Context switching through an ISR in RTEMS
Utkarsh Rai utkarsh.rai60 at gmail.com
Mon Aug 17 16:30:19 UTC 2020
On Mon, Aug 17, 2020 at 9:24 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Aug 17, 2020 at 5:53 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
> wrote:
> > On Mon, Aug 17, 2020 at 11:32 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >> On 16/08/2020 18:09, Utkarsh Rai wrote:
> >> > On Sun, Aug 16, 2020 at 9:18 PM Gedare Bloom <gedare at rtems.org
> >> > <mailto:gedare at rtems.org>> wrote:
> >> >     On Sat, Aug 15, 2020 at 9:03 PM Utkarsh Rai
> >> >     <utkarsh.rai60 at gmail.com <mailto:utkarsh.rai60 at gmail.com>> wrote:
> >> >     > On Sun, Aug 16, 2020 at 6:12 AM Utkarsh Rai
> >> >     >> On Sat, Aug 15, 2020 at 7:26 PM Gedare Bloom <gedare at rtems.org
> >> >     >>> On Sat, Aug 15, 2020 at 6:26 AM Utkarsh Rai
> >> >     >>> > On Thu, Aug 13, 2020 at 5:10 AM Utkarsh Rai
> >> >     >>> >> Thanks, I'll check them out.
> >> >     >>> >> On Thu, Aug 13, 2020 at 12:56 AM Gedare Bloom
> >> >     <gedare at rtems.org <mailto:gedare at rtems.org>> wrote:
> >> >     >>> >>> On Wed, Aug 12, 2020 at 11:33 AM Utkarsh Rai
> >> >     >>> >>> > Hello,
> >> >     >>> >>> > I have been testing my code for thread stack isolation
> >> >     against various tests( Some written by me, and remaining already
> >> >     present). One of the limitations that I have found is that I
> >> >     encounter fatal errors whenever a context switch takes place
> >> >     through an ISR. Can you please explain how the context switching
> >> >     procedure works when an interrupt occurs. When I use gdb for
> >> >     stepping through the code it asynchronously moves to context
> >> >     switching code from the executing thread( for example psx16 test).
> >> >     >>> >>> > For thread stack protection, the part that deals with
> >> >     context switching simply 'sets 'the memory entries of the heir
> >> >     stack and 'unsets' that of the executing stack.
> >> >     >>> >>> There are two issues to start: interrupt stacks and
> >> >     dispatching from an ISR.
> >> >     >>> >>> I think you can start by reading some of the
> documentation:
> https://docs.rtems.org/branches/master/c-user/interrupt_manager.html#processing-an-interrupt
> https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#dispatching-tasks
> https://docs.rtems.org/branches/master/c-user/config/general.html#configure-interrupt-stack-size
> https://docs.rtems.org/branches/master/cpu-supplement/port.html#interrupt-processing
> >> >     >>> >>> You can also find some material in rtems-docs.git/porting
> >> >     -- I don't
> >> >     >>> >>> know where that gets generated.
> >> >     >>> >>> Continue to ask questions, and writing blog posts.
> >> >     >>> > So after going through the materials, I was able to
> >> >     understand how an ISR is registered, ISR stack initialization.
> >> >     What is still not clear to me is what are the differences between
> >> >     dispatching a task in ISR different and  a normal context-switch?
> >> >     >>> > For example the psxsignal06 test, we wait for a signal
> >> >     here,  on setting the breakpoint at the context switch code
> >> >     (cpu_asm.S), after this line,  I find that the heir context stack
> >> >     is the ISR stack. The next thread is dispatched from this ISR but
> >> >     as soon as I unset the memory attributes of the ISR stack I get a
> >> >     fatal error. One possible reason is that the ISR stack is not page
> >> >     aligned and unsettling its attributes unsets nearby memory
> >> >     regions. Is there something else that I am missing?
> >> >     >>> what else is on the same page as the ISR stack?
> >> >     >> The idle thread stack is between 0x202e40 to 0x203e40 and the
> >> >     ISR stack is between 0x203e40 to 0x204e40. So when we unset the
> >> >     memory for the ISR it unsets between 0x203000 to 0x205000, I think
> >> >     this may be the problem.
> >> >     >>> Not quite related, you'll need to also make sure to map the
> >> >     ISR stack
> >> >     >>> back in during ISR Handling, before using it.
> >> >     >> When the ISR gets called for the first time, it already has R/W
> >> >     permission and for subsequent context switches it's memory entry
> >> >     is accordingly set/unset.
> >> >     > The idle thread stack and the ISR stack are placed at these
> >> >     addresses with the BSP specific linker script as "rtemsstack.idle"
> >> >     and "rtemsstack.interrupt". So to make them page-aligned we may
> >> >     have to make changes in the lnker script.
> >> >     Give it a try. It should be relatively easy to hack in a couple of
> >> >     alignments.
> >> >     We can discuss later the correctness of that.
> >> > Ok, I will report how it goes.
> >> Please use the CPU port option
> >> #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
> >> to define the interrupt and idle stack alignment. There is no need to
> >> change the linker command file.
> > Thank you, this solves the issue.
> > I have used,
> >  #define CPU_INTERRUPT_STACK_ALIGNMENT 4096,  in the application code as
> well as cpu.h, to align for 4K pages.
> Great. Now, a question: can the Idle Task and Interrupt Stack share
> the same 4K page?
I am not sure whether you mean if they should have the same address or if
they have overlapping addresses ( For example if the idle thread stack is
at 0x202e40 and interrupt stack is at 0x204e40 then they should have the
0x20300-0x20400 address as common)?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200817/31b08975/attachment.html>
