[PATCH 1/1] Adding QEP driver to Beaglebone bsp
James Fitzsimons
james.fitzsimons at gmail.com
Fri Aug 21 10:01:12 UTC 2020
bsps/arm/beagle/headers.am | 2 +
bsps/arm/beagle/include/bsp/bbb-pwm.h | 11 -
bsps/arm/beagle/include/bsp/pwmss.h | 54 +++
bsps/arm/beagle/include/bsp/qep.h | 331 ++++++++++++++++++
bsps/arm/beagle/pwm/pwm.c | 64 +---
bsps/arm/beagle/pwmss/pwmss.c | 64 ++++
bsps/arm/beagle/qep/qep.c | 435 ++++++++++++++++++++++++
c/src/lib/libbsp/arm/beagle/Makefile.am | 6 +
8 files changed, 896 insertions(+), 71 deletions(-)
create mode 100644 bsps/arm/beagle/include/bsp/pwmss.h
create mode 100644 bsps/arm/beagle/include/bsp/qep.h
create mode 100644 bsps/arm/beagle/pwmss/pwmss.c
create mode 100644 bsps/arm/beagle/qep/qep.c
diff --git a/bsps/arm/beagle/headers.am b/bsps/arm/beagle/headers.am
index 4dc35f2e2a..e4a746b2e1 100644
--- a/bsps/arm/beagle/headers.am
+++ b/bsps/arm/beagle/headers.am
@@ -13,3 +13,5 @@ include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/beagleboneb
include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/i2c.h
include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/irq.h
include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/spi.h
+include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/qep.h
+include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/pwmss.h
diff --git a/bsps/arm/beagle/include/bsp/bbb-pwm.h b/bsps/arm/beagle/include/bsp/bbb-pwm.h
index cf5d6fe552..6fdba486be 100644
--- a/bsps/arm/beagle/include/bsp/bbb-pwm.h
+++ b/bsps/arm/beagle/include/bsp/bbb-pwm.h
@@ -31,17 +31,6 @@ extern "C" {
#define BBB_CONTROL_CONF_GPMC_AD(n) (0x800 + (n * 4))
#define BBB_CONTROL_CONF_LCD_DATA(n) (0x8a0 + (n * 4))
- * @brief The set of possible PWM subsystem module
- * Enumerated type to define various instance of pwm module.
-typedef enum{
- BBB_PWMSS0 = 0,
- BBB_PWMSS1,
- BBB_PWMSS2,
- BBB_PWMSS_COUNT
-}BBB_PWMSS;
typedef enum{
BBB_P8_13_2B = 3,
diff --git a/bsps/arm/beagle/include/bsp/pwmss.h b/bsps/arm/beagle/include/bsp/pwmss.h
new file mode 100644
index 0000000000..3a9dcbb70a
--- /dev/null
+++ b/bsps/arm/beagle/include/bsp/pwmss.h
@@ -0,0 +1,54 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief Shared PWMSS module functions used by PWM, eQEP and eCAP (when added).
+ * Copyright (c) 2020 James Fitzsimons <james.fitzsimons at gmail.com>
+#ifndef LIBBSP_ARM_BEAGLE_PWMSS_H
+#define LIBBSP_ARM_BEAGLE_PWMSS_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+/* The following definitions are bitmasks for the clk control registers for
+ * the PWMSS module clocks. All three modules have the same clock control
+ * hence the EPMSSx to signify these values are consistent across all
+ * EPWMSS instances. */
+#define AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE_ENABLE (0x2u)
+#define AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE (0x00000003u)
+#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST_FUNC (0x0u)
+#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST_SHIFT (0x00000010u)
+#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST (0x00030000u)
+ * @brief The set of possible PWM subsystem module
+ * Enumerated type to define various instance of pwm module.
+typedef enum {
+ BBB_PWMSS0 = 0,
+ BBB_PWMSS1,
+ BBB_PWMSS2,
+ BBB_PWMSS_COUNT
+} BBB_PWMSS;
+rtems_status_code pwmss_module_clk_config(BBB_PWMSS pwmss_id);
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_BEAGLE_PWMSS_H */
diff --git a/bsps/arm/beagle/include/bsp/qep.h b/bsps/arm/beagle/include/bsp/qep.h
index 0000000000..671d9cca6c
--- /dev/null
+++ b/bsps/arm/beagle/include/bsp/qep.h
@@ -0,0 +1,331 @@
+ * @file
+ * @brief eQEP (enhanced Quadrature Encoder Pulse) support API.
+ * For details of the Enhanced Quadrature Encoder Pulse (eQEP) Module refer to
+ * page 2511 of the TI Technical Reference Manual
+ * (https://www.ti.com/lit/ug/spruh73q/spruh73q.pdf)
+ * This driver supports using the QEP modules in Quadrature-clock Mode.
+ * Direction-count Mode is not currently supported. Similarly the QEPI: Index
+ * or Zero Marker and QEPS: Strobe Input pins are not currently supported.
+ * The mode can be any one of:
+ * - Quadrature-count mode - For encoders that generate pulses 90 degrees
+ * out of phase for determining direction and speed.
+ * - Direction-count mode - for position encoders that provide direction and
+ * clock outputs, instead of quadrature outputs.
+ * - UP-count mode - The counter direction signal is hard-wired for up count
+ * and the position counter is used to measure the frequency of the QEPA
+ * input.
+ * - DOWN-count mode - The counter direction signal is hard-wired for a down
+ * count and the position counter is used to measure the frequency of the
+ * QEPA input.
+ * When the eQEP module is configured in quadrature mode, the module
+ * can either provide an absolute position, or a relative position. Absolute
+ * simply increments or decrements depending on the direction. Relative
+ * increments until the unit timer overflows at which point it latches the
+ * position value, resets the position count to zero and starts again.
+#ifndef LIBBSP_ARM_BEAGLE_QEP_H
+#define LIBBSP_ARM_BEAGLE_QEP_H
+#ifdef __cplusplus
+extern "C" {
+#define AM335X_EQEP_REGS (0x00000180)
+#define AM335X_EQEP_0_REGS (AM335X_PWMSS0_MMAP_ADDR + AM335X_EQEP_REGS)
+#define AM335X_EQEP_1_REGS (AM335X_PWMSS1_MMAP_ADDR + AM335X_EQEP_REGS)
+#define AM335X_EQEP_2_REGS (AM335X_PWMSS2_MMAP_ADDR + AM335X_EQEP_REGS)
+/* eQEP registers of the PWMSS modules - see page 1672 of the TRM for details */
+#define AM335x_EQEP_QPOSCNT 0x0 /* eQEP Position Counter */
+#define AM335x_EQEP_QPOSINIT 0x4 /* eQEP Position Counter Initialization */
+#define AM335x_EQEP_QPOSMAX 0x8 /* eQEP Maximum Position Count */
+#define AM335x_EQEP_QPOSCMP 0xC /* eQEP Position-Compare */
+#define AM335x_EQEP_QPOSILAT 0x10 /* eQEP Index Position Latch */
+#define AM335x_EQEP_QPOSSLAT 0x14 /* eQEP Strobe Position Latch */
+#define AM335x_EQEP_QPOSLAT 0x18 /* eQEP Position Counter Latch */
+#define AM335x_EQEP_QUTMR 0x1C /* eQEP Unit Timer */
+#define AM335x_EQEP_QUPRD 0x20 /* eQEP Unit Period */
+#define AM335x_EQEP_QWDTMR 0x24 /* eQEP Watchdog Timer */
+#define AM335x_EQEP_QWDPRD 0x26 /* eQEP Watchdog Period */
+#define AM335x_EQEP_QDECCTL 0x28 /* eQEP Decoder Control */
+#define AM335x_EQEP_QEPCTL 0x2A /* eQEP Control */
+#define AM335x_EQEP_QCAPCTL 0x2C /* eQEP Capture Control */
+#define AM335x_EQEP_QPOSCTL 0x2E /* eQEP Position-Compare Control */
+#define AM335x_EQEP_QEINT 0x30 /* eQEP Interrupt Enable */
+#define AM335x_EQEP_QFLG 0x32 /* eQEP Interrupt Flag */
+#define AM335x_EQEP_QCLR 0x34 /* eQEP Interrupt Clear */
+#define AM335x_EQEP_QFRC 0x36 /* eQEP Interrupt Force */
+#define AM335x_EQEP_QEPSTS 0x38 /* eQEP Status */
+#define AM335x_EQEP_QCTMR 0x3A /* eQEP Capture Timer */
+#define AM335x_EQEP_QCPRD 0x3C /* eQEP Capture Period */
+#define AM335x_EQEP_QCTMRLAT 0x3E /* eQEP Capture Timer Latch */
+#define AM335x_EQEP_QCPRDLAT 0x40 /* eQEP Capture Period Latch */
+#define AM335x_EQEP_REVID 0x5C /* eQEP Revision ID */
+/* bitmasks for eQEP registers */
+#define AM335x_EQEP_QEPCTL_UTE (1 << 1)
+#define AM335x_EQEP_QEPCTL_QCLM (1 << 2)
+#define AM335x_EQEP_QEPCTL_PHEN (1 << 3)
+#define AM335x_EQEP_QEPCTL_IEL (1 << 4)
+#define AM335x_EQEP_QEPCTL_SWI (1 << 7)
+#define AM335x_EQEP_QEPCTL_PCRM (3 << 12)
+#define AM335x_EQEP_QDECCTL_QSRC (3 << 14)
+#define AM335x_EQEP_QDECCTL_XCR (1 << 11)
+#define AM335x_EQEP_QDECCTL_SWAP (1 << 10)
+#define AM335x_EQEP_QDECCTL_IGATE (1 << 9)
+#define AM335x_EQEP_QDECCTL_QAP (1 << 8)
+#define AM335x_EQEP_QDECCTL_QBP (1 << 7)
+#define AM335x_EQEP_QDECCTL_QIP (1 << 6)
+#define AM335x_EQEP_QDECCTL_QSP (1 << 5)
+#define AM335x_EQEP_CLK_EN (1 << 4)
+#define AM335x_EQEP_QEINT_UTO (1 << 11)
+#define AM335x_EQEP_QFLG_UTO (1 << 11)
+#define AM335x_EQEP_QFLG_MASK 0x0FFF
+/* The pin mux modes for the QEP input pins on the P8 and P9 headers */
+#define BBB_P8_11_MUX_QEP 4
+#define BBB_P8_12_MUX_QEP 4
+#define BBB_P8_15_MUX_QEP 4
+#define BBB_P8_16_MUX_QEP 4
+#define BBB_P8_31_MUX_QEP 2
+#define BBB_P8_32_MUX_QEP 2
+#define BBB_P8_33_MUX_QEP 2
+#define BBB_P8_35_MUX_QEP 2
+#define BBB_P8_39_MUX_QEP 3
+#define BBB_P8_40_MUX_QEP 3
+#define BBB_P8_41_MUX_QEP 3
+#define BBB_P8_42_MUX_QEP 3
+#define BBB_P9_25_MUX_QEP 1
+#define BBB_P9_27_MUX_QEP 1
+#define BBB_P9_41_MUX_QEP 1
+#define BBB_P9_42_MUX_QEP 1
+#define NANO_SEC_PER_SEC 1000000000
+/* This is the max clock rate for the EPWMSS module. See 15.1.2.2 of the TRM.
+ * If the CPU was using dynamic scaling this could potentially be wrong */
+#define SYSCLKOUT 100000000
+ * @brief The set of possible eQEP Position Counter Input Modes
+ * Enumerated type to define various modes for the eQEP module. The values
+ * correspond to the values for the QSRC bits of the QDECCTL register.
+typedef enum {
+ QUADRATURE_COUNT = 0,
+ DIRECTION_COUNT,
+ UP_COUNT,
+ DOWN_COUNT
+} BBB_QEP_COUNT_MODE;
+ * @brief The set of possible modes for Quadrature decode
+typedef enum {
+ ABSOLUTE = 0,
+ RELATIVE
+} BBB_QEP_QUADRATURE_MODE;
+ * @brief The set of possible eQEP input pins
+typedef enum {
+ BBB_P8_11_2B_IN,
+ BBB_P8_12_2A_IN,
+ BBB_P8_15_2_STROBE,
+ BBB_P8_16_2_IDX,
+ BBB_P8_31_1_IDX,
+ BBB_P8_32_1_STROBE,
+ BBB_P8_33_1B_IN,
+ BBB_P8_35_1A_IN,
+ BBB_P8_39_2_IDX,
+ BBB_P8_40_2_STROBE,
+ BBB_P8_41_2A_IN,
+ BBB_P8_42_2B_IN,
+ BBB_P9_25_0_STROBE,
+ BBB_P9_27_0B_IN,
+ BBB_P9_41_0_IDX,
+ BBB_P9_42_0A_IN
+} bbb_qep_pin;
+typedef void (*bbb_eqep_timer_callback)(BBB_PWMSS);
+ * @brief This structure represents an eQEP module instance.
+ * The members are closely modelled on the FDT structure. *
+typedef struct {
+ const BBB_PWMSS pwmss_id;
+ const uint32_t mmio_base;
+ const rtems_vector_number irq;
+ bbb_eqep_timer_callback timer_callback;
+ BBB_QEP_COUNT_MODE count_mode;
+ BBB_QEP_QUADRATURE_MODE quadrature_mode;
+ uint32_t invert_qa;
+ uint32_t invert_qb;
+ uint32_t invert_qi;
+ uint32_t invert_qs;
+ uint32_t swap_inputs;
+} bbb_eqep;
+ * @brief Initialises the eQEP module of the specified PWMSS unit. This
+ * configures the clocks, sets up the interrupt handler and unit timer,
+ * The module is configured in Quadrature decode mode using
+ * absolute position by default.
+ * @param pwmss_id The PWMSS module to configure the eQEP for.
+ * @return RTEMS_SUCCESSFUL if ok, RTEMS_INVALID_ID if an invalid pwmss_id is
+ * supplied.
+rtems_status_code beagle_qep_init(BBB_PWMSS pwmss_id);
+ * @brief Enables the eQEP module of the specified PWMSS unit.
+ * @param pwmss_id The PWMSS module which will have the eQEP function enabled.
+ * supplied.
+rtems_status_code beagle_qep_enable(BBB_PWMSS pwmss_id);
+ * @brief Disables the eQEP module of the specified PWMSS unit.
+ * @param pwmss_id The PWMSS module which will have the eQEP function disabled.
+ * supplied.
+rtems_status_code beagle_qep_disable(BBB_PWMSS pwmss_id);
+ * @brief Configures a given pin for use with the eQEP function of the supplied
+ * PWMSS module.
+ * @param pin_no The P9 or P8 header pin to be configured for the eQEP function.
+ * @param pullup_enable If true then the internal pull up resistor on the
+ * specified pin will be enabled, if false the pull down will be enabled.
+ * supplied.
+rtems_status_code beagle_qep_pinmux_setup(
+ bbb_qep_pin pin_no,
+ BBB_PWMSS pwmss_id,
+ bool pullup_enable
+ * @brief Returns the current position value of the eQEP function for the
+ * specified PWMSS module.
+ * @param pwmss_id Identifies which PWMSS module to return the eQEP position for
+ * @return int32_t The current position value.
+int32_t beagle_qep_get_position(BBB_PWMSS pwmss_id);
+ * @brief Sets the initial position value of the eQEP function for the
+ * @param pwmss_id Identifies which PWMSS module to set the eQEP position for
+ * @param position The value to initialise the position register with.
+ * supplied.
+rtems_status_code beagle_qep_set_position(
+ uint32_t position
+ * @brief Sets the count mode for the eQEP module.
+ * @param pwmss_id Identifies which PWMSS module to set the eQEP count mode for.
+ * @param mode One of the above modes to configure the eQEP module for.
+ * supplied.
+rtems_status_code beagle_qep_set_count_mode(
+ BBB_QEP_COUNT_MODE mode
+ * @brief Gets the currently configured count mode for the eQEP module.
+ * @return An enum value representing the current count mode.
+BBB_QEP_COUNT_MODE beagle_qep_get_count_mode(BBB_PWMSS pwmss_id);
+ * @brief Returns the currently configured quadrature mode - either absolute,
+ * or relative.
+ * @param pwmss_id Identifies which PWMSS module to get the eQEP quadrature
+ * mode for.
+ * @return BBB_QEP_QUADRATURE_MODE The currently configured quadrature mode.
+BBB_QEP_QUADRATURE_MODE beagle_qep_get_quadrature_mode(BBB_PWMSS pwmss_id);
+ * @brief Sets the quadrature mode to either absolute or relative.
+ * @param pwmss_id Identifies which PWMSS module to set the eQEP quadrature
+ * mode for.
+ * @param mode BBB_QEP_QUADRATURE_MODE Set the mode of the eQEP to either
+ * absolute or relative.
+ * supplied.
+rtems_status_code beagle_qep_set_quadrature_mode(
+ BBB_QEP_QUADRATURE_MODE mode
+ * @brief Returns the the currently configured unit timer period.
+ * @param pwmss_id Identifies which PWMSS module to get the eQEP timer value for
+ * @return uint32_t The current unit timer value in nanoseconds
+uint32_t beagle_eqep_get_timer_period(BBB_PWMSS pwmss_id);
+ * @brief Sets the unit timer period for the eQEP module.
+ * 0 = off, greater than zero sets the period.
+ * @param pwmss_id Identifies which PWMSS module to set the eQEP unit timer for.
+ * @param period The value in nanoseconds to set the unit timer period to.
+ * supplied.
+rtems_status_code beagle_eqep_set_timer_period(
+ uint64_t period,
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_BEAGLE_QEP_H */
diff --git a/bsps/arm/beagle/pwm/pwm.c b/bsps/arm/beagle/pwm/pwm.c
index 0bc5d125bf..4bd09293e8 100644
--- a/bsps/arm/beagle/pwm/pwm.c
+++ b/bsps/arm/beagle/pwm/pwm.c
@@ -23,6 +23,7 @@
#include <bsp/gpio.h>
#include <bsp/bbb-gpio.h>
#include <bsp.h>
+#include <bsp/pwmss.h>
#include <bsp/bbb-pwm.h>
#include <bsp/beagleboneblack.h>
@@ -38,7 +39,7 @@
* @param pwm_id It is the instance number of EPWM of pwm sub system.
* @return Base Address of respective pwm instant.
static uint32_t select_pwm(BBB_PWMSS pwm_id)
uint32_t baseAddr=0;
@@ -102,9 +103,9 @@ bool beagle_pwm_pinmux_setup(bbb_pwm_pin_t pin_no, BBB_PWMSS pwm_id)
} else if (pin_no == BBB_P8_36_1A) {
REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(10)) = BBB_MUXMODE(BBB_P8_36_MUX_PWM);
} else if (pin_no == BBB_P9_14_1A) {
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(2)) = BBB_MUXMODE(BBB_P9_14_MUX_PWM);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_A2) = BBB_MUXMODE(BBB_P9_14_MUX_PWM);
} else if (pin_no == BBB_P9_16_1B) {
- REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(3)) = BBB_MUXMODE(BBB_P9_16_MUX_PWM);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_A3) = BBB_MUXMODE(BBB_P9_16_MUX_PWM);
} else {
is_valid = false;
@@ -181,63 +182,6 @@ static bool pwm_clock_enable(BBB_PWMSS pwm_id)
return status;
- * @brief This function configures the L3 and L4_PER system clocks.
- * It also configures the system clocks for the specified ePWMSS
- * instance.
- * @param pwmss_id The instance number of ePWMSS whose system clocks
- * have to be configured.
- * 'pwmss_id' can take one of the following values:
- * (0 <= pwmss_id <= 2)
- * @return True if successful
- * False if Unsuccessful
-static bool pwmss_module_clk_config(BBB_PWMSS pwmss_id)
- bool is_valid = true;
- if(pwmss_id == BBB_PWMSS0) {
- const uint32_t is_functional = AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_FUNC <<
- AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_SHIFT;
- const uint32_t clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS0_CLKCTRL;
- const uint32_t idle_bits = AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST;
- const uint32_t is_enable = AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE;
- const uint32_t module_mode = AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE;
- REG(clkctrl) |= is_enable;
- while((REG(clkctrl) & module_mode) != is_enable);
- while((REG(clkctrl) & idle_bits) != is_functional);
- else if(pwmss_id == BBB_PWMSS1) {
- const uint32_t is_functional = AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_FUNC <<
- AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_SHIFT;
- const uint32_t clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS1_CLKCTRL;
- const uint32_t idle_bits = AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST;
- const uint32_t is_enable = AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE;
- const uint32_t module_mode = AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE;
- } else if(pwmss_id == BBB_PWMSS2) {
- const uint32_t is_functional = AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_FUNC <<
- AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_SHIFT;
- const uint32_t clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS2_CLKCTRL;
- const uint32_t idle_bits = AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST;
- const uint32_t is_enable = AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE;
- const uint32_t module_mode = AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE;
- } else
- is_valid = false;
- return is_valid;
bool beagle_pwm_init(BBB_PWMSS pwmss_id)
const bool id_is_valid = pwmss_id < BBB_PWMSS_COUNT;
diff --git a/bsps/arm/beagle/pwmss/pwmss.c b/bsps/arm/beagle/pwmss/pwmss.c
index 0000000000..c4d36d8ae1
--- /dev/null
+++ b/bsps/arm/beagle/pwmss/pwmss.c
@@ -0,0 +1,64 @@
+ * @file
+ * @brief Support for eQEP for the BeagleBone Black.
+#include <libcpu/am335x.h>
+#include <stdio.h>
+#include <bsp.h>
+#include <bsp/beagleboneblack.h>
+ * @brief This function configures the L3 and L4_PER system clocks.
+ * It also configures the system clocks for the specified ePWMSS
+ * instance.
+ * @param pwmss_id The instance number of ePWMSS whose system clocks
+ * have to be configured.
+ * 'pwmss_id' can take one of the following values:
+ * (0 <= pwmss_id <= 2)
+ * @return True if successful
+ * False if Unsuccessful
+ uint32_t clkctrl;
+ /* calculate the address of the clock control register for the PWMSS
+ * module we are configuring */
+ if(pwmss_id == BBB_PWMSS0) {
+ clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS0_CLKCTRL;
+ } else if(pwmss_id == BBB_PWMSS1) {
+ clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS1_CLKCTRL;
+ } else if(pwmss_id == BBB_PWMSS2) {
+ clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS2_CLKCTRL;
+ /* when the module is functional the IDLEST bits (16 -17) of the
+ * CM_PER_EPWMSSx_CLKCTRL register will be 0x0. */
+ const uint32_t is_functional = 0x0;
+ const uint32_t idle_bits = AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST;
+ const uint32_t is_enable = AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE_ENABLE;
+ const uint32_t module_mode = AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE;
+ REG(clkctrl) |= is_enable;
+ while((REG(clkctrl) & module_mode) != is_enable);
+ while((REG(clkctrl) & idle_bits) != is_functional);
+ return RTEMS_SUCCESSFUL;
diff --git a/bsps/arm/beagle/qep/qep.c b/bsps/arm/beagle/qep/qep.c
index 0000000000..d0fc9fc6ba
--- /dev/null
+++ b/bsps/arm/beagle/qep/qep.c
@@ -0,0 +1,435 @@
+ * @file
+#include <stdio.h>
+#include <stdlib.h>
+#include <bsp/gpio.h>
+#include <bsp/bbb-gpio.h>
+#include <bsp.h>
+#include <bsp/qep.h>
+ * @brief Represents all the PWMSS QEP modules and their default values.
+static bbb_eqep bbb_eqep_table[ BBB_PWMSS_COUNT ] =
+ .pwmss_id = BBB_PWMSS0,
+ .mmio_base = AM335X_EQEP_0_REGS,
+ .irq = AM335X_INT_eQEP0INT,
+ .timer_callback = NULL,
+ .count_mode = QUADRATURE_COUNT,
+ .quadrature_mode = ABSOLUTE,
+ .invert_qa = 0,
+ .invert_qb = 0,
+ .invert_qi = 0,
+ .invert_qs = 0,
+ .swap_inputs = 0
+ .pwmss_id = BBB_PWMSS1,
+ .mmio_base = AM335X_EQEP_1_REGS,
+ .irq = AM335X_INT_eQEP1INT,
+ .invert_qa = 0,
+ .invert_qb = 0,
+ .invert_qi = 0,
+ .invert_qs = 0,
+ .swap_inputs = 0
+ .pwmss_id = BBB_PWMSS2,
+ .mmio_base = AM335X_EQEP_2_REGS,
+ .irq = AM335X_INT_eQEP2INT,
+ .invert_qa = 0,
+ .invert_qb = 0,
+ .invert_qi = 0,
+ .invert_qs = 0,
+ .swap_inputs = 0
+/* eQEP Interrupt handler */
+static void beagle_eqep_irq_handler(void *arg)
+ uint16_t flags;
+ bbb_eqep* eqep = arg;
+ /* Use the interrupt register (QFLG) mask to determine what caused the
+ * interrupt. */
+ flags = REG16(eqep->mmio_base + AM335x_EQEP_QFLG) & AM335x_EQEP_QFLG_MASK;
+ /* Check the interrupt source to see if it was a unit timer overflow */
+ if (flags & AM335x_EQEP_QFLG_UTO && eqep->timer_callback != NULL) {
+ /* Handle the unit timer overflow interrupt */
+ eqep->timer_callback(eqep->pwmss_id);
+ /* Clear interrupt flags (write back triggered flags to the clear register) */
+ REG16(eqep->mmio_base + AM335x_EQEP_QCLR) = flags;
+ rtems_status_code sc;
+ uint16_t qdecctl;
+ if ( pwmss_id >= BBB_PWMSS_COUNT ) {
+ return RTEMS_INVALID_ID;
+ bbb_eqep* eqep = &bbb_eqep_table[pwmss_id];
+ sc = pwmss_module_clk_config(eqep->pwmss_id);
+ if (sc != RTEMS_SUCCESSFUL) {
+ /* failed to successfully configure the PWMSS module clocks */
+ return sc;
+ /* This enables clock for EQEP module in PWMSS subsystem. */
+ REG(eqep->mmio_base + AM335X_PWMSS_CLKCONFIG) |= AM335x_EQEP_CLK_EN;
+ /* Setup interrupt handler */
+ sc = rtems_interrupt_handler_install(
+ eqep->irq,
+ NULL,
+ RTEMS_INTERRUPT_UNIQUE,
+ (rtems_interrupt_handler)beagle_eqep_irq_handler,
+ (void*)eqep
+ /* The QDECCTL register configures the QEP Decoder module. We use it to set */
+ /* the count mode, input inversion, channel swaps, unit timer interrupt etc. */
+ qdecctl = 0;
+ if (eqep->count_mode <= 3) {
+ qdecctl |= eqep->count_mode << 14;
+ /* If the count mode is UP_COUNT or DOWN_COUNT then only count on
+ * the rising edge. QUADRATURE_COUNT and DIRECTION_COUNT count on
+ * both edges. */
+ if (eqep->count_mode >= 2) {
+ qdecctl |= AM335x_EQEP_QDECCTL_XCR;
+ /* Should we swap the cha and chb inputs */
+ if (eqep->swap_inputs == 1) {
+ qdecctl |= AM335x_EQEP_QDECCTL_SWAP;
+ /* Should we invert the qa input */
+ if (eqep->invert_qa == 1) {
+ qdecctl |= AM335x_EQEP_QDECCTL_QAP;
+ /* Should we invert the qb input */
+ if (eqep->invert_qb == 1) {
+ qdecctl |= AM335x_EQEP_QDECCTL_QBP;
+ /* Should we invert the index input */
+ if (eqep->invert_qi == 1) {
+ qdecctl |= AM335x_EQEP_QDECCTL_QIP;
+ /* Should we invert the strobe input */
+ if (eqep->invert_qs == 1) {
+ qdecctl |= AM335x_EQEP_QDECCTL_QSP;
+ /* Write the configured decoder control settings to the QDECCTL register */
+ REG16(eqep->mmio_base + AM335x_EQEP_QDECCTL) = qdecctl;
+ /* Set the position counter initialisation register */
+ REG(eqep->mmio_base + AM335x_EQEP_QPOSINIT) = 0;
+ /* initialise the maximum position counter value */
+ REG(eqep->mmio_base + AM335x_EQEP_QPOSMAX) = ~0;
+ /* initialise the position counter register */
+ REG(eqep->mmio_base + AM335x_EQEP_QPOSCNT) = 0;
+ /* Enable Unit Time Period interrupt. */
+ REG16(eqep->mmio_base + AM335x_EQEP_QEINT) |= AM335x_EQEP_QEINT_UTO;
+ /* The following bitmasks enable the eQEP module with:
+ * - the unit timer disabled
+ * - will latch the value in QPOSLAT to QPOSCNT upon unit timer overflow
+ * - will latch QPOSILAT on index signal.
+ * - Software initialisation of position counter (will be set to 0 because
+ * QPOSINIT = 0).
+ uint32_t value = AM335x_EQEP_QEPCTL_QCLM | AM335x_EQEP_QEPCTL_IEL |
+ AM335x_EQEP_QEPCTL_PHEN | AM335x_EQEP_QEPCTL_SWI;
+ /* set the enable bit of the control register */
+ REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL) = value;
+ const bbb_eqep* eqep = &bbb_eqep_table[pwmss_id];
+ REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL) |= AM335x_EQEP_QEPCTL_PHEN;
+ /* clear the enable bit of the control register */
+ REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL) &= ~AM335x_EQEP_QEPCTL_PHEN;
+ rtems_status_code result = RTEMS_SUCCESSFUL;
+ /* enable internal pull up / pull down resistor in pull up mode, and set the
+ * pin as an input. */
+ uint32_t pin_mode = BBB_RXACTIVE;
+ if ( pullup_enable ) {
+ pin_mode |= BBB_PU_EN;
+ // The offsets from AM335X_PADCONF_BASE (44e10000) are named after the mode0 mux for that pin.
+ if (pin_no == BBB_P9_25_0_STROBE) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_AHCLKX) = pin_mode | BBB_MUXMODE(BBB_P9_25_MUX_QEP);
+ } else if (pin_no == BBB_P9_27_0B_IN) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_FSR) = pin_mode | BBB_MUXMODE(BBB_P9_27_MUX_QEP);
+ } else if (pin_no == BBB_P9_41_0_IDX) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_AXR1) = pin_mode | BBB_MUXMODE(BBB_P9_41_MUX_QEP);
+ } else if (pin_no == BBB_P9_42_0A_IN) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_ACLKR) = pin_mode | BBB_MUXMODE(BBB_P9_42_MUX_QEP);
+ } else {
+ result = RTEMS_INTERNAL_ERROR;
+ } else if (pwmss_id == BBB_PWMSS1) {
+ if (pin_no == BBB_P8_31_1_IDX) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA14) = pin_mode | BBB_MUXMODE(BBB_P8_31_MUX_QEP);
+ } else if (pin_no == BBB_P8_32_1_STROBE) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA15) = pin_mode | BBB_MUXMODE(BBB_P8_32_MUX_QEP);
+ } else if (pin_no == BBB_P8_33_1B_IN) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA13) = pin_mode | BBB_MUXMODE(BBB_P8_33_MUX_QEP);
+ } else if (pin_no == BBB_P8_35_1A_IN) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA12) = pin_mode | BBB_MUXMODE(BBB_P8_35_MUX_QEP);
+ } else {
+ } else if (pwmss_id == BBB_PWMSS2) {
+ if (pin_no == BBB_P8_11_2B_IN) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_AD13) = pin_mode | BBB_MUXMODE(BBB_P8_11_MUX_QEP);
+ } else if (pin_no == BBB_P8_12_2A_IN) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_AD12) = pin_mode | BBB_MUXMODE(BBB_P8_12_MUX_QEP);
+ } else if (pin_no == BBB_P8_15_2_STROBE) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_AD15) = pin_mode | BBB_MUXMODE(BBB_P8_15_MUX_QEP);
+ } else if (pin_no == BBB_P8_16_2_IDX) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_AD14) = pin_mode | BBB_MUXMODE(BBB_P8_16_MUX_QEP);
+ } else if (pin_no == BBB_P8_39_2_IDX) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA6) = pin_mode | BBB_MUXMODE(BBB_P8_39_MUX_QEP);
+ } else if (pin_no == BBB_P8_40_2_STROBE) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA7) = pin_mode | BBB_MUXMODE(BBB_P8_40_MUX_QEP);
+ } else if (pin_no == BBB_P8_41_2A_IN) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA4) = pin_mode | BBB_MUXMODE(BBB_P8_41_MUX_QEP);
+ } else if (pin_no == BBB_P8_42_2B_IN) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA5) = pin_mode | BBB_MUXMODE(BBB_P8_42_MUX_QEP);
+ } else {
+ } else {
+ return result;
+ int32_t position = 0;
+ return -1;
+ if (eqep->quadrature_mode == ABSOLUTE) {
+ /* return the current value of the QPOSCNT register */
+ position = REG(eqep->mmio_base + AM335x_EQEP_QPOSCNT);
+ } else if (eqep->quadrature_mode == RELATIVE) {
+ /* return the latched value from the last unit timer interrupt */
+ position = REG(eqep->mmio_base + AM335x_EQEP_QPOSLAT);
+ return position;
+rtems_status_code beagle_qep_set_position(BBB_PWMSS pwmss_id, uint32_t position)
+ /* setting the position only really makes sense in ABSOLUTE mode. */
+ REG(eqep->mmio_base + AM335x_EQEP_QPOSCNT) = position;
+ eqep->count_mode = mode;
+ return eqep->count_mode;
+ uint16_t qepctl;
+ qepctl = REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL);
+ if (mode == ABSOLUTE) {
+ * Disable the unit timer position reset
+ qepctl &= ~AM335x_EQEP_QEPCTL_PCRM;
+ eqep->quadrature_mode = ABSOLUTE;
+ } else if (mode == RELATIVE) {
+ * enable the unit timer position reset
+ qepctl |= AM335x_EQEP_QEPCTL_PCRM;
+ eqep->quadrature_mode = RELATIVE;
+ REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL) = qepctl;
+ return -1;
+ return eqep->quadrature_mode;
+/* Function to read the period of the unit time event timer */
+ uint64_t period;
+ uint32_t timer_period;
+ return -1;
+ /* Convert from counts per interrupt back into period_ns */
+ period = REG(eqep->mmio_base + AM335x_EQEP_QUPRD);
+ period = period * NANO_SEC_PER_SEC;
+ timer_period = (uint32_t)(period / SYSCLKOUT);
+ return timer_period;
+ uint64_t period,
+ uint16_t qepctl;
+ uint64_t tmp_period;
+ /* Disable the unit timer before modifying its period register */
+ qepctl = readw(eqep->mmio_base + AM335x_EQEP_QEPCTL);
+ qepctl &= ~(AM335x_EQEP_QEPCTL_UTE | AM335x_EQEP_QEPCTL_QCLM);
+ /* Zero the unit timer counter register */
+ REG(eqep->mmio_base + AM335x_EQEP_QUTMR) = 0;
+ /* If the timer is enabled (a non-zero period has been passed) */
+ if (period) {
+ /* update the period */
+ tmp_period = period * SYSCLKOUT;
+ timer_period = (uint32_t)(tmp_period / NANO_SEC_PER_SEC);
+ REG(eqep->mmio_base + AM335x_EQEP_QUPRD) = timer_period;
+ /* Enable unit timer, and latch QPOSLAT to QPOSCNT on timer expiration */
+ qepctl |= AM335x_EQEP_QEPCTL_UTE | AM335x_EQEP_QEPCTL_QCLM;
+ /* attach the unit timer interrupt handler if one has been supplied */
+ if (timer_callback != NULL) {
+ eqep->timer_callback = timer_callback;
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index e37472373c..c9492f41a1 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -76,9 +76,15 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/spi/spi.c
# GPIO
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/gpio/bbb-gpio.c
+#pwmss shared
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/pwmss/pwmss.c
#pwm
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/pwm/pwm.c
+#qep
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/qep/qep.c
#RTC
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/rtc/rtc.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/rtc/rtc-support.c
2.17.1
