[PATCH] bsps/shared/ofw: Implement RTEMS OFW interface
Chris Johns
chrisj at rtems.org
Sun Aug 16 08:55:21 UTC 2020
On 16/8/20 4:49 am, G S Niteesh Babu wrote:
> bsps/include/ofw/ofw.h | 534 ++++++++++++++++++++++++++++++++
> bsps/shared/ofw/ofw.c | 654 ++++++++++++++++++++++++++++++++++++++++
> spec/build/bsps/obj.yml | 4 +
> 3 files changed, 1192 insertions(+)
> create mode 100644 bsps/include/ofw/ofw.h
> create mode 100644 bsps/shared/ofw/ofw.c
> diff --git a/bsps/include/ofw/ofw.h b/bsps/include/ofw/ofw.h
> new file mode 100644
> index 0000000000..2ca5328abc
> --- /dev/null
> +++ b/bsps/include/ofw/ofw.h
> @@ -0,0 +1,534 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup ofw
> + * RTEMS FDT implementation of OpenFirmWare Interface.
> + * RTEMS OFW is a FDT only implementation of the OpenFirmWare interface.
> + * This API is created to be compatible with FreeBSD OpenFirmWare interface.
> + * The main intention is to make porting of FreeBSD drivers to RTEMS easier.
> + * Copyright (C) 2020 Niteesh Babu G S <niteesh.gs at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _OFW_H
> +#define _OFW_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#include <stdint.h>
> +#include <stddef.h>
> + * Represents a node in the device tree. The offset from fdtp to node is used
> + * instead of fdt offset to make sure this is compatible with OF interface in
> + * FreeBSD.
> +typedef uint32_t phandle_t;
> + * Represents the effective phandle of the node.
> +typedef uint32_t ihandle_t;
> + * Represents the data type of the buffer.
> +typedef uint32_t pcell_t;
> + * @struct rtems_ofw_memory_area
> + * This is used to represent elements(FDT properties) that define
> + * region of memory address.
> +typedef struct {
> + /** The start address of the memory region. */
> + uint32_t start;
> + /** The size of the memory region. */
> + uint32_t size;
> +} rtems_ofw_memory_area;
> + * @struct rtems_ofw_ranges
> + * This is used to represent the ranges property in the device tree.
> +typedef struct {
> + /** The physical address within the child bus address space */
> + uint32_t child_bus;
> + /** The physical address within the parent bus address space */
> + uint32_t parent_bus;
> + /** The size of the range in the child’s address space */
> + uint32_t size;
> +} rtems_ofw_ranges;
> + * @brief Gets the node that is next to @a node.
> + * @param[in] node Node offset
> + * @retval Peer node offset Successful operation.
> + * @retval 0 No peer node or invalid node handle
> +phandle_t rtems_ofw_peer(
> + phandle_t node
> + * @brief Gets the node that is the child of @a node.
> + * @retval child node offset Successful operation.
> + * @retval 0 No child node or invalid node handle
> +phandle_t rtems_ofw_child(
> + phandle_t node
> + * @brief Gets the node that is the parent of @a node.
> +phandle_t rtems_ofw_parent(
> + phandle_t node
> + * @brief Gets the length of the property mentioned in @a propname.
> + * @param[in] prop Property name
> + * @retval -1 Invalid node or property
> + * @retval Length of property on successful operation
> +size_t rtems_ofw_get_prop_len(
> + phandle_t node,
> + const char *propname
> + * @brief Gets the value of property mentioned in @a propname.
> + * @param[out] buf The property value gets stored in this buffer (Pre-allocated)
> + * @param[in] len Length of the buffer
> +size_t rtems_ofw_get_prop(
> + phandle_t node,
> + const char *propname,
> + void *buf,
> + size_t len
> + * @brief Gets the value of property mentioned in @a prop.
> + * Gets the value of property of @a node and converts the value into the host's
> + * endianness.
> + * @param[out] buf The property value gets stored in this buffer(Pre-allocated)
> + * after converted to the host's endianness
> +size_t rtems_ofw_get_enc_prop(
> + phandle_t node,
> + const char *prop,
> + pcell_t *buf,
> + size_t len
> + * @brief Checks if the property @a propname is present in @a node.
> + * @param[in] propname Property name
> + * @retval 0 Property not present.
> + * @retval 1 Property is present.
> +int rtems_ofw_has_prop(
> + phandle_t node,
> + * @brief Searches for property @a propname in @a node.
> + * Searches the node and its parent recursively for the property and fills the
> + * buffer with the first found value.
> + * @retval Length of the property if property is found.
> + * @retval -1 Property is not found.
> +size_t rtems_ofw_search_prop(
> + phandle_t node,
> + void *buf,
> + size_t len
> + * buffer with the first value found after converting it to the endianness of
> + * the host.
> +size_t rtems_ofw_search_enc_prop(
> + phandle_t node,
> + pcell_t *buf,
> + size_t len
> + * Same as rtems_ofw_getprop, but the @a buf is allocated in this routine and
> + * the user is responsible for freeing it.
> + * @param[out] buf The buffer is allocated in this routine and user is
> + * responsible for freeing.
> +size_t rtems_ofw_get_prop_alloc(
> + phandle_t node,
> + void **buf
> + * @brief Gets multiple values of the property @a propname.
> + * Same as rtems_ofw_getprop_alloc but it can read properties with multiple
> + * values.
> + * For eg: reg = <0x1000 0x10 0x2000 0x20>
> + * @param[in] elsz Size of the single value
> + * @retval Number of values read.
> +size_t rtems_ofw_get_prop_alloc_multi(
> + phandle_t node,
> + int elsz,
> + void **buf
> + * Same as rtems_ofw_getprop_alloc but the value stored in the buffer is
> + * converted into the host's endianness.
> +size_t rtems_ofw_get_enc_prop_alloc(
> + phandle_t node,
> + void **buf
> + * Same as rtems_ofw_getprop_alloc_multi but the values stored in the buffer
> + * are converted to the host's endianness.
> +size_t rtems_ofw_get_enc_prop_alloc_multi(
> + phandle_t node,
> + int elsz,
> + void **buf
> + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc functions.
> + * @param[in] buf Buffer to be freed
> +void rtems_ofw_free(
> + void *buf
> + * @brief Finds the next property of @a node.
> + * Finds the next property of the node and when @a propname is NULL it returns
> + * the value in the first property.
> + * @param[in] previous Previous property name
> + * @param[out] buf The value of the next property gets stored in this buffer
> + * (Pre-allocated)
> + * @retval -1 node or previous property does not exist
> + * @retval 0 no more properties
> + * @retval 1 success
> +int rtems_ofw_next_prop(
> + phandle_t node,
> + const char *previous,
> + char *buf,
> + size_t len
> + * @brief Sets the property @name of @a node to @a buf.
> + * @param[in] name Property name
> + * @param[in] buf Buffer contains the value to be set.
> + * @retval -1 node does not exist
> + * @retval 0 on success
> + * @retval libFDT error codes on unsuccessful setting operation
> +int rtems_ofw_set_prop(
> + phandle_t node,
> + const char *name,
> + const void *buf,
> + size_t len
> + * @brief Converts a device specifier to a fully qualified path name.
> + * @param[in] dev device specifier
> + * @param[out] buf The path is filled into the buffer(Pre-allocated)
> + * @param[in] length of the buffer
> + * @retval -1 always. Unimplemented.
> +size_t rtems_ofw_canon(
> + const char *dev,
> + char *buf,
> + size_t len
> + * @brief Finds the node at the given path
> + * @param[in] path to the node from root
> + * @retval node handle on success
> +phandle_t rtems_ofw_find_device(
> + const char *path
> + * @brief This routine converts effective phandle @a xref to node offset.
> + * @param[in] xref Node phandle
> + * @retval Node offset on success
> + * @retval Node phandle on failure
> +phandle_t rtems_ofw_node_from_xref(
> + phandle_t xref
> + * @brief This routine converts node offset to effective phandle of @a node.
> + * @retval Node phandle on success
> + * @retval Node offset on failure
> +phandle_t rtems_ofw_xref_from_node(
> + phandle_t node
> + * instance handles(ihandle_t) as same as phandles in the FDT implementation
> + * of OF interface.
> + * @brief Converts @a instance handle to phandle.
> + * instance are same as node offsets in FDT.
> + * @param[in] instance Node offset
> + * @retval phandle of node on success.
> + * @retval instance of node on failure.
> +phandle_t rtems_ofw_instance_to_package(
> + ihandle_t instance
> + * @brief Find the node's path from phandle.
> + * @param[out] buf Path is filled into this buffer(Pre-allocated).
> + * @param[in] len Length of the buffer.
> +size_t rtems_ofw_package_to_path(
> + phandle_t node,
> + char *buf,
> + size_t len
> + * @brief Find the node's path from ihandle.
> +size_t rtems_ofw_instance_to_path(
> + ihandle_t instance,
> + char *buf,
> + size_t len
> + * @brief Queries the node's reg value.
> + * This routine fills the buffer @a buf with the values in reg property of node
> + * @a node. It reads all the values of the property and fills the buffer to max
> + * size.
> + * This routine is local to RTEMS OFW and does not have an corresponding
> + * FreeBSD OFW pair.
> + * @param[out] buf Register values are stored in this buffer(Pre-allocated).
> + * @param[in] size Length of the buffer.
> + * @retval -1 If reg property is missing.
> + * @retval Length of the reg property in bytes.
> +int rtems_ofw_get_reg(
> + phandle_t node,
> + rtems_ofw_memory_area *buf,
> + size_t size
> + * @brief Queries the node's interrupt value.
> + * This routine fills the buffer @a buf with the interrupt number. In case of
> + * multiple numbers it fills the buffer to its full extent.
> + * @param[out] buf Interrupt values are stored in this buffer(Pre-allocated).
> + * @retval -1 If interrupts property is missing.
> + * @retval Length of the interrupts property in bytes.
> +int rtems_ofw_get_interrupts(
> + phandle_t node,
> + void *buf,
> + size_t size
> + * @brief Queries the node's status.
> + * @retval true Status is OK or empty.
> + * @retval false Status is not OK or missing.
> +bool rtems_ofw_node_status( phandle_t node );
> +#ifdef __cplusplus
> +#endif
> +#endif /* _OFW_H */
> \ No newline at end of file
> diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
> index 0000000000..57423e62fc
> --- /dev/null
> +++ b/bsps/shared/ofw/ofw.c
> @@ -0,0 +1,654 @@
> + * @file
> + * @ingroup ofw
> + * are met:
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <bsp/fdt.h>
> +#include <sys/param.h>
> +#include <ofw/ofw.h>
> +#include <libfdt.h>
> +#include <assert.h>
> +#include <rtems/sysinit.h>
> +const void *fdtp = NULL;
> +static phandle_t rtems_fdt_offset_to_phandle( int offset )
> + if (offset < 0) {
> + return 0;
> + return (phandle_t)offset + fdt_off_dt_struct(fdtp);
> +static int rtems_fdt_phandle_to_offset( phandle_t handle )
> + int off;
> + int fdt_off;
> + off = (int) handle;
> + fdt_off = fdt_off_dt_struct(fdtp);
> + if (off < fdt_off) {
> + return -1;
> + return off - fdt_off;
> +static void rtems_ofw_init( void ) {
> + int rv;
> + const void *fdt;
> + fdt = bsp_fdt_get();
> + rv = fdt_check_header(fdt);
> + * Is assert a good option to handle error?
> + * AFIAK there is no other way to recover from invalid FDT.
> + * On providing an invalid FDT most driver's will fail/crash anyway.
If you want to fail with an error I suggest a documented internal error. I
however would prefer we fail in degraded manner but I understand this may not be
possible.
> + assert(rv == 0);
I would prefer we did not make this code dependent on -DNDEBUG.
> + fdtp = fdt;
> +RTEMS_SYSINIT_ITEM(
> + rtems_ofw_init,
> + RTEMS_SYSINIT_BSP_PRE_DRIVERS,
> + RTEMS_SYSINIT_ORDER_FIRST
> +phandle_t rtems_ofw_peer( phandle_t node )
> + int offset;
> + if (node == 0) {
> + int root = fdt_path_offset(fdtp, "/");
> + return rtems_fdt_offset_to_phandle(root);
> + offset = rtems_fdt_phandle_to_offset(node);
> + if (offset < 0) {
> + return 0;
> + offset = fdt_next_subnode(fdtp, offset);
> + return rtems_fdt_offset_to_phandle(offset);
> +phandle_t rtems_ofw_child( phandle_t node )
> + int offset;
> + if (offset < 0) {
> + return 0;
> + offset = fdt_first_subnode(fdtp, offset);
> +phandle_t rtems_ofw_parent( phandle_t node )
> + int offset;
> + if (offset < 0) {
> + return 0;
> + offset = fdt_parent_offset(fdtp, offset);
> + phandle_t node,
> + int offset;
> + int len;
> + const void *prop;
> + if (offset < 0) {
> + return -1;
> + prop = fdt_getprop(fdtp, offset, propname, &len);
> + if (prop == NULL && strcmp(propname, "name") == 0) {
> + fdt_get_name(fdtp, offset, &len);
> + return len + 1;
> + if (prop == NULL && strcmp(propname, "/chosen") == 0) {
> + if (strcmp(propname, "fdtbootcpu") == 0)
> + return sizeof(pcell_t);
> + if (strcmp(propname, "fdtmemreserv") == 0)
> + return 2 * sizeof(uint64_t) * fdt_num_mem_rsv(fdtp);
> + if (prop == NULL) {
> + return -1;
> + return len;
> + phandle_t node,
> + void *buf,
> + size_t bufsize
> + int offset;
> + int len;
> + const void *prop;
> + if (offset < 0) {
> + return -1;
> + return len + 1;
> + return -1;
> + bcopy(prop, buf, MIN(len, bufsize));
> + return len;
> + phandle_t node,
> + const char *prop,
> + pcell_t *buf,
> + size_t len
> + size_t rv;
> + assert(len % 4 == 0);
> + rv = rtems_ofw_get_prop(node, prop, buf, len);
> + if (rv < 0) {
> + return rv;
> + for (int i = 0; i < (len / 4); i++) {
> + buf[i] = fdt32_to_cpu(buf[i]);
> + return rv;
> + phandle_t node,
> + size_t rv;
> + rv = rtems_ofw_get_prop_len(node, propname);
> + return rv >= 0 ? 1 : 0;
> + phandle_t node,
> + void *buf,
> + size_t len
> + size_t rv;
> + for (; node != 0; node = rtems_ofw_parent(node)) {
> + if ((rv = rtems_ofw_get_prop(node, propname, buf, len) != -1)) {
> + return rv;
> + return -1;
> + phandle_t node,
> + pcell_t *buf,
> + size_t len
> + size_t rv;
> + if ((rv = rtems_ofw_get_enc_prop(node, propname, buf, len) != -1)) {
> + return rv;
> + return -1;
> + phandle_t node,
> + void **buf
> + size_t len;
> + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1) {
> + return -1;
> + *buf = NULL;
> + if (len > 0) {
> + *buf = malloc(len);
> + if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
> + rtems_ofw_free(buf);
> + *buf = NULL;
> + return -1;
> + return len;
> + phandle_t node,
> + int elsz,
> + void **buf
> + size_t len;
> + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1 ||
> + (len % elsz != 0)) {
> + return -1;
> + *buf = NULL;
> + if (len > 0) {
> + *buf = NULL;
> + return -1;
> + return (len / elsz);
> + phandle_t node,
> + void **buf
> + size_t len;
> + return -1;
> + *buf = NULL;
> + if (len > 0) {
> + if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
> + *buf = NULL;
> + return -1;
> + return len;
> + phandle_t node,
> + int elsz,
> + void **buf
> + size_t len;
> + return -1;
> + *buf = NULL;
> + if (len > 0) {
> + *buf = NULL;
> + return -1;
> +void rtems_ofw_free( void *buf )
> + free(buf);
> + phandle_t node,
> + char *buf,
> + size_t len
> + const void *name;
> + const void *prop;
> + int offset;
> + if (offset < 0) {
> + return -1;
> + if (previous == NULL) {
> + offset = fdt_first_property_offset(fdtp, offset);
> + } else {
> + fdt_for_each_property_offset(offset, fdtp, offset) {
> + prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name, NULL);
> + if (prop == NULL)
> + return -1;
> + if (strcmp(previous, name) != 0)
> + continue;
> + offset = fdt_next_property_offset(fdtp, offset);
> + break;
> + if (offset < 0)
> + return 0;
> + prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name, &offset);
> + if (prop == NULL)
> + return -1;
> + strncpy(buf, name, len);
> + return 1;
> + phandle_t node,
> + const char *name,
> + const void *buf,
> + size_t len
> + int offset;
> + if (offset < 0)
> + return -1;
> + if (fdt_setprop_inplace(fdtp, offset, name, buf, len) != 0)
> + return (fdt_setprop(fdtp, offset, name, buf, len));
> + return 0;
> +phandle_t rtems_ofw_find_device( const char *path )
> + int offset;
> + offset = fdt_path_offset(fdtp, path);
> + if (offset < 0)
> + return -1;
> +static phandle_t rtems_ofw_get_effective_phandle(
> + phandle_t node,
> + phandle_t xref
> + phandle_t child;
> + phandle_t ref;
> + for (child = rtems_ofw_child(node); child != 0; child = rtems_ofw_peer(node)) {
> + ref = rtems_ofw_get_effective_phandle(child, xref);
> + if (ref != -1)
> + return ref;
> + if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref)) == -1 &&
> + rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref, sizeof(ref)) == -1 &&
> + rtems_ofw_get_enc_prop(child, "linux,phandle", &ref, sizeof(ref)) == -1
> + continue;
> + if (ref == xref)
> + return child;
> + return -1;
> +phandle_t rtems_ofw_node_from_xref( phandle_t xref )
> + phandle_t node;
> + if ((node = rtems_ofw_get_effective_phandle(rtems_ofw_peer(0), xref)) == -1)
> + return xref;
> + return node;
> +phandle_t rtems_ofw_xref_from_node( phandle_t node )
> + phandle_t ref;
> + if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref)) == -1 &&
> + rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref, sizeof(ref)) == -1 &&
> + rtems_ofw_get_enc_prop(node, "linux,phandle", &ref, sizeof(ref)) == -1)
> + return node;
> + return ref;
> +phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
> + return rtems_ofw_node_from_xref(instance);
> + phandle_t node,
> + char *buf,
> + size_t len
> + int offset;
> + int rv;
> + rv = fdt_get_path(fdtp, offset, buf, len);
> + if (rv != 0)
> + return -1;
> + return rv;
> + char *buf,
> + size_t len
> + int offset;
> + int rv;
> + offset = rtems_ofw_instance_to_package(instance);
> + offset = rtems_fdt_phandle_to_offset(offset);
> + if (rv != 0)
> + return -1;
> + return rv;
> + phandle_t node,
> + size_t size
> + int len;
> + int offset;
> + int nranges;
> + int nregs;
> + phandle_t parent;
> + rtems_ofw_ranges range;
> + const rtems_ofw_ranges *ptr;
> + len = rtems_ofw_get_enc_prop(node, "reg", (pcell_t *)buf, size);
> + if (len <= 0) {
> + return len;
> + nregs = MIN(len, size) / sizeof(rtems_ofw_memory_area);
> + for (parent = rtems_ofw_parent(node); parent > 0;
> + parent = rtems_ofw_parent(parent)) {
> + offset = rtems_fdt_phandle_to_offset(parent);
> + ptr = fdt_getprop(fdtp, offset, "ranges", &len);
> + if (len < 0) {
> + break;
> + nranges = len / sizeof(rtems_ofw_ranges);
> + offset = 0;
> + for (int i=0; i < nregs; i++) {
> + for (int j=0; j < nranges; j++) {
> + range.parent_bus = fdt32_to_cpu(ptr[j].parent_bus);
> + range.child_bus = fdt32_to_cpu(ptr[j].child_bus);
> + range.size = fdt32_to_cpu(ptr[j].size);
> + if (buf[i].start >= range.child_bus &&
> + buf[i].start < range.child_bus + range.size) {
> + offset = range.parent_bus - range.child_bus;
> + break;
> + buf[i].start += offset;
> + return nregs;
> + phandle_t node,
> + void *buf,
> + size_t size
> + int rv;
> + rv = rtems_ofw_get_enc_prop(node, "interrupts", buf, size);
> + return rv;
> + int len;
> + const char buf[10];
> + len = rtems_ofw_get_prop(node, "status", &buf[0], sizeof(buf));
> + if ((len == -1) ||
> + (strncmp(buf, "okay", MIN(5, len)) == 0) ||
> + (strncmp(buf, "ok", MIN(3, len)) == 0)) {
> + return true;
> + return false;
> diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
> index 8809238057..141ba25f5e 100644
> --- a/spec/build/bsps/obj.yml
> +++ b/spec/build/bsps/obj.yml
> @@ -24,6 +24,9 @@ install:
> - bsps/include/bsp/u-boot.h
> - bsps/include/bsp/uart-output-char.h
> - bsps/include/bsp/utility.h
> +- destination: ${BSP_INCLUDEDIR}/ofw
> + source:
> + - bsps/include/ofw/ofw.h
> - destination: ${BSP_INCLUDEDIR}/libchip
> source:
> - bsps/include/libchip/am29lv160.h
> @@ -104,4 +107,5 @@ source:
> - bsps/shared/dev/serial/z85c30_reg.c
> - bsps/shared/start/bootcard.c
> - bsps/shared/rtems-version.c
> +- bsps/shared/ofw/ofw.c
> type: build
