[PATCH 1/3] score: Constify objects name to id functions
Fri Aug 21 08:32:36 UTC 2020
 cpukit/include/rtems/score/objectimpl.h |  8 ++++----
 cpukit/include/rtems/score/objectmp.h   |  8 ++++----
 cpukit/score/src/objectmp.c             |  8 ++++----
 cpukit/score/src/objectnametoid.c       | 10 +++++-----
 4 files changed, 17 insertions(+), 17 deletions(-)
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index c540f90166..a8c7fcb457 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -237,10 +237,10 @@ typedef enum {
  * @retval OBJECTS_INVALID_ID The id is not 0 before the operation.
 Objects_Name_or_id_lookup_errors _Objects_Name_to_id_u32(
-  Objects_Information *information,
-  uint32_t             name,
-  uint32_t             node,
-  Objects_Id          *id
+  const Objects_Information *information,
+  uint32_t                   name,
+  uint32_t                   node,
+  Objects_Id                *id
 typedef enum {
diff --git a/cpukit/include/rtems/score/objectmp.h b/cpukit/include/rtems/score/objectmp.h
index fcdfa78aa3..c2621c3857 100644
--- a/cpukit/include/rtems/score/objectmp.h
+++ b/cpukit/include/rtems/score/objectmp.h
@@ -150,10 +150,10 @@ void _Objects_MP_Close (
  * @retval OBJECTS_INVALID_NAME There is no global object with this name.
 Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search (
-  Objects_Name         the_name,
-  uint32_t             nodes_to_search,
-  Objects_Id          *the_id
+  Objects_Name               the_name,
+  uint32_t                   nodes_to_search,
+  Objects_Id                *the_id
diff --git a/cpukit/score/src/objectmp.c b/cpukit/score/src/objectmp.c
index 987b86a968..e956135a91 100644
--- a/cpukit/score/src/objectmp.c
+++ b/cpukit/score/src/objectmp.c
@@ -284,10 +284,10 @@ void _Objects_MP_Close (
 Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search(
   Objects_Name_or_id_lookup_errors  status;
diff --git a/cpukit/score/src/objectnametoid.c b/cpukit/score/src/objectnametoid.c
index bafa7b23f4..2a9052d948 100644
--- a/cpukit/score/src/objectnametoid.c
+++ b/cpukit/score/src/objectnametoid.c
@@ -21,14 +21,14 @@
-  uint32_t             name,
-  uint32_t             node,
-  Objects_Id          *id
+  uint32_t                   name,
+  uint32_t                   node,
+  Objects_Id                *id
   bool                       search_local_node;
-  Objects_Control           *the_object;
+  const Objects_Control     *the_object;
   Objects_Maximum            maximum;
   Objects_Maximum            index;
 #if defined(RTEMS_MULTIPROCESSING)
2.26.2
