What happens during boot time in terms of scheduling?
Sebastian Huber
Fri Aug 14 12:48:34 UTC 2020
On 14/08/2020 11:25, Richi Dubey wrote:
> Is _RTEMS_tasks_Initialize_user_task responsible for starting the Init
> task?
Yes.
> Also how does the following code which is part
> of rtems_initialize_executive:
> /* Invoke the registered system initialization handlers */
> RTEMS_LINKER_SET_FOREACH( _Sysinit, item ) {
> ( *item->handler )();
> call _RTEMS_tasks_Initialize_user_task?
This is done via a linker set:
https://docs.rtems.org/branches/master/c-user/linker_sets.html
You can see the entries with this host command line tool:
https://docs.rtems.org/branches/master/user/tools/exeinfo.html
