[PATCH 7/8] libtest: Add fixture steps
Sebastian Huber
Thu Aug 13 10:11:32 UTC 2020
Support a new test plan for each nested fixture.
Update #3199.
cpukit/include/rtems/test.h | 3 +
cpukit/libtest/t-test.c | 83 ++++++++++++++--------
testsuites/libtests/ttest01/init.c | 2 +-
testsuites/libtests/ttest01/test-fixture.c | 34 ++++-----
testsuites/libtests/ttest02/init.c | 7 +-
5 files changed, 80 insertions(+), 49 deletions(-)
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index 212d4a5ae2..95e078ceff 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -71,6 +71,9 @@ typedef struct T_fixture_node {
struct T_fixture_node *previous;
const T_fixture *fixture;
void *context;
+ unsigned int next_planned_steps;
+ unsigned int next_steps;
+ unsigned int failures;
} T_fixture_node;
#define T_ARRAY_SIZE(array) (sizeof(array) / sizeof((array)[0]))
diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
index 21e9afe190..306f9439c4 100644
--- a/cpukit/libtest/t-test.c
+++ b/cpukit/libtest/t-test.c
@@ -68,6 +68,7 @@ typedef struct {
atomic_uint steps;
atomic_uint failures;
jmp_buf case_begin_context;
+ unsigned int fixture_steps;
unsigned int overall_cases;
unsigned int overall_steps;
unsigned int overall_failures;
@@ -633,6 +634,32 @@ T_check_putc(int c, void *arg)
+static void
+T_check_print_steps(T_context *ctx, T_putchar_string_context *sctx,
+ unsigned int step)
+ T_fixture_node *node;
+ node = &ctx->case_fixture;
+ while (true) {
+ node = node->previous;
+ if (node != NULL) {
+ _IO_Printf(T_check_putc, sctx, "%u.",
+ node->next_steps);
+ } else {
+ break;
+ if (step != UINT_MAX) {
+ _IO_Printf(T_check_putc, sctx, "%u", step);
+ } else {
+ T_check_putc('*', sctx);
void
T_check(const T_check_context *t, bool ok, ...)
@@ -686,13 +713,7 @@ T_check(const T_check_context *t, bool ok, ...)
sctx.n = sizeof(line) - 1;
sctx.s = &line[1];
T_check_putc(':', &sctx);
- if (step != UINT_MAX) {
- _IO_Printf(T_check_putc, &sctx, "%u", step);
- } else {
- T_check_putc('*', &sctx);
+ T_check_print_steps(ctx, &sctx, step);
_IO_Printf(T_check_putc, &sctx, ":%i:", T_cpu());
chunk = T_scope(ctx, sctx.s, sctx.n);
sctx.s += chunk;
@@ -887,8 +908,6 @@ T_do_run_initialize(const T_config *config)
ctx->putchar = config->putchar;
ctx->putchar_arg = config->putchar_arg;
ctx->verbosity = config->verbosity;
- atomic_store_explicit(&ctx->steps, 0, memory_order_relaxed);
- atomic_store_explicit(&ctx->failures, 0, memory_order_relaxed);
ctx->overall_cases = 0;
ctx->overall_steps = 0;
ctx->overall_failures = 0;
@@ -919,6 +938,7 @@ T_do_case_begin(T_context *ctx, const T_case_context *tc)
+ ctx->fixture_steps = 0;
T_actions_forward(config, T_EVENT_CASE_EARLY, tc->name);
T_do_log(ctx, T_NORMAL, "B:%s\n", tc->name);
@@ -950,33 +970,18 @@ static void
T_do_case_end(T_context *ctx, const T_case_context *tc)
const T_config *config;
- T_fixture_node *node;
unsigned int planned_steps;
unsigned int steps;
T_time delta;
T_time_string ts;
- config = ctx->config;
- node = ctx->fixtures;
- ctx->fixtures = NULL;
- while (node != NULL) {
- const T_fixture *fixture;
- T_fixture_node *dead;
- fixture = node->fixture;
- if (fixture != NULL && fixture->teardown != NULL) {
- (*fixture->teardown)(node->context);
- dead = node;
- node = node->next;
- memset(dead, 0, sizeof(*dead));
+ while (ctx->fixtures != NULL) {
+ T_pop_fixture();
T_call_destructors(ctx);
+ config = ctx->config;
T_actions_backward(config, T_EVENT_CASE_END, tc->name);
planned_steps = atomic_fetch_add_explicit(&ctx->planned_steps,
@@ -989,6 +994,7 @@ T_do_case_end(T_context *ctx, const T_case_context *tc)
failures = atomic_load_explicit(&ctx->failures, memory_order_relaxed);
delta = (*config->now)() - ctx->case_begin_time;
+ steps += ctx->fixture_steps;
T_do_log(ctx, T_QUIET, "E:%s:N:%u:F:%u:D:%s\n",
tc->name, steps, failures, T_time_to_string_us(delta, ts));
@@ -1179,6 +1185,12 @@ T_push_fixture(T_fixture_node *node, const T_fixture *fixture)
node->fixture = fixture;
context = fixture->initial_context;
node->context = context;
+ node->next_planned_steps = atomic_exchange_explicit(
+ &ctx->planned_steps, UINT_MAX, memory_order_relaxed);
+ node->next_steps = atomic_exchange_explicit(&ctx->steps, 0,
+ memory_order_relaxed);
+ node->failures = atomic_fetch_add_explicit(&ctx->failures, 0,
ctx->fixtures = node;
if (fixture != NULL && fixture->setup != NULL) {
@@ -1199,7 +1211,6 @@ T_pop_fixture(void)
ctx = &T_instance;
next = node->next;
- next->previous = NULL;
ctx->fixtures = next;
@@ -1207,6 +1218,22 @@ T_pop_fixture(void)
+ if (next != NULL) {
+ unsigned int planned_steps;
+ unsigned int steps;
+ next->previous = NULL;
+ planned_steps = atomic_exchange_explicit(&ctx->planned_steps,
+ node->next_planned_steps, memory_order_relaxed);
+ steps = atomic_exchange_explicit(&ctx->steps, node->next_steps,
+ failures = atomic_fetch_add_explicit(&ctx->failures, 0,
+ ctx->fixture_steps += steps;
+ T_check_steps(planned_steps, steps, node->failures - failures);
memset(node, 0, sizeof(*node));
diff --git a/testsuites/libtests/ttest01/init.c b/testsuites/libtests/ttest01/init.c
index 35b7023385..8636cdadd4 100644
--- a/testsuites/libtests/ttest01/init.c
+++ b/testsuites/libtests/ttest01/init.c
@@ -183,7 +183,7 @@ run_initialize(void)
static const char expected_final[] = "Z:ttest01:C:343:N:1335:F:795:D:0.689999\n"
-"Y:ReportHash:SHA256:f018ab0c9ddf5c5bc0ba8377492dc52205f9b63146c787fb669222e346c65d0f\n";
+"Y:ReportHash:SHA256:525591019364543d5694dd09fef3bf2f0b7db69694f959e4298f22f4f9803fef\n";
static void
run_finalize(void)
diff --git a/testsuites/libtests/ttest01/test-fixture.c b/testsuites/libtests/ttest01/test-fixture.c
index 0e97c1c71c..e1f59876ca 100644
--- a/testsuites/libtests/ttest01/test-fixture.c
+++ b/testsuites/libtests/ttest01/test-fixture.c
@@ -144,35 +144,35 @@ T_TEST_OUTPUT(fixture,
"L:setup end\n"
"P:3:0:UI1/More:test-fixture.c:125\n"
"L:setup 2 begin\n"
-"P:4:0:UI1/More/AndMore:test-fixture.c:71\n"
-"P:5:0:UI1/More/AndMore:test-fixture.c:72\n"
-"P:6:0:UI1/More/AndMore:test-fixture.c:76\n"
+"P:4.0:0:UI1/More/AndMore:test-fixture.c:71\n"
+"P:4.1:0:UI1/More/AndMore:test-fixture.c:72\n"
+"P:4.2:0:UI1/More/AndMore:test-fixture.c:76\n"
"L:setup 2 end\n"
-"P:7:0:UI1/More/AndMore:test-fixture.c:127\n"
+"P:4.3:0:UI1/More/AndMore:test-fixture.c:127\n"
"L:teardown 2 begin\n"
-"P:8:0:UI1/More:test-fixture.c:98\n"
-"P:9:0:UI1/More:test-fixture.c:100\n"
+"P:4.4:0:UI1/More/AndMore:test-fixture.c:98\n"
+"P:4.5:0:UI1/More/AndMore:test-fixture.c:100\n"
"L:teardown 2 end\n"
"L:setup 2 begin\n"
-"P:10:0:UI1/More/AndMore:test-fixture.c:71\n"
-"P:11:0:UI1/More/AndMore:test-fixture.c:72\n"
-"P:12:0:UI1/More/AndMore:test-fixture.c:76\n"
"L:setup 2 end\n"
-"P:13:0:UI1/More/AndMore:test-fixture.c:131\n"
-"F:14:0:UI1/More/AndMore:test-fixture.c:132:test fails and we stop the test case\n"
+"P:4.3:0:UI1/More/AndMore:test-fixture.c:131\n"
+"F:4.4:0:UI1/More/AndMore:test-fixture.c:132:test fails and we stop the test case\n"
"L:stop 2 begin\n"
-"P:15:0:UI1/More/AndMore:test-fixture.c:86\n"
+"P:4.5:0:UI1/More/AndMore:test-fixture.c:86\n"
"L:stop 2 end\n"
"L:stop begin\n"
-"P:16:0:UI1/More/AndMore:test-fixture.c:28\n"
+"P:4.6:0:UI1/More/AndMore:test-fixture.c:28\n"
"L:stop end\n"
-"P:17:0:UI1/More/AndMore:test-fixture.c:98\n"
-"P:18:0:UI1/More/AndMore:test-fixture.c:100\n"
+"P:4.7:0:UI1/More/AndMore:test-fixture.c:98\n"
+"P:4.8:0:UI1/More/AndMore:test-fixture.c:100\n"
"L:teardown begin\n"
-"P:19:0:UI1/More:test-fixture.c:40\n"
-"P:20:0:UI1/More:test-fixture.c:42\n"
+"P:4:0:UI1/More:test-fixture.c:40\n"
+"P:5:0:UI1/More:test-fixture.c:42\n"
"L:teardown end\n"
"E:fixture:N:21:F:1:D:0.001000\n");
diff --git a/testsuites/libtests/ttest02/init.c b/testsuites/libtests/ttest02/init.c
index 846a778536..7f972aec7e 100644
--- a/testsuites/libtests/ttest02/init.c
+++ b/testsuites/libtests/ttest02/init.c
@@ -134,6 +134,7 @@ static void
fatal(void *arg)
(void)arg;
+ T_plan(1);
T_step(0);
T_stop();
@@ -149,7 +150,6 @@ T_TEST_CASE(TestInterruptFatal)
Atomic_Uint action_state;
- T_plan(1);
T_interrupt_test(&fatal_config, &action_state);
T_unreachable();
@@ -161,6 +161,7 @@ suspend(void *arg)
rtems_id *id;
id = arg;
+ T_plan(2);
sc = rtems_task_suspend(*id);
T_step_rsc_success(1, sc);
@@ -202,10 +203,10 @@ T_TEST_CASE(TestInterruptBlocked)
T_interrupt_test_state state;
rtems_id id;
- T_plan(3);
+ T_plan(1);
id = rtems_task_self();
state = T_interrupt_test(&blocked_config, &id);
- T_step_eq_int(2, state, T_INTERRUPT_TEST_DONE);
+ T_step_eq_int(0, state, T_INTERRUPT_TEST_DONE);
T_TEST_CASE(TestThreadSwitch)
2.26.2
