[PATCH] Confstr Patches
Eshan Dhawan
eshandhawan51 at gmail.com
Wed Aug 19 13:57:24 UTC 2020
On Wed, Aug 19, 2020 at 7:05 PM Sebastian Huber <
> On 19/08/2020 15:04, Eshan dhawan wrote:
> > diff --git a/testsuites/psxtests/psxconfstr/init.c
> b/testsuites/psxtests/psxconfstr/init.c
> > new file mode 100644
> > index 0000000000..8660f04b29
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxconfstr/init.c
> > @@ -0,0 +1,137 @@
> > + * @file
> > + * @brief Test suite for getcpuclockid methods
> Really?
I took the template from that file
Forgot to change it :)
> > + * SPDX-License-Identifier: BSD-2-Clause
> > + * Copyright (C) 2020 embedded brains GmbH, Eshan Dhawan
> Please follow the source file template:
> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#c-c-assembler-source-file-template
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + * notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + * notice, this list of conditions and the following disclaimer in
> the
> > + * documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +#include <errno.h>
> > +#include <stdint.h>
> > +#include <stdio.h>
> > +#include <string.h>
> > +#include <rtems.h>
> > +#include <rtems/test.h>
> > +#include <unistd.h>
> > +#include <assert.h>
> > +#include <rtems/bspIo.h>
> > +#include "tmacros.h"
> > +#include "test_support.h"
> Please cut down the includes to the minimum.
> > +const char rtems_test_name[] = "PSXCONFSTR";
> > +/* Forward declaration to avoid warnings */
> > +void *POSIX_Init (void * argument);
> > +void *test_pthread(void *);
> > +static char buffer[512];
> > +static const T_action actions[] = {
> > + T_report_hash_sha256,
> > + T_check_task_context,
> > + T_check_file_descriptors,
> > + T_check_rtems_barriers,
> > + T_check_rtems_extensions,
> > + T_check_rtems_message_queues,
> > + T_check_rtems_partitions,
> > + T_check_rtems_periods,
> > + T_check_rtems_regions,
> > + T_check_rtems_semaphores,
> > + T_check_rtems_tasks,
> > + T_check_rtems_timers,
> > + T_check_posix_keys
> > +static const T_config config = {
> > + .name = "psxconfstr",
> > + .buf = buffer,
> > + .putchar = rtems_put_char,
> > + .buf_size = sizeof(buffer),
> > + .verbosity = T_VERBOSE,
> > + .now = T_now_clock,
> > + .action_count = T_ARRAY_SIZE(actions),
> > + .actions = actions
> > +/* init test function begins */
> > +T_TEST_CASE(confstr)
> > +int r;
> > + char * buf ;
> > + const char UPE[] = "unsupported programming environment";
> > + size_t len1;
> > + len1 = strlen(UPE) + 1;
> sizeof(UPE)
> > + r = confstr(_CS_PATH, buf, sizeof(buf));
> > + if (r != 0){
> > + printf("This Function is not supported");
> Please don't add hand crafted output like this just use the check
> functions of the test framework.
> > + T_quiet_psx_success(r);
> > + r = confstr(_CS_POSIX_V6_ILP32_OFFBIG_CFLAGS, buf, sizeof(buf));
> > + if ( r != len1 ){
> > + printf("lenght not matched");
> > + assert(r == len1);
> Use a check function of the test framework and not assert().
> > + int exit_code;
> > + TEST_BEGIN();
> > + T_register();
> > + exit_code = T_main(&config);
> > + if (exit_code == 0) {
> > + TEST_END();
> > + rtems_test_exit(exit_code);
> Please use an RTEMS initialization task and rtems_test_run().
> > +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> Do you need a clock driver?
> > +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> > +#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
> > +#define CONFIGURE_MAXIMUM_TASKS 1
> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > +#define CONFIGURE_POSIX_INIT_THREAD_TABLE
> > +#include <rtems/confdefs.h>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200819/5e0dc361/attachment.html>
