[PATCH 6/7] score: Add stack free handler to TCB
Fri Aug 21 11:51:02 UTC 2020
This avoids a dependency to the stack free function in the thread
destruction.
Update #3959.
 cpukit/Makefile.am                           |  1 +
 cpukit/include/rtems/score/stackimpl.h       |  7 +++
 cpukit/include/rtems/score/thread.h          |  5 +--
 cpukit/include/rtems/score/threadimpl.h      |  6 ++-
 cpukit/posix/src/pthreadcreate.c             |  4 +-
 cpukit/rtems/src/taskcreate.c                |  2 +-
 cpukit/score/src/stackallocatorfreenothing.c | 45 ++++++++++++++++++++
 cpukit/score/src/threadinitialize.c          | 30 ++++++-------
 cpukit/score/src/threadrestart.c             |  2 +-
 9 files changed, 78 insertions(+), 24 deletions(-)
 create mode 100644 cpukit/score/src/stackallocatorfreenothing.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 54e558b4b4..bc56822cf8 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -932,6 +932,7 @@ librtemscpu_a_SOURCES += score/src/schedulercbsreleasejob.c
 librtemscpu_a_SOURCES += score/src/schedulercbsunblock.c
 librtemscpu_a_SOURCES += score/src/stackallocator.c
 librtemscpu_a_SOURCES += score/src/stackallocatorfree.c
+librtemscpu_a_SOURCES += score/src/stackallocatorfreenothing.c
 librtemscpu_a_SOURCES += score/src/stackallocatorinit.c
 librtemscpu_a_SOURCES += score/src/pheapallocate.c
 librtemscpu_a_SOURCES += score/src/pheapextend.c
diff --git a/cpukit/include/rtems/score/stackimpl.h b/cpukit/include/rtems/score/stackimpl.h
index 305c4e4e51..df9f87d5a3 100644
--- a/cpukit/include/rtems/score/stackimpl.h
+++ b/cpukit/include/rtems/score/stackimpl.h
@@ -166,6 +166,13 @@ void *_Stack_Allocate( size_t stack_size );
 void _Stack_Free( void *stack_area );
+ * @brief This function does nothing.
+ * @param stack_area is not used.
+void _Stack_Free_nothing( void *stack_area );
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index ee0aee5b79..1daf6143f9 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -194,10 +194,9 @@ typedef struct {
   /** This field is the initial priority. */
   Priority_Control                     initial_priority;
-   * @brief This field is a pointer to the allocated stack area, otherwise it
-   * is NULL.
+   * @brief This field points to the handler which should free the stack.
-  void                                *allocated_stack;
+  void                              ( *stack_free )( void * );
   /** This field is the stack information. */
   Stack_Control                        Initial_stack;
   #if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 0b69caf962..61454eb7fe 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -144,9 +144,11 @@ typedef struct {
   size_t stack_size;
-   * @brief The address of the allocated stack area or NULL.
+   * @brief This member contains the handler to free the stack.
+   * It shall not be NULL.  Use _Stack_Free_nothing() if nothing is to free.
    * @brief The new thread's priority.
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index d431c64a3e..33c5f8d03a 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -218,8 +218,10 @@ int pthread_create(
   if ( config.stack_area == NULL ) {
+    config.stack_free = _Stack_Free;
     config.stack_area = _Stack_Allocate( config.stack_size );
-    config.allocated_stack = config.stack_area;
+  } else {
+    config.stack_free = _Stack_Free_nothing;
   status = ( config.stack_area != NULL );
diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
index b430d3c705..5486ac9b6e 100644
--- a/cpukit/rtems/src/taskcreate.c
+++ b/cpukit/rtems/src/taskcreate.c
@@ -146,8 +146,8 @@ rtems_status_code rtems_task_create(
 #endif
diff --git a/cpukit/score/src/stackallocatorfreenothing.c b/cpukit/score/src/stackallocatorfreenothing.c
new file mode 100644
index 0000000000..b469f650b6
--- /dev/null
+++ b/cpukit/score/src/stackallocatorfreenothing.c
@@ -0,0 +1,45 @@
+ * @file
+ * @ingroup RTEMSScoreStack
+ * @brief _Stack_Free_nothing() Implementation
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/stackimpl.h>
+  (void) stack_area;
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 4872f84950..4a74426498 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -36,8 +36,8 @@ bool _Thread_Initialize(
   uintptr_t                tls_size;
   bool                     extension_status;
   size_t                   i;
-  char                    *stack_area;
-  size_t                   stack_size;
+  char                    *stack_begin;
+  char                    *stack_end;
   Scheduler_Node          *scheduler_node;
 #if defined(RTEMS_SMP)
   Scheduler_Node          *scheduler_node_for_index;
@@ -61,7 +61,7 @@ bool _Thread_Initialize(
   /* Set everything to perform the error case clean up */
   scheduler_index = 0;
-  the_thread->Start.allocated_stack = config->allocated_stack;
+  the_thread->Start.stack_free = config->stack_free;
   if (
@@ -83,16 +83,15 @@ bool _Thread_Initialize(
 #endif
-  stack_area = config->stack_area;
-  stack_size = config->stack_size;
+  stack_begin = config->stack_area;
+  stack_end = stack_begin + config->stack_size;
   /* Allocate floating-point context in stack area */
   if ( config->is_fp ) {
-    the_thread->fp_context = ( Context_Control_fp *) stack_area;
-    the_thread->Start.fp_context = ( Context_Control_fp *) stack_area;
-    stack_size -= CONTEXT_FP_SIZE;
-    stack_area += CONTEXT_FP_SIZE;
+    stack_end -= CONTEXT_FP_SIZE;
+    the_thread->fp_context = (Context_Control_fp *) stack_end;
+    the_thread->Start.fp_context = (Context_Control_fp *) stack_end;
 #endif
@@ -102,17 +101,16 @@ bool _Thread_Initialize(
   if ( tls_size > 0 ) {
     uintptr_t tls_align;
+    stack_end -= tls_size;
     tls_align = (uintptr_t) _TLS_Alignment;
     the_thread->Start.tls_area = (void *)
-      ( ( (uintptr_t) stack_area + tls_align - 1 ) & ~( tls_align - 1 ) );
-    stack_size -= tls_size;
-    stack_area += tls_size;
+      ( ( (uintptr_t) stack_end + tls_align - 1 ) & ~( tls_align - 1 ) );
   _Stack_Initialize(
-     &the_thread->Start.Initial_stack,
-     stack_area,
-     stack_size
+    &the_thread->Start.Initial_stack,
+    stack_begin,
+    stack_end - stack_begin
@@ -279,6 +277,6 @@ failed:
     &information->Thread_queue_heads.Free,
     the_thread->Wait.spare_heads
-  _Stack_Free( the_thread->Start.allocated_stack );
+  ( *the_thread->Start.stack_free )( the_thread->Start.Initial_stack.area );
   return false;
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 6a035ada90..fcae5b1e3c 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -185,7 +185,7 @@ static void _Thread_Free( Thread_Control *the_thread )
    *  Free the rest of the memory associated with this task
    *  and set the associated pointers to NULL for safety.
   _ISR_lock_Destroy( &the_thread->Scheduler.Lock );
2.26.2
