Need help figuring out why ARM hits data_abort right after hitting Exception_interrupt
Sebastian Huber
Wed Aug 19 07:23:14 UTC 2020
On 19/08/2020 09:18, Richi Dubey wrote:
> This mail is in continuation of
> https://lists.rtems.org/pipermail/devel/2020-August/061446.html.
> Right after the check_cpu_allocation test for the last action gets
> passed (code here
> <https://github.com/richidubey/rtems/blob/6e455a5d77417dcbc2f00330ebc37a7a143c5384/testsuites/smptests/smpstrongapa01/init.c#L125>), _ARMV4_Exception_interrupt
> gets called when the timer function finishes.
> But soon thereafter _ARMV4_Exception_data_abort_default occurs. Why
> does that happen? I believe it might have something to do with the
> fact that T0 (the task that was earlier running on processor 0 and was
> responsible for running the timer function and later returning to
> Init) has changed its processor to processor 2 (as we know since the
> check_cpu_allocation passed).
When you get a data abort exception you destroyed some data structures
or use data structures wrongly. The goal is to figure out which data
structure is involved and how is the bad actor. I would use the "bt"
command when you hit the _ARMV4_Exception_data_abort_default break point.
