_FLAG) != 0 &&
step != T_CHECK_STEP_FROM_FLAGS(t->flags)) {
T_add_failure(ctx);
T_printf("F:%u:%i:%s:%s:%i:planned step (%u)\n", step,
- T_cpu(), T_scope(ctx, scope), T_file(t), t->line,
- T_CHECK_STEP_FROM_FLAGS(t->flags));
+ T_cpu(), scope, T_file(t),
+ t->line, T_CHECK_STEP_FROM_FLAGS(t->flags));
} else if (!ok) {
T_add_failure(ctx);
if (ctx->verbosity >= T_NORMAL) {
if ((t->flags & T_CHECK_QUIET) == 0) {
T_printf("F:%u:%i:%s:%s:%i",
- step, T_cpu(), T_scope(ctx, scope),
- T_file(t), t->line);
+ step, T_cpu(), scope, T_file(t), t->line);
} else if (t->line >= 0) {
- T_printf("F:*:%i:%s:%s:%i", T_cpu(),
- T_scope(ctx, scope), T_file(t),
- t->line);
+ T_printf("F:*:%i:%s:%s:%i", T_cpu(), scope,
+ T_file(t), t->line);
} else {
- T_printf("F:*:%i:%s:%s:*", T_cpu(),
- T_scope(ctx, scope), T_file(t));
+ T_printf("F:*:%i:%s:%s:*", T_cpu(), scope,
+ T_file(t));
if ((t->flags & T_CHECK_FMT) != 0) {
@@ -593,8 +606,8 @@ T_check(const T_check_context *t, bool ok, ...)
} else if ((t->flags & T_CHECK_QUIET) == 0 &&
ctx->verbosity >= T_VERBOSE) {
- T_printf("P:%u:%i:%s:%s:%i\n", step, T_cpu(),
- T_scope(ctx, scope), T_file(t), t->line);
+ T_printf("P:%u:%i:%s:%s:%i\n", step, T_cpu(), scope, T_file(t),
+ t->line);
@@ -847,10 +860,13 @@ T_do_case_end(T_context *ctx, const T_case_context *tc)
+ size_t len;
T_printf("F:*:%i:%s:*:*:actual steps (%u), "
"planned steps (%u)\n", T_cpu(),
- T_scope(ctx, scope), steps, planned_steps);
+ scope, steps, planned_steps);
@@ -1106,12 +1122,14 @@ T_pop_fixture(void)
memset(node, 0, sizeof(*node));
-void
+size_t
T_get_scope(const char * const * const *desc, char *buf, size_t n,
const size_t *second_indices)
+ size_t c;
size_t i;
+ c = n;
i = 0;
while (true) {
@@ -1121,26 +1139,22 @@ T_get_scope(const char * const * const *desc, char *buf, size_t n,
desc2 = desc[i];
if (desc2 == NULL) {
- return;
+ break;
- if (n > 1) {
+ if (c > 1) {
buf[0] = '/';
- --n;
+ --c;
++buf;
} else {
- return;
- m = strlcpy(buf, desc2[second_indices[i]], n);
- if (m < n) {
- n -= m;
- buf += m;
- } else {
- return;
+ break;
+ m = T_str_copy(buf, desc2[second_indices[i]], c);
+ buf += m;
+ c -= m;
++i;
+ return n - c;
diff --git a/testsuites/libtests/ttest01/test-fixture.c b/testsuites/libtests/ttest01/test-fixture.c
index 545fbf19dc..0e97c1c71c 100644
--- a/testsuites/libtests/ttest01/test-fixture.c
+++ b/testsuites/libtests/ttest01/test-fixture.c
@@ -43,11 +43,11 @@ teardown(void *ctx)
T_log(T_QUIET, "teardown end");
-static void
+static size_t
scope(void *ctx, char *buf, size_t n)
- strlcpy(buf, "/More", n);
+ return T_str_copy(buf, "/More", n);
static const T_fixture fixture = {
@@ -101,11 +101,11 @@ teardown_2(void *ctx)
T_log(T_QUIET, "teardown 2 end");
-static void
+static size_t
scope_2(void *ctx, char *buf, size_t n)
- strlcpy(buf, "/AndMore", n);
+ return T_str_copy(buf, "/AndMore", n);
static const T_fixture fixture_2 = {
2.26.2
