[GSoC 2020]: Need help in writing sed alternative in Python for RSB recipes
Mritunjay Sharma mritunjaysharma394 at gmail.com
Sat Aug 15 14:17:59 UTC 2020
On Sat, Aug 15, 2020 at 7:42 PM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> [Update]: I have built a workable python cli package known as 'pycli'
> which works as an alternative for 'sed'.
> I made the following changes in the config file:
> diff --git a/source-builder/config/epics-7-1.cfg
> b/source-builder/config/epics-7-1.cfg
> index f51c658..6408534 100644
> --- a/source-builder/config/epics-7-1.cfg
> +++ b/source-builder/config/epics-7-1.cfg
> @@ -34,12 +34,11 @@ URL:  https://epics.mpg.de/
>  # Changing the RTEMS Version in
> epics-base/configure/os/CONFIG_SITE.Common.RTEMS
> -sed -i 's/RTEMS_VERSION = .*/RTEMS_VERSION = 5/g'
> +pycli 'RTEMS_VERSION = .*' 'RTEMS_VERSION = 5'
>  # Changing the RTEMS Base in
> -sed -i "s/^RTEMS_BASE .*/RTEMS_BASE =
> \/home\/mritunjay\/development\/rtems\/\$\(RTEMS_VERSION\)\-arm/g"
> +pycli '^RTEMS_BASE .*' 'RTEMS_BASE =
> /home/mritunjay/development/rtems/$(RTEMS_VERSION)-arm/'
>    cd ${build_top}
Kindly ignore this spike part, It was mistakenly sent.
> diff --git a/source-builder/config/spike-1-1.cfg
> b/source-builder/config/spike-1-1.cfg
> index e731348..aff3f35 100644
> --- a/source-builder/config/spike-1-1.cfg
> +++ b/source-builder/config/spike-1-1.cfg
> @@ -3,7 +3,7 @@
>  # This configuration file configure's, make's and install's RISC-V's
> spike simulator.
> +%define spike_version 01252686902fa30665fbecfc1476d169ad1333d1
>  %if %{release} == %{nil}
>  %define release 1
>  %endif
> This worked successfully and the build ran fine. I am going to upload the
> entire python pycli project on the github in a couple of hours.
> The main part of the python script that did the work is here:
> '''import re
> def replace(oldstring, newstring, infile, dryrun=False):
>     Sed-like Replace
>     Usage: pycli <Old string>  <Replacement String> <Text File>
>     Example: pycli 'xyz' 'XYZ' '/path/to/file.txt'
>     linelist = []
>     with open(infile) as f:
>         for item in f:
>             newitem = re.sub(oldstring, newstring, item)
>             linelist.append(newitem)
>     if dryrun == False:
>         with open(infile, "w") as f:
>             f.truncate()
>             for line in linelist: f.writelines(line)
>     elif dryrun == True:
>         for line in linelist: print(line, end='')
>     else:
>         exit("Unknown option specified to 'dryrun' argument, Usage:
> dryrun=<True|False>.")'''
> Please do give the feedback if this has been done in the right way?
> Thanks
> Mritunjay Sharma
> On Fri, Aug 14, 2020 at 3:13 AM Mritunjay Sharma <
>> Hello everyone,
>> Based on the input received by Gedare, I have started working
>> on finding a 'sed' alternative to be used in the RSB recipes to
>> do streamline text replacements.
>> I have gone through the Python Development Guidelines (
>> https://docs.rtems.org/branches/master/eng/python-devel.html)
>> and have installed the things suggested in this for the development
>> environment.
>> To start with the research work, I found this interesting
>> the discussion here
>> https://unix.stackexchange.com/questions/13711/differences-between-sed-on-mac-osx-and-other-standard-sed that
>> gave me an idea
>> on how sed differs in BSD and UNIX platforms.
>> I learnt about differences like:
>> `OS X's sed uses -E for ERE and GNU sed uses -r. -E is an alias for -r in
>> GNU sed (added in 4.2, not documented until 4.3). Newer versions of FreeBSD
>> and NetBSD sed support both -E and -r. OpenBSD sed only supports -E.
>> I also found a similar project https://github.com/chmln/sd which can
>> help us in
>> developing the Python code needed in our case.
>> I would request the mentors to guide me on how and where to begin from
>> in writing this alternative?
>> Where do I have to write it? Is it the rtems-tools project (
>> https://github.com/RTEMS/rtems-tools) where I have to contribute to for
>> building this alternative?
>> Thanks
>> Mritunjay Sharma
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200815/7e0c54a7/attachment.html>
