[GSoC 2020]: Need help in writing sed alternative in Python for RSB recipes
Wed Aug 19 04:14:57 UTC 2020
On Tue, Aug 18, 2020 at 7:13 PM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> Hi Mritunjay,
> To define the architecture you can create a file “CONFIG_SITE.local” in “configure”.
> Look at the comment at the end of the file "CONFIG_SITE":
> # Overrides for the settings above may appear in a CONFIG_SITE.local file
> -include $(CONFIG)/CONFIG_SITE.local.
Can we generate/inject the file/variables directly from scripts?
> Heinz
> > On 16. Aug 2020, at 12:16, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
> > On Sun, Aug 16, 2020 at 1:12 PM Chris Johns <chrisj at rtems.org> wrote:
> > On 16/8/20 8:29 am, Mritunjay Sharma wrote:
> > > On Sun, Aug 16, 2020 at 12:15 AM Gedare Bloom <gedare at rtems.org
> > > <mailto:gedare at rtems.org>> wrote:
> > >     Hi Mritunjay, Chris:
> > >     For the RSB, since it is user-facing, we need to be sure to minimize
> > >     its dependencies on the user environment and platform. So this pycli
> > >     can only be used if it is distributed standard with Python 2 and
> > >     Python 3.
> > >     Would someone be able to apply this patch and use it to build epics?
> > >     No, because (1) they won't have pycli available, and (2) they don't
> > >     have a path /home/mritunjay
> > > I think what you are saying is absolutely right. It will be really a great help
> > > if Chris can guide on what next can be done.
> > See below.
> > > As far as 'pycli' is concerned, I have made a couple of minor tweaks. Gave it a
> > > better name 'sedpy' and made it public on GitHub.
> > > Please find the link to the
> > > project here: https://github.com/mritunjaysharma394/sedpy
> > Thanks but I currently do not see a need for this tool.
> > > I will appreciate if mentors can have a look and try this and see if it in any
> > > way can be modified
> > > to be used with RSB or else we will go with what is suggested.
> > Please put the RSB to one side. I will let you know when we can return to it.
> > I believe patching config files in EPCIS from the RSB is fragile. EPICS should
> > be free to change any of these files without needing to considering the effect
> > it has on the RSB. Just because we can peek inside does not means we are free to
> > exploit what we see.
> > What happens if you define the needed variables on the make command line? For
> > example:
> >  gmake RTEMS_BASE=$HOME/development/rtems/5 RTEMS_VERSION=5.1-rc2
> > These variables are just normal make ones and so they can be overridden from the
> > command line.
> > Please investigate this and see what happens?
> > Hi Chris,
> > I investigated and used:
> >  `make RTEMS_BASE=$HOME/development/rtems/5-arm RTEMS_VERSION=5`
> > This worked perfectly fine and the build was successful. Thank you so much for telling this. It makes it so
> > easy. What can we do next? This surely removes the requirement of `sed` or the tool I built to make command line changes.
> > Thanks
> > Mritunjay
> > Chris
