When does heir become executing on calling _Thread_Dispatch_request from another cpu?
Richi Dubey richidubey at gmail.com
Fri Aug 21 15:07:09 UTC 2020
Yes, it is. It also takes away the modularity of different parts of an
operating system.
Thanks for the help.
On Fri, Aug 21, 2020 at 4:40 PM Sebastian Huber <
> On 21/08/2020 13:06, Richi Dubey wrote:
> > I understand what you're saying. Accessing the chain of scheduled node
> > to figure out which node is scheduled on which processor is a more
> > formal and safer way to do it than directly accessing a cpu's variable.
> The difference is a bit more than just safer. Using the per-processor
> variables in the scheduler code is simply wrong.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200821/4baffdd9/attachment.html>
