[PATCH] Confstr Patches
Sebastian Huber
Wed Aug 19 13:34:59 UTC 2020
On 19/08/2020 15:04, Eshan dhawan wrote:
> diff --git a/testsuites/psxtests/psxconfstr/init.c b/testsuites/psxtests/psxconfstr/init.c
> new file mode 100644
> index 0000000000..8660f04b29
> --- /dev/null
> +++ b/testsuites/psxtests/psxconfstr/init.c
> @@ -0,0 +1,137 @@
> + * @file
> + * @brief Test suite for getcpuclockid methods
Really?
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2020 embedded brains GmbH, Eshan Dhawan
Please follow the source file template:
https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#c-c-assembler-source-file-template
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <errno.h>
> +#include <stdint.h>
> +#include <stdio.h>
> +#include <string.h>
> +#include <rtems.h>
> +#include <rtems/test.h>
> +#include <unistd.h>
> +#include <assert.h>
> +#include <rtems/bspIo.h>
> +#include "tmacros.h"
> +#include "test_support.h"
Please cut down the includes to the minimum.
> +const char rtems_test_name[] = "PSXCONFSTR";
> +/* Forward declaration to avoid warnings */
> +void *POSIX_Init (void * argument);
> +void *test_pthread(void *);
> +static char buffer[512];
> +static const T_action actions[] = {
> + T_report_hash_sha256,
> + T_check_task_context,
> + T_check_file_descriptors,
> + T_check_rtems_barriers,
> + T_check_rtems_extensions,
> + T_check_rtems_message_queues,
> + T_check_rtems_partitions,
> + T_check_rtems_periods,
> + T_check_rtems_regions,
> + T_check_rtems_semaphores,
> + T_check_rtems_tasks,
> + T_check_rtems_timers,
> + T_check_posix_keys
> +static const T_config config = {
> + .name = "psxconfstr",
> + .buf = buffer,
> + .putchar = rtems_put_char,
> + .buf_size = sizeof(buffer),
> + .verbosity = T_VERBOSE,
> + .now = T_now_clock,
> + .action_count = T_ARRAY_SIZE(actions),
> + .actions = actions
> +/* init test function begins */
> +T_TEST_CASE(confstr)
> +int r;
> + char * buf ;
> + const char UPE[] = "unsupported programming environment";
> + size_t len1;
> + len1 = strlen(UPE) + 1;
sizeof(UPE)
> + r = confstr(_CS_PATH, buf, sizeof(buf));
> + if (r != 0){
> + printf("This Function is not supported");
Please don't add hand crafted output like this just use the check
functions of the test framework.
> + T_quiet_psx_success(r);
> + r = confstr(_CS_POSIX_V6_ILP32_OFFBIG_CFLAGS, buf, sizeof(buf));
> + if ( r != len1 ){
> + printf("lenght not matched");
> + assert(r == len1);
Use a check function of the test framework and not assert().
> + int exit_code;
> + TEST_BEGIN();
> + T_register();
> + exit_code = T_main(&config);
> + if (exit_code == 0) {
> + TEST_END();
> + rtems_test_exit(exit_code);
Please use an RTEMS initialization task and rtems_test_run().
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
Do you need a clock driver?
> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_POSIX_INIT_THREAD_TABLE
> +#include <rtems/confdefs.h>
