[PATCH v1 0/6] [libbsd] Fix e1000 driver for i386 in master and 5
Joel Sherrill
joel at rtems.org
Sat Aug 15 00:45:02 UTC 2020
On Fri, Aug 14, 2020, 7:04 PM Chris Johns <chrisj at rtems.org> wrote:
> On 15/8/20 8:31 am, Joel Sherrill wrote:
> > On Fri, Aug 14, 2020 at 4:42 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 15/8/20 5:57 am, Jan Sommer wrote:
> > > Hello,
> > > I finally got around to port the e1000 driver fixes which are
> already
> > > present in the 5-freebsd-12 branch of rtems-libbsd also for the
> master
> > > (and 5) branch.
> > Thanks. I will push these soon.
> > I am not sure if the 5 branch in the rtems-libbsd.git repo is right
> and if it
> > should be made from the 5-freebsd-12 branch? I feel it is currently
> confusing
> > but either way it has issues.
> > If I remember correctly, Sebastian told me 5 was FreeBSD master on RTEMS
> 5.
> > If that's right, it would have been better with the longer name
> 5-freebsd-master
> > since we use 5 as the name for other repos to indicate trusted "5".
> Problems appear when we have variants in names because management around
> the
> repos needs to handle special cases ...
> https://git.rtems.org/rtems-release/tree/rtems-release-package-start?h=5#n109
> On the other hand the difference in one repo like libbsd has created a
> special
> case in the release scripts because 5 was being picked up and released
> without
> error until I caught it testing. Thus the need for the mapping and that
> rippled
> out in to other issues.
> I am not sure what the answer is but any solution or change needs to be
> worked
> through our procedures.
+1
I rather like the idea of combining RTEMS version with the bsd version in
the branch name. I know it is a bit of a pain in scripts..even explaining
it to people is odd. But a regular pattern would help and not having simple
numbers would help avoid mistakes.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200814/2eb9029b/attachment-0001.html>
