[PATCH 2/3] rtems: Add _RTEMS_Name_to_id()
Sebastian Huber
Fri Aug 21 08:32:37 UTC 2020
Simplify object name to identifier directives. Using
_RTEMS_Name_to_id() to implement the directives enables a tail call
optimization.
Change license to BSD-2-Clause according to file history.
Update #3053.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/rtems/objectimpl.h | 82 +++++++++++++++++++++++
cpukit/include/rtems/score/objectimpl.h | 23 ++++---
cpukit/rtems/src/barrierident.c | 55 +++++++++------
cpukit/rtems/src/dpmemident.c | 51 ++++++++------
cpukit/rtems/src/msgqident.c | 57 ++++++++--------
cpukit/rtems/src/partident.c | 47 ++++++++-----
cpukit/rtems/src/ratemonident.c | 56 +++++++++-------
cpukit/rtems/src/regionident.c | 57 +++++++++-------
cpukit/rtems/src/rtemsnametoid.c | 55 +++++++++++++++
cpukit/rtems/src/semident.c | 44 ++++++++----
cpukit/rtems/src/taskident.c | 65 +++++++++++-------
cpukit/rtems/src/timerident.c | 56 +++++++++-------
cpukit/sapi/src/extensionident.c | 52 ++++++++------
cpukit/score/src/objectnametoid.c | 4 +-
testsuites/sptests/spsimplesched02/init.c | 4 +-
16 files changed, 479 insertions(+), 230 deletions(-)
create mode 100644 cpukit/include/rtems/rtems/objectimpl.h
create mode 100644 cpukit/rtems/src/rtemsnametoid.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index aa1fe5fc16..1ea3def4ef 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -745,6 +745,7 @@ librtemscpu_a_SOURCES += rtems/src/regionreturnsegment.c
librtemscpu_a_SOURCES += rtems/src/rtemsbuildid.c
librtemscpu_a_SOURCES += rtems/src/rtemsbuildname.c
librtemscpu_a_SOURCES += rtems/src/rtemsmaxprio.c
+librtemscpu_a_SOURCES += rtems/src/rtemsnametoid.c
librtemscpu_a_SOURCES += rtems/src/rtemsobjectapimaximumclass.c
librtemscpu_a_SOURCES += rtems/src/rtemsobjectapiminimumclass.c
librtemscpu_a_SOURCES += rtems/src/rtemsobjectgetapiclassname.c
diff --git a/cpukit/include/rtems/rtems/objectimpl.h b/cpukit/include/rtems/rtems/objectimpl.h
new file mode 100644
index 0000000000..08a9749832
--- /dev/null
+++ b/cpukit/include/rtems/rtems/objectimpl.h
@@ -0,0 +1,82 @@
+ * @file
+ * @ingroup ClassicObjectImpl
+ * @brief Implementation Interfaces for Classic Objects
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_RTEMS_OBJECTIMPL_H
+#define _RTEMS_RTEMS_OBJECTIMPL_H
+#include <rtems/score/objectimpl.h>
+#include <rtems/rtems/status.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup ClassicObjectImpl Classic Object Implementation
+ * @ingroup RTEMSInternalClassic
+ * @brief Calls _Objects_Name_to_id_u32() and converts the status.
+ * @param name is the name of the object to find.
+ * @param node is the set of nodes to search.
+ * @param[out] id is the pointer to an object identifier variable or NULL. The
+ * object identifier will be stored in the referenced variable, if the
+ * operation was successful.
+ * @param information is the pointer to an object class information block.
+ * @retval RTEMS_SUCCESSFUL The operations was successful.
+ * @retval RTEMS_INVALID_ADDRESS The id parameter was NULL.
+ * @retval RTEMS_INVALID_NAME No object exists with the specified name on the
+ * specified node set.
+rtems_status_code _RTEMS_Name_to_id(
+ uint32_t name,
+ uint32_t node,
+ Objects_Id *id,
+ const Objects_Information *information
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_RTEMS_OBJECTIMPL_H */
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index a8c7fcb457..32387594f2 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -221,26 +221,29 @@ typedef enum {
#define OBJECTS_NAME_ERRORS_LAST OBJECTS_INVALID_NODE
- * @brief Converts an object name to an Id.
+ * @brief Searches an object of the specified class with the specified name on
+ * the specified set of nodes.
- * This method converts an object name to an Id. It performs a look up
+ * This method converts an object name to an identifier. It performs a look up
* using the object information block for this object class.
- * @param information points to an object class information block.
- * @param[out] id will contain the Id if the search is successful.
- * @retval OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL The operations was successful
- * @a id contains the ID.
- * @retval OBJECTS_INVALID_NAME The name was invalid.
- * @retval OBJECTS_INVALID_ID The id is not 0 before the operation.
+ * @retval OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL The operations was successful.
+ * @retval OBJECTS_INVALID_ADDRESS The id parameter was NULL.
+ * @retval OBJECTS_INVALID_NAME No object exists with the specified name on the
Objects_Name_or_id_lookup_errors _Objects_Name_to_id_u32(
- const Objects_Information *information,
uint32_t name,
uint32_t node,
- Objects_Id *id
+ Objects_Id *id,
typedef enum {
diff --git a/cpukit/rtems/src/barrierident.c b/cpukit/rtems/src/barrierident.c
index e3d6a84b80..928cc0ce9e 100644
--- a/cpukit/rtems/src/barrierident.c
+++ b/cpukit/rtems/src/barrierident.c
@@ -1,41 +1,52 @@
- * @file
+ * @file
+ * @ingroup ClassicBarrierImpl
- * @brief RTEMS Barrier name to Id
- * @ingroup ClassicBarrier
+ * @brief rtems_barrier_ident() Implementation
- * COPYRIGHT (c) 1989-2006.
- * On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 1989 On-Line Applications Research Corporation (OAR).
+ * are met:
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
-#include <rtems/rtems/statusimpl.h>
-#include <rtems/rtems/support.h>
-#include <rtems/rtems/options.h>
#include <rtems/rtems/barrierimpl.h>
+#include <rtems/rtems/objectimpl.h>
-rtems_status_code rtems_barrier_ident(
- rtems_name name,
- rtems_id *id
+rtems_status_code rtems_barrier_ident( rtems_name name, rtems_id *id )
- Objects_Name_or_id_lookup_errors status;
- status = _Objects_Name_to_id_u32(
- &_Barrier_Information,
+ return _RTEMS_Name_to_id(
name,
OBJECTS_SEARCH_LOCAL_NODE,
- id
+ id,
+ &_Barrier_Information
- return _Status_Object_name_errors_to_status[ status ];
diff --git a/cpukit/rtems/src/dpmemident.c b/cpukit/rtems/src/dpmemident.c
index 775d833bde..38d906833f 100644
--- a/cpukit/rtems/src/dpmemident.c
+++ b/cpukit/rtems/src/dpmemident.c
@@ -1,42 +1,55 @@
- * @file
+ * @file
+ * @ingroup ClassicDPMEMImpl
- * @brief RTEMS Port Name to Id
- * @ingroup ClassicDPMEM
+ * @brief rtems_port_ident() Implementation
- * COPYRIGHT (c) 1989-1999.
+ * are met:
#include "config.h"
#endif
-#include <rtems/score/address.h>
#include <rtems/rtems/dpmemimpl.h>
-#include <rtems/score/thread.h>
rtems_status_code rtems_port_ident(
rtems_name name,
rtems_id *id
- &_Dual_ported_memory_Information,
name,
OBJECTS_SEARCH_ALL_NODES,
- id
+ id,
+ &_Dual_ported_memory_Information
diff --git a/cpukit/rtems/src/msgqident.c b/cpukit/rtems/src/msgqident.c
index f25f0cdc6c..dfd68d21f0 100644
--- a/cpukit/rtems/src/msgqident.c
+++ b/cpukit/rtems/src/msgqident.c
@@ -1,33 +1,45 @@
- * @file
+ * @file
+ * @ingroup ClassicMessageQueueImpl
- * @brief RTEMS Message Queue Name to Id
- * @ingroup ClassicMessageQueue
+ * @brief rtems_message_queue_ident() Implementation
+ * are met:
#include "config.h"
#endif
-#include <rtems/score/chain.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/coremsgimpl.h>
-#include <rtems/score/wkspace.h>
-#include <rtems/rtems/attrimpl.h>
#include <rtems/rtems/messageimpl.h>
rtems_status_code rtems_message_queue_ident(
rtems_name name,
@@ -35,14 +47,5 @@ rtems_status_code rtems_message_queue_ident(
rtems_id *id
- &_Message_queue_Information,
- name,
- node,
- id
+ return _RTEMS_Name_to_id( name, node, id, &_Message_queue_Information );
diff --git a/cpukit/rtems/src/partident.c b/cpukit/rtems/src/partident.c
index 03490cd95d..5e7140f8d9 100644
--- a/cpukit/rtems/src/partident.c
+++ b/cpukit/rtems/src/partident.c
@@ -1,28 +1,45 @@
- * @file
+ * @file
+ * @ingroup ClassicPartitionImpl
- * @brief RTEMS Partition Name to Id
- * @ingroup ClassicPart
+ * @brief rtems_partition_ident() Implementation
+ * are met:
#include "config.h"
#endif
#include <rtems/rtems/partimpl.h>
rtems_status_code rtems_partition_ident(
rtems_name name,
@@ -30,9 +47,5 @@ rtems_status_code rtems_partition_ident(
rtems_id *id
- status = _Objects_Name_to_id_u32( &_Partition_Information, name, node, id );
+ return _RTEMS_Name_to_id( name, node, id, &_Partition_Information );
diff --git a/cpukit/rtems/src/ratemonident.c b/cpukit/rtems/src/ratemonident.c
index 9c1ae3fba0..67ba13b476 100644
--- a/cpukit/rtems/src/ratemonident.c
+++ b/cpukit/rtems/src/ratemonident.c
@@ -1,42 +1,52 @@
- * @file
+ * @file
+ * @ingroup ClassicRateMonImpl
- * @brief RTEMS Rate Monotonic Name to Id
- * @ingroup ClassicRateMon
+ * @brief rtems_rate_monotonic_ident() Implementation
- * COPYRIGHT (c) 1989-2007.
+ * are met:
#include "config.h"
#endif
#include <rtems/rtems/ratemonimpl.h>
-rtems_status_code rtems_rate_monotonic_ident(
- rtems_name name,
- rtems_id *id
+rtems_status_code rtems_rate_monotonic_ident( rtems_name name, rtems_id *id )
- &_Rate_monotonic_Information,
name,
- id
+ id,
+ &_Rate_monotonic_Information
diff --git a/cpukit/rtems/src/regionident.c b/cpukit/rtems/src/regionident.c
index 9e4d4b7085..c8a643c356 100644
--- a/cpukit/rtems/src/regionident.c
+++ b/cpukit/rtems/src/regionident.c
@@ -1,43 +1,52 @@
- * @file
+ * @file
+ * @ingroup ClassicRegionImpl
- * @brief RTEMS Region Name to Id
- * @ingroup ClassicRegion
+ * @brief rtems_region_ident() Implementation
+ * are met:
#include "config.h"
#endif
#include <rtems/rtems/regionimpl.h>
-#include <rtems/score/apimutex.h>
-rtems_status_code rtems_region_ident(
- rtems_name name,
- rtems_id *id
+rtems_status_code rtems_region_ident( rtems_name name, rtems_id *id )
- &_Region_Information,
name,
- id
+ id,
+ &_Region_Information
diff --git a/cpukit/rtems/src/rtemsnametoid.c b/cpukit/rtems/src/rtemsnametoid.c
index 0000000000..43a6d20908
--- /dev/null
+++ b/cpukit/rtems/src/rtemsnametoid.c
@@ -0,0 +1,55 @@
+ * @file
+ * @brief _RTEMS_Name_to_id() Implementation
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/statusimpl.h>
+ uint32_t name,
+ uint32_t node,
+ Objects_Id *id,
+ Objects_Name_or_id_lookup_errors status;
+ status = _Objects_Name_to_id_u32( name, node, id, information );
+ return _Status_Object_name_errors_to_status[ status ];
diff --git a/cpukit/rtems/src/semident.c b/cpukit/rtems/src/semident.c
index 37c776cf81..93c325c48d 100644
--- a/cpukit/rtems/src/semident.c
+++ b/cpukit/rtems/src/semident.c
@@ -1,17 +1,37 @@
- * @file
+ * @file
+ * @ingroup ClassicSemImpl
- * @brief RTEMS Semaphore Name to Id
- * @ingroup ClassicSem
+ * @brief rtems_semaphore_ident() Implementation
+ * are met:
@@ -19,7 +39,7 @@
#endif
rtems_status_code rtems_semaphore_ident(
rtems_name name,
@@ -27,9 +47,5 @@ rtems_status_code rtems_semaphore_ident(
rtems_id *id
- status = _Objects_Name_to_id_u32( &_Semaphore_Information, name, node, id );
+ return _RTEMS_Name_to_id( name, node, id, &_Semaphore_Information );
diff --git a/cpukit/rtems/src/taskident.c b/cpukit/rtems/src/taskident.c
index d35a617c1f..501bd0b05f 100644
--- a/cpukit/rtems/src/taskident.c
+++ b/cpukit/rtems/src/taskident.c
@@ -1,53 +1,66 @@
- * @file
+ * @file
+ * @ingroup ClassicTasksImpl
- * @brief RTEMS Task Name to Id
- * @ingroup ClassicTasks
+ * @brief rtems_task_ident() Implementation
+ * are met:
#include "config.h"
#endif
-#include <rtems/rtems/modes.h>
-#include <rtems/score/stack.h>
+#include <rtems/score/percpu.h>
rtems_status_code rtems_task_ident(
- rtems_name name,
- uint32_t node,
- rtems_id *id
+ rtems_name name,
+ uint32_t node,
+ rtems_id *id
- if ( !id )
+ if ( id == NULL ) {
return RTEMS_INVALID_ADDRESS;
if ( name == OBJECTS_ID_OF_SELF ) {
*id = _Thread_Get_executing()->Object.id;
return RTEMS_SUCCESSFUL;
- &_RTEMS_tasks_Information.Objects,
name,
node,
- id
+ id,
+ &_RTEMS_tasks_Information.Objects
diff --git a/cpukit/rtems/src/timerident.c b/cpukit/rtems/src/timerident.c
index b11550a744..8259507c15 100644
--- a/cpukit/rtems/src/timerident.c
+++ b/cpukit/rtems/src/timerident.c
@@ -1,42 +1,52 @@
- * @file
+ * @file
+ * @ingroup ClassicTimerImpl
- * @brief RTEMS Timer Name to Id
- * @ingroup ClassicTimer
+ * @brief rtems_timer_ident() Implementation
- * COPYRIGHT (c) 1989-2002.
+ * are met:
#include "config.h"
#endif
#include <rtems/rtems/timerimpl.h>
-#include <rtems/score/watchdog.h>
-rtems_status_code rtems_timer_ident(
- rtems_name name,
- rtems_id *id
+rtems_status_code rtems_timer_ident( rtems_name name, rtems_id *id )
- &_Timer_Information,
name,
- id
+ id,
+ &_Timer_Information
diff --git a/cpukit/sapi/src/extensionident.c b/cpukit/sapi/src/extensionident.c
index c92a779c0b..d408f68dd1 100644
--- a/cpukit/sapi/src/extensionident.c
+++ b/cpukit/sapi/src/extensionident.c
@@ -1,42 +1,52 @@
* @file
- * @ingroup ClassicUserExtensions
+ * @ingroup ClassicUserExtensionsImpl
- * @brief User Extensions Implementation.
+ * @brief rtems_extension_ident() Implementation
+ * are met:
#include "config.h"
#endif
#include <rtems/extensionimpl.h>
-rtems_status_code rtems_extension_ident(
- rtems_name name,
- rtems_id *id
+rtems_status_code rtems_extension_ident( rtems_name name, rtems_id *id )
- &_Extension_Information,
name,
- id
+ id,
+ &_Extension_Information
diff --git a/cpukit/score/src/objectnametoid.c b/cpukit/score/src/objectnametoid.c
index 2a9052d948..d89e161c8c 100644
--- a/cpukit/score/src/objectnametoid.c
+++ b/cpukit/score/src/objectnametoid.c
@@ -21,10 +21,10 @@
uint32_t name,
uint32_t node,
- Objects_Id *id
+ Objects_Id *id,
bool search_local_node;
diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
index 27e2f6577c..d19d3553d9 100644
--- a/testsuites/sptests/spsimplesched02/init.c
+++ b/testsuites/sptests/spsimplesched02/init.c
@@ -81,10 +81,10 @@ rtems_task Init(
TEST_BEGIN();
- &_Thread_Information.Objects,
rtems_build_name( 'I', 'D', 'L', 'E' ),
RTEMS_SEARCH_LOCAL_NODE,
- &Idle_id
+ &Idle_id,
+ &_Thread_Information.Objects
rtems_test_assert( status == RTEMS_SUCCESSFUL );
2.26.2
