[GSoC 2020]: Need help in writing sed alternative in Python for RSB recipes
Mritunjay Sharma mritunjaysharma394 at gmail.com
Sat Aug 15 14:12:33 UTC 2020
[Update]: I have built a workable python cli package known as 'pycli'
which works as an alternative for 'sed'.
I made the following changes in the config file:
diff --git a/source-builder/config/epics-7-1.cfg
b/source-builder/config/epics-7-1.cfg
index f51c658..6408534 100644
--- a/source-builder/config/epics-7-1.cfg
+++ b/source-builder/config/epics-7-1.cfg
@@ -34,12 +34,11 @@ URL:  https://epics.mpg.de/
 # Changing the RTEMS Version in
epics-base/configure/os/CONFIG_SITE.Common.RTEMS
-sed -i 's/RTEMS_VERSION = .*/RTEMS_VERSION = 5/g'
+pycli 'RTEMS_VERSION = .*' 'RTEMS_VERSION = 5'
 # Changing the RTEMS Base in
-sed -i "s/^RTEMS_BASE .*/RTEMS_BASE =
\/home\/mritunjay\/development\/rtems\/\$\(RTEMS_VERSION\)\-arm/g"
+pycli '^RTEMS_BASE .*' 'RTEMS_BASE =
/home/mritunjay/development/rtems/$(RTEMS_VERSION)-arm/'
   cd ${build_top}
diff --git a/source-builder/config/spike-1-1.cfg
b/source-builder/config/spike-1-1.cfg
index e731348..aff3f35 100644
--- a/source-builder/config/spike-1-1.cfg
+++ b/source-builder/config/spike-1-1.cfg
@@ -3,7 +3,7 @@
 # This configuration file configure's, make's and install's RISC-V's spike
simulator.
+%define spike_version 01252686902fa30665fbecfc1476d169ad1333d1
 %if %{release} == %{nil}
 %define release 1
 %endif
This worked successfully and the build ran fine. I am going to upload the
entire python pycli project on the github in a couple of hours.
The main part of the python script that did the work is here:
'''import re
def replace(oldstring, newstring, infile, dryrun=False):
    Sed-like Replace
    Usage: pycli <Old string>  <Replacement String> <Text File>
    Example: pycli 'xyz' 'XYZ' '/path/to/file.txt'
    linelist = []
    with open(infile) as f:
        for item in f:
            newitem = re.sub(oldstring, newstring, item)
            linelist.append(newitem)
    if dryrun == False:
        with open(infile, "w") as f:
            f.truncate()
            for line in linelist: f.writelines(line)
    elif dryrun == True:
        for line in linelist: print(line, end='')
    else:
        exit("Unknown option specified to 'dryrun' argument, Usage:
dryrun=<True|False>.")'''
Please do give the feedback if this has been done in the right way?
Thanks
Mritunjay Sharma
On Fri, Aug 14, 2020 at 3:13 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Hello everyone,
> Based on the input received by Gedare, I have started working
> on finding a 'sed' alternative to be used in the RSB recipes to
> do streamline text replacements.
> I have gone through the Python Development Guidelines (
> https://docs.rtems.org/branches/master/eng/python-devel.html)
> and have installed the things suggested in this for the development
> environment.
> To start with the research work, I found this interesting
> the discussion here
> https://unix.stackexchange.com/questions/13711/differences-between-sed-on-mac-osx-and-other-standard-sed that
> gave me an idea
> on how sed differs in BSD and UNIX platforms.
> I learnt about differences like:
> `OS X's sed uses -E for ERE and GNU sed uses -r. -E is an alias for -r in
> GNU sed (added in 4.2, not documented until 4.3). Newer versions of FreeBSD
> and NetBSD sed support both -E and -r. OpenBSD sed only supports -E.
> I also found a similar project https://github.com/chmln/sd which can help
> us in
> developing the Python code needed in our case.
> I would request the mentors to guide me on how and where to begin from
> in writing this alternative?
> Where do I have to write it? Is it the rtems-tools project (
> https://github.com/RTEMS/rtems-tools) where I have to contribute to for
> building this alternative?
> Thanks
> Mritunjay Sharma
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200815/f496ef70/attachment-0001.html>
