What happens during boot time in terms of scheduling?
Richi Dubey
richidubey at gmail.com
Fri Aug 14 15:50:23 UTC 2020
My god. There's so much that a bachelor's degree does not teach.
Thank you for your answer.
On Fri, Aug 14, 2020 at 6:18 PM Sebastian Huber <
> On 14/08/2020 11:25, Richi Dubey wrote:
> > Is _RTEMS_tasks_Initialize_user_task responsible for starting the Init
> > task?
> Yes.
> > Also how does the following code which is part
> > of rtems_initialize_executive:
> > /* Invoke the registered system initialization handlers */
> > RTEMS_LINKER_SET_FOREACH( _Sysinit, item ) {
> > ( *item->handler )();
> > call _RTEMS_tasks_Initialize_user_task?
> This is done via a linker set:
> https://docs.rtems.org/branches/master/c-user/linker_sets.html
> You can see the entries with this host command line tool:
> https://docs.rtems.org/branches/master/user/tools/exeinfo.html
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200814/0db288c1/attachment.html>
