[PATCH 7/7] rtems: Add rtems_task_build()
Sebastian Huber
Fri Aug 21 11:51:03 UTC 2020
In contrast to rtems_task_create() this function creates a task with a
user-provided task storage area.
Close #3959.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/rtems/tasks.h | 65 ++++++
cpukit/include/rtems/rtems/tasksimpl.h | 11 +
cpukit/rtems/src/taskbuild.c | 273 ++++++++++++++++++++++++
cpukit/rtems/src/taskcreate.c | 274 +++++--------------------
testsuites/sptests/sp01/init.c | 22 +-
testsuites/sptests/sp01/sp01.doc | 1 +
testsuites/sptests/sp01/system.h | 2 +-
8 files changed, 413 insertions(+), 236 deletions(-)
create mode 100644 cpukit/rtems/src/taskbuild.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index bc56822cf8..e382478eac 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -785,6 +785,7 @@ librtemscpu_a_SOURCES += rtems/src/statustext.c
librtemscpu_a_SOURCES += rtems/src/statustoerrno.c
librtemscpu_a_SOURCES += rtems/src/systemeventreceive.c
librtemscpu_a_SOURCES += rtems/src/systemeventsend.c
+librtemscpu_a_SOURCES += rtems/src/taskbuild.c
librtemscpu_a_SOURCES += rtems/src/taskcreate.c
librtemscpu_a_SOURCES += rtems/src/taskdelete.c
librtemscpu_a_SOURCES += rtems/src/taskexit.c
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 12c323e60e..dff811686a 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -164,6 +164,71 @@ rtems_status_code rtems_task_create(
rtems_id *id
+ * @brief This structure defines the configuration of a task to build with
+ * rtems_task_build().
+typedef struct {
+ * @brief This member defines the name of the task.
+ rtems_name name;
+ * @brief This member defines initial priority of the task.
+ rtems_task_priority initial_priority;
+ * @brief This member shall point to the task storage area begin.
+ * The task storage area will contain the task stack, the thread-local
+ * storage, and, on some architectures, the floating-point context.
+ void *storage_area;
+ * @brief This member defines size of the task storage area in bytes.
+ size_t storage_size;
+ * @brief This member defines the optional handler to free the task storage
+ * area.
+ * It may be NULL.
+ void ( *storage_free )( void * );
+ * @brief This member defines the initial modes of the task.
+ rtems_mode initial_modes;
+ * @brief This member defines the attributes of the task.
+ rtems_attribute attributes;
+} rtems_task_config;
+ * @brief Builds a task according to the specified configuration.
+ * @param config The task configuration.
+ * @param[out] id The task identifier of the new task.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ADDRESS The id parameter is @c NULL.
+ * @retval RTEMS_INVALID_NAME The task name is invalid.
+ * @retval RTEMS_INVALID_PRIORITY The initial priority of the task is invalid.
+ * @retval RTEMS_TOO_MANY No task is available.
+ * @retval RTEMS_UNSATISFIED A task create extension failed.
+rtems_status_code rtems_task_build(
+ const rtems_task_config *config,
+ rtems_id *id
* @brief RTEMS Task Name to Id
diff --git a/cpukit/include/rtems/rtems/tasksimpl.h b/cpukit/include/rtems/rtems/tasksimpl.h
index c9544f8c27..b1c1f38899 100644
--- a/cpukit/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/include/rtems/rtems/tasksimpl.h
@@ -42,6 +42,17 @@ extern "C" {
void _RTEMS_tasks_Initialize_user_tasks( void );
+typedef void ( *RTEMS_tasks_Prepare_stack )(
+ Thread_Configuration *,
+rtems_status_code _RTEMS_tasks_Build(
+ rtems_id *id,
+ RTEMS_tasks_Prepare_stack prepare_stack
RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
_Objects_Allocator_lock();
diff --git a/cpukit/rtems/src/taskbuild.c b/cpukit/rtems/src/taskbuild.c
new file mode 100644
index 0000000000..28f9f536f6
--- /dev/null
+++ b/cpukit/rtems/src/taskbuild.c
@@ -0,0 +1,273 @@
+ * @file
+ * @brief RTEMS Task Create
+ * @ingroup ClassicTasks
+ * COPYRIGHT (c) 1989-2014,2016.
+ * On-Line Applications Research Corporation (OAR).
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/tasksimpl.h>
+#include <rtems/rtems/attrimpl.h>
+#include <rtems/rtems/eventimpl.h>
+#include <rtems/rtems/modesimpl.h>
+#include <rtems/rtems/support.h>
+#include <rtems/score/apimutex.h>
+#include <rtems/score/schedulerimpl.h>
+#include <rtems/score/stackimpl.h>
+#include <rtems/score/sysstate.h>
+#include <rtems/score/threadimpl.h>
+#include <rtems/score/userextimpl.h>
+#include <rtems/sysinit.h>
+#include <string.h>
+static void _RTEMS_tasks_Prepare_user_stack(
+ Thread_Configuration *thread_config,
+ thread_config->stack_size = config->storage_size;
+ thread_config->stack_area = config->storage_area;
+ if ( config->storage_free != NULL ) {
+ thread_config->stack_free = config->storage_free;
+ } else {
+ thread_config->stack_free = _Stack_Free_nothing;
+ rtems_id *id
+ return _RTEMS_tasks_Build( config, id, _RTEMS_tasks_Prepare_user_stack );
+ rtems_id *id,
+ Thread_Control *the_thread;
+ Thread_Configuration thread_config;
+#if defined(RTEMS_MULTIPROCESSING)
+ Objects_MP_Control *the_global_object = NULL;
+ bool is_global;
+#endif
+ bool status;
+ bool valid;
+ RTEMS_API_Control *api;
+ ASR_Information *asr;
+ if ( !id )
+ return RTEMS_INVALID_ADDRESS;
+ if ( !rtems_is_name_valid( config->name ) )
+ return RTEMS_INVALID_NAME;
+ * Core Thread Initialize insures we get the minimum amount of
+ * stack space.
+ * Fix the attribute set to match the attributes which
+ * this processor (1) requires and (2) is able to support.
+ * First add in the required flags for attributes
+ * Typically this might include FP if the platform
+ * or application required all tasks to be fp aware.
+ * Then turn off the requested bits which are not supported.
+ attributes = _Attributes_Set( config->attributes, ATTRIBUTES_REQUIRED );
+ attributes = _Attributes_Clear( attributes, ATTRIBUTES_NOT_SUPPORTED );
+ memset( &thread_config, 0, sizeof( thread_config ) );
+ thread_config.budget_algorithm = _Modes_Is_timeslice( config->initial_modes ) ?
+ THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE
+ : THREAD_CPU_BUDGET_ALGORITHM_NONE,
+ thread_config.isr_level = _Modes_Get_interrupt_level( config->initial_modes );
+ thread_config.name.name_u32 = config->name;
+ thread_config.is_fp = _Attributes_Is_floating_point( attributes );
+ thread_config.is_preemptible = _Modes_Is_preempt( config->initial_modes );
+ * Validate the RTEMS API priority and convert it to the core priority range.
+ if ( !_Attributes_Is_system_task( attributes ) ) {
+ if ( config->initial_priority == PRIORITY_MINIMUM ) {
+ return RTEMS_INVALID_PRIORITY;
+ thread_config.scheduler =
+ _Thread_Scheduler_get_home( _Thread_Get_executing() );
+ thread_config.priority = _RTEMS_Priority_To_core(
+ thread_config.scheduler,
+ config->initial_priority,
+ &valid
+ if ( !valid ) {
+ if ( !_System_state_Is_multiprocessing ) {
+ attributes = _Attributes_Clear( attributes, RTEMS_GLOBAL );
+ is_global = _Attributes_Is_global( attributes );
+#endif
+ * Allocate the thread control block and -- if the task is global --
+ * allocate a global object control block.
+ * NOTE: This routine does not use the combined allocate and open
+ * global object routine (_Objects_MP_Allocate_and_open) because
+ * this results in a lack of control over when memory is allocated
+ * and can be freed in the event of an error.
+ the_thread = _RTEMS_tasks_Allocate();
+ if ( !the_thread ) {
+ _Objects_Allocator_unlock();
+ return RTEMS_TOO_MANY;
+ if ( is_global ) {
+ the_global_object = _Objects_MP_Allocate_global_object();
+ if ( _Objects_MP_Is_null_global_object( the_global_object ) ) {
+ _RTEMS_tasks_Free( the_thread );
+#endif
+ ( *prepare_stack )( &thread_config, config );
+ status = ( thread_config.stack_area != NULL );
+ * Initialize the core thread for this task.
+ if ( status ) {
+ status = _Thread_Initialize(
+ &_RTEMS_tasks_Information,
+ the_thread,
+ &thread_config
+ if ( !status ) {
+ if ( is_global )
+ _Objects_MP_Free_global_object( the_global_object );
+#endif
+ return RTEMS_UNSATISFIED;
+ api = the_thread->API_Extensions[ THREAD_API_RTEMS ];
+ asr = &api->Signal;
+ asr->is_enabled = !_Modes_Is_asr_disabled( config->initial_modes );
+ *id = the_thread->Object.id;
+ the_thread->is_global = is_global;
+ _Objects_MP_Open(
+ &_RTEMS_tasks_Information.Objects,
+ the_global_object,
+ config->name,
+ the_thread->Object.id
+ _RTEMS_tasks_MP_Send_process_packet(
+ RTEMS_TASKS_MP_ANNOUNCE_CREATE,
+ the_thread->Object.id,
+ config->name
+#endif
+ return RTEMS_SUCCESSFUL;
+static void _RTEMS_tasks_Start_extension(
+ Thread_Control *executing,
+ Thread_Control *started
+ api = started->API_Extensions[ THREAD_API_RTEMS ];
+ _Event_Initialize( &api->Event );
+ _Event_Initialize( &api->System_event );
+static void _RTEMS_tasks_Terminate_extension( Thread_Control *executing )
+ if ( executing->is_global ) {
+ _Objects_MP_Close(
+ executing->Object.id
+ RTEMS_TASKS_MP_ANNOUNCE_DELETE,
+ executing->Object.id,
+ 0 /* Not used */
+#endif
+static User_extensions_Control _RTEMS_tasks_User_extensions = {
+ .Callouts = {
+ .thread_terminate = _RTEMS_tasks_Terminate_extension,
+#endif
+ .thread_start = _RTEMS_tasks_Start_extension,
+ .thread_restart = _RTEMS_tasks_Start_extension
+static void _RTEMS_tasks_Manager_initialization( void )
+ _Thread_Initialize_information( &_RTEMS_tasks_Information );
+ _User_extensions_Add_API_set( &_RTEMS_tasks_User_extensions );
+RTEMS_SYSINIT_ITEM(
+ _RTEMS_tasks_Manager_initialization,
+ RTEMS_SYSINIT_CLASSIC_TASKS,
+ RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
index 5486ac9b6e..3a0badf285 100644
--- a/cpukit/rtems/src/taskcreate.c
+++ b/cpukit/rtems/src/taskcreate.c
@@ -1,17 +1,36 @@
- * @file
+ * @file
- * @brief RTEMS Task Create
- * @ingroup ClassicTasks
- * COPYRIGHT (c) 1989-2014,2016.
- * On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
@@ -19,20 +38,24 @@
#endif
-#include <rtems/rtems/attrimpl.h>
-#include <rtems/rtems/eventimpl.h>
-#include <rtems/rtems/modesimpl.h>
-#include <rtems/rtems/support.h>
-#include <rtems/score/apimutex.h>
-#include <rtems/score/schedulerimpl.h>
-#include <rtems/score/sysstate.h>
-#include <rtems/score/threadimpl.h>
-#include <rtems/score/userextimpl.h>
-#include <rtems/sysinit.h>
+static void _RTEMS_tasks_Allocate_and_prepare_stack(
+ size_t size;
+ thread_config->stack_free = _Stack_Free;
+ size = _Stack_Ensure_minimum( config->storage_size );
+ size = _Stack_Extend_size( size, thread_config->is_fp );
+ thread_config->stack_size = size;
+ thread_config->stack_area = _Stack_Allocate( size );
rtems_name name,
rtems_task_priority initial_priority,
@@ -42,215 +65,14 @@ rtems_status_code rtems_task_create(
rtems_id *id
- Thread_Control *the_thread;
- Thread_Configuration config;
-#if defined(RTEMS_MULTIPROCESSING)
- Objects_MP_Control *the_global_object = NULL;
- bool is_global;
-#endif
- bool status;
- rtems_attribute the_attribute_set;
- bool valid;
- RTEMS_API_Control *api;
- ASR_Information *asr;
- if ( !id )
- return RTEMS_INVALID_ADDRESS;
- if ( !rtems_is_name_valid( name ) )
- return RTEMS_INVALID_NAME;
- * Core Thread Initialize insures we get the minimum amount of
- * stack space.
- * Fix the attribute set to match the attributes which
- * this processor (1) requires and (2) is able to support.
- * First add in the required flags for attribute_set
- * Typically this might include FP if the platform
- * or application required all tasks to be fp aware.
- * Then turn off the requested bits which are not supported.
- the_attribute_set = _Attributes_Set( attribute_set, ATTRIBUTES_REQUIRED );
- _Attributes_Clear( the_attribute_set, ATTRIBUTES_NOT_SUPPORTED );
+ rtems_task_config config;
memset( &config, 0, sizeof( config ) );
- config.budget_algorithm = _Modes_Is_timeslice( initial_modes ) ?
- THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE
- : THREAD_CPU_BUDGET_ALGORITHM_NONE,
- config.isr_level = _Modes_Get_interrupt_level( initial_modes );
- config.name.name_u32 = name;
- config.is_fp = _Attributes_Is_floating_point( the_attribute_set );
- config.is_preemptible = _Modes_Is_preempt( initial_modes );
- config.stack_size = _Stack_Ensure_minimum( stack_size );
- config.stack_size = _Stack_Extend_size( config.stack_size, config.is_fp );
- * Validate the RTEMS API priority and convert it to the core priority range.
- if ( !_Attributes_Is_system_task( the_attribute_set ) ) {
- if ( initial_priority == PRIORITY_MINIMUM ) {
- return RTEMS_INVALID_PRIORITY;
- config.scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing() );
- config.priority = _RTEMS_Priority_To_core(
- config.scheduler,
- initial_priority,
- &valid
- if ( !valid ) {
- if ( !_System_state_Is_multiprocessing ) {
- the_attribute_set = _Attributes_Clear( the_attribute_set, RTEMS_GLOBAL );
- is_global = _Attributes_Is_global( the_attribute_set );
-#endif
- * Allocate the thread control block and -- if the task is global --
- * allocate a global object control block.
- * NOTE: This routine does not use the combined allocate and open
- * global object routine (_Objects_MP_Allocate_and_open) because
- * this results in a lack of control over when memory is allocated
- * and can be freed in the event of an error.
- the_thread = _RTEMS_tasks_Allocate();
- if ( !the_thread ) {
- _Objects_Allocator_unlock();
- return RTEMS_TOO_MANY;
- if ( is_global ) {
- the_global_object = _Objects_MP_Allocate_global_object();
- if ( _Objects_MP_Is_null_global_object( the_global_object ) ) {
- _RTEMS_tasks_Free( the_thread );
-#endif
- config.stack_free = _Stack_Free;
- config.stack_area = _Stack_Allocate( config.stack_size );
- status = ( config.stack_area != NULL );
- * Initialize the core thread for this task.
+ config.name = name;
+ config.initial_priority = initial_priority;
+ config.storage_size = stack_size;
+ config.initial_modes = initial_modes;
+ config.attributes = attribute_set;
- if ( status ) {
- status = _Thread_Initialize(
- &_RTEMS_tasks_Information,
- the_thread,
- &config
- if ( !status ) {
- if ( is_global )
- _Objects_MP_Free_global_object( the_global_object );
-#endif
- return RTEMS_UNSATISFIED;
- api = the_thread->API_Extensions[ THREAD_API_RTEMS ];
- asr = &api->Signal;
- asr->is_enabled = _Modes_Is_asr_disabled(initial_modes) ? false : true;
- *id = the_thread->Object.id;
- the_thread->is_global = is_global;
- _Objects_MP_Open(
- &_RTEMS_tasks_Information.Objects,
- the_global_object,
- name,
- the_thread->Object.id
- _RTEMS_tasks_MP_Send_process_packet(
- RTEMS_TASKS_MP_ANNOUNCE_CREATE,
- the_thread->Object.id,
- name
-#endif
- return RTEMS_SUCCESSFUL;
+ return _RTEMS_tasks_Build( &config, id, _RTEMS_tasks_Allocate_and_prepare_stack );
-static void _RTEMS_tasks_Start_extension(
- Thread_Control *executing,
- Thread_Control *started
- api = started->API_Extensions[ THREAD_API_RTEMS ];
- _Event_Initialize( &api->Event );
- _Event_Initialize( &api->System_event );
-static void _RTEMS_tasks_Terminate_extension( Thread_Control *executing )
- if ( executing->is_global ) {
- _Objects_MP_Close(
- executing->Object.id
- RTEMS_TASKS_MP_ANNOUNCE_DELETE,
- executing->Object.id,
- 0 /* Not used */
-#endif
-static User_extensions_Control _RTEMS_tasks_User_extensions = {
- .Callouts = {
- .thread_terminate = _RTEMS_tasks_Terminate_extension,
-#endif
- .thread_start = _RTEMS_tasks_Start_extension,
- .thread_restart = _RTEMS_tasks_Start_extension
-static void _RTEMS_tasks_Manager_initialization( void )
- _Thread_Initialize_information( &_RTEMS_tasks_Information );
- _User_extensions_Add_API_set( &_RTEMS_tasks_User_extensions );
-RTEMS_SYSINIT_ITEM(
- _RTEMS_tasks_Manager_initialization,
- RTEMS_SYSINIT_CLASSIC_TASKS,
- RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/testsuites/sptests/sp01/init.c b/testsuites/sptests/sp01/init.c
index 2719c84fc8..f25300e5bb 100644
--- a/testsuites/sptests/sp01/init.c
+++ b/testsuites/sptests/sp01/init.c
@@ -16,6 +16,17 @@
const char rtems_test_name[] = "SP 1";
+static char Task_1_storage[ 2 * RTEMS_MINIMUM_STACK_SIZE ];
+static const rtems_task_config Task_1_config = {
+ .name = rtems_build_name( 'T', 'A', '1', ' ' ),
+ .initial_priority = 1,
+ .storage_area = Task_1_storage,
+ .storage_size = sizeof( Task_1_storage ),
+ .initial_modes = RTEMS_DEFAULT_MODES,
+ .attributes = RTEMS_DEFAULT_ATTRIBUTES
rtems_task Init(
rtems_task_argument argument
@@ -30,15 +41,8 @@ rtems_task Init(
status = rtems_clock_set( &time );
directive_failed( status, "rtems_clock_set" );
- status = rtems_task_create(
- rtems_build_name( 'T', 'A', '1', ' ' ),
- 1,
- RTEMS_MINIMUM_STACK_SIZE * 2,
- RTEMS_DEFAULT_MODES,
- RTEMS_DEFAULT_ATTRIBUTES,
- &id
- directive_failed( status, "rtems_task_create of TA1" );
+ status = rtems_task_build( &Task_1_config, &id );
+ directive_failed( status, "rtems_task_build of TA1" );
status = rtems_task_start( id, Task_1_through_3, 1 );
directive_failed( status, "rtems_task_start of TA1" );
diff --git a/testsuites/sptests/sp01/sp01.doc b/testsuites/sptests/sp01/sp01.doc
index d7d9f5d902..62bbe956d3 100644
--- a/testsuites/sptests/sp01/sp01.doc
+++ b/testsuites/sptests/sp01/sp01.doc
@@ -9,6 +9,7 @@
test name: sp01
directives:
+ rtems_task_build
rtems_task_create
rtems_task_start
rtems_task_wake_after
diff --git a/testsuites/sptests/sp01/system.h b/testsuites/sptests/sp01/system.h
index bde5328aa9..e2047b4d3a 100644
--- a/testsuites/sptests/sp01/system.h
+++ b/testsuites/sptests/sp01/system.h
@@ -28,7 +28,7 @@ rtems_task Task_1_through_3(
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_EXTRA_TASK_STACKS (4 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_EXTRA_TASK_STACKS (2 * RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_MAXIMUM_TASKS 4
#include <rtems/confdefs.h>
2.26.2
