[PATCH] rtems: Use unique option values
Sebastian Huber
Mon Aug 17 10:31:25 UTC 2020
The RTEMS_BARRIER_AUTOMATIC_RELEASE and RTEMS_BINARY_SEMAPHORE options
had the same value. In order to better detect a misuse of option values
(for example using RTEMS_BINARY_SEMAPHORE for rtems_barrier_create()),
the options should have unique values.
Close #4054.
cpukit/include/rtems/rtems/attr.h | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/rtems/attr.h b/cpukit/include/rtems/rtems/attr.h
index abc9da08cd..74ed96fdba 100644
--- a/cpukit/include/rtems/rtems/attr.h
+++ b/cpukit/include/rtems/rtems/attr.h
@@ -156,7 +156,7 @@ typedef uint32_t rtems_attribute;
* This attribute constant indicates that the Classic API Barrier
* instance created will use an automatic release protocol.
-#define RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000010
+#define RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000200
2.26.2
