[PATCH 7/7] rtems: Add rtems_task_build()
Sat Aug 22 07:49:24 UTC 2020
On 21/8/20 9:51 pm, Sebastian Huber wrote:
> In contrast to rtems_task_create() this function creates a task with a
> user-provided task storage area.
The name is build but it creates a task? I am wondering about
rtems_task_create_static or something along this line?
> Close #3959.
Sorry, I had not read the ticket's details.
>  cpukit/Makefile.am                     |   1 +
>  cpukit/include/rtems/rtems/tasks.h     |  65 ++++++
>  cpukit/include/rtems/rtems/tasksimpl.h |  11 +
>  cpukit/rtems/src/taskbuild.c           | 273 ++++++++++++++++++++++++
>  cpukit/rtems/src/taskcreate.c          | 274 +++++--------------------
>  testsuites/sptests/sp01/init.c         |  22 +-
>  testsuites/sptests/sp01/sp01.doc       |   1 +
>  testsuites/sptests/sp01/system.h       |   2 +-
>  8 files changed, 413 insertions(+), 236 deletions(-)
>  create mode 100644 cpukit/rtems/src/taskbuild.c
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index bc56822cf8..e382478eac 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -785,6 +785,7 @@ librtemscpu_a_SOURCES += rtems/src/statustext.c
>  librtemscpu_a_SOURCES += rtems/src/statustoerrno.c
>  librtemscpu_a_SOURCES += rtems/src/systemeventreceive.c
>  librtemscpu_a_SOURCES += rtems/src/systemeventsend.c
> +librtemscpu_a_SOURCES += rtems/src/taskbuild.c
>  librtemscpu_a_SOURCES += rtems/src/taskcreate.c
>  librtemscpu_a_SOURCES += rtems/src/taskdelete.c
>  librtemscpu_a_SOURCES += rtems/src/taskexit.c
> diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
> index 12c323e60e..dff811686a 100644
> --- a/cpukit/include/rtems/rtems/tasks.h
> +++ b/cpukit/include/rtems/rtems/tasks.h
> @@ -164,6 +164,71 @@ rtems_status_code rtems_task_create(
>    rtems_id            *id
> + * @brief This structure defines the configuration of a task to build with
> + *   rtems_task_build().
> +typedef struct {
> +   * @brief This member defines the name of the task.
> +  rtems_name name;
> +   * @brief This member defines initial priority of the task.
> +  rtems_task_priority initial_priority;
> +   * @brief This member shall point to the task storage area begin.
> +   * The task storage area will contain the task stack, the thread-local
> +   * storage, and, on some architectures, the floating-point context.
> +  void *storage_area;
> +   * @brief This member defines size of the task storage area in bytes.
> +  size_t storage_size;
> +   * @brief This member defines the optional handler to free the task storage
> +   *   area.
> +   * It may be NULL.
> +  void ( *storage_free )( void * );
Called under what context? What can this call do? For example call the standard
heap allocator.
> +   * @brief This member defines the initial modes of the task.
> +  rtems_mode initial_modes;
> +   * @brief This member defines the attributes of the task.
> +  rtems_attribute attributes;
> +} rtems_task_config;
> + * @brief Builds a task according to the specified configuration.
> + * @param config The task configuration.
> + * @param[out] id The task identifier of the new task.
> + * @retval RTEMS_SUCCESSFUL Successful operation.
> + * @retval RTEMS_INVALID_ADDRESS The id parameter is @c NULL.
> + * @retval RTEMS_INVALID_NAME The task name is invalid.
> + * @retval RTEMS_INVALID_PRIORITY The initial priority of the task is invalid.
> + * @retval RTEMS_TOO_MANY No task is available.
> + * @retval RTEMS_UNSATISFIED A task create extension failed.
> +rtems_status_code rtems_task_build(
> +  const rtems_task_config *config,
> +  rtems_id                *id
>   * @brief RTEMS Task Name to Id
> diff --git a/cpukit/include/rtems/rtems/tasksimpl.h b/cpukit/include/rtems/rtems/tasksimpl.h
> index c9544f8c27..b1c1f38899 100644
> --- a/cpukit/include/rtems/rtems/tasksimpl.h
> +++ b/cpukit/include/rtems/rtems/tasksimpl.h
> @@ -42,6 +42,17 @@ extern "C" {
>  void _RTEMS_tasks_Initialize_user_tasks( void );
> +typedef void ( *RTEMS_tasks_Prepare_stack )(
> +  Thread_Configuration *,
> +rtems_status_code _RTEMS_tasks_Build(
> +  rtems_id                  *id,
> +  RTEMS_tasks_Prepare_stack  prepare_stack
>  RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
>    _Objects_Allocator_lock();
> diff --git a/cpukit/rtems/src/taskbuild.c b/cpukit/rtems/src/taskbuild.c
> new file mode 100644
> index 0000000000..28f9f536f6
> --- /dev/null
> +++ b/cpukit/rtems/src/taskbuild.c
> @@ -0,0 +1,273 @@
> + *  @file
> + *  @brief RTEMS Task Create
> + *  @ingroup ClassicTasks
> + *  COPYRIGHT (c) 1989-2014,2016.
> + *  On-Line Applications Research Corporation (OAR).
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/rtems/tasksimpl.h>
> +#include <rtems/rtems/attrimpl.h>
> +#include <rtems/rtems/eventimpl.h>
> +#include <rtems/rtems/modesimpl.h>
> +#include <rtems/rtems/support.h>
> +#include <rtems/score/apimutex.h>
> +#include <rtems/score/schedulerimpl.h>
> +#include <rtems/score/stackimpl.h>
> +#include <rtems/score/sysstate.h>
> +#include <rtems/score/threadimpl.h>
> +#include <rtems/score/userextimpl.h>
> +#include <rtems/sysinit.h>
> +#include <string.h>
> +static void _RTEMS_tasks_Prepare_user_stack(
> +  Thread_Configuration    *thread_config,
> +  thread_config->stack_size = config->storage_size;
> +  thread_config->stack_area = config->storage_area;
> +  if ( config->storage_free != NULL ) {
> +    thread_config->stack_free = config->storage_free;
> +  } else {
> +    thread_config->stack_free = _Stack_Free_nothing;
> +  rtems_id                *id
> +  return _RTEMS_tasks_Build( config, id, _RTEMS_tasks_Prepare_user_stack );
> +  rtems_id                  *id,
> +  Thread_Control          *the_thread;
> +  Thread_Configuration     thread_config;
> +#if defined(RTEMS_MULTIPROCESSING)
> +  Objects_MP_Control      *the_global_object = NULL;
> +  bool                     is_global;
> +#endif
> +  bool                     status;
> +  bool                     valid;
> +  RTEMS_API_Control       *api;
> +  ASR_Information         *asr;
> +  if ( !id )
> +   return RTEMS_INVALID_ADDRESS;
> +  if ( !rtems_is_name_valid( config->name ) )
> +    return RTEMS_INVALID_NAME;
> +   *  Core Thread Initialize insures we get the minimum amount of
> +   *  stack space.
> +   *  Fix the attribute set to match the attributes which
> +   *  this processor (1) requires and (2) is able to support.
> +   *  First add in the required flags for attributes
> +   *  Typically this might include FP if the platform
> +   *  or application required all tasks to be fp aware.
> +   *  Then turn off the requested bits which are not supported.
> +  attributes = _Attributes_Set( config->attributes, ATTRIBUTES_REQUIRED );
> +  attributes = _Attributes_Clear( attributes, ATTRIBUTES_NOT_SUPPORTED );
> +  memset( &thread_config, 0, sizeof( thread_config ) );
> +  thread_config.budget_algorithm = _Modes_Is_timeslice( config->initial_modes ) ?
> +    THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE
> +      : THREAD_CPU_BUDGET_ALGORITHM_NONE,
> +  thread_config.isr_level =  _Modes_Get_interrupt_level( config->initial_modes );
> +  thread_config.name.name_u32 = config->name;
> +  thread_config.is_fp = _Attributes_Is_floating_point( attributes );
> +  thread_config.is_preemptible = _Modes_Is_preempt( config->initial_modes );
> +   *  Validate the RTEMS API priority and convert it to the core priority range.
> +  if ( !_Attributes_Is_system_task( attributes ) ) {
> +    if ( config->initial_priority == PRIORITY_MINIMUM ) {
> +      return RTEMS_INVALID_PRIORITY;
> +  thread_config.scheduler =
> +    _Thread_Scheduler_get_home( _Thread_Get_executing() );
> +  thread_config.priority = _RTEMS_Priority_To_core(
> +    thread_config.scheduler,
> +    config->initial_priority,
> +    &valid
> +  if ( !valid ) {
> +  if ( !_System_state_Is_multiprocessing ) {
> +    attributes = _Attributes_Clear( attributes, RTEMS_GLOBAL );
> +  is_global = _Attributes_Is_global( attributes );
> +#endif
> +   *  Allocate the thread control block and -- if the task is global --
> +   *  allocate a global object control block.
> +   *  NOTE:  This routine does not use the combined allocate and open
> +   *         global object routine (_Objects_MP_Allocate_and_open) because
> +   *         this results in a lack of control over when memory is allocated
> +   *         and can be freed in the event of an error.
> +  the_thread = _RTEMS_tasks_Allocate();
> +  if ( !the_thread ) {
> +    _Objects_Allocator_unlock();
> +    return RTEMS_TOO_MANY;
> +  if ( is_global ) {
> +    the_global_object = _Objects_MP_Allocate_global_object();
> +    if ( _Objects_MP_Is_null_global_object( the_global_object ) ) {
> +      _RTEMS_tasks_Free( the_thread );
> +#endif
> +  ( *prepare_stack )( &thread_config, config );
> +  status = ( thread_config.stack_area != NULL );
> +   *  Initialize the core thread for this task.
> +  if ( status ) {
> +    status = _Thread_Initialize(
> +      &_RTEMS_tasks_Information,
> +      the_thread,
> +      &thread_config
> +  if ( !status ) {
> +    if ( is_global )
> +      _Objects_MP_Free_global_object( the_global_object );
> +#endif
> +    return RTEMS_UNSATISFIED;
> +  api = the_thread->API_Extensions[ THREAD_API_RTEMS ];
> +  asr = &api->Signal;
> +  asr->is_enabled = !_Modes_Is_asr_disabled( config->initial_modes );
> +  *id = the_thread->Object.id;
> +  the_thread->is_global = is_global;
> +    _Objects_MP_Open(
> +      &_RTEMS_tasks_Information.Objects,
> +      the_global_object,
> +      config->name,
> +      the_thread->Object.id
> +    _RTEMS_tasks_MP_Send_process_packet(
> +      RTEMS_TASKS_MP_ANNOUNCE_CREATE,
> +      the_thread->Object.id,
> +      config->name
> +#endif
> +  return RTEMS_SUCCESSFUL;
> +static void _RTEMS_tasks_Start_extension(
> +  Thread_Control *executing,
> +  Thread_Control *started
> +  api = started->API_Extensions[ THREAD_API_RTEMS ];
> +  _Event_Initialize( &api->Event );
> +  _Event_Initialize( &api->System_event );
> +static void _RTEMS_tasks_Terminate_extension( Thread_Control *executing )
> +  if ( executing->is_global ) {
> +    _Objects_MP_Close(
> +      executing->Object.id
> +      RTEMS_TASKS_MP_ANNOUNCE_DELETE,
> +      executing->Object.id,
> +      0                                /* Not used */
> +#endif
> +static User_extensions_Control _RTEMS_tasks_User_extensions = {
> +  .Callouts = {
> +    .thread_terminate = _RTEMS_tasks_Terminate_extension,
> +#endif
> +    .thread_start     = _RTEMS_tasks_Start_extension,
> +    .thread_restart   = _RTEMS_tasks_Start_extension
> +static void _RTEMS_tasks_Manager_initialization( void )
> +  _Thread_Initialize_information( &_RTEMS_tasks_Information );
> +  _User_extensions_Add_API_set( &_RTEMS_tasks_User_extensions );
> +RTEMS_SYSINIT_ITEM(
> +  _RTEMS_tasks_Manager_initialization,
> +  RTEMS_SYSINIT_CLASSIC_TASKS,
> +  RTEMS_SYSINIT_ORDER_MIDDLE
> diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
> index 5486ac9b6e..3a0badf285 100644
> --- a/cpukit/rtems/src/taskcreate.c
> +++ b/cpukit/rtems/src/taskcreate.c
> @@ -1,17 +1,36 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> - *  @file
> + * @file
> - *  @brief RTEMS Task Create
> - *  @ingroup ClassicTasks
> - *  COPYRIGHT (c) 1989-2014,2016.
> - *  On-Line Applications Research Corporation (OAR).
> + * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> @@ -19,20 +38,24 @@
>  #endif
> -#include <rtems/rtems/attrimpl.h>
> -#include <rtems/rtems/eventimpl.h>
> -#include <rtems/rtems/modesimpl.h>
> -#include <rtems/rtems/support.h>
> -#include <rtems/score/apimutex.h>
> -#include <rtems/score/schedulerimpl.h>
> -#include <rtems/score/sysstate.h>
> -#include <rtems/score/threadimpl.h>
> -#include <rtems/score/userextimpl.h>
> -#include <rtems/sysinit.h>
>  #include <string.h>
> +static void _RTEMS_tasks_Allocate_and_prepare_stack(
> +  size_t size;
> +  thread_config->stack_free = _Stack_Free;
> +  size = _Stack_Ensure_minimum( config->storage_size );
> +  size = _Stack_Extend_size( size, thread_config->is_fp );
> +  thread_config->stack_size = size;
> +  thread_config->stack_area = _Stack_Allocate( size );
>    rtems_name           name,
>    rtems_task_priority  initial_priority,
> @@ -42,215 +65,14 @@ rtems_status_code rtems_task_create(
>    rtems_id            *id
> -  Thread_Control          *the_thread;
> -  Thread_Configuration     config;
> -#if defined(RTEMS_MULTIPROCESSING)
> -  Objects_MP_Control      *the_global_object = NULL;
> -  bool                     is_global;
> -#endif
> -  bool                     status;
> -  rtems_attribute          the_attribute_set;
> -  bool                     valid;
> -  RTEMS_API_Control       *api;
> -  ASR_Information         *asr;
> -  if ( !id )
> -   return RTEMS_INVALID_ADDRESS;
> -  if ( !rtems_is_name_valid( name ) )
> -    return RTEMS_INVALID_NAME;
> -   *  Core Thread Initialize insures we get the minimum amount of
> -   *  stack space.
> -   *  Fix the attribute set to match the attributes which
> -   *  this processor (1) requires and (2) is able to support.
> -   *  First add in the required flags for attribute_set
> -   *  Typically this might include FP if the platform
> -   *  or application required all tasks to be fp aware.
> -   *  Then turn off the requested bits which are not supported.
> -  the_attribute_set = _Attributes_Set( attribute_set, ATTRIBUTES_REQUIRED );
> -    _Attributes_Clear( the_attribute_set, ATTRIBUTES_NOT_SUPPORTED );
> +  rtems_task_config config;
>    memset( &config, 0, sizeof( config ) );
> -  config.budget_algorithm = _Modes_Is_timeslice( initial_modes ) ?
> -    THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE
> -      : THREAD_CPU_BUDGET_ALGORITHM_NONE,
> -  config.isr_level =  _Modes_Get_interrupt_level( initial_modes );
> -  config.name.name_u32 = name;
> -  config.is_fp = _Attributes_Is_floating_point( the_attribute_set );
> -  config.is_preemptible = _Modes_Is_preempt( initial_modes );
> -  config.stack_size = _Stack_Ensure_minimum( stack_size );
> -  config.stack_size = _Stack_Extend_size( config.stack_size, config.is_fp );
> -   *  Validate the RTEMS API priority and convert it to the core priority range.
> -  if ( !_Attributes_Is_system_task( the_attribute_set ) ) {
> -    if ( initial_priority == PRIORITY_MINIMUM ) {
> -      return RTEMS_INVALID_PRIORITY;
> -  config.scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing() );
> -  config.priority = _RTEMS_Priority_To_core(
> -    config.scheduler,
> -    initial_priority,
> -    &valid
> -  if ( !valid ) {
> -  if ( !_System_state_Is_multiprocessing ) {
> -    the_attribute_set = _Attributes_Clear( the_attribute_set, RTEMS_GLOBAL );
> -  is_global = _Attributes_Is_global( the_attribute_set );
> -#endif
> -   *  Allocate the thread control block and -- if the task is global --
> -   *  allocate a global object control block.
> -   *  NOTE:  This routine does not use the combined allocate and open
> -   *         global object routine (_Objects_MP_Allocate_and_open) because
> -   *         this results in a lack of control over when memory is allocated
> -   *         and can be freed in the event of an error.
> -  the_thread = _RTEMS_tasks_Allocate();
> -  if ( !the_thread ) {
> -    _Objects_Allocator_unlock();
> -    return RTEMS_TOO_MANY;
> -  if ( is_global ) {
> -    the_global_object = _Objects_MP_Allocate_global_object();
> -    if ( _Objects_MP_Is_null_global_object( the_global_object ) ) {
> -      _RTEMS_tasks_Free( the_thread );
> -#endif
> -  config.stack_free = _Stack_Free;
> -  config.stack_area = _Stack_Allocate( config.stack_size );
> -  status = ( config.stack_area != NULL );
> -   *  Initialize the core thread for this task.
> +  config.name = name;
> +  config.initial_priority = initial_priority;
> +  config.storage_size = stack_size;
> +  config.initial_modes = initial_modes;
> +  config.attributes = attribute_set;
> -  if ( status ) {
> -    status = _Thread_Initialize(
> -      &_RTEMS_tasks_Information,
> -      the_thread,
> -      &config
> -  if ( !status ) {
> -    if ( is_global )
> -      _Objects_MP_Free_global_object( the_global_object );
> -#endif
> -    return RTEMS_UNSATISFIED;
> -  api = the_thread->API_Extensions[ THREAD_API_RTEMS ];
> -  asr = &api->Signal;
> -  asr->is_enabled = _Modes_Is_asr_disabled(initial_modes) ? false : true;
> -  *id = the_thread->Object.id;
> -  the_thread->is_global = is_global;
> -    _Objects_MP_Open(
> -      &_RTEMS_tasks_Information.Objects,
> -      the_global_object,
> -      name,
> -      the_thread->Object.id
> -    _RTEMS_tasks_MP_Send_process_packet(
> -      RTEMS_TASKS_MP_ANNOUNCE_CREATE,
> -      the_thread->Object.id,
> -      name
> -#endif
> -  return RTEMS_SUCCESSFUL;
> +  return _RTEMS_tasks_Build( &config, id, _RTEMS_tasks_Allocate_and_prepare_stack );
> -static void _RTEMS_tasks_Start_extension(
> -  Thread_Control *executing,
> -  Thread_Control *started
> -  api = started->API_Extensions[ THREAD_API_RTEMS ];
> -  _Event_Initialize( &api->Event );
> -  _Event_Initialize( &api->System_event );
> -static void _RTEMS_tasks_Terminate_extension( Thread_Control *executing )
> -  if ( executing->is_global ) {
> -    _Objects_MP_Close(
> -      executing->Object.id
> -      RTEMS_TASKS_MP_ANNOUNCE_DELETE,
> -      executing->Object.id,
> -      0                                /* Not used */
> -#endif
> -static User_extensions_Control _RTEMS_tasks_User_extensions = {
> -  .Callouts = {
> -    .thread_terminate = _RTEMS_tasks_Terminate_extension,
> -#endif
> -    .thread_start     = _RTEMS_tasks_Start_extension,
> -    .thread_restart   = _RTEMS_tasks_Start_extension
> -static void _RTEMS_tasks_Manager_initialization( void )
> -  _Thread_Initialize_information( &_RTEMS_tasks_Information );
> -  _User_extensions_Add_API_set( &_RTEMS_tasks_User_extensions );
> -RTEMS_SYSINIT_ITEM(
> -  _RTEMS_tasks_Manager_initialization,
> -  RTEMS_SYSINIT_CLASSIC_TASKS,
> -  RTEMS_SYSINIT_ORDER_MIDDLE
> diff --git a/testsuites/sptests/sp01/init.c b/testsuites/sptests/sp01/init.c
> index 2719c84fc8..f25300e5bb 100644
> --- a/testsuites/sptests/sp01/init.c
> +++ b/testsuites/sptests/sp01/init.c
> @@ -16,6 +16,17 @@
>  const char rtems_test_name[] = "SP 1";
> +static char Task_1_storage[ 2 * RTEMS_MINIMUM_STACK_SIZE ];
> +static const rtems_task_config Task_1_config = {
> +  .name = rtems_build_name( 'T', 'A', '1', ' ' ),
> +  .initial_priority = 1,
> +  .storage_area = Task_1_storage,
> +  .storage_size = sizeof( Task_1_storage ),
> +  .initial_modes = RTEMS_DEFAULT_MODES,
> +  .attributes = RTEMS_DEFAULT_ATTRIBUTES
>  rtems_task Init(
>    rtems_task_argument argument
> @@ -30,15 +41,8 @@ rtems_task Init(
>    status = rtems_clock_set( &time );
>    directive_failed( status, "rtems_clock_set" );
> -  status = rtems_task_create(
> -    rtems_build_name( 'T', 'A', '1', ' ' ),
> -    1,
> -    RTEMS_MINIMUM_STACK_SIZE * 2,
> -    RTEMS_DEFAULT_MODES,
> -    RTEMS_DEFAULT_ATTRIBUTES,
> -    &id
> -  directive_failed( status, "rtems_task_create of TA1" );
> +  status = rtems_task_build( &Task_1_config, &id );
> +  directive_failed( status, "rtems_task_build of TA1" );
>    status = rtems_task_start( id, Task_1_through_3, 1 );
>    directive_failed( status, "rtems_task_start of TA1" );
> diff --git a/testsuites/sptests/sp01/sp01.doc b/testsuites/sptests/sp01/sp01.doc
> index d7d9f5d902..62bbe956d3 100644
> --- a/testsuites/sptests/sp01/sp01.doc
> +++ b/testsuites/sptests/sp01/sp01.doc
> @@ -9,6 +9,7 @@
>  test name:  sp01
>  directives:
> +  rtems_task_build
>    rtems_task_create
>    rtems_task_start
>    rtems_task_wake_after
> diff --git a/testsuites/sptests/sp01/system.h b/testsuites/sptests/sp01/system.h
> index bde5328aa9..e2047b4d3a 100644
> --- a/testsuites/sptests/sp01/system.h
> +++ b/testsuites/sptests/sp01/system.h
> @@ -28,7 +28,7 @@ rtems_task Task_1_through_3(
>  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> -#define CONFIGURE_EXTRA_TASK_STACKS         (4 * RTEMS_MINIMUM_STACK_SIZE)
> +#define CONFIGURE_EXTRA_TASK_STACKS         (2 * RTEMS_MINIMUM_STACK_SIZE)
>  #define CONFIGURE_MAXIMUM_TASKS             4
>  #include <rtems/confdefs.h>
