[GSoC 2020]: Need help in writing sed alternative in Python for RSB recipes
Mritunjay Sharma mritunjaysharma394 at gmail.com
Wed Aug 19 05:09:24 UTC 2020
Hi everyone,
Before I begin my queries [ mainly regarding epics upstream], let me give a
few updates.
As per the suggestion of Gedare, I started building by hand the pc-386 and
xilinx_zynq_a9_qemu using
the terminal configured make command.
What I did initially as an experiment is that, in
configure/os/CONFIG_SITE.Common.RTEMS:
I made
RTEMS_VERSION =
RTEMS_BASE =
That is both were left blank.
Similarly, I did it for configure/CONFIG_SITE:
CROSS_COMPILER_TARGET_ARCHS=
After this, I started building EPICS for xilinx_zynq_a9_qemu from the
'epics-base' downloaded from this source of Heinz [
https://gitlab.fhi.mpg.de/junkes/epics-base]
The command I used was:
` make RTEMS_BASE=$HOME/development/rtems/5-arm RTEMS_VERSION=5
CROSS_COMPILER_TARGET_ARCHS=RTEMS-xilinx_zynq_a9_qemu`
The Build was successful for xilinx_zynq_a9_qemu.
However, if I used the same `epics-base` and tried to build it for pc-386
using the command:
`make RTEMS_BASE=$HOME/development/rtems/5 RTEMS_VERSION=5
BUILD_ARCHS=RTEMS-pc386`
The Build failed and I got this error:
`make -C ./configure install
make[1]: Entering directory
'/home/mritunjay/development/EPICS/epics-base/configure'
make -C O.RTEMS-pc386 -f ../Makefile TOP=../.. \
    T_A=RTEMS-pc386 install
make[2]: Entering directory
'/home/mritunjay/development/EPICS/epics-base/configure/O.RTEMS-pc386'
../../configure/os/CONFIG.Common.RTEMS:36:
/home/mritunjay/development/rtems/5//pc386/Makefile.inc: No such file or
directory
make[2]: *** No rule to make target
'/home/mritunjay/development/rtems/5//pc386/Makefile.inc'.  Stop.
make[2]: Leaving directory
make[1]: *** [../configure/RULES_ARCHS:58: install.RTEMS-pc386] Error 2
make[1]: Leaving directory
make: *** [configure/RULES_DIRS:84: configure.install] Error 2
This made me try another `epics-base` of Heinz that he earlier suggested
which is:
https://github.com/hjunkes/epicsBaseOwnPlayground/tree/3afec267ab08568ea454789e562450b00feea5c0
Running the same `make RTEMS_BASE=$HOME/development/rtems/5 RTEMS_VERSION=5
the command worked here and EPICS for pc-386 was successfully built.
Therefore, we need to make changes in the epics code base so that we can
have one common epics-base which works for both.
This was the update. I am modifying the RSB recipes and soon will update
regarding the build related to it.
Now, I am commenting on the queries further below.
On Wed, Aug 19, 2020 at 9:45 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Aug 18, 2020 at 7:13 PM Heinz Junkes <junkes at fhi-berlin.mpg.de>
> wrote:
> > Hi Mritunjay,
> > To define the architecture you can create a file “CONFIG_SITE.local” in
> “configure”.
> > Look at the comment at the end of the file "CONFIG_SITE":
Do I have to just write `CROSS_COMPILER_TARGET_ARCHS=` in CONFIG_SITE.local
file?
Please if you can tell more about what changes it can bring for us?
> > # Overrides for the settings above may appear in a CONFIG_SITE.local file
> > -include $(CONFIG)/CONFIG_SITE.local.
> Can we generate/inject the file/variables directly from scripts?
I also have the same question.
Thanks
Mritunjay Sharma
> > Heinz
> > > On 16. Aug 2020, at 12:16, Mritunjay Sharma <
> mritunjaysharma394 at gmail.com> wrote:
> > > On Sun, Aug 16, 2020 at 1:12 PM Chris Johns <chrisj at rtems.org> wrote:
> > > On 16/8/20 8:29 am, Mritunjay Sharma wrote:
> > > > On Sun, Aug 16, 2020 at 12:15 AM Gedare Bloom <gedare at rtems.org
> > > > <mailto:gedare at rtems.org>> wrote:
> > > >     Hi Mritunjay, Chris:
> > > >     For the RSB, since it is user-facing, we need to be sure to
> minimize
> > > >     its dependencies on the user environment and platform. So this
> pycli
> > > >     can only be used if it is distributed standard with Python 2 and
> > > >     Python 3.
> > > >     Would someone be able to apply this patch and use it to build
> epics?
> > > >     No, because (1) they won't have pycli available, and (2) they
> don't
> > > >     have a path /home/mritunjay
> > > > I think what you are saying is absolutely right. It will be really a
> great help
> > > > if Chris can guide on what next can be done.
> > > See below.
> > > > As far as 'pycli' is concerned, I have made a couple of minor
> tweaks. Gave it a
> > > > better name 'sedpy' and made it public on GitHub.
> > > > Please find the link to the
> > > > project here: https://github.com/mritunjaysharma394/sedpy
> > > Thanks but I currently do not see a need for this tool.
> > > > I will appreciate if mentors can have a look and try this and see if
> it in any
> > > > way can be modified
> > > > to be used with RSB or else we will go with what is suggested.
> > > Please put the RSB to one side. I will let you know when we can return
> to it.
> > > I believe patching config files in EPCIS from the RSB is fragile.
> EPICS should
> > > be free to change any of these files without needing to considering
> the effect
> > > it has on the RSB. Just because we can peek inside does not means we
> are free to
> > > exploit what we see.
> > > What happens if you define the needed variables on the make command
> line? For
> > > example:
> > >  gmake RTEMS_BASE=$HOME/development/rtems/5 RTEMS_VERSION=5.1-rc2
> > > These variables are just normal make ones and so they can be
> overridden from the
> > > command line.
> > > Please investigate this and see what happens?
> > > Hi Chris,
> > > I investigated and used:
> > >  `make RTEMS_BASE=$HOME/development/rtems/5-arm RTEMS_VERSION=5`
> > > This worked perfectly fine and the build was successful. Thank you so
> much for telling this. It makes it so
> > > easy. What can we do next? This surely removes the requirement of
> `sed` or the tool I built to make command line changes.
> > > Thanks
> > > Mritunjay
> > > Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200819/701e36e3/attachment-0001.html>
