Context switching through an ISR in RTEMS
Gedare Bloom
gedare at rtems.org
Mon Aug 17 15:54:23 UTC 2020
On Mon, Aug 17, 2020 at 5:53 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> On Mon, Aug 17, 2020 at 11:32 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 16/08/2020 18:09, Utkarsh Rai wrote:
>> > On Sun, Aug 16, 2020 at 9:18 PM Gedare Bloom <gedare at rtems.org
>> > <mailto:gedare at rtems.org>> wrote:
>> > On Sat, Aug 15, 2020 at 9:03 PM Utkarsh Rai
>> > <utkarsh.rai60 at gmail.com <mailto:utkarsh.rai60 at gmail.com>> wrote:
>> > > On Sun, Aug 16, 2020 at 6:12 AM Utkarsh Rai
>> > >> On Sat, Aug 15, 2020 at 7:26 PM Gedare Bloom <gedare at rtems.org
>> > >>> On Sat, Aug 15, 2020 at 6:26 AM Utkarsh Rai
>> > >>> > On Thu, Aug 13, 2020 at 5:10 AM Utkarsh Rai
>> > >>> >> Thanks, I'll check them out.
>> > >>> >> On Thu, Aug 13, 2020 at 12:56 AM Gedare Bloom
>> > <gedare at rtems.org <mailto:gedare at rtems.org>> wrote:
>> > >>> >>> On Wed, Aug 12, 2020 at 11:33 AM Utkarsh Rai
>> > >>> >>> > Hello,
>> > >>> >>> > I have been testing my code for thread stack isolation
>> > against various tests( Some written by me, and remaining already
>> > present). One of the limitations that I have found is that I
>> > encounter fatal errors whenever a context switch takes place
>> > through an ISR. Can you please explain how the context switching
>> > procedure works when an interrupt occurs. When I use gdb for
>> > stepping through the code it asynchronously moves to context
>> > switching code from the executing thread( for example psx16 test).
>> > >>> >>> > For thread stack protection, the part that deals with
>> > context switching simply 'sets 'the memory entries of the heir
>> > stack and 'unsets' that of the executing stack.
>> > >>> >>> There are two issues to start: interrupt stacks and
>> > dispatching from an ISR.
>> > >>> >>> I think you can start by reading some of the documentation:
>> > https://docs.rtems.org/branches/master/c-user/interrupt_manager.html#processing-an-interrupt
>> > https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#dispatching-tasks
>> > https://docs.rtems.org/branches/master/c-user/config/general.html#configure-interrupt-stack-size
>> > https://docs.rtems.org/branches/master/cpu-supplement/port.html#interrupt-processing
>> > >>> >>> You can also find some material in rtems-docs.git/porting
>> > -- I don't
>> > >>> >>> know where that gets generated.
>> > >>> >>> Continue to ask questions, and writing blog posts.
>> > >>> > So after going through the materials, I was able to
>> > understand how an ISR is registered, ISR stack initialization.
>> > What is still not clear to me is what are the differences between
>> > dispatching a task in ISR different and a normal context-switch?
>> > >>> > For example the psxsignal06 test, we wait for a signal
>> > here, on setting the breakpoint at the context switch code
>> > (cpu_asm.S), after this line, I find that the heir context stack
>> > is the ISR stack. The next thread is dispatched from this ISR but
>> > as soon as I unset the memory attributes of the ISR stack I get a
>> > fatal error. One possible reason is that the ISR stack is not page
>> > aligned and unsettling its attributes unsets nearby memory
>> > regions. Is there something else that I am missing?
>> > >>> what else is on the same page as the ISR stack?
>> > >> The idle thread stack is between 0x202e40 to 0x203e40 and the
>> > ISR stack is between 0x203e40 to 0x204e40. So when we unset the
>> > memory for the ISR it unsets between 0x203000 to 0x205000, I think
>> > this may be the problem.
>> > >>> Not quite related, you'll need to also make sure to map the
>> > ISR stack
>> > >>> back in during ISR Handling, before using it.
>> > >> When the ISR gets called for the first time, it already has R/W
>> > permission and for subsequent context switches it's memory entry
>> > is accordingly set/unset.
>> > > The idle thread stack and the ISR stack are placed at these
>> > addresses with the BSP specific linker script as "rtemsstack.idle"
>> > and "rtemsstack.interrupt". So to make them page-aligned we may
>> > have to make changes in the lnker script.
>> > Give it a try. It should be relatively easy to hack in a couple of
>> > alignments.
>> > We can discuss later the correctness of that.
>> > Ok, I will report how it goes.
>> Please use the CPU port option
>> #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
>> to define the interrupt and idle stack alignment. There is no need to
>> change the linker command file.
> Thank you, this solves the issue.
> I have used,
> #define CPU_INTERRUPT_STACK_ALIGNMENT 4096, in the application code as well as cpu.h, to align for 4K pages.
Great. Now, a question: can the Idle Task and Interrupt Stack share
the same 4K page?
