[PATCH] bsps/shared/ofw: Implement RTEMS OFW interface
Niteesh G. S.
niteesh.gs at gmail.com
Sat Aug 15 18:55:42 UTC 2020
Hello,
This patch adds the FDT implementation of the OpenFirmWare interface to
RTEMS.
This patch is compilable and has been tested on real hardware using the
following
test.
https://github.com/gs-niteesh/rtems/commit/163160bae483d2e12bb7ab9208228989adf01e66
Sorry for sending in a large patch. These are actually separate commits in
my repo but
the commits were too messed up so I merged them all in a separate branch
and sent
them.
Thanks,
Niteesh.
On Sun, Aug 16, 2020 at 12:19 AM G S Niteesh Babu <niteesh.gs at gmail.com>
wrote:
> bsps/include/ofw/ofw.h | 534 ++++++++++++++++++++++++++++++++
> bsps/shared/ofw/ofw.c | 654 ++++++++++++++++++++++++++++++++++++++++
> spec/build/bsps/obj.yml | 4 +
> 3 files changed, 1192 insertions(+)
> create mode 100644 bsps/include/ofw/ofw.h
> create mode 100644 bsps/shared/ofw/ofw.c
> diff --git a/bsps/include/ofw/ofw.h b/bsps/include/ofw/ofw.h
> new file mode 100644
> index 0000000000..2ca5328abc
> --- /dev/null
> +++ b/bsps/include/ofw/ofw.h
> @@ -0,0 +1,534 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup ofw
> + * RTEMS FDT implementation of OpenFirmWare Interface.
> + * RTEMS OFW is a FDT only implementation of the OpenFirmWare interface.
> + * This API is created to be compatible with FreeBSD OpenFirmWare
> interface.
> + * The main intention is to make porting of FreeBSD drivers to RTEMS
> easier.
> + * Copyright (C) 2020 Niteesh Babu G S <niteesh.gs at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _OFW_H
> +#define _OFW_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#include <stdint.h>
> +#include <stddef.h>
> + * Represents a node in the device tree. The offset from fdtp to node is
> used
> + * instead of fdt offset to make sure this is compatible with OF
> interface in
> + * FreeBSD.
> +typedef uint32_t phandle_t;
> + * Represents the effective phandle of the node.
> +typedef uint32_t ihandle_t;
> + * Represents the data type of the buffer.
> +typedef uint32_t pcell_t;
> + * @struct rtems_ofw_memory_area
> + * This is used to represent elements(FDT properties) that define
> + * region of memory address.
> +typedef struct {
> + /** The start address of the memory region. */
> + uint32_t start;
> + /** The size of the memory region. */
> + uint32_t size;
> +} rtems_ofw_memory_area;
> + * @struct rtems_ofw_ranges
> + * This is used to represent the ranges property in the device tree.
> +typedef struct {
> + /** The physical address within the child bus address space */
> + uint32_t child_bus;
> + /** The physical address within the parent bus address space */
> + uint32_t parent_bus;
> + /** The size of the range in the child’s address space */
> + uint32_t size;
> +} rtems_ofw_ranges;
> + * @brief Gets the node that is next to @a node.
> + * @param[in] node Node offset
> + * @retval Peer node offset Successful operation.
> + * @retval 0 No peer node or invalid node handle
> +phandle_t rtems_ofw_peer(
> + phandle_t node
> + * @brief Gets the node that is the child of @a node.
> + * @retval child node offset Successful operation.
> + * @retval 0 No child node or invalid node handle
> +phandle_t rtems_ofw_child(
> + phandle_t node
> + * @brief Gets the node that is the parent of @a node.
> +phandle_t rtems_ofw_parent(
> + phandle_t node
> + * @brief Gets the length of the property mentioned in @a propname.
> + * @param[in] prop Property name
> + * @retval -1 Invalid node or property
> + * @retval Length of property on successful operation
> +size_t rtems_ofw_get_prop_len(
> + phandle_t node,
> + const char *propname
> + * @brief Gets the value of property mentioned in @a propname.
> + * @param[out] buf The property value gets stored in this buffer
> (Pre-allocated)
> + * @param[in] len Length of the buffer
> +size_t rtems_ofw_get_prop(
> + phandle_t node,
> + const char *propname,
> + void *buf,
> + size_t len
> + * @brief Gets the value of property mentioned in @a prop.
> + * Gets the value of property of @a node and converts the value into the
> host's
> + * endianness.
> buffer(Pre-allocated)
> + * after converted to the host's endianness
> +size_t rtems_ofw_get_enc_prop(
> + phandle_t node,
> + const char *prop,
> + pcell_t *buf,
> + size_t len
> + * @brief Checks if the property @a propname is present in @a node.
> + * @param[in] propname Property name
> + * @retval 0 Property not present.
> + * @retval 1 Property is present.
> +int rtems_ofw_has_prop(
> + phandle_t node,
> + * @brief Searches for property @a propname in @a node.
> + * Searches the node and its parent recursively for the property and
> fills the
> + * buffer with the first found value.
> (Pre-allocated)
> + * @retval Length of the property if property is found.
> + * @retval -1 Property is not found.
> +size_t rtems_ofw_search_prop(
> + phandle_t node,
> + void *buf,
> + size_t len
> fills the
> + * buffer with the first value found after converting it to the
> endianness of
> + * the host.
> +size_t rtems_ofw_search_enc_prop(
> + phandle_t node,
> + pcell_t *buf,
> + size_t len
> + * Same as rtems_ofw_getprop, but the @a buf is allocated in this routine
> and
> + * the user is responsible for freeing it.
> + * @param[out] buf The buffer is allocated in this routine and user is
> + * responsible for freeing.
> +size_t rtems_ofw_get_prop_alloc(
> + phandle_t node,
> + void **buf
> + * @brief Gets multiple values of the property @a propname.
> + * Same as rtems_ofw_getprop_alloc but it can read properties with
> multiple
> + * values.
> + * For eg: reg = <0x1000 0x10 0x2000 0x20>
> + * @param[in] elsz Size of the single value
> + * @retval Number of values read.
> +size_t rtems_ofw_get_prop_alloc_multi(
> + phandle_t node,
> + int elsz,
> + void **buf
> + * Same as rtems_ofw_getprop_alloc but the value stored in the buffer is
> + * converted into the host's endianness.
> +size_t rtems_ofw_get_enc_prop_alloc(
> + phandle_t node,
> + void **buf
> + * Same as rtems_ofw_getprop_alloc_multi but the values stored in the
> buffer
> + * are converted to the host's endianness.
> +size_t rtems_ofw_get_enc_prop_alloc_multi(
> + phandle_t node,
> + int elsz,
> + void **buf
> + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc functions.
> + * @param[in] buf Buffer to be freed
> +void rtems_ofw_free(
> + void *buf
> + * @brief Finds the next property of @a node.
> + * Finds the next property of the node and when @a propname is NULL it
> returns
> + * the value in the first property.
> + * @param[in] previous Previous property name
> + * @param[out] buf The value of the next property gets stored in this
> buffer
> + * (Pre-allocated)
> + * @retval -1 node or previous property does not exist
> + * @retval 0 no more properties
> + * @retval 1 success
> +int rtems_ofw_next_prop(
> + phandle_t node,
> + const char *previous,
> + char *buf,
> + size_t len
> + * @brief Sets the property @name of @a node to @a buf.
> + * @param[in] name Property name
> + * @param[in] buf Buffer contains the value to be set.
> + * @retval -1 node does not exist
> + * @retval 0 on success
> + * @retval libFDT error codes on unsuccessful setting operation
> +int rtems_ofw_set_prop(
> + phandle_t node,
> + const char *name,
> + const void *buf,
> + size_t len
> + * @brief Converts a device specifier to a fully qualified path name.
> + * @param[in] dev device specifier
> + * @param[out] buf The path is filled into the buffer(Pre-allocated)
> + * @param[in] length of the buffer
> + * @retval -1 always. Unimplemented.
> +size_t rtems_ofw_canon(
> + const char *dev,
> + char *buf,
> + size_t len
> + * @brief Finds the node at the given path
> + * @param[in] path to the node from root
> + * @retval node handle on success
> +phandle_t rtems_ofw_find_device(
> + const char *path
> + * @brief This routine converts effective phandle @a xref to node offset.
> + * @param[in] xref Node phandle
> + * @retval Node offset on success
> + * @retval Node phandle on failure
> +phandle_t rtems_ofw_node_from_xref(
> + phandle_t xref
> + * @brief This routine converts node offset to effective phandle of @a
> node.
> + * @retval Node phandle on success
> + * @retval Node offset on failure
> +phandle_t rtems_ofw_xref_from_node(
> + phandle_t node
> + * instance handles(ihandle_t) as same as phandles in the FDT
> implementation
> + * of OF interface.
> + * @brief Converts @a instance handle to phandle.
> + * instance are same as node offsets in FDT.
> + * @param[in] instance Node offset
> + * @retval phandle of node on success.
> + * @retval instance of node on failure.
> +phandle_t rtems_ofw_instance_to_package(
> + ihandle_t instance
> + * @brief Find the node's path from phandle.
> + * @param[out] buf Path is filled into this buffer(Pre-allocated).
> + * @param[in] len Length of the buffer.
> +size_t rtems_ofw_package_to_path(
> + phandle_t node,
> + char *buf,
> + size_t len
> + * @brief Find the node's path from ihandle.
> +size_t rtems_ofw_instance_to_path(
> + ihandle_t instance,
> + char *buf,
> + size_t len
> + * @brief Queries the node's reg value.
> + * This routine fills the buffer @a buf with the values in reg property
> of node
> + * @a node. It reads all the values of the property and fills the buffer
> to max
> + * size.
> + * This routine is local to RTEMS OFW and does not have an corresponding
> + * FreeBSD OFW pair.
> + * @param[out] buf Register values are stored in this
> + * @param[in] size Length of the buffer.
> + * @retval -1 If reg property is missing.
> + * @retval Length of the reg property in bytes.
> +int rtems_ofw_get_reg(
> + phandle_t node,
> + rtems_ofw_memory_area *buf,
> + size_t size
> + * @brief Queries the node's interrupt value.
> + * This routine fills the buffer @a buf with the interrupt number. In
> case of
> + * multiple numbers it fills the buffer to its full extent.
> + * @param[out] buf Interrupt values are stored in this
> + * @retval -1 If interrupts property is missing.
> + * @retval Length of the interrupts property in bytes.
> +int rtems_ofw_get_interrupts(
> + phandle_t node,
> + void *buf,
> + size_t size
> + * @brief Queries the node's status.
> + * @retval true Status is OK or empty.
> + * @retval false Status is not OK or missing.
> +bool rtems_ofw_node_status( phandle_t node );
> +#ifdef __cplusplus
> +#endif
> +#endif /* _OFW_H */
> \ No newline at end of file
> diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
> index 0000000000..57423e62fc
> --- /dev/null
> +++ b/bsps/shared/ofw/ofw.c
> @@ -0,0 +1,654 @@
> + * @file
> + * @ingroup ofw
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <bsp/fdt.h>
> +#include <sys/param.h>
> +#include <ofw/ofw.h>
> +#include <libfdt.h>
> +#include <assert.h>
> +#include <rtems/sysinit.h>
> +const void *fdtp = NULL;
> +static phandle_t rtems_fdt_offset_to_phandle( int offset )
> + if (offset < 0) {
> + return 0;
> + return (phandle_t)offset + fdt_off_dt_struct(fdtp);
> +static int rtems_fdt_phandle_to_offset( phandle_t handle )
> + int off;
> + int fdt_off;
> + off = (int) handle;
> + fdt_off = fdt_off_dt_struct(fdtp);
> + if (off < fdt_off) {
> + return -1;
> + return off - fdt_off;
> +static void rtems_ofw_init( void ) {
> + int rv;
> + const void *fdt;
> + fdt = bsp_fdt_get();
> + rv = fdt_check_header(fdt);
> + * Is assert a good option to handle error?
> + * AFIAK there is no other way to recover from invalid FDT.
> + * On providing an invalid FDT most driver's will fail/crash anyway.
> + assert(rv == 0);
> + fdtp = fdt;
> +RTEMS_SYSINIT_ITEM(
> + rtems_ofw_init,
> + RTEMS_SYSINIT_BSP_PRE_DRIVERS,
> + RTEMS_SYSINIT_ORDER_FIRST
> +phandle_t rtems_ofw_peer( phandle_t node )
> + int offset;
> + if (node == 0) {
> + int root = fdt_path_offset(fdtp, "/");
> + return rtems_fdt_offset_to_phandle(root);
> + offset = rtems_fdt_phandle_to_offset(node);
> + if (offset < 0) {
> + return 0;
> + offset = fdt_next_subnode(fdtp, offset);
> + return rtems_fdt_offset_to_phandle(offset);
> +phandle_t rtems_ofw_child( phandle_t node )
> + int offset;
> + if (offset < 0) {
> + return 0;
> + offset = fdt_first_subnode(fdtp, offset);
> +phandle_t rtems_ofw_parent( phandle_t node )
> + int offset;
> + if (offset < 0) {
> + return 0;
> + offset = fdt_parent_offset(fdtp, offset);
> + phandle_t node,
> + int offset;
> + int len;
> + const void *prop;
> + if (offset < 0) {
> + return -1;
> + prop = fdt_getprop(fdtp, offset, propname, &len);
> + if (prop == NULL && strcmp(propname, "name") == 0) {
> + fdt_get_name(fdtp, offset, &len);
> + return len + 1;
> + if (prop == NULL && strcmp(propname, "/chosen") == 0) {
> + if (strcmp(propname, "fdtbootcpu") == 0)
> + return sizeof(pcell_t);
> + if (strcmp(propname, "fdtmemreserv") == 0)
> + return 2 * sizeof(uint64_t) * fdt_num_mem_rsv(fdtp);
> + if (prop == NULL) {
> + return -1;
> + return len;
> + phandle_t node,
> + void *buf,
> + size_t bufsize
> + int offset;
> + int len;
> + const void *prop;
> + if (offset < 0) {
> + return -1;
> + return len + 1;
> + return -1;
> + bcopy(prop, buf, MIN(len, bufsize));
> + return len;
> + phandle_t node,
> + const char *prop,
> + pcell_t *buf,
> + size_t len
> + size_t rv;
> + assert(len % 4 == 0);
> + rv = rtems_ofw_get_prop(node, prop, buf, len);
> + if (rv < 0) {
> + return rv;
> + for (int i = 0; i < (len / 4); i++) {
> + buf[i] = fdt32_to_cpu(buf[i]);
> + return rv;
> + phandle_t node,
> + size_t rv;
> + rv = rtems_ofw_get_prop_len(node, propname);
> + return rv >= 0 ? 1 : 0;
> + phandle_t node,
> + void *buf,
> + size_t len
> + size_t rv;
> + for (; node != 0; node = rtems_ofw_parent(node)) {
> + if ((rv = rtems_ofw_get_prop(node, propname, buf, len) != -1)) {
> + return rv;
> + return -1;
> + phandle_t node,
> + pcell_t *buf,
> + size_t len
> + size_t rv;
> + if ((rv = rtems_ofw_get_enc_prop(node, propname, buf, len) != -1)) {
> + return rv;
> + return -1;
> + phandle_t node,
> + void **buf
> + size_t len;
> + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1) {
> + return -1;
> + *buf = NULL;
> + if (len > 0) {
> + *buf = malloc(len);
> + if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
> + rtems_ofw_free(buf);
> + *buf = NULL;
> + return -1;
> + return len;
> + phandle_t node,
> + int elsz,
> + void **buf
> + size_t len;
> + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1 ||
> + (len % elsz != 0)) {
> + return -1;
> + *buf = NULL;
> + if (len > 0) {
> + *buf = NULL;
> + return -1;
> + return (len / elsz);
> + phandle_t node,
> + void **buf
> + size_t len;
> + return -1;
> + *buf = NULL;
> + if (len > 0) {
> + if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
> + *buf = NULL;
> + return -1;
> + return len;
> + phandle_t node,
> + int elsz,
> + void **buf
> + size_t len;
> + return -1;
> + *buf = NULL;
> + if (len > 0) {
> + *buf = NULL;
> + return -1;
> +void rtems_ofw_free( void *buf )
> + free(buf);
> + phandle_t node,
> + char *buf,
> + size_t len
> + const void *name;
> + const void *prop;
> + int offset;
> + if (offset < 0) {
> + return -1;
> + if (previous == NULL) {
> + offset = fdt_first_property_offset(fdtp, offset);
> + } else {
> + fdt_for_each_property_offset(offset, fdtp, offset) {
> + prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name,
> NULL);
> + if (prop == NULL)
> + return -1;
> + if (strcmp(previous, name) != 0)
> + continue;
> + offset = fdt_next_property_offset(fdtp, offset);
> + break;
> + if (offset < 0)
> + return 0;
> &offset);
> + if (prop == NULL)
> + return -1;
> + strncpy(buf, name, len);
> + return 1;
> + phandle_t node,
> + const char *name,
> + const void *buf,
> + size_t len
> + int offset;
> + if (offset < 0)
> + return -1;
> + if (fdt_setprop_inplace(fdtp, offset, name, buf, len) != 0)
> + return (fdt_setprop(fdtp, offset, name, buf, len));
> + return 0;
> +phandle_t rtems_ofw_find_device( const char *path )
> + int offset;
> + offset = fdt_path_offset(fdtp, path);
> + if (offset < 0)
> + return -1;
> +static phandle_t rtems_ofw_get_effective_phandle(
> + phandle_t node,
> + phandle_t xref
> + phandle_t child;
> + phandle_t ref;
> + for (child = rtems_ofw_child(node); child != 0; child =
> rtems_ofw_peer(node)) {
> + ref = rtems_ofw_get_effective_phandle(child, xref);
> + if (ref != -1)
> + return ref;
> + if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref)) == -1
> + rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref, sizeof(ref))
> == -1 &&
> + rtems_ofw_get_enc_prop(child, "linux,phandle", &ref, sizeof(ref))
> == -1
> + continue;
> + if (ref == xref)
> + return child;
> + return -1;
> +phandle_t rtems_ofw_node_from_xref( phandle_t xref )
> + phandle_t node;
> + if ((node = rtems_ofw_get_effective_phandle(rtems_ofw_peer(0), xref))
> == -1)
> + return xref;
> + return node;
> +phandle_t rtems_ofw_xref_from_node( phandle_t node )
> + phandle_t ref;
> + if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref)) == -1
> + rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref, sizeof(ref)) ==
> -1 &&
> + rtems_ofw_get_enc_prop(node, "linux,phandle", &ref, sizeof(ref))
> == -1)
> + return node;
> + return ref;
> +phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
> + return rtems_ofw_node_from_xref(instance);
> + phandle_t node,
> + char *buf,
> + size_t len
> + int offset;
> + int rv;
> + rv = fdt_get_path(fdtp, offset, buf, len);
> + if (rv != 0)
> + return -1;
> + return rv;
> + char *buf,
> + size_t len
> + int offset;
> + int rv;
> + offset = rtems_ofw_instance_to_package(instance);
> + offset = rtems_fdt_phandle_to_offset(offset);
> + if (rv != 0)
> + return -1;
> + return rv;
> + phandle_t node,
> + size_t size
> + int len;
> + int offset;
> + int nranges;
> + int nregs;
> + phandle_t parent;
> + rtems_ofw_ranges range;
> + const rtems_ofw_ranges *ptr;
> + len = rtems_ofw_get_enc_prop(node, "reg", (pcell_t *)buf, size);
> + if (len <= 0) {
> + return len;
> + nregs = MIN(len, size) / sizeof(rtems_ofw_memory_area);
> + for (parent = rtems_ofw_parent(node); parent > 0;
> + parent = rtems_ofw_parent(parent)) {
> + offset = rtems_fdt_phandle_to_offset(parent);
> + ptr = fdt_getprop(fdtp, offset, "ranges", &len);
> + if (len < 0) {
> + break;
> + nranges = len / sizeof(rtems_ofw_ranges);
> + offset = 0;
> + for (int i=0; i < nregs; i++) {
> + for (int j=0; j < nranges; j++) {
> + range.parent_bus = fdt32_to_cpu(ptr[j].parent_bus);
> + range.child_bus = fdt32_to_cpu(ptr[j].child_bus);
> + range.size = fdt32_to_cpu(ptr[j].size);
> + if (buf[i].start >= range.child_bus &&
> + buf[i].start < range.child_bus + range.size) {
> + offset = range.parent_bus - range.child_bus;
> + break;
> + buf[i].start += offset;
> + return nregs;
> + phandle_t node,
> + void *buf,
> + size_t size
> + int rv;
> + rv = rtems_ofw_get_enc_prop(node, "interrupts", buf, size);
> + return rv;
> + int len;
> + const char buf[10];
> + len = rtems_ofw_get_prop(node, "status", &buf[0], sizeof(buf));
> + if ((len == -1) ||
> + (strncmp(buf, "okay", MIN(5, len)) == 0) ||
> + (strncmp(buf, "ok", MIN(3, len)) == 0)) {
> + return true;
> + return false;
> diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
> index 8809238057..141ba25f5e 100644
> --- a/spec/build/bsps/obj.yml
> +++ b/spec/build/bsps/obj.yml
> @@ -24,6 +24,9 @@ install:
> - bsps/include/bsp/u-boot.h
> - bsps/include/bsp/uart-output-char.h
> - bsps/include/bsp/utility.h
> +- destination: ${BSP_INCLUDEDIR}/ofw
> + source:
> + - bsps/include/ofw/ofw.h
> - destination: ${BSP_INCLUDEDIR}/libchip
> source:
> - bsps/include/libchip/am29lv160.h
> @@ -104,4 +107,5 @@ source:
> - bsps/shared/dev/serial/z85c30_reg.c
> - bsps/shared/start/bootcard.c
> - bsps/shared/rtems-version.c
> +- bsps/shared/ofw/ofw.c
> type: build
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200816/25923998/attachment-0001.html>
