Context switching through an ISR in RTEMS
Utkarsh Rai
utkarsh.rai60 at gmail.com
Mon Aug 17 11:53:29 UTC 2020
On Mon, Aug 17, 2020 at 11:32 AM Sebastian Huber <
> On 16/08/2020 18:09, Utkarsh Rai wrote:
> > On Sun, Aug 16, 2020 at 9:18 PM Gedare Bloom <gedare at rtems.org
> > <mailto:gedare at rtems.org>> wrote:
> > On Sat, Aug 15, 2020 at 9:03 PM Utkarsh Rai
> > <utkarsh.rai60 at gmail.com <mailto:utkarsh.rai60 at gmail.com>> wrote:
> > > On Sun, Aug 16, 2020 at 6:12 AM Utkarsh Rai
> > >> On Sat, Aug 15, 2020 at 7:26 PM Gedare Bloom <gedare at rtems.org
> > >>> On Sat, Aug 15, 2020 at 6:26 AM Utkarsh Rai
> > >>> > On Thu, Aug 13, 2020 at 5:10 AM Utkarsh Rai
> > >>> >> Thanks, I'll check them out.
> > >>> >> On Thu, Aug 13, 2020 at 12:56 AM Gedare Bloom
> > <gedare at rtems.org <mailto:gedare at rtems.org>> wrote:
> > >>> >>> On Wed, Aug 12, 2020 at 11:33 AM Utkarsh Rai
> > >>> >>> > Hello,
> > >>> >>> > I have been testing my code for thread stack isolation
> > against various tests( Some written by me, and remaining already
> > present). One of the limitations that I have found is that I
> > encounter fatal errors whenever a context switch takes place
> > through an ISR. Can you please explain how the context switching
> > procedure works when an interrupt occurs. When I use gdb for
> > stepping through the code it asynchronously moves to context
> > switching code from the executing thread( for example psx16 test).
> > >>> >>> > For thread stack protection, the part that deals with
> > context switching simply 'sets 'the memory entries of the heir
> > stack and 'unsets' that of the executing stack.
> > >>> >>> There are two issues to start: interrupt stacks and
> > dispatching from an ISR.
> > >>> >>> I think you can start by reading some of the documentation:
> https://docs.rtems.org/branches/master/c-user/interrupt_manager.html#processing-an-interrupt
> https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#dispatching-tasks
> https://docs.rtems.org/branches/master/c-user/config/general.html#configure-interrupt-stack-size
> https://docs.rtems.org/branches/master/cpu-supplement/port.html#interrupt-processing
> > >>> >>> You can also find some material in rtems-docs.git/porting
> > -- I don't
> > >>> >>> know where that gets generated.
> > >>> >>> Continue to ask questions, and writing blog posts.
> > >>> > So after going through the materials, I was able to
> > understand how an ISR is registered, ISR stack initialization.
> > What is still not clear to me is what are the differences between
> > dispatching a task in ISR different and a normal context-switch?
> > >>> > For example the psxsignal06 test, we wait for a signal
> > here, on setting the breakpoint at the context switch code
> > (cpu_asm.S), after this line, I find that the heir context stack
> > is the ISR stack. The next thread is dispatched from this ISR but
> > as soon as I unset the memory attributes of the ISR stack I get a
> > fatal error. One possible reason is that the ISR stack is not page
> > aligned and unsettling its attributes unsets nearby memory
> > regions. Is there something else that I am missing?
> > >>> what else is on the same page as the ISR stack?
> > >> The idle thread stack is between 0x202e40 to 0x203e40 and the
> > ISR stack is between 0x203e40 to 0x204e40. So when we unset the
> > memory for the ISR it unsets between 0x203000 to 0x205000, I think
> > this may be the problem.
> > >>> Not quite related, you'll need to also make sure to map the
> > ISR stack
> > >>> back in during ISR Handling, before using it.
> > >> When the ISR gets called for the first time, it already has R/W
> > permission and for subsequent context switches it's memory entry
> > is accordingly set/unset.
> > > The idle thread stack and the ISR stack are placed at these
> > addresses with the BSP specific linker script as "rtemsstack.idle"
> > and "rtemsstack.interrupt". So to make them page-aligned we may
> > have to make changes in the lnker script.
> > Give it a try. It should be relatively easy to hack in a couple of
> > alignments.
> > We can discuss later the correctness of that.
> > Ok, I will report how it goes.
> Please use the CPU port option
> #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
> to define the interrupt and idle stack alignment. There is no need to
> change the linker command file.
Thank you, this solves the issue.
I have used,
#define CPU_INTERRUPT_STACK_ALIGNMENT 4096, in the application code as
well as cpu.h, to align for 4K pages.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200817/48b11e46/attachment.html>
