[PATCH v2] Pre Release: Strong APA
Mon Aug 24 17:37:15 UTC 2020
On Mon, Aug 24, 2020 at 10:14 AM Richi Dubey <richidubey at gmail.com> wrote:
>  cpukit/include/rtems/scheduler.h              |   6 +-
>  .../include/rtems/score/schedulerstrongapa.h  | 284 ++++--
>  cpukit/score/src/schedulerstrongapa.c         | 913 ++++++++++++++----
>  3 files changed, 901 insertions(+), 302 deletions(-)
> diff --git a/cpukit/include/rtems/scheduler.h b/cpukit/include/rtems/scheduler.h
> index 955a83cfb4..b101842ba7 100644
> --- a/cpukit/include/rtems/scheduler.h
> +++ b/cpukit/include/rtems/scheduler.h
> @@ -257,16 +257,14 @@
>    #define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
>      static struct { \
>        Scheduler_strong_APA_Context Base; \
> -      Chain_Control                Ready[ ( prio_count ) ]; \
> +      Scheduler_strong_APA_Struct Struct[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
I don't like this name at all either the type or the variable
"Struct". Just like I wouldn't call a variable
   int Int;
>      } SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
>    #define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
>        &SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
>        SCHEDULER_STRONG_APA_ENTRY_POINTS, \
> -      RTEMS_ARRAY_SIZE( \
> -        SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Ready \
> -      ) - 1, \
> +      SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
>        ( obj_name ) \
>        SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
> diff --git a/cpukit/include/rtems/score/schedulerstrongapa.h b/cpukit/include/rtems/score/schedulerstrongapa.h
> index 0ac28cb439..86d91688e8 100644
> --- a/cpukit/include/rtems/score/schedulerstrongapa.h
> +++ b/cpukit/include/rtems/score/schedulerstrongapa.h
> @@ -6,31 +6,38 @@
>   * @brief Strong APA Scheduler API
> - * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
> + * Copyright (c) 2020 Richi Dubey
> - *  embedded brains GmbH
> - *  Dornierstr. 4
> - *  82178 Puchheim
> - *  Germany
> - *  <rtems at embedded-brains.de>
> + *  <richidubey at gmail.com>
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> + * Copyright (c) 2013, 2018 embedded brains GmbH. All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
>   * http://www.rtems.org/license/LICENSE.
relicense 2-bsd -- EB allows it, and your new code should be put under it
>  #ifndef _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
>  #define _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
>  #include <rtems/score/scheduler.h>
> -#include <rtems/score/schedulerpriority.h>
>  #include <rtems/score/schedulersmp.h>
> +#include <rtems/score/percpu.h>
>  #ifdef __cplusplus
>  extern "C" {
>  #endif /* __cplusplus */
> +#define STRONG_SCHEDULER_NODE_OF_CHAIN( node ) \
> +  RTEMS_CONTAINER_OF( next, Scheduler_strong_APA_Node, Chain )
somehow this is not using 'node' parameter?
>   * @defgroup RTEMSScoreSchedulerStrongAPA Strong APA Scheduler
> @@ -38,43 +45,98 @@ extern "C" {
> - * This is an implementation of the global fixed priority scheduler (G-FP).  It
> - * uses one ready chain per priority to ensure constant time insert operations.
> - * The scheduled chain uses linear insert operations and has at most processor
> - * count entries.  Since the processor and priority count are constants all
> - * scheduler operations complete in a bounded execution time.
> + * This is an implementation of the Strong APA scheduler defined by
> + * Cerqueira et al. in Linux's Processor Affinity API, Refined:
> + * Shifting Real-Time Tasks Towards Higher Schedulability.
> - * The the_thread preempt mode will be ignored.
repeating text?
You should add a bit more comment about the high-level design here. Of
course anyone wanting more details can go to the paper.
> - * @brief Scheduler context specialization for Strong APA
> - * schedulers.
> -typedef struct {
> -  Scheduler_SMP_Context    Base;
> -  Priority_bit_map_Control Bit_map;
> -  Chain_Control            Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
> -} Scheduler_strong_APA_Context;
> - * @brief Scheduler node specialization for Strong APA
> - * schedulers.
> + * @brief Scheduler node specialization for Strong APA schedulers.
>  typedef struct {
>     * @brief SMP scheduler node.
>    Scheduler_SMP_Node Base;
> +   * @brief Chain node for Scheduler_strong_APA_Context::All_nodes
> +  Chain_Node Chain;
Don't call this Chain. We refer to a Chain_Control object as the
chain. Some other ideas:
* APA_Node
* All_nodes_Node
* All_nodes_Link
* Link
* Node (that could be confusing)
* Link_Node
I always felt like Joel missed an opportunity to call them Chain Links
instead of Chain Nodes. Then compiler memory fences for synchronizing
them could be Chain Link Fences? (A bit of dad humor.)
> +   * @brief CPU that this node would preempt in the backtracking part of
> +   * _Scheduler_strong_APA_Get_highest_ready and
> +   * _Scheduler_strong_APA_Do_Enqueue.
> +  Per_CPU_Control *invoker;
I don't like this name either. What is the invoker invoking? Since it
is used to go backwards, maybe think of a word that conveys that use.
'lowest_scheduled'? 'next_to_preempt'?
> -   * @brief The associated ready queue of this node.
> +   * @brief The associated affinity set of this node.
> -  Scheduler_priority_Ready_queue Ready_queue;
> +  Processor_mask Affinity;
>  } Scheduler_strong_APA_Node;
> + * @brief Struct for each index of the variable size arrays
clarify this comment, no one knows what this means.
Add a period (full stop) after brief sentence.
> +typedef struct
> +   * @brief The node that called this CPU, i.e. a node which has
'called' the CPU? That doesn't make sense to me.
> +   * the cpu at the index of Scheduler_strong_APA_Context::Struct in
this comment makes no sense without understanding how this structure
is being used.
furthermore, the 'instance' of this structure is "at the index of
Scheduler_strong_APA_Context::Struct" so you can just say "The
scheduling node (owning the thread? executing on?) of a cpu in the BFS
queue. Since by now you'll already have explained what is the BFS algo
and queue in use.
> +   * its affinity set.
> +  Scheduler_Node *caller;
Not sure what it called. Think about what this name means a bit more.
> +   * @brief Cpu at the index of Scheduler_strong_APA_Context::Struct
Isn't this self-referencing? Just say "CPU in a queue"?
> +   * in Queue implementation.
> +  Per_CPU_Control *cpu;
> +   * @brief Indicates if the CPU at the index of
> +   * Scheduler_strong_APA_Context::Struct is already
> +   * added to the Queue or not.
Whether or not this cpu has been added to the queue (visited in the BFS)
> +  bool visited;
> +} Scheduler_strong_APA_Struct;
Maybe, Scheduler_strong_APA_BFS_node;
> + * @brief Scheduler context for Strong APA scheduler.
> + * Has the structure for scheduler context
> + * and Node defintion for Strong APA scheduler
typo: definition
This little phrase seems not that helpful. Either merge to the brief
or expand it further with details.
"@brief Scheduler context and node definition for Strong APA scheduler."
> +typedef struct {
> +   * @brief SMP Context to refer to SMP implementation
> +   * code.
> +  Scheduler_SMP_Context Base;
I don't think these 'Base' need to be documented, or at best you can
just have @see Scheduler_SMP_Context?
> +   * @brief Chain of all the nodes present in
> +   * the system. Accounts for ready and scheduled nodes.
Not the system, but the (strong APA) scheduler?
> +  Chain_Control All_nodes;
> +   * @brief Struct with important variables for each cpu
improve this comment.
> +  Scheduler_strong_APA_Struct Struct[ RTEMS_ZERO_LENGTH_ARRAY ];
> +} Scheduler_strong_APA_Context;
> +#define SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY 255
>   * @brief Entry points for the Strong APA Scheduler.
> @@ -100,81 +162,90 @@ typedef struct {
>      _Scheduler_default_Release_job, \
>      _Scheduler_default_Cancel_job, \
>      _Scheduler_default_Tick, \
> -    _Scheduler_SMP_Start_idle \
> -    SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
> +    _Scheduler_strong_APA_Start_idle, \
> +    _Scheduler_strong_APA_Set_affinity \
> - * @brief Initializes the scheduler.
> + * @brief Initializes the Strong_APA scheduler.
> - * @param scheduler The scheduler to initialize.
> -void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler );
> + * Sets the chain containing all the nodes to empty
> + * and initializes the SMP scheduler.
> + * @param scheduler used to get reference to Strong APA scheduler context
> + * @retval void
I don't think we document void retval. It is a kind of oxymoron.
> + * @see _Scheduler_strong_APA_Node_initialize()
> +void _Scheduler_strong_APA_Initialize(
> +  const Scheduler_Control *scheduler
> - * @brief Initializes the node with the given priority.
> + * @brief Called when a node yields the processor
add period.
I think technically the thread yields the processor.
>   * @param scheduler The scheduler control instance.
> - * @param[out] node The node to initialize.
> - * @param the_thread The thread of the node to initialize.
> - * @param priority The priority for @a node.
> + * @param thread Thread corresponding to @node
> + * @param node Node that yield the processor
Kind of backwards. The thread yields the processor, and the Node is
corresponding to the thread.
Maybe check how other schedulers document this stuff. I don't know why
you are changing it from the existing template file?  I shouldn't have
to be spending time reviewing these kinds of reformatting changes
(especially when what's in the repo seems correct and your changes
seem wrong). I'm going to ignore the rest of your doxygen, but please
make similar fixes as I mentioned already, or revert the changes you
made to the existing doco.
> -void _Scheduler_strong_APA_Node_initialize(
> +void _Scheduler_strong_APA_Yield(
>    const Scheduler_Control *scheduler,
> -  Scheduler_Node          *node,
> -  Thread_Control          *the_thread,
> -  Priority_Control         priority
> +  Thread_Control          *thread,
> +  Scheduler_Node          *node
> - * @brief Blocks the thread.
> + * @brief Blocks a node
> - * @param scheduler The scheduler control instance.
> - * @param[in, out] the_thread The thread to block.
> - * @param[in, out] node The node of the thread to block.
> + * Changes the state of the node and extracts it from the queue
> + * calls _Scheduler_SMP_Block().
> + * @param context The scheduler control instance.
> + * @param thread Thread correspoding to the @node.
> + * @param node node which is to be blocked
>  void _Scheduler_strong_APA_Block(
> - * @brief Unblocks the thread.
> + * @brief Unblocks a node
> + * Changes the state of the node and calls _Scheduler_SMP_Unblock().
> - * @param[in, out] the_thread The thread to unblock.
> - * @param[in, out] node The node of the thread to unblock.
> + * @param node node which is to be unblocked
> + * @see _Scheduler_strong_APA_Enqueue()
> + * @see _Scheduler_strong_APA_Do_update()
>  void _Scheduler_strong_APA_Unblock(
> - * @brief Updates the priority of the node.
> + * @brief Updates the priority of the node
See, this one just really bugs me. I really am going to ignore these
doxygen changes.
> - * @param the_thread The thread for the operation.
> - * @param[in, out] node The node to update the priority of.
> + * @param node Node whose priority has to be updated
>  void _Scheduler_strong_APA_Update_priority(
> - * @brief Asks for help.
> + * @brief Calls the SMP Ask_for_help
> - * @param the_thread The thread that asks for help.
> - * @param node The node of @a the_thread.
> - * @retval true The request for help was successful.
> - * @retval false The request for help was not successful.
> + * @param scheduler The scheduler control instance.
> + * @param thread Thread correspoding to the @node that asks for help.
> + * @param node node associated with @thread
>  bool _Scheduler_strong_APA_Ask_for_help(
> @@ -182,12 +253,13 @@ bool _Scheduler_strong_APA_Ask_for_help(
> - * @brief Reconsiders help request.
> + * @brief To Reconsider the help request
> - * @param the_thread The thread to reconsider the help request of.
> - * @param[in, out] node The node of @a the_thread
> + * @param node Node corresponding to @thread which asks for
> + * reconsideration
>  void _Scheduler_strong_APA_Reconsider_help_request(
> @@ -195,13 +267,13 @@ void _Scheduler_strong_APA_Reconsider_help_request(
> - * @brief Withdraws the node.
> + * @brief Withdraws a node
> - * @param[in, out] the_thread The thread to change the state to @a next_state.
> - * @param[in, out] node The node to withdraw.
> - * @param next_state The next state for @a the_thread.
> + * @param node Node that has to be withdrawn
> + * @param next_state the state that the node goes to
>  void _Scheduler_strong_APA_Withdraw_node(
> @@ -210,42 +282,66 @@ void _Scheduler_strong_APA_Withdraw_node(
> - * @brief Adds the idle thread to a processor.
> + * @brief Adds a processor to the scheduler instance
> + * and allocates an idle thread to the processor.
> - * @param[in, out] The idle thread to add to the processor.
> + * @param idle Idle thread to be allocated to the processor
>  void _Scheduler_strong_APA_Add_processor(
>    Thread_Control          *idle
> - * @brief Removes an idle thread from the given cpu.
> - * @param scheduler The scheduler instance.
> - * @param cpu The cpu control to remove from @a scheduler.
> + * @brief Removes a processor from the scheduler instance
> - * @return The idle thread of the processor.
> + * @param cpu processor that is removed
>  Thread_Control *_Scheduler_strong_APA_Remove_processor(
> -  struct Per_CPU_Control  *cpu
> - * @brief Performs a yield operation.
> + * @brief Initializes the node with the given priority.
> - * @param the_thread The thread to yield.
> - * @param[in, out] node The node of @a the_thread.
> + * @param[out] node The node to initialize.
> + * @param the_thread The thread of the node to initialize.
> + * @param priority The priority for @a node.
> -void _Scheduler_strong_APA_Yield(
> +void _Scheduler_strong_APA_Node_initialize(
> +  Scheduler_Node          *node,
> +  Priority_Control         priority
> + * @brief Starts an idle thread on a CPU
> + * @param idle Idle Thread
> + * @param cpu processor that gets the idle thread
> +void _Scheduler_strong_APA_Start_idle(
> +  const Scheduler_Control *scheduler,
> +  Thread_Control          *idle,
> + * @brief Sets the affinity of the @node_base to @affinity
> +bool _Scheduler_strong_APA_Set_affinity(
> +  Scheduler_Node          *node_base,
> +  const Processor_mask    *affinity
>  #ifdef __cplusplus
> diff --git a/cpukit/score/src/schedulerstrongapa.c b/cpukit/score/src/schedulerstrongapa.c
> index 924cd86412..a3f4c49cab 100644
> --- a/cpukit/score/src/schedulerstrongapa.c
> +++ b/cpukit/score/src/schedulerstrongapa.c
> @@ -6,320 +6,758 @@
>   * @brief Strong APA Scheduler Implementation
> - * Copyright (c) 2013, 2016 embedded brains GmbH.  All rights reserved.
> - *  Dornierstr. 4
> - *  82178 Puchheim
> - *  Germany
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
>  #ifdef HAVE_CONFIG_H
>  #include "config.h"
>  #endif
>  #include <rtems/score/schedulerstrongapa.h>
> -#include <rtems/score/schedulerpriorityimpl.h>
>  #include <rtems/score/schedulersmpimpl.h>
> +#include <rtems/score/assert.h>
> +#include <rtems/malloc.h>
> -static Scheduler_strong_APA_Context *_Scheduler_strong_APA_Get_self(
> -  Scheduler_Context *context
> +static inline Scheduler_strong_APA_Context *
> +_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
> +  return (Scheduler_strong_APA_Context *) _Scheduler_Get_context( scheduler );
> +_Scheduler_strong_APA_Get_self( Scheduler_Context *context )
>    return (Scheduler_strong_APA_Context *) context;
> -static Scheduler_strong_APA_Node *
> +static inline Scheduler_strong_APA_Node *
>  _Scheduler_strong_APA_Node_downcast( Scheduler_Node *node )
>    return (Scheduler_strong_APA_Node *) node;
> -static void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
> +static inline void _Scheduler_strong_APA_Do_update(
>    Scheduler_Context *context,
> -  Scheduler_Node    *scheduled_to_ready
> +  Priority_Control   new_priority
> -  Scheduler_strong_APA_Context *self =
> -    _Scheduler_strong_APA_Get_self( context );
> -  Scheduler_strong_APA_Node *node =
> -    _Scheduler_strong_APA_Node_downcast( scheduled_to_ready );
> -  _Chain_Extract_unprotected( &node->Base.Base.Node.Chain );
> -  _Scheduler_priority_Ready_queue_enqueue_first(
> -    &node->Base.Base.Node.Chain,
> -    &node->Ready_queue,
> -    &self->Bit_map
> +  Scheduler_SMP_Node *smp_node;
> +  (void) context;
> +  smp_node = _Scheduler_SMP_Node_downcast( node );
> +  _Scheduler_SMP_Node_update_priority( smp_node, new_priority );
Although we don't need doxygen for static (private) methods, a little
bit of comment can be helpful to understand what the helper function
does.
> +static inline bool _Scheduler_strong_APA_Has_ready( Scheduler_Context *context )
> +  Scheduler_strong_APA_Context *self = _Scheduler_strong_APA_Get_self( context );
> +  bool                       ret;
> +  const Chain_Node          *tail;
> +  Chain_Node                *next;
> +  Scheduler_strong_APA_Node *node;
> +  tail = _Chain_Immutable_tail( &self->All_nodes );
> +  next = _Chain_First( &self->All_nodes );
> +  ret = false;
> +  while ( next != tail ) {
> +    node = (Scheduler_strong_APA_Node *) STRONG_SCHEDULER_NODE_OF_CHAIN( next );
I see, this only works by chance. fix your macro so it works on purpose.
> +    if (
> +    _Scheduler_SMP_Node_state( &node->Base.Base ) == SCHEDULER_SMP_NODE_READY
not enough indent levels
To break this you should use
  if (
I know it is kind of ugly.
> +      ret = true;
> +      break;
this is fine, but it could also be 'return true;' and then ...
> +    next = _Chain_Next( next );
> +  return ret;
return false;
Minor nit, but it does simplify your code
> +static inline void _Scheduler_strong_APA_Allocate_processor(
> +  Scheduler_Context *context,
> +  Scheduler_Node    *scheduled_base,
> +  Scheduler_Node    *victim_base,
> +  Per_CPU_Control   *victim_cpu
> +  Scheduler_strong_APA_Node *scheduled;
> +  (void) victim_base;
I personally would like a blank line after this warning suppression to
separate it from 'real code' in my head.
> +  scheduled = _Scheduler_strong_APA_Node_downcast( scheduled_base );
> +  _Scheduler_SMP_Allocate_processor_exact(
> +    context,
> +    &(scheduled->Base.Base),
> +    NULL,
> +    victim_cpu
> -static void _Scheduler_strong_APA_Move_from_ready_to_scheduled(
> +static inline Scheduler_Node * _Scheduler_strong_APA_Find_highest_ready(
> +  Scheduler_strong_APA_Context *self,
> +  uint32_t                      front,
> +  uint32_t                      rear
> +  Scheduler_Node              *highest_ready;
> +  Scheduler_strong_APA_Struct *Struct;
> +  Chain_Node                  *next;
> +  uint32_t                     index_assigned_cpu;
> +  Priority_Control             min_priority_num;
> +  Priority_Control             curr_priority;
> +  Per_CPU_Control             *assigned_cpu;
> +  Scheduler_SMP_Node_state     curr_state;
> +  Per_CPU_Control             *curr_CPU;
> +  bool                         first_task;
> +  Struct = self->Struct;
> +   //When the first task accessed has nothing to compare its priority against
> +  // So, it is the task with the highest priority witnessed so far!
Use /* */
> +  first_task = true;
> +  while( front <= rear ) {
> +    curr_CPU = Struct[ front ].cpu;
Who ensures that rear < sizeof(Struct)?
> +    front = front + 1;
> +      node = (Scheduler_strong_APA_Node*) STRONG_SCHEDULER_NODE_OF_CHAIN( next );
> +      //Check if the curr_CPU is in the affinity set of the node
> +      if (
> +        _Processor_mask_Is_set(&node->Affinity, _Per_CPU_Get_index(curr_CPU))
extra ws at end of line
you can search a regex like "\s\s*$" for that kind of problem
> +        curr_state = _Scheduler_SMP_Node_state( &node->Base.Base );
> +        if ( curr_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
> +          assigned_cpu = _Thread_Get_CPU( node->Base.Base.user );
> +          index_assigned_cpu =  _Per_CPU_Get_index( assigned_cpu );
> +          if ( Struct[ index_assigned_cpu ].visited == false ) {
> +            rear = rear + 1;
> +            Struct[ rear ].cpu = assigned_cpu;
> +            Struct[ index_assigned_cpu ].visited = true;
OK this is a little bit confusing. You are using the same 'Struct[]'
entry to store metadata for two different CPUs. Somehow you need to
either clarify this, or make it consistent.
> +            // The curr CPU of the queue invoked this node to add its CPU
> +            // that it is executing on to the queue. So this node might get
> +            // preempted because of the invoker curr_CPU and this curr_CPU
> +            // is the CPU that node should preempt in case this node
> +            // gets preempted.
> +            node->invoker = curr_CPU;
> +        else if ( curr_state == SCHEDULER_SMP_NODE_READY ) {
> +          curr_priority = _Scheduler_Node_get_priority( &node->Base.Base );
> +          curr_priority = SCHEDULER_PRIORITY_PURIFY( curr_priority );
> +          if ( first_task == true || curr_priority < min_priority_num ) {
you can also initialize min_priority_num to  the scheduler's maximum
priority value? Then get rid of this first_task var?
> +            min_priority_num = curr_priority;
> +           highest_ready = &node->Base.Base;
> +           first_task = false;
> +           //In case this task is directly reachable from thread_CPU
I don't know what this comment means.
> +  return highest_ready;
> +static inline void  _Scheduler_strong_APA_Move_from_ready_to_scheduled(
>    Scheduler_Node    *ready_to_scheduled
> -  Scheduler_strong_APA_Context *self;
> -  Scheduler_strong_APA_Node    *node;
> -  Priority_Control              insert_priority;
> +  Priority_Control insert_priority;
> -  self = _Scheduler_strong_APA_Get_self( context );
> -  node = _Scheduler_strong_APA_Node_downcast( ready_to_scheduled );
> -  _Scheduler_priority_Ready_queue_extract(
> -    &self->Bit_map
> -  insert_priority = _Scheduler_SMP_Node_priority( &node->Base.Base );
> +  insert_priority = _Scheduler_SMP_Node_priority( ready_to_scheduled );
>    insert_priority = SCHEDULER_PRIORITY_APPEND( insert_priority );
> -  _Chain_Insert_ordered_unprotected(
> -    &self->Base.Scheduled,
> -    &insert_priority,
> -    _Scheduler_SMP_Priority_less_equal
> +  _Scheduler_SMP_Insert_scheduled(
> +    context,
> +    ready_to_scheduled,
> +    insert_priority
> -static void _Scheduler_strong_APA_Insert_ready(
> +static inline Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
> -  Scheduler_Node    *node_base,
> +  Scheduler_Node    *filter
> +  //Implement the BFS Algorithm for task departure
> +  //to get the highest ready task for a particular CPU
> +  //return the highest ready Scheduler_Node and Scheduler_Node filter here points
> +  // to the victim node that is blocked resulting which this function is called.
> +  Per_CPU_Control              *filter_cpu;
> -  node = _Scheduler_strong_APA_Node_downcast( node_base );
> -  if ( SCHEDULER_PRIORITY_IS_APPEND( insert_priority ) ) {
> -    _Scheduler_priority_Ready_queue_enqueue(
> -      &self->Bit_map
> -  } else {
> -      &self->Bit_map
> +  Scheduler_Node               *curr_node;
> +  Scheduler_Node               *next_node;
> +  uint32_t                     front;
> +  uint32_t                     rear;
> +  uint32_t                     cpu_max;
> +  uint32_t                             cpu_index;
> +  self=_Scheduler_strong_APA_Get_self( context );
ws
> +  //Denotes front and rear of the queue
> +  front = 0;
> +  rear = -1;
> +  filter_cpu = _Thread_Get_CPU( filter->user );
> +  cpu_max = _SMP_Get_processor_maximum();
I think there is a valid scheduler at cpu_max?
> +  for ( cpu_index = 0 ; cpu_index < cpu_max ; ++cpu_index ) {
So this should be <= not <
Maybe?
> +    Struct[ cpu_index ].visited = false;
> +  rear = rear + 1;
why not just init rear to 0?
> +  Struct[ rear ].cpu = filter_cpu;
> +  Struct[ _Per_CPU_Get_index( filter_cpu ) ].visited = true;
> +  highest_ready = _Scheduler_strong_APA_Find_highest_ready(
> +                    self,
> +                    front,
> +                    rear
wrong indents
> +  if ( highest_ready != filter ) {
> +    //Backtrack on the path from
> +    //filter_cpu to highest_ready, shifting along every task.
> +    node = _Scheduler_strong_APA_Node_downcast( highest_ready );
> +    if( node->invoker != filter_cpu ) {
> +      // Highest ready is not just directly reachable from the victim cpu
> +      // So there is need of task shifting
> +      curr_node = &node->Base.Base;
> +      next_node = _Thread_Scheduler_get_home_node( node->invoker->heir );
> +      _Scheduler_SMP_Preempt(
> +        context,
> +        curr_node,
> +        _Thread_Scheduler_get_home_node( node->invoker->heir ),
> +        _Scheduler_strong_APA_Allocate_processor
> +      _Scheduler_strong_APA_Move_from_ready_to_scheduled(context, curr_node);
> +      node = _Scheduler_strong_APA_Node_downcast( next_node );
> +      while( node->invoker !=  filter_cpu ){
> +          context,
> +          curr_node,
This is repetitive code, can you merge the first part of the 'if'
block into the while loop?
> +      //To save the last node so that the caller SMP_* function
> +      //can do the allocation
> +      highest_ready = curr_node;
> -static void _Scheduler_strong_APA_Extract_from_ready(
> +static inline Scheduler_Node *_Scheduler_strong_APA_Get_lowest_scheduled(
> -  Scheduler_Node    *the_thread
> +  Scheduler_Node    *filter_base
> -    _Scheduler_strong_APA_Node_downcast( the_thread );
> -    &self->Bit_map
> +  //Checks the lowest scheduled directly reachable task
put as /* */ before the function declaration
> +  uint32_t                  cpu_max;
> +  Thread_Control            *curr_thread;
> +  Scheduler_Node            *lowest_scheduled;
> +  Priority_Control           max_priority_num;
> +  Scheduler_strong_APA_Node *filter_strong_node;
> +  lowest_scheduled = NULL; //To remove compiler warning.
> +  max_priority_num = 0;//Max (Lowest) priority encountered so far.
ws
> +  filter_strong_node = _Scheduler_strong_APA_Node_downcast( filter_base );
> +  //lowest_scheduled is NULL if affinty of a node is 0
typo
> +  _Assert( !_Processor_mask_Zero( &filter_strong_node->Affinity ) );
> +    //Checks if the CPU is in the affinity set of filter_strong_node
> +    if ( _Processor_mask_Is_set( &filter_strong_node->Affinity, cpu_index) ) {
> +      Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
> +      if ( _Per_CPU_Is_processor_online( cpu ) ) {
> +        curr_thread = cpu->heir;
> +        curr_node = _Thread_Scheduler_get_home_node( curr_thread );
> +        curr_priority = _Scheduler_Node_get_priority( curr_node );
> +        if ( curr_priority > max_priority_num ) {
> +          lowest_scheduled = curr_node;
> +          max_priority_num = curr_priority;
> +  return lowest_scheduled;
Is it possible this is NULL? what happens if it is?
> -static void _Scheduler_strong_APA_Do_update(
> +static inline void _Scheduler_strong_APA_Extract_from_scheduled(
> -  Scheduler_Node *node_to_update,
> -  Priority_Control new_priority
> +  Scheduler_Node    *node_to_extract
> -    _Scheduler_strong_APA_Node_downcast( node_to_update );
> -  _Scheduler_SMP_Node_update_priority( &node->Base, new_priority );
> -  _Scheduler_priority_Ready_queue_update(
> -    SCHEDULER_PRIORITY_UNMAP( new_priority ),
> -    &self->Bit_map,
> -    &self->Ready[ 0 ]
> +  Scheduler_strong_APA_Context *self;
> -_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
> -  return (Scheduler_strong_APA_Context *) _Scheduler_Get_context( scheduler );
> +  self = _Scheduler_strong_APA_Get_self( context );
> +  node = _Scheduler_strong_APA_Node_downcast( node_to_extract );
> +  _Scheduler_SMP_Extract_from_scheduled( &self->Base.Base, &node->Base.Base );
> +  //Not removing it from All_nodes since the node could go in the ready state.
> +static inline void _Scheduler_strong_APA_Extract_from_ready(
> -    _Scheduler_strong_APA_Get_context( scheduler );
> -  _Scheduler_SMP_Initialize( &self->Base );
> -  _Priority_bit_map_Initialize( &self->Bit_map );
> -  _Scheduler_priority_Ready_queue_initialize(
> -    &self->Ready[ 0 ],
> -    scheduler->maximum_priority
> +  _Assert( !_Chain_Is_empty(self->All_nodes) );
> +  _Assert( !_Chain_Is_node_off_chain( &node->Chain ) );
> +   _Chain_Extract_unprotected( &node->Chain ); //Removed from All_nodes
All_nodes name is now confusing me. I thought  maybe it meant blocked
nodes too, but I understand now.
You can call the All_nodes chain 'Ready'. It should be OK to leave
Executing tasks on a Ready structure. That is how the uniprocessor
schedulers work as I recall.
> +   _Chain_Set_off_chain( &node->Chain );
> -  const Scheduler_Control *scheduler,
> +static inline void _Scheduler_strong_APA_Insert_ready(
> -  Scheduler_Context            *context;
> -  Scheduler_strong_APA_Node    *the_node;
> -  the_node = _Scheduler_strong_APA_Node_downcast( node );
> -  _Scheduler_SMP_Node_initialize(
> -    scheduler,
> -    &the_node->Base,
> -    the_thread,
> -    priority
> -  context = _Scheduler_Get_context( scheduler );
> -    &the_node->Ready_queue,
> -    SCHEDULER_PRIORITY_UNMAP( priority ),
> -    &self->Bit_map,
> -    &self->Ready[ 0 ]
> +  node = _Scheduler_strong_APA_Node_downcast( node_base );
> +  if(_Chain_Is_node_off_chain( &node->Chain ) )
ws after if and { } needed
> +    _Chain_Append_unprotected( &self->All_nodes, &node->Chain );
> -static bool _Scheduler_strong_APA_Has_ready( Scheduler_Context *context )
> +static inline void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
> +  Scheduler_Node    *scheduled_to_ready
> -  return !_Priority_bit_map_Is_empty( &self->Bit_map );
> +  _Scheduler_SMP_Extract_from_scheduled( context, scheduled_to_ready );
> +  insert_priority = _Scheduler_SMP_Node_priority( scheduled_to_ready );
> +  _Scheduler_strong_APA_Insert_ready(
> +    context,
> +    scheduled_to_ready,
> +    insert_priority
> -static Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
> +static inline Scheduler_Node* _Scheduler_strong_APA_Get_lowest_reachable(
> +  uint32_t                      front,
> +  uint32_t                      rear,
> +  Per_CPU_Control             **cpu_to_preempt
> +  Scheduler_Node              *lowest_reachable;
> +  uint32_t                    cpu_max;
> +  Scheduler_strong_APA_Node   *curr_strong_node; //Current Strong_APA_Node
> +    curr_thread = curr_CPU->heir;
> +    curr_strong_node = _Scheduler_strong_APA_Node_downcast( curr_node );
> +      lowest_reachable = curr_node;
> +      *cpu_to_preempt = curr_CPU;
> +    if ( !curr_thread->is_idle ) {
> +        if ( _Processor_mask_Is_set( &curr_strong_node->Affinity, cpu_index ) ) {
> +          //Checks if the thread_CPU is in the affinity set of the node
> +          if ( _Per_CPU_Is_processor_online( cpu ) && Struct[ cpu_index ].visited == false ) {
> +            rear = rear + 1;
> +            Struct[ rear ].cpu = cpu;
> +            Struct[ cpu_index ].visited = true;
> +            Struct[ cpu_index ].caller = curr_node;
maybe instead of caller it should be 'ancestor' or something similar
to denote the ordering.
> +  return lowest_reachable;
> +static inline bool _Scheduler_strong_APA_Do_enqueue(
> +  Scheduler_Node    *lowest_reachable,
> +  Priority_Control  insert_priority,
> +  Per_CPU_Control  *cpu_to_preempt
> -  (void) node;
> -  return (Scheduler_Node *) _Scheduler_priority_Ready_queue_first(
> -    &self->Bit_map,
> -    &self->Ready[ 0 ]
> +  bool                          needs_help;
> +  Priority_Control              node_priority;
> +  Priority_Control              lowest_priority;
> +  Thread_Control               *next_thread;
> +  node_priority = _Scheduler_Node_get_priority( node );
> +  node_priority = SCHEDULER_PRIORITY_PURIFY( node_priority );
> +  lowest_priority =  _Scheduler_Node_get_priority( lowest_reachable );
> +  lowest_priority = SCHEDULER_PRIORITY_PURIFY( lowest_priority );
> +  if( lowest_priority > node_priority ) {
> +    //_Thread_Get_CPU(lowest_reachable->user) to lowest_reachable, shifting
> +    //along every task
> +    curr_node = Struct[ _Per_CPU_Get_index(cpu_to_preempt) ].caller;
> +    curr_strong_node->invoker = cpu_to_preempt;
> +    //Save which cpu to preempt in invoker value of the node
> +    while( curr_node != node ) {
ws after while, and delete at end of line
> +      curr_CPU = _Thread_Get_CPU( curr_node->user );
> +      curr_node = Struct[ _Per_CPU_Get_index( curr_CPU ) ].caller;
> +      curr_strong_node->invoker =  curr_CPU;
> +    next_thread = curr_strong_node->invoker->heir;
> +    next_node = _Thread_Scheduler_get_home_node( next_thread );
> +    node_priority = _Scheduler_Node_get_priority( curr_node );
> +    _Scheduler_SMP_Enqueue_to_scheduled(
> +      context,
> +      curr_node,
> +      node_priority,
> +      next_node,
> +      _Scheduler_SMP_Insert_scheduled,
> +      _Scheduler_strong_APA_Move_from_scheduled_to_ready,
> +    curr_node = next_node;
> +    while( curr_node !=  lowest_reachable) {
ws
> +      //curr_node preempts the next_node;
> +       context,
> +       curr_node,
> +       next_node,
> +    _Scheduler_strong_APA_Move_from_scheduled_to_ready(context, lowest_reachable);
> +    needs_help = false;
> +  } else {
> +    needs_help = true;
> +  //Add it to All_nodes chain since it is now either scheduled or just ready.
> +  _Scheduler_strong_APA_Insert_ready(context,node,insert_priority);
ws in params
> +  return needs_help;
> -void _Scheduler_strong_APA_Block(
> +static inline bool _Scheduler_strong_APA_Enqueue(
> -  Scheduler_Context *context = _Scheduler_Get_context( scheduler );
> +  //Idea: BFS Algorithm for task arrival
> +  //Enqueue node either in the scheduled chain or in the ready chain
> +  //node is the newly arrived node and is not scheduled.
> +  uint32_t                     cpu_max;
> +  Per_CPU_Control              *cpu_to_preempt;
> +  Scheduler_strong_APA_Node    *strong_node;
> +  uint32_t     front;
> +  uint32_t     rear;
> +  front = 0;
> +  rear = -1;
> -  _Scheduler_SMP_Block(
> +  strong_node = _Scheduler_strong_APA_Node_downcast( node );
> +    if ( _Processor_mask_Is_set( &strong_node->Affinity, cpu_index) ) {
> +        rear = rear + 1;
> +        Struct[ cpu_index ].caller = node;
> +  //This assert makes sure that there always exist an element in the
> +  // Queue when we start the queue traversal.
> +  _Assert( !_Processor_mask_Zero( &strong_node->Affinity ) );
> +  lowest_reachable = _Scheduler_strong_APA_Get_lowest_reachable(
> +                       self,
> +                       front,
> +                       rear,
> +                       &cpu_to_preempt
indents
> +  return _Scheduler_strong_APA_Do_enqueue(
> +           context,
> +           lowest_reachable,
> +           node,
> +           insert_priority,
> +           cpu_to_preempt
indents
> +static inline bool _Scheduler_strong_APA_Enqueue_scheduled(
> +  return _Scheduler_SMP_Enqueue_scheduled(
>      context,
> -    the_thread,
>      node,
> -    _Scheduler_SMP_Extract_from_scheduled,
> +    insert_priority,
> +    _Scheduler_SMP_Priority_less_equal,
>      _Scheduler_strong_APA_Extract_from_ready,
>      _Scheduler_strong_APA_Get_highest_ready,
> +    _Scheduler_strong_APA_Insert_ready,
>      _Scheduler_strong_APA_Move_from_ready_to_scheduled,
> -    _Scheduler_SMP_Allocate_processor_exact
> -static bool _Scheduler_strong_APA_Enqueue(
> +static inline bool _Scheduler_strong_APA_Do_ask_for_help(
> +  Thread_Control    *the_thread,
> -  return _Scheduler_SMP_Enqueue(
> +  return _Scheduler_SMP_Ask_for_help(
>      context,
> +    the_thread,
>      node,
> -    insert_priority,
> -    _Scheduler_SMP_Get_lowest_scheduled,
> +    _Scheduler_strong_APA_Get_lowest_scheduled,
> -static bool _Scheduler_strong_APA_Enqueue_scheduled(
> +static inline void _Scheduler_strong_APA_Register_idle(
> +  Scheduler_Node    *idle_base,
> -  return _Scheduler_SMP_Enqueue_scheduled(
> +  (void) context;
> +  (void) idle_base;
> +  (void) cpu;
> +  //We do not maintain a variable to access the scheduled
> +  //node for a CPU. So this function does nothing.
> +static inline  void  _Scheduler_strong_APA_Do_set_affinity(
> +  void              *arg
> +  const Processor_mask      *affinity;
> +  affinity = arg;
> +  node->Affinity = *affinity;
can simplify to:
   node->Affinity = (const Processor_mask *)arg;
> +void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler )
> +    _Scheduler_strong_APA_Get_context( scheduler );
two more spaces, need to indent 2 levels for line break
> +  _Scheduler_SMP_Initialize( &self->Base );
> +  _Chain_Initialize_empty( &self->All_nodes );
> +  Scheduler_Context *context = _Scheduler_Get_context( scheduler );
> +  _Scheduler_SMP_Yield(
>      context,
> +    thread,
>      node,
> -    insert_priority,
> -    _Scheduler_SMP_Priority_less_equal,
> -    _Scheduler_strong_APA_Get_highest_ready,
> -    _Scheduler_strong_APA_Insert_ready,
> -    _Scheduler_SMP_Insert_scheduled,
> -    _Scheduler_strong_APA_Move_from_ready_to_scheduled,
> +    _Scheduler_strong_APA_Enqueue,
> +    _Scheduler_strong_APA_Enqueue_scheduled
> -void _Scheduler_strong_APA_Unblock(
> +void _Scheduler_strong_APA_Block(
> -  _Scheduler_SMP_Unblock(
> +  //The extract from ready automatically removes the node from All_nodes chain.
> +  _Scheduler_SMP_Block(
>      context,
> -    the_thread,
> +    thread,
>      node,
> -    _Scheduler_strong_APA_Do_update,
> -    _Scheduler_strong_APA_Enqueue
> +    _Scheduler_strong_APA_Extract_from_scheduled,
> +    _Scheduler_strong_APA_Extract_from_ready,
> +    _Scheduler_strong_APA_Get_highest_ready,
> +    _Scheduler_strong_APA_Move_from_ready_to_scheduled,
> -static bool _Scheduler_strong_APA_Do_ask_for_help(
> -  Scheduler_Context *context,
> +void _Scheduler_strong_APA_Unblock(
> -  return _Scheduler_SMP_Ask_for_help(
> +  _Scheduler_SMP_Unblock(
>      context,
> -    the_thread,
> +    thread,
>      node,
> -    _Scheduler_strong_APA_Move_from_scheduled_to_ready,
> -    _Scheduler_SMP_Allocate_processor_lazy
> +    _Scheduler_strong_APA_Do_update,
> @@ -327,7 +765,7 @@ void _Scheduler_strong_APA_Update_priority(
>    _Scheduler_SMP_Update_priority(
>      context,
> -    the_thread,
> +    thread,
>      node,
> @@ -345,7 +783,11 @@ bool _Scheduler_strong_APA_Ask_for_help(
> -  return _Scheduler_strong_APA_Do_ask_for_help( context, the_thread, node );
> +  return _Scheduler_strong_APA_Do_ask_for_help(
> +    context,
> +    the_thread,
> +    node
> @@ -381,7 +823,7 @@ void _Scheduler_strong_APA_Withdraw_node(
> @@ -397,7 +839,7 @@ void _Scheduler_strong_APA_Add_processor(
>      idle,
>      _Scheduler_strong_APA_Has_ready,
>      _Scheduler_strong_APA_Enqueue_scheduled,
> -    _Scheduler_SMP_Do_nothing_register_idle
> +    _Scheduler_strong_APA_Register_idle
why not use the Do_nothing?
> @@ -416,20 +858,83 @@ Thread_Control *_Scheduler_strong_APA_Remove_processor(
> +  _Scheduler_SMP_Node_initialize( scheduler, smp_node, the_thread, priority );
> +  _Processor_mask_Assign(
> +    &strong_node->Affinity,
> +   _SMP_Get_online_processors()
> -  _Scheduler_SMP_Yield(
> +  Scheduler_Context *context;
> +  context = _Scheduler_Get_context( scheduler );
> +  _Scheduler_SMP_Do_start_idle(
>      context,
> -    the_thread,
> -    node,
> -    _Scheduler_strong_APA_Extract_from_ready,
> -    _Scheduler_strong_APA_Enqueue,
> -    _Scheduler_strong_APA_Enqueue_scheduled
> +    idle,
> +    cpu,
> +  Processor_mask             local_affinity;
> +  _Processor_mask_And( &local_affinity, &context->Processors, affinity );
> +  if ( _Processor_mask_Is_zero( &local_affinity ) ) {
> +    return false;
> +  if ( _Processor_mask_Is_equal( &node->Affinity, affinity ) )
> +    return true;       //Nothing to do. Return true.
> + _Processor_mask_Assign( &node->Affinity, &local_affinity );
> + _Scheduler_SMP_Set_affinity(
> +   context,
> +   thread,
> +   node_base,
> +   &local_affinity,
> +   _Scheduler_strong_APA_Do_set_affinity,
> +  return true;
> 2.17.1
> devel mailing list
> devel at rtems.org
