Context switching through an ISR in RTEMS
Mon Aug 17 06:02:46 UTC 2020
On 16/08/2020 18:09, Utkarsh Rai wrote:
> On Sun, Aug 16, 2020 at 9:18 PM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
>     On Sat, Aug 15, 2020 at 9:03 PM Utkarsh Rai
>     <utkarsh.rai60 at gmail.com <mailto:utkarsh.rai60 at gmail.com>> wrote:
>     > On Sun, Aug 16, 2020 at 6:12 AM Utkarsh Rai
>     >> On Sat, Aug 15, 2020 at 7:26 PM Gedare Bloom <gedare at rtems.org
>     >>> On Sat, Aug 15, 2020 at 6:26 AM Utkarsh Rai
>     >>> > On Thu, Aug 13, 2020 at 5:10 AM Utkarsh Rai
>     >>> >> Thanks, I'll check them out.
>     >>> >> On Thu, Aug 13, 2020 at 12:56 AM Gedare Bloom
>     <gedare at rtems.org <mailto:gedare at rtems.org>> wrote:
>     >>> >>> On Wed, Aug 12, 2020 at 11:33 AM Utkarsh Rai
>     >>> >>> > Hello,
>     >>> >>> > I have been testing my code for thread stack isolation
>     against various tests( Some written by me, and remaining already
>     present). One of the limitations that I have found is that I
>     encounter fatal errors whenever a context switch takes place
>     through an ISR. Can you please explain how the context switching
>     procedure works when an interrupt occurs. When I use gdb for
>     stepping through the code it asynchronously moves to context
>     switching code from the executing thread( for example psx16 test).
>     >>> >>> > For thread stack protection, the part that deals with
>     context switching simply 'sets 'the memory entries of the heir
>     stack and 'unsets' that of the executing stack.
>     >>> >>> There are two issues to start: interrupt stacks and
>     dispatching from an ISR.
>     >>> >>> I think you can start by reading some of the documentation:
>     https://docs.rtems.org/branches/master/c-user/interrupt_manager.html#processing-an-interrupt
>     https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#dispatching-tasks
>     https://docs.rtems.org/branches/master/c-user/config/general.html#configure-interrupt-stack-size
>     https://docs.rtems.org/branches/master/cpu-supplement/port.html#interrupt-processing
>     >>> >>> You can also find some material in rtems-docs.git/porting
>     -- I don't
>     >>> >>> know where that gets generated.
>     >>> >>> Continue to ask questions, and writing blog posts.
>     >>> > So after going through the materials, I was able to
>     understand how an ISR is registered, ISR stack initialization.
>     What is still not clear to me is what are the differences between
>     dispatching a task in ISR different and  a normal context-switch?
>     >>> > For example the psxsignal06 test, we wait for a signal
>     here,  on setting the breakpoint at the context switch code
>     (cpu_asm.S), after this line,  I find that the heir context stack
>     is the ISR stack. The next thread is dispatched from this ISR but
>     as soon as I unset the memory attributes of the ISR stack I get a
>     fatal error. One possible reason is that the ISR stack is not page
>     aligned and unsettling its attributes unsets nearby memory
>     regions. Is there something else that I am missing?
>     >>> what else is on the same page as the ISR stack?
>     >> The idle thread stack is between 0x202e40 to 0x203e40 and the
>     ISR stack is between 0x203e40 to 0x204e40. So when we unset the
>     memory for the ISR it unsets between 0x203000 to 0x205000, I think
>     this may be the problem.
>     >>> Not quite related, you'll need to also make sure to map the
>     ISR stack
>     >>> back in during ISR Handling, before using it.
>     >> When the ISR gets called for the first time, it already has R/W
>     permission and for subsequent context switches it's memory entry
>     is accordingly set/unset.
>     > The idle thread stack and the ISR stack are placed at these
>     addresses with the BSP specific linker script as "rtemsstack.idle"
>     and "rtemsstack.interrupt". So to make them page-aligned we may
>     have to make changes in the lnker script.
>     Give it a try. It should be relatively easy to hack in a couple of
>     alignments.
>     We can discuss later the correctness of that.
> Ok, I will report how it goes.
Please use the CPU port option
#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
to define the interrupt and idle stack alignment. There is no need to
change the linker command file.
