[PATCH 1/1] Adding QEP driver to Beaglebone bsp
Sat Aug 22 08:41:04 UTC 2020
On 21/8/20 8:01 pm, James Fitzsimons wrote:
>  bsps/arm/beagle/headers.am              |   2 +
>  bsps/arm/beagle/include/bsp/bbb-pwm.h   |  11 -
>  bsps/arm/beagle/include/bsp/pwmss.h     |  54 +++
>  bsps/arm/beagle/include/bsp/qep.h       | 331 ++++++++++++++++++
>  bsps/arm/beagle/pwm/pwm.c               |  64 +---
>  bsps/arm/beagle/pwmss/pwmss.c           |  64 ++++
>  bsps/arm/beagle/qep/qep.c               | 435 ++++++++++++++++++++++++
>  c/src/lib/libbsp/arm/beagle/Makefile.am |   6 +
>  8 files changed, 896 insertions(+), 71 deletions(-)
>  create mode 100644 bsps/arm/beagle/include/bsp/pwmss.h
>  create mode 100644 bsps/arm/beagle/include/bsp/qep.h
>  create mode 100644 bsps/arm/beagle/pwmss/pwmss.c
>  create mode 100644 bsps/arm/beagle/qep/qep.c
> diff --git a/bsps/arm/beagle/headers.am b/bsps/arm/beagle/headers.am
> index 4dc35f2e2a..e4a746b2e1 100644
> --- a/bsps/arm/beagle/headers.am
> +++ b/bsps/arm/beagle/headers.am
> @@ -13,3 +13,5 @@ include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/beagleboneb
>  include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/i2c.h
>  include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/irq.h
>  include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/spi.h
> +include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/qep.h
> +include_bsp_HEADERS += ../../../../../../bsps/arm/beagle/include/bsp/pwmss.h
> diff --git a/bsps/arm/beagle/include/bsp/bbb-pwm.h b/bsps/arm/beagle/include/bsp/bbb-pwm.h
> index cf5d6fe552..6fdba486be 100644
> --- a/bsps/arm/beagle/include/bsp/bbb-pwm.h
> +++ b/bsps/arm/beagle/include/bsp/bbb-pwm.h
> @@ -31,17 +31,6 @@ extern "C" {
>  #define BBB_CONTROL_CONF_GPMC_AD(n)   (0x800 + (n * 4))
>  #define BBB_CONTROL_CONF_LCD_DATA(n)   (0x8a0 + (n * 4))
> - * @brief The set of possible PWM subsystem module
> - * Enumerated type to define various instance of pwm module.
> -typedef enum{
> -  BBB_PWMSS0 = 0,
> -  BBB_PWMSS1,
> -  BBB_PWMSS2,
> -  BBB_PWMSS_COUNT
> -}BBB_PWMSS;
>  typedef enum{
>    BBB_P8_13_2B = 3,
> diff --git a/bsps/arm/beagle/include/bsp/pwmss.h b/bsps/arm/beagle/include/bsp/pwmss.h
> new file mode 100644
> index 0000000000..3a9dcbb70a
> --- /dev/null
> +++ b/bsps/arm/beagle/include/bsp/pwmss.h
> @@ -0,0 +1,54 @@
> + * @file
> + * @ingroup arm_beagle
> + * @brief Shared PWMSS module functions used by PWM, eQEP and eCAP (when added).
> + * Copyright (c) 2020 James Fitzsimons <james.fitzsimons at gmail.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#ifndef LIBBSP_ARM_BEAGLE_PWMSS_H
> +#define LIBBSP_ARM_BEAGLE_PWMSS_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +/* The following definitions are bitmasks for the clk control registers for
> + * the PWMSS module clocks. All three modules have the same clock control
> + * hence the EPMSSx to signify these values are consistent across all
> + * EPWMSS instances. */
> +#define AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
> +#define AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE   (0x00000003u)
> +#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST_FUNC  (0x0u)
> +#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST_SHIFT (0x00000010u)
> +#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST       (0x00030000u)
> + * @brief The set of possible PWM subsystem module
> + * Enumerated type to define various instance of pwm module.
> +typedef enum {
> +  BBB_PWMSS0 = 0,
> +  BBB_PWMSS1,
> +  BBB_PWMSS2,
> +  BBB_PWMSS_COUNT
> +} BBB_PWMSS;
> +rtems_status_code pwmss_module_clk_config(BBB_PWMSS pwmss_id);
> +#ifdef __cplusplus
> +#endif /* LIBBSP_ARM_BEAGLE_PWMSS_H */
> diff --git a/bsps/arm/beagle/include/bsp/qep.h b/bsps/arm/beagle/include/bsp/qep.h
> index 0000000000..671d9cca6c
> --- /dev/null
> +++ b/bsps/arm/beagle/include/bsp/qep.h
> @@ -0,0 +1,331 @@
> + * @file
> + * @brief eQEP (enhanced Quadrature Encoder Pulse) support API.
> + * For details of the Enhanced Quadrature Encoder Pulse (eQEP) Module refer to
> + * page 2511 of the TI Technical Reference Manual
> + * (https://www.ti.com/lit/ug/spruh73q/spruh73q.pdf)
> + * This driver supports using the QEP modules in Quadrature-clock Mode.
> + * Direction-count Mode is not currently supported. Similarly the QEPI: Index
> + * or Zero Marker and QEPS: Strobe Input pins are not currently supported.
> + * The mode can be any one of:
> + *  - Quadrature-count mode - For encoders that generate pulses 90 degrees
> + *      out of phase for determining direction and speed.
> + *  - Direction-count mode - for position encoders that provide direction and
> + *      clock outputs, instead of quadrature outputs.
> + *  - UP-count mode - The counter direction signal is hard-wired for up count
> + *      and the position counter is used to measure the frequency of the QEPA
> + *      input.
> + *  - DOWN-count mode - The counter direction signal is hard-wired for a down
> + *      count and the position counter is used to measure the frequency of the
> + *      QEPA input.
> + * When the eQEP module is configured in quadrature mode, the module
> + * can either provide an absolute position, or a relative position. Absolute
> + * simply increments or decrements depending on the direction. Relative
> + * increments until the unit timer overflows at which point it latches the
> + * position value, resets the position count to zero and starts again.
> +#ifndef LIBBSP_ARM_BEAGLE_QEP_H
> +#define LIBBSP_ARM_BEAGLE_QEP_H
> +#ifdef __cplusplus
> +extern "C" {
> +#define AM335X_EQEP_REGS                       (0x00000180)
> +#define AM335X_EQEP_0_REGS                     (AM335X_PWMSS0_MMAP_ADDR + AM335X_EQEP_REGS)
> +#define AM335X_EQEP_1_REGS                     (AM335X_PWMSS1_MMAP_ADDR + AM335X_EQEP_REGS)
> +#define AM335X_EQEP_2_REGS                     (AM335X_PWMSS2_MMAP_ADDR + AM335X_EQEP_REGS)
> +/* eQEP registers of the PWMSS modules - see page 1672 of the TRM for details */
> +#define AM335x_EQEP_QPOSCNT       0x0   /* eQEP Position Counter */
> +#define AM335x_EQEP_QPOSINIT      0x4   /* eQEP Position Counter Initialization */
> +#define AM335x_EQEP_QPOSMAX       0x8   /* eQEP Maximum Position Count */
> +#define AM335x_EQEP_QPOSCMP       0xC   /* eQEP Position-Compare */
> +#define AM335x_EQEP_QPOSILAT      0x10  /* eQEP Index Position Latch */
> +#define AM335x_EQEP_QPOSSLAT      0x14  /* eQEP Strobe Position Latch */
> +#define AM335x_EQEP_QPOSLAT       0x18  /* eQEP Position Counter Latch */
> +#define AM335x_EQEP_QUTMR         0x1C  /* eQEP Unit Timer */
> +#define AM335x_EQEP_QUPRD         0x20  /* eQEP Unit Period */
> +#define AM335x_EQEP_QWDTMR        0x24  /* eQEP Watchdog Timer */
> +#define AM335x_EQEP_QWDPRD        0x26  /* eQEP Watchdog Period */
> +#define AM335x_EQEP_QDECCTL       0x28  /* eQEP Decoder Control */
> +#define AM335x_EQEP_QEPCTL        0x2A  /* eQEP Control */
> +#define AM335x_EQEP_QCAPCTL       0x2C  /* eQEP Capture Control */
> +#define AM335x_EQEP_QPOSCTL       0x2E  /* eQEP Position-Compare Control */
> +#define AM335x_EQEP_QEINT         0x30  /* eQEP Interrupt Enable */
> +#define AM335x_EQEP_QFLG          0x32  /* eQEP Interrupt Flag */
> +#define AM335x_EQEP_QCLR          0x34  /* eQEP Interrupt Clear */
> +#define AM335x_EQEP_QFRC          0x36  /* eQEP Interrupt Force */
> +#define AM335x_EQEP_QEPSTS        0x38  /* eQEP Status */
> +#define AM335x_EQEP_QCTMR         0x3A  /* eQEP Capture Timer */
> +#define AM335x_EQEP_QCPRD         0x3C  /* eQEP Capture Period */
> +#define AM335x_EQEP_QCTMRLAT      0x3E  /* eQEP Capture Timer Latch */
> +#define AM335x_EQEP_QCPRDLAT      0x40  /* eQEP Capture Period Latch */
> +#define AM335x_EQEP_REVID         0x5C  /* eQEP Revision ID */
> +/* bitmasks for eQEP registers  */
> +#define AM335x_EQEP_QEPCTL_UTE    (1 << 1)
> +#define AM335x_EQEP_QEPCTL_QCLM   (1 << 2)
> +#define AM335x_EQEP_QEPCTL_PHEN   (1 << 3)
> +#define AM335x_EQEP_QEPCTL_IEL    (1 << 4)
> +#define AM335x_EQEP_QEPCTL_SWI    (1 << 7)
> +#define AM335x_EQEP_QEPCTL_PCRM   (3 << 12)
> +#define AM335x_EQEP_QDECCTL_QSRC  (3 << 14)
> +#define AM335x_EQEP_QDECCTL_XCR   (1 << 11)
> +#define AM335x_EQEP_QDECCTL_SWAP  (1 << 10)
> +#define AM335x_EQEP_QDECCTL_IGATE (1 << 9)
> +#define AM335x_EQEP_QDECCTL_QAP   (1 << 8)
> +#define AM335x_EQEP_QDECCTL_QBP   (1 << 7)
> +#define AM335x_EQEP_QDECCTL_QIP   (1 << 6)
> +#define AM335x_EQEP_QDECCTL_QSP   (1 << 5)
> +#define AM335x_EQEP_CLK_EN        (1 << 4)
> +#define AM335x_EQEP_QEINT_UTO     (1 << 11)
> +#define AM335x_EQEP_QFLG_UTO      (1 << 11)
> +#define AM335x_EQEP_QFLG_MASK     0x0FFF
> +/* The pin mux modes for the QEP input pins on the P8 and P9 headers */
> +#define BBB_P8_11_MUX_QEP 4
> +#define BBB_P8_12_MUX_QEP 4
> +#define BBB_P8_15_MUX_QEP 4
> +#define BBB_P8_16_MUX_QEP 4
> +#define BBB_P8_31_MUX_QEP 2
> +#define BBB_P8_32_MUX_QEP 2
> +#define BBB_P8_33_MUX_QEP 2
> +#define BBB_P8_35_MUX_QEP 2
> +#define BBB_P8_39_MUX_QEP 3
> +#define BBB_P8_40_MUX_QEP 3
> +#define BBB_P8_41_MUX_QEP 3
> +#define BBB_P8_42_MUX_QEP 3
> +#define BBB_P9_25_MUX_QEP 1
> +#define BBB_P9_27_MUX_QEP 1
> +#define BBB_P9_41_MUX_QEP 1
> +#define BBB_P9_42_MUX_QEP 1
> +#define NANO_SEC_PER_SEC  1000000000
> +/* This is the max clock rate for the EPWMSS module. See 15.1.2.2 of the TRM.
> + * If the CPU was using dynamic scaling this could potentially be wrong */
> +#define SYSCLKOUT         100000000
> + * @brief The set of possible eQEP Position Counter Input Modes
> + * Enumerated type to define various modes for the eQEP module. The values
> + * correspond to the values for the QSRC bits of the QDECCTL register.
> +typedef enum {
> +  QUADRATURE_COUNT = 0,
> +  DIRECTION_COUNT,
> +  UP_COUNT,
> +  DOWN_COUNT
> +} BBB_QEP_COUNT_MODE;
> + * @brief The set of possible modes for Quadrature decode
> +typedef enum {
> +  ABSOLUTE = 0,
> +  RELATIVE
> +} BBB_QEP_QUADRATURE_MODE;
> + * @brief The set of possible eQEP input pins
> +typedef enum {
> +  BBB_P8_11_2B_IN,
> +  BBB_P8_12_2A_IN,
> +  BBB_P8_15_2_STROBE,
> +  BBB_P8_16_2_IDX,
> +  BBB_P8_31_1_IDX,
> +  BBB_P8_32_1_STROBE,
> +  BBB_P8_33_1B_IN,
> +  BBB_P8_35_1A_IN,
> +  BBB_P8_39_2_IDX,
> +  BBB_P8_40_2_STROBE,
> +  BBB_P8_41_2A_IN,
> +  BBB_P8_42_2B_IN,
> +  BBB_P9_25_0_STROBE,
> +  BBB_P9_27_0B_IN,
> +  BBB_P9_41_0_IDX,
> +  BBB_P9_42_0A_IN
> +} bbb_qep_pin;
> +typedef void (*bbb_eqep_timer_callback)(BBB_PWMSS);
What is BBB_PWMSS used for as an argument?
Could a `void* user` be passed back? It helps if the interrupt provides a user
specific data pointer.
> + * @brief This structure represents an eQEP module instance.
> + * The members are closely modelled on the FDT structure. *
> +typedef struct {
> +  const BBB_PWMSS pwmss_id;
> +  const uint32_t mmio_base;
> +  const rtems_vector_number irq;
> +  bbb_eqep_timer_callback timer_callback;
Is this part of the FDT? I think some extra documentation here would be good to
have.
Can we have a `void* user;`?
Thanks
> +  BBB_QEP_COUNT_MODE count_mode;
> +  BBB_QEP_QUADRATURE_MODE quadrature_mode;
> +  uint32_t invert_qa;
> +  uint32_t invert_qb;
> +  uint32_t invert_qi;
> +  uint32_t invert_qs;
> +  uint32_t swap_inputs;
> +} bbb_eqep;
> + * @brief Initialises the eQEP module of the specified PWMSS unit. This
> + * configures the clocks, sets up the interrupt handler and unit timer,
> + * The module is configured in Quadrature decode mode using
> + * absolute position by default.
> + * @param pwmss_id The PWMSS module to configure the eQEP for.
> + * @return RTEMS_SUCCESSFUL if ok, RTEMS_INVALID_ID if an invalid pwmss_id is
> + * supplied.
> +rtems_status_code beagle_qep_init(BBB_PWMSS pwmss_id);
> + * @brief Enables the eQEP module of the specified PWMSS unit.
> + * @param pwmss_id The PWMSS module which will have the eQEP function enabled.
> + * supplied.
> +rtems_status_code beagle_qep_enable(BBB_PWMSS pwmss_id);
> + * @brief Disables the eQEP module of the specified PWMSS unit.
> + * @param pwmss_id The PWMSS module which will have the eQEP function disabled.
> + * supplied.
> +rtems_status_code beagle_qep_disable(BBB_PWMSS pwmss_id);
> + * @brief Configures a given pin for use with the eQEP function of the supplied
> + * PWMSS module.
> + * @param pin_no The P9 or P8 header pin to be configured for the eQEP function.
> + * @param pullup_enable If true then the internal pull up resistor on the
> + * specified pin will be enabled, if false the pull down will be enabled.
> + * supplied.
> +rtems_status_code beagle_qep_pinmux_setup(
> +  bbb_qep_pin pin_no,
> +  BBB_PWMSS pwmss_id,
> +  bool pullup_enable
> + * @brief Returns the current position value of the eQEP function for the
> + * specified PWMSS module.
> + * @param pwmss_id Identifies which PWMSS module to return the eQEP position for
> + * @return int32_t The current position value.
> +int32_t beagle_qep_get_position(BBB_PWMSS pwmss_id);
> + * @brief Sets the initial position value of the eQEP function for the
> + * @param pwmss_id Identifies which PWMSS module to set the eQEP position for
> + * @param position The value to initialise the position register with.
> + * supplied.
> +rtems_status_code beagle_qep_set_position(
> +    uint32_t position
> + * @brief Sets the count mode for the eQEP module.
> + * @param pwmss_id Identifies which PWMSS module to set the eQEP count mode for.
> + * @param mode One of the above modes to configure the eQEP module for.
> + * supplied.
> +rtems_status_code beagle_qep_set_count_mode(
> +  BBB_QEP_COUNT_MODE mode
> + * @brief Gets the currently configured count mode for the eQEP module.
> + * @return An enum value representing the current count mode.
> +BBB_QEP_COUNT_MODE beagle_qep_get_count_mode(BBB_PWMSS pwmss_id);
> + * @brief Returns the currently configured quadrature mode - either absolute,
> + * or relative.
> + * @param pwmss_id Identifies which PWMSS module to get the eQEP quadrature
> + * mode for.
> + * @return BBB_QEP_QUADRATURE_MODE The currently configured quadrature mode.
> +BBB_QEP_QUADRATURE_MODE beagle_qep_get_quadrature_mode(BBB_PWMSS pwmss_id);
> + * @brief Sets the quadrature mode to either absolute or relative.
> + * @param pwmss_id Identifies which PWMSS module to set the eQEP quadrature
> + * mode for.
> + * @param mode BBB_QEP_QUADRATURE_MODE Set the mode of the eQEP to either
> + * absolute or relative.
> + * supplied.
> +rtems_status_code beagle_qep_set_quadrature_mode(
> +    BBB_QEP_QUADRATURE_MODE mode
> + * @brief Returns the the currently configured unit timer period.
> + * @param pwmss_id Identifies which PWMSS module to get the eQEP timer value for
> + * @return uint32_t The current unit timer value in nanoseconds
> +uint32_t beagle_eqep_get_timer_period(BBB_PWMSS pwmss_id);
> + * @brief Sets the unit timer period for the eQEP module.
> + * 0 = off, greater than zero sets the period.
> + * @param pwmss_id Identifies which PWMSS module to set the eQEP unit timer for.
> + * @param period The value in nanoseconds to set the unit timer period to.
> + * supplied.
> +rtems_status_code beagle_eqep_set_timer_period(
> +    uint64_t period,
> +#ifdef __cplusplus
> +#endif /* LIBBSP_ARM_BEAGLE_QEP_H */
> diff --git a/bsps/arm/beagle/pwm/pwm.c b/bsps/arm/beagle/pwm/pwm.c
> index 0bc5d125bf..4bd09293e8 100644
> --- a/bsps/arm/beagle/pwm/pwm.c
> +++ b/bsps/arm/beagle/pwm/pwm.c
> @@ -23,6 +23,7 @@
>  #include <bsp/gpio.h>
>  #include <bsp/bbb-gpio.h>
>  #include <bsp.h>
> +#include <bsp/pwmss.h>
>  #include <bsp/bbb-pwm.h>
>  #include <bsp/beagleboneblack.h>
> @@ -38,7 +39,7 @@
>   * @param pwm_id It is the instance number of EPWM of pwm sub system.
>   * @return Base Address of respective pwm instant.
>  static uint32_t select_pwm(BBB_PWMSS pwm_id)
>    uint32_t baseAddr=0;
> @@ -102,9 +103,9 @@ bool beagle_pwm_pinmux_setup(bbb_pwm_pin_t pin_no, BBB_PWMSS pwm_id)
>  	} else if (pin_no == BBB_P8_36_1A) {
>  	  REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(10)) = BBB_MUXMODE(BBB_P8_36_MUX_PWM);
>  	} else if (pin_no == BBB_P9_14_1A) {
> -	  REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(2)) = BBB_MUXMODE(BBB_P9_14_MUX_PWM);
> +	  REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_A2) = BBB_MUXMODE(BBB_P9_14_MUX_PWM);
>  	} else if (pin_no == BBB_P9_16_1B) {
> -	  REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(3)) = BBB_MUXMODE(BBB_P9_16_MUX_PWM);
> +	  REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_A3) = BBB_MUXMODE(BBB_P9_16_MUX_PWM);
>  	} else {
>  	  is_valid = false;
> @@ -181,63 +182,6 @@ static bool pwm_clock_enable(BBB_PWMSS pwm_id)
>    return status;
> - * @brief   This function configures the L3 and L4_PER system clocks.
> - *          It also configures the system clocks for the specified ePWMSS
> - *          instance.
> - * @param   pwmss_id    The instance number of ePWMSS whose system clocks
> - *                         have to be configured.
> - * 'pwmss_id' can take one of the following values:
> - * (0 <= pwmss_id <= 2)
> - * @return  True if successful
> - *          False if Unsuccessful
> -static bool pwmss_module_clk_config(BBB_PWMSS pwmss_id)
> -  bool is_valid = true;
> -  if(pwmss_id == BBB_PWMSS0) {
> -    const uint32_t is_functional = AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_FUNC <<
> -                         AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_SHIFT;
> -    const uint32_t clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS0_CLKCTRL;
> -    const uint32_t idle_bits = AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST;
> -    const uint32_t is_enable = AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE;
> -    const uint32_t module_mode = AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE;
> -    REG(clkctrl) |= is_enable;
> -    while((REG(clkctrl) & module_mode) != is_enable);
> -    while((REG(clkctrl) & idle_bits) != is_functional);
> -    else if(pwmss_id == BBB_PWMSS1) {
> -    const uint32_t is_functional = AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_FUNC <<
> -                         AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_SHIFT;
> -    const uint32_t clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS1_CLKCTRL;
> -    const uint32_t idle_bits = AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST;
> -    const uint32_t is_enable = AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE;
> -    const uint32_t module_mode = AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE;
> -    } else if(pwmss_id == BBB_PWMSS2) {
> -    const uint32_t is_functional = AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_FUNC <<
> -                         AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_SHIFT;
> -    const uint32_t clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS2_CLKCTRL;
> -    const uint32_t idle_bits = AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST;
> -    const uint32_t is_enable = AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE;
> -    const uint32_t module_mode = AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE;
> -    } else
> -	is_valid = false;
> -  return is_valid;
>  bool beagle_pwm_init(BBB_PWMSS pwmss_id)
>    const bool id_is_valid = pwmss_id < BBB_PWMSS_COUNT;
> diff --git a/bsps/arm/beagle/pwmss/pwmss.c b/bsps/arm/beagle/pwmss/pwmss.c
> index 0000000000..c4d36d8ae1
> --- /dev/null
> +++ b/bsps/arm/beagle/pwmss/pwmss.c
> @@ -0,0 +1,64 @@
> + * @file
> + * @brief Support for eQEP for the BeagleBone Black.
> +#include <libcpu/am335x.h>
> +#include <stdio.h>
> +#include <bsp.h>
> +#include <bsp/beagleboneblack.h>
> + * @brief   This function configures the L3 and L4_PER system clocks.
> + *          It also configures the system clocks for the specified ePWMSS
> + *          instance.
> + * @param   pwmss_id    The instance number of ePWMSS whose system clocks
> + *                         have to be configured.
> + * 'pwmss_id' can take one of the following values:
> + * (0 <= pwmss_id <= 2)
> + * @return  True if successful
> + *          False if Unsuccessful
> +    uint32_t clkctrl;
> +    /* calculate the address of the clock control register for the PWMSS
> +     * module we are configuring */
> +    if(pwmss_id == BBB_PWMSS0) {
> +        clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS0_CLKCTRL;
> +    } else if(pwmss_id == BBB_PWMSS1) {
> +        clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS1_CLKCTRL;
> +    } else if(pwmss_id == BBB_PWMSS2) {
> +        clkctrl = AM335X_CM_PER_ADDR + AM335X_CM_PER_EPWMSS2_CLKCTRL;
> +    /* when the module is functional the IDLEST bits (16 -17) of the
> +     * CM_PER_EPWMSSx_CLKCTRL register will be 0x0. */
> +    const uint32_t is_functional = 0x0;
> +    const uint32_t idle_bits = AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST;
> +    const uint32_t is_enable = AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE_ENABLE;
> +    const uint32_t module_mode = AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE;
> +    REG(clkctrl) |= is_enable;
> +    while((REG(clkctrl) & module_mode) != is_enable);
> +    while((REG(clkctrl) & idle_bits) != is_functional);
> +    return RTEMS_SUCCESSFUL;
> diff --git a/bsps/arm/beagle/qep/qep.c b/bsps/arm/beagle/qep/qep.c
> index 0000000000..d0fc9fc6ba
> --- /dev/null
> +++ b/bsps/arm/beagle/qep/qep.c
> @@ -0,0 +1,435 @@
> + * @file
> +#include <stdio.h>
> +#include <stdlib.h>
> +#include <bsp/gpio.h>
> +#include <bsp/bbb-gpio.h>
> +#include <bsp.h>
> +#include <bsp/qep.h>
> + * @brief Represents all the PWMSS QEP modules and their default values.
> +static bbb_eqep bbb_eqep_table[ BBB_PWMSS_COUNT ] =
> +  .pwmss_id = BBB_PWMSS0,
> +  .mmio_base = AM335X_EQEP_0_REGS,
> +  .irq = AM335X_INT_eQEP0INT,
> +  .timer_callback = NULL,
> +  .count_mode = QUADRATURE_COUNT,
> +  .quadrature_mode = ABSOLUTE,
> +  .invert_qa = 0,
> +  .invert_qb = 0,
> +  .invert_qi = 0,
> +  .invert_qs = 0,
> +  .swap_inputs = 0
> +  .pwmss_id = BBB_PWMSS1,
> +  .mmio_base = AM335X_EQEP_1_REGS,
> +  .irq = AM335X_INT_eQEP1INT,
> +  .invert_qa = 0,
> +  .invert_qb = 0,
> +  .invert_qi = 0,
> +  .invert_qs = 0,
> +  .swap_inputs = 0
> +  .pwmss_id = BBB_PWMSS2,
> +  .mmio_base = AM335X_EQEP_2_REGS,
> +  .irq = AM335X_INT_eQEP2INT,
> +  .invert_qa = 0,
> +  .invert_qb = 0,
> +  .invert_qi = 0,
> +  .invert_qs = 0,
> +  .swap_inputs = 0
> +/* eQEP Interrupt handler */
> +static void beagle_eqep_irq_handler(void *arg)
> +  uint16_t flags;
> +  bbb_eqep* eqep = arg;
> +  /* Use the interrupt register (QFLG) mask to determine what caused the
> +   * interrupt. */
> +  flags = REG16(eqep->mmio_base + AM335x_EQEP_QFLG) & AM335x_EQEP_QFLG_MASK;
> +  /* Check the interrupt source to see if it was a unit timer overflow  */
> +  if (flags & AM335x_EQEP_QFLG_UTO && eqep->timer_callback != NULL) {
> +    /* Handle the unit timer overflow interrupt */
> +    eqep->timer_callback(eqep->pwmss_id);
> +  /* Clear interrupt flags (write back triggered flags to the clear register) */
> +  REG16(eqep->mmio_base + AM335x_EQEP_QCLR) = flags;
> +  rtems_status_code sc;
> +  uint16_t qdecctl;
> +  if ( pwmss_id >= BBB_PWMSS_COUNT ) {
> +    return RTEMS_INVALID_ID;
> +  bbb_eqep* eqep = &bbb_eqep_table[pwmss_id];
> +  sc = pwmss_module_clk_config(eqep->pwmss_id);
> +  if (sc != RTEMS_SUCCESSFUL) {
> +    /* failed to successfully configure the PWMSS module clocks */
> +    return sc;
> +  /* This enables clock for EQEP module in PWMSS subsystem. */
> +  REG(eqep->mmio_base + AM335X_PWMSS_CLKCONFIG) |= AM335x_EQEP_CLK_EN;
> +  /* Setup interrupt handler */
> +  sc = rtems_interrupt_handler_install(
> +      eqep->irq,
> +      NULL,
> +      RTEMS_INTERRUPT_UNIQUE,
> +      (rtems_interrupt_handler)beagle_eqep_irq_handler,
> +      (void*)eqep
> +  /* The QDECCTL register configures the QEP Decoder module. We use it to set */
> +  /* the count mode, input inversion, channel swaps, unit timer interrupt etc. */
> +  qdecctl = 0;
> +  if (eqep->count_mode <= 3) {
> +    qdecctl |= eqep->count_mode << 14;
> +    /* If the count mode is UP_COUNT or DOWN_COUNT then only count on
> +     * the rising edge. QUADRATURE_COUNT and DIRECTION_COUNT count on
> +     * both edges.  */
> +    if (eqep->count_mode >= 2) {
> +      qdecctl |= AM335x_EQEP_QDECCTL_XCR;
> +  /* Should we swap the cha and chb inputs */
> +  if (eqep->swap_inputs == 1) {
> +    qdecctl |= AM335x_EQEP_QDECCTL_SWAP;
> +  /* Should we invert the qa input */
> +  if (eqep->invert_qa == 1) {
> +    qdecctl |= AM335x_EQEP_QDECCTL_QAP;
> +  /* Should we invert the qb input */
> +  if (eqep->invert_qb == 1) {
> +    qdecctl |= AM335x_EQEP_QDECCTL_QBP;
> +  /* Should we invert the index input */
> +  if (eqep->invert_qi == 1) {
> +    qdecctl |= AM335x_EQEP_QDECCTL_QIP;
> +  /* Should we invert the strobe input */
> +  if (eqep->invert_qs == 1) {
> +    qdecctl |= AM335x_EQEP_QDECCTL_QSP;
> +  /* Write the configured decoder control settings to the QDECCTL register */
> +  REG16(eqep->mmio_base + AM335x_EQEP_QDECCTL) = qdecctl;
> +  /* Set the position counter initialisation register */
> +  REG(eqep->mmio_base + AM335x_EQEP_QPOSINIT) = 0;
> +  /* initialise the maximum position counter value */
> +  REG(eqep->mmio_base + AM335x_EQEP_QPOSMAX) = ~0;
> +  /* initialise the position counter register */
> +  REG(eqep->mmio_base + AM335x_EQEP_QPOSCNT) = 0;
> +  /* Enable Unit Time Period interrupt. */
> +  REG16(eqep->mmio_base + AM335x_EQEP_QEINT) |= AM335x_EQEP_QEINT_UTO;
> +  /* The following bitmasks enable the eQEP module with:
> +   * - the unit timer disabled
> +   * - will latch the value in QPOSLAT to QPOSCNT upon unit timer overflow
> +   * - will latch QPOSILAT on index signal.
> +   * - Software initialisation of position counter (will be set to 0 because
> +   *   QPOSINIT = 0).
> +  uint32_t value = AM335x_EQEP_QEPCTL_QCLM | AM335x_EQEP_QEPCTL_IEL |
> +      AM335x_EQEP_QEPCTL_PHEN | AM335x_EQEP_QEPCTL_SWI;
> +  /* set the enable bit of the control register */
> +  REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL) = value;
> +  const bbb_eqep* eqep = &bbb_eqep_table[pwmss_id];
> +  REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL) |= AM335x_EQEP_QEPCTL_PHEN;
> +  /* clear the enable bit of the control register */
> +  REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL) &= ~AM335x_EQEP_QEPCTL_PHEN;
> +  rtems_status_code result = RTEMS_SUCCESSFUL;
> +  /* enable internal pull up / pull down resistor in pull up mode, and set the
> +   * pin as an input. */
> +  uint32_t pin_mode =  BBB_RXACTIVE;
> +  if ( pullup_enable ) {
> +    pin_mode |= BBB_PU_EN;
> +  // The offsets from AM335X_PADCONF_BASE (44e10000) are named after the mode0 mux for that pin.
> +    if (pin_no == BBB_P9_25_0_STROBE) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_AHCLKX) = pin_mode | BBB_MUXMODE(BBB_P9_25_MUX_QEP);
> +    } else if (pin_no == BBB_P9_27_0B_IN) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_FSR) = pin_mode | BBB_MUXMODE(BBB_P9_27_MUX_QEP);
> +    } else if (pin_no == BBB_P9_41_0_IDX) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_AXR1) = pin_mode | BBB_MUXMODE(BBB_P9_41_MUX_QEP);
> +    } else if (pin_no == BBB_P9_42_0A_IN) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_MCASP0_ACLKR) = pin_mode | BBB_MUXMODE(BBB_P9_42_MUX_QEP);
> +    } else {
> +      result = RTEMS_INTERNAL_ERROR;
> +  } else if (pwmss_id == BBB_PWMSS1) {
> +    if (pin_no == BBB_P8_31_1_IDX) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA14) = pin_mode | BBB_MUXMODE(BBB_P8_31_MUX_QEP);
> +    } else if (pin_no == BBB_P8_32_1_STROBE) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA15) = pin_mode | BBB_MUXMODE(BBB_P8_32_MUX_QEP);
> +    } else if (pin_no == BBB_P8_33_1B_IN) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA13) = pin_mode | BBB_MUXMODE(BBB_P8_33_MUX_QEP);
> +    } else if (pin_no == BBB_P8_35_1A_IN) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA12) = pin_mode | BBB_MUXMODE(BBB_P8_35_MUX_QEP);
> +    } else {
> +  } else if (pwmss_id == BBB_PWMSS2) {
> +    if (pin_no == BBB_P8_11_2B_IN) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_AD13) = pin_mode | BBB_MUXMODE(BBB_P8_11_MUX_QEP);
> +    } else if (pin_no == BBB_P8_12_2A_IN) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_AD12) = pin_mode | BBB_MUXMODE(BBB_P8_12_MUX_QEP);
> +    } else if (pin_no == BBB_P8_15_2_STROBE) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_AD15) = pin_mode | BBB_MUXMODE(BBB_P8_15_MUX_QEP);
> +    } else if (pin_no == BBB_P8_16_2_IDX) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_GPMC_AD14) = pin_mode | BBB_MUXMODE(BBB_P8_16_MUX_QEP);
> +    } else if (pin_no == BBB_P8_39_2_IDX) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA6) = pin_mode | BBB_MUXMODE(BBB_P8_39_MUX_QEP);
> +    } else if (pin_no == BBB_P8_40_2_STROBE) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA7) = pin_mode | BBB_MUXMODE(BBB_P8_40_MUX_QEP);
> +    } else if (pin_no == BBB_P8_41_2A_IN) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA4) = pin_mode | BBB_MUXMODE(BBB_P8_41_MUX_QEP);
> +    } else if (pin_no == BBB_P8_42_2B_IN) {
> +      REG(AM335X_PADCONF_BASE + AM335X_CONF_LCD_DATA5) = pin_mode | BBB_MUXMODE(BBB_P8_42_MUX_QEP);
> +    } else {
> +  } else {
> +  return result;
> +  int32_t position = 0;
> +    return -1;
> +  if (eqep->quadrature_mode == ABSOLUTE) {
> +    /* return the current value of the QPOSCNT register */
> +    position = REG(eqep->mmio_base + AM335x_EQEP_QPOSCNT);
> +  } else if (eqep->quadrature_mode == RELATIVE) {
> +    /* return the latched value from the last unit timer interrupt */
> +    position = REG(eqep->mmio_base + AM335x_EQEP_QPOSLAT);
> +  return position;
> +rtems_status_code beagle_qep_set_position(BBB_PWMSS pwmss_id, uint32_t position)
> +  /* setting the position only really makes sense in ABSOLUTE mode. */
> +    REG(eqep->mmio_base + AM335x_EQEP_QPOSCNT) = position;
> +  eqep->count_mode = mode;
> +  return eqep->count_mode;
> +  uint16_t qepctl;
> +  qepctl = REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL);
> +  if (mode == ABSOLUTE) {
> +     * Disable the unit timer position reset
> +    qepctl &= ~AM335x_EQEP_QEPCTL_PCRM;
> +    eqep->quadrature_mode = ABSOLUTE;
> +  } else if (mode == RELATIVE) {
> +     *  enable the unit timer position reset
> +    qepctl |= AM335x_EQEP_QEPCTL_PCRM;
> +    eqep->quadrature_mode = RELATIVE;
> +  REG16(eqep->mmio_base + AM335x_EQEP_QEPCTL) = qepctl;
> +    return -1;
> +  return eqep->quadrature_mode;
> +/* Function to read the period of the unit time event timer */
> +  uint64_t period;
> +  uint32_t timer_period;
> +    return -1;
> +  /* Convert from counts per interrupt back into period_ns */
> +  period = REG(eqep->mmio_base + AM335x_EQEP_QUPRD);
> +  period = period * NANO_SEC_PER_SEC;
> +  timer_period = (uint32_t)(period / SYSCLKOUT);
> +  return timer_period;
> +    uint64_t period,
> +  uint16_t qepctl;
> +  uint64_t tmp_period;
> +  /* Disable the unit timer before modifying its period register */
> +  qepctl = readw(eqep->mmio_base + AM335x_EQEP_QEPCTL);
> +  qepctl &= ~(AM335x_EQEP_QEPCTL_UTE | AM335x_EQEP_QEPCTL_QCLM);
> +  /* Zero the unit timer counter register */
> +  REG(eqep->mmio_base + AM335x_EQEP_QUTMR) = 0;
> +  /* If the timer is enabled (a non-zero period has been passed) */
> +  if (period) {
> +    /* update the period */
> +    tmp_period = period * SYSCLKOUT;
> +    timer_period = (uint32_t)(tmp_period / NANO_SEC_PER_SEC);
> +    REG(eqep->mmio_base + AM335x_EQEP_QUPRD) = timer_period;
> +    /* Enable unit timer, and latch QPOSLAT to QPOSCNT on timer expiration */
> +    qepctl |= AM335x_EQEP_QEPCTL_UTE | AM335x_EQEP_QEPCTL_QCLM;
> +    /* attach the unit timer interrupt handler if one has been supplied */
> +    if (timer_callback != NULL) {
> +      eqep->timer_callback = timer_callback;
> diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
> index e37472373c..c9492f41a1 100644
> --- a/c/src/lib/libbsp/arm/beagle/Makefile.am
> +++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
> @@ -76,9 +76,15 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/spi/spi.c
>  # GPIO
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/gpio/bbb-gpio.c
> +#pwmss shared
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/pwmss/pwmss.c
>  #pwm
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/pwm/pwm.c
> +#qep
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/qep/qep.c
>  #RTC
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/rtc/rtc.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/rtc/rtc-support.c
