[PATCH 6/8] libtest: Add T_check_steps()
Thu Aug 13 10:11:31 UTC 2020
Update #3199.
 cpukit/libtest/t-test.c | 31 +++++++++++++------------------
 1 file changed, 13 insertions(+), 18 deletions(-)
diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
index 26fe988b11..21e9afe190 100644
--- a/cpukit/libtest/t-test.c
+++ b/cpukit/libtest/t-test.c
@@ -49,8 +49,6 @@
 #define T_LINE_SIZE 128
-#define T_SCOPE_SIZE 64
 typedef struct {
 	pthread_spinlock_t lock;
 	char *buf;
@@ -937,6 +935,17 @@ T_do_case_begin(T_context *ctx, const T_case_context *tc)
+static void
+T_check_steps(unsigned int planned_steps, unsigned int steps,
+    unsigned int failures)
+	if (planned_steps != UINT_MAX && planned_steps != steps &&
+	    failures == 0) {
+		T_check(&T_special, false, "actual steps (%u), "
+		    "planned steps (%u)", steps, planned_steps);
 static void
 T_do_case_end(T_context *ctx, const T_case_context *tc)
@@ -976,23 +985,9 @@ T_do_case_end(T_context *ctx, const T_case_context *tc)
 	    memory_order_relaxed);
 	failures = atomic_fetch_add_explicit(&ctx->failures, 0,
+	T_check_steps(planned_steps, steps, failures);
-	if (planned_steps != UINT_MAX && planned_steps != steps &&
-	    failures == 0) {
-		++failures;
-		if (ctx->verbosity >= T_NORMAL) {
-			char scope[T_SCOPE_SIZE];
-			size_t len;
-			len = T_scope(ctx, scope, sizeof(scope) - 1);
-			scope[len] = '\0';
-			T_printf("F:*:%i:%s:*:*:actual steps (%u), "
-			    "planned steps (%u)\n", T_cpu(),
-			    scope, steps, planned_steps);
+	failures = atomic_load_explicit(&ctx->failures, memory_order_relaxed);
 	delta = (*config->now)() - ctx->case_begin_time;
 	T_do_log(ctx, T_QUIET, "E:%s:N:%u:F:%u:D:%s\n",
 	    tc->name, steps, failures, T_time_to_string_us(delta, ts));
2.26.2
