[PATCH] config: Provide file descriptors only if necessary
Fri Aug 21 08:44:35 UTC 2020
Only provide the file descriptor array if
CONFIGURE_MAXIMUM_FILE_DESCRIPTORS > 0.  If someone configured
CONFIGURE_MAXIMUM_FILE_DESCRIPTORS == 0 and the appplication uses
something which requires a file descriptor, then a linker error will
show up.  An alternative would be to add a zero-length array
rtems_libio_iops[ 0 ] to librtemscpu.a which would be used in this
case.
Conditionally include some header files.
 cpukit/include/rtems/confdefs/libio.h | 24 +++++++++++++++---------
 1 file changed, 15 insertions(+), 9 deletions(-)
diff --git a/cpukit/include/rtems/confdefs/libio.h b/cpukit/include/rtems/confdefs/libio.h
index e986262e3e..8f43c490b1 100644
--- a/cpukit/include/rtems/confdefs/libio.h
+++ b/cpukit/include/rtems/confdefs/libio.h
@@ -43,7 +43,6 @@
 #ifdef CONFIGURE_INIT
 #include <rtems/confdefs/bsp.h>
-#include <rtems/libio.h>
 #include <rtems/sysinit.h>
 #ifdef CONFIGURE_FILESYSTEM_ALL
@@ -86,6 +85,15 @@
   #define CONFIGURE_IMFS_DISABLE_UTIME
 #endif
+#ifndef CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
+  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 3
+#endif
+#if !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM) || \
+  CONFIGURE_MAXIMUM_FILE_DESCRIPTORS > 0
+  #include <rtems/libio.h>
+#endif
 #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
   #ifdef CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
     #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM"
@@ -122,10 +130,10 @@
   #ifdef CONFIGURE_FILESYSTEM_TFTPFS
     #error "CONFIGURE_APPLICATION_DISABLE_FILESYSTEM cannot be used together with CONFIGURE_FILESYSTEM_TFTPFS"
   #endif
+#else
+  #include <rtems/imfs.h>
 #endif
-#include <rtems/imfs.h>
 #ifdef CONFIGURE_FILESYSTEM_DOSFS
 #include <rtems/dosfs.h>
 #endif
@@ -316,13 +324,11 @@ RTEMS_SYSINIT_ITEM(
 #endif /* !CONFIGURE_APPLICATION_DISABLE_FILESYSTEM */
-#ifndef CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
-  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 3
-#endif
-rtems_libio_t rtems_libio_iops[ CONFIGURE_MAXIMUM_FILE_DESCRIPTORS ];
+#if CONFIGURE_MAXIMUM_FILE_DESCRIPTORS > 0
+  rtems_libio_t rtems_libio_iops[ CONFIGURE_MAXIMUM_FILE_DESCRIPTORS ];
-const uint32_t rtems_libio_number_iops = RTEMS_ARRAY_SIZE( rtems_libio_iops );
+  const uint32_t rtems_libio_number_iops = RTEMS_ARRAY_SIZE( rtems_libio_iops );
+#endif
 #ifdef __cplusplus
2.26.2
