[PATCH v2] Pre Release: Strong APA
Richi Dubey
richidubey at gmail.com
Tue Aug 25 11:04:13 UTC 2020
Hi,
Thanks a lot for this detailed review. I will work on each point that you
mentioned.
On Mon, Aug 24, 2020 at 11:07 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Aug 24, 2020 at 10:14 AM Richi Dubey <richidubey at gmail.com> wrote:
> > cpukit/include/rtems/scheduler.h | 6 +-
> > .../include/rtems/score/schedulerstrongapa.h | 284 ++++--
> > cpukit/score/src/schedulerstrongapa.c | 913 ++++++++++++++----
> > 3 files changed, 901 insertions(+), 302 deletions(-)
> > diff --git a/cpukit/include/rtems/scheduler.h
> b/cpukit/include/rtems/scheduler.h
> > index 955a83cfb4..b101842ba7 100644
> > --- a/cpukit/include/rtems/scheduler.h
> > +++ b/cpukit/include/rtems/scheduler.h
> > @@ -257,16 +257,14 @@
> > #define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
> > static struct { \
> > Scheduler_strong_APA_Context Base; \
> > - Chain_Control Ready[ ( prio_count ) ]; \
> > + Scheduler_strong_APA_Struct Struct[ CONFIGURE_MAXIMUM_PROCESSORS
> I don't like this name at all either the type or the variable
> "Struct". Just like I wouldn't call a variable
> int Int;
> > } SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
> > #define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
> > &SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
> > SCHEDULER_STRONG_APA_ENTRY_POINTS, \
> > - RTEMS_ARRAY_SIZE( \
> > - SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Ready \
> > - ) - 1, \
> > + SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
> > ( obj_name ) \
> > SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
> > diff --git a/cpukit/include/rtems/score/schedulerstrongapa.h
> b/cpukit/include/rtems/score/schedulerstrongapa.h
> > index 0ac28cb439..86d91688e8 100644
> > --- a/cpukit/include/rtems/score/schedulerstrongapa.h
> > +++ b/cpukit/include/rtems/score/schedulerstrongapa.h
> > @@ -6,31 +6,38 @@
> > * @brief Strong APA Scheduler API
> > - * Copyright (c) 2013, 2018 embedded brains GmbH. All rights reserved.
> > + * Copyright (c) 2020 Richi Dubey
> > - * embedded brains GmbH
> > - * Dornierstr. 4
> > - * 82178 Puchheim
> > - * Germany
> > - * <rtems at embedded-brains.de>
> > + * <richidubey at gmail.com>
> > - * The license and distribution terms for this file may be
> > - * found in the file LICENSE in this distribution or at
> > + * Copyright (c) 2013, 2018 embedded brains GmbH. All rights reserved.
> > + * embedded brains GmbH
> > + * Dornierstr. 4
> > + * 82178 Puchheim
> > + * Germany
> > + * <rtems at embedded-brains.de>
> > + * The license and distribution terms for this file may be
> > + * found in the file LICENSE in this distribution or at
> > * http://www.rtems.org/license/LICENSE.
> relicense 2-bsd -- EB allows it, and your new code should be put under it
> > #ifndef _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
> > #define _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
> > #include <rtems/score/scheduler.h>
> > -#include <rtems/score/schedulerpriority.h>
> > #include <rtems/score/schedulersmp.h>
> > +#include <rtems/score/percpu.h>
> > #ifdef __cplusplus
> > extern "C" {
> > #endif /* __cplusplus */
> > +#define STRONG_SCHEDULER_NODE_OF_CHAIN( node ) \
> > + RTEMS_CONTAINER_OF( next, Scheduler_strong_APA_Node, Chain )
> somehow this is not using 'node' parameter?
> > * @defgroup RTEMSScoreSchedulerStrongAPA Strong APA Scheduler
> > @@ -38,43 +45,98 @@ extern "C" {
> > - * This is an implementation of the global fixed priority scheduler
> (G-FP). It
> > - * uses one ready chain per priority to ensure constant time insert
> operations.
> > - * The scheduled chain uses linear insert operations and has at most
> processor
> > - * count entries. Since the processor and priority count are constants
> all
> > - * scheduler operations complete in a bounded execution time.
> > + * This is an implementation of the Strong APA scheduler defined by
> > + * Cerqueira et al. in Linux's Processor Affinity API, Refined:
> > + * Shifting Real-Time Tasks Towards Higher Schedulability.
> > - * The the_thread preempt mode will be ignored.
> repeating text?
> You should add a bit more comment about the high-level design here. Of
> course anyone wanting more details can go to the paper.
> > - * @brief Scheduler context specialization for Strong APA
> > - * schedulers.
> > -typedef struct {
> > - Scheduler_SMP_Context Base;
> > - Priority_bit_map_Control Bit_map;
> > - Chain_Control Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
> > -} Scheduler_strong_APA_Context;
> > - * @brief Scheduler node specialization for Strong APA
> > - * schedulers.
> > + * @brief Scheduler node specialization for Strong APA schedulers.
> > typedef struct {
> > * @brief SMP scheduler node.
> > Scheduler_SMP_Node Base;
> > + * @brief Chain node for Scheduler_strong_APA_Context::All_nodes
> > + Chain_Node Chain;
> Don't call this Chain. We refer to a Chain_Control object as the
> chain. Some other ideas:
> * APA_Node
> * All_nodes_Node
> * All_nodes_Link
> * Link
> * Node (that could be confusing)
> * Link_Node
> I always felt like Joel missed an opportunity to call them Chain Links
> instead of Chain Nodes. Then compiler memory fences for synchronizing
> them could be Chain Link Fences? (A bit of dad humor.)
> > + * @brief CPU that this node would preempt in the backtracking part of
> > + * _Scheduler_strong_APA_Get_highest_ready and
> > + * _Scheduler_strong_APA_Do_Enqueue.
> > + Per_CPU_Control *invoker;
> I don't like this name either. What is the invoker invoking? Since it
> is used to go backwards, maybe think of a word that conveys that use.
> 'lowest_scheduled'? 'next_to_preempt'?
> > - * @brief The associated ready queue of this node.
> > + * @brief The associated affinity set of this node.
> > - Scheduler_priority_Ready_queue Ready_queue;
> > + Processor_mask Affinity;
> > } Scheduler_strong_APA_Node;
> > + * @brief Struct for each index of the variable size arrays
> clarify this comment, no one knows what this means.
> Add a period (full stop) after brief sentence.
> > +typedef struct
> > + * @brief The node that called this CPU, i.e. a node which has
> 'called' the CPU? That doesn't make sense to me.
> > + * the cpu at the index of Scheduler_strong_APA_Context::Struct in
> this comment makes no sense without understanding how this structure
> is being used.
> furthermore, the 'instance' of this structure is "at the index of
> Scheduler_strong_APA_Context::Struct" so you can just say "The
> scheduling node (owning the thread? executing on?) of a cpu in the BFS
> queue. Since by now you'll already have explained what is the BFS algo
> and queue in use.
> > + * its affinity set.
> > + Scheduler_Node *caller;
> Not sure what it called. Think about what this name means a bit more.
> > + * @brief Cpu at the index of Scheduler_strong_APA_Context::Struct
> Isn't this self-referencing? Just say "CPU in a queue"?
> > + * in Queue implementation.
> > + Per_CPU_Control *cpu;
> > + * @brief Indicates if the CPU at the index of
> > + * Scheduler_strong_APA_Context::Struct is already
> > + * added to the Queue or not.
> Whether or not this cpu has been added to the queue (visited in the BFS)
> > + bool visited;
> > +} Scheduler_strong_APA_Struct;
> Maybe, Scheduler_strong_APA_BFS_node;
> > + * @brief Scheduler context for Strong APA scheduler.
> > + * Has the structure for scheduler context
> > + * and Node defintion for Strong APA scheduler
> typo: definition
> This little phrase seems not that helpful. Either merge to the brief
> or expand it further with details.
> "@brief Scheduler context and node definition for Strong APA scheduler."
> > +typedef struct {
> > + * @brief SMP Context to refer to SMP implementation
> > + * code.
> > + Scheduler_SMP_Context Base;
> I don't think these 'Base' need to be documented, or at best you can
> just have @see Scheduler_SMP_Context?
> > + * @brief Chain of all the nodes present in
> > + * the system. Accounts for ready and scheduled nodes.
> Not the system, but the (strong APA) scheduler?
> > + Chain_Control All_nodes;
> > + * @brief Struct with important variables for each cpu
> improve this comment.
> > + Scheduler_strong_APA_Struct Struct[ RTEMS_ZERO_LENGTH_ARRAY ];
> > +} Scheduler_strong_APA_Context;
> > +#define SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY 255
> > * @brief Entry points for the Strong APA Scheduler.
> > @@ -100,81 +162,90 @@ typedef struct {
> > _Scheduler_default_Release_job, \
> > _Scheduler_default_Cancel_job, \
> > _Scheduler_default_Tick, \
> > - _Scheduler_SMP_Start_idle \
> > - SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
> > + _Scheduler_strong_APA_Start_idle, \
> > + _Scheduler_strong_APA_Set_affinity \
> > - * @brief Initializes the scheduler.
> > + * @brief Initializes the Strong_APA scheduler.
> > - * @param scheduler The scheduler to initialize.
> > -void _Scheduler_strong_APA_Initialize( const Scheduler_Control
> *scheduler );
> > + * Sets the chain containing all the nodes to empty
> > + * and initializes the SMP scheduler.
> > + * @param scheduler used to get reference to Strong APA scheduler
> context
> > + * @retval void
> I don't think we document void retval. It is a kind of oxymoron.
> > + * @see _Scheduler_strong_APA_Node_initialize()
> > +void _Scheduler_strong_APA_Initialize(
> > + const Scheduler_Control *scheduler
> > - * @brief Initializes the node with the given priority.
> > + * @brief Called when a node yields the processor
> add period.
> I think technically the thread yields the processor.
> > * @param scheduler The scheduler control instance.
> > - * @param[out] node The node to initialize.
> > - * @param the_thread The thread of the node to initialize.
> > - * @param priority The priority for @a node.
> > + * @param thread Thread corresponding to @node
> > + * @param node Node that yield the processor
> Kind of backwards. The thread yields the processor, and the Node is
> corresponding to the thread.
> Maybe check how other schedulers document this stuff. I don't know why
> you are changing it from the existing template file? I shouldn't have
> to be spending time reviewing these kinds of reformatting changes
> (especially when what's in the repo seems correct and your changes
> seem wrong). I'm going to ignore the rest of your doxygen, but please
> make similar fixes as I mentioned already, or revert the changes you
> made to the existing doco.
> > -void _Scheduler_strong_APA_Node_initialize(
> > +void _Scheduler_strong_APA_Yield(
> > const Scheduler_Control *scheduler,
> > - Scheduler_Node *node,
> > - Thread_Control *the_thread,
> > - Priority_Control priority
> > + Thread_Control *thread,
> > + Scheduler_Node *node
> > - * @brief Blocks the thread.
> > + * @brief Blocks a node
> > - * @param scheduler The scheduler control instance.
> > - * @param[in, out] the_thread The thread to block.
> > - * @param[in, out] node The node of the thread to block.
> > + * Changes the state of the node and extracts it from the queue
> > + * calls _Scheduler_SMP_Block().
> > + * @param context The scheduler control instance.
> > + * @param thread Thread correspoding to the @node.
> > + * @param node node which is to be blocked
> > void _Scheduler_strong_APA_Block(
> > - * @brief Unblocks the thread.
> > + * @brief Unblocks a node
> > + * Changes the state of the node and calls _Scheduler_SMP_Unblock().
> > - * @param[in, out] the_thread The thread to unblock.
> > - * @param[in, out] node The node of the thread to unblock.
> > + * @param node node which is to be unblocked
> > + * @see _Scheduler_strong_APA_Enqueue()
> > + * @see _Scheduler_strong_APA_Do_update()
> > void _Scheduler_strong_APA_Unblock(
> > - * @brief Updates the priority of the node.
> > + * @brief Updates the priority of the node
> See, this one just really bugs me. I really am going to ignore these
> doxygen changes.
> > - * @param the_thread The thread for the operation.
> > - * @param[in, out] node The node to update the priority of.
> > + * @param node Node whose priority has to be updated
> > void _Scheduler_strong_APA_Update_priority(
> > - * @brief Asks for help.
> > + * @brief Calls the SMP Ask_for_help
> > - * @param the_thread The thread that asks for help.
> > - * @param node The node of @a the_thread.
> > - * @retval true The request for help was successful.
> > - * @retval false The request for help was not successful.
> > + * @param scheduler The scheduler control instance.
> > + * @param thread Thread correspoding to the @node that asks for help.
> > + * @param node node associated with @thread
> > bool _Scheduler_strong_APA_Ask_for_help(
> > @@ -182,12 +253,13 @@ bool _Scheduler_strong_APA_Ask_for_help(
> > - * @brief Reconsiders help request.
> > + * @brief To Reconsider the help request
> > - * @param the_thread The thread to reconsider the help request of.
> > - * @param[in, out] node The node of @a the_thread
> > + * @param node Node corresponding to @thread which asks for
> > + * reconsideration
> > void _Scheduler_strong_APA_Reconsider_help_request(
> > @@ -195,13 +267,13 @@ void _Scheduler_strong_APA_Reconsider_help_request(
> > - * @brief Withdraws the node.
> > + * @brief Withdraws a node
> > - * @param[in, out] the_thread The thread to change the state to @a
> next_state.
> > - * @param[in, out] node The node to withdraw.
> > - * @param next_state The next state for @a the_thread.
> > + * @param node Node that has to be withdrawn
> > + * @param next_state the state that the node goes to
> > void _Scheduler_strong_APA_Withdraw_node(
> > @@ -210,42 +282,66 @@ void _Scheduler_strong_APA_Withdraw_node(
> > - * @brief Adds the idle thread to a processor.
> > + * @brief Adds a processor to the scheduler instance
> > + * and allocates an idle thread to the processor.
> > - * @param[in, out] The idle thread to add to the processor.
> > + * @param idle Idle thread to be allocated to the processor
> > void _Scheduler_strong_APA_Add_processor(
> > Thread_Control *idle
> > - * @brief Removes an idle thread from the given cpu.
> > - * @param scheduler The scheduler instance.
> > - * @param cpu The cpu control to remove from @a scheduler.
> > + * @brief Removes a processor from the scheduler instance
> > - * @return The idle thread of the processor.
> > + * @param cpu processor that is removed
> > Thread_Control *_Scheduler_strong_APA_Remove_processor(
> > - struct Per_CPU_Control *cpu
> > - * @brief Performs a yield operation.
> > + * @brief Initializes the node with the given priority.
> > - * @param the_thread The thread to yield.
> > - * @param[in, out] node The node of @a the_thread.
> > + * @param[out] node The node to initialize.
> > + * @param the_thread The thread of the node to initialize.
> > + * @param priority The priority for @a node.
> > -void _Scheduler_strong_APA_Yield(
> > +void _Scheduler_strong_APA_Node_initialize(
> > + Scheduler_Node *node,
> > + Priority_Control priority
> > + * @brief Starts an idle thread on a CPU
> > + * @param idle Idle Thread
> > + * @param cpu processor that gets the idle thread
> > +void _Scheduler_strong_APA_Start_idle(
> > + const Scheduler_Control *scheduler,
> > + Thread_Control *idle,
> > + * @brief Sets the affinity of the @node_base to @affinity
> > +bool _Scheduler_strong_APA_Set_affinity(
> > + Scheduler_Node *node_base,
> > + const Processor_mask *affinity
> > #ifdef __cplusplus
> > diff --git a/cpukit/score/src/schedulerstrongapa.c
> b/cpukit/score/src/schedulerstrongapa.c
> > index 924cd86412..a3f4c49cab 100644
> > --- a/cpukit/score/src/schedulerstrongapa.c
> > +++ b/cpukit/score/src/schedulerstrongapa.c
> > @@ -6,320 +6,758 @@
> > * @brief Strong APA Scheduler Implementation
> > - * Copyright (c) 2013, 2016 embedded brains GmbH. All rights reserved.
> > - * Dornierstr. 4
> > - * 82178 Puchheim
> > - * Germany
> > + * Dornierstr. 4
> > + * 82178 Puchheim
> > + * Germany
> > #ifdef HAVE_CONFIG_H
> > #include "config.h"
> > #endif
> > #include <rtems/score/schedulerstrongapa.h>
> > -#include <rtems/score/schedulerpriorityimpl.h>
> > #include <rtems/score/schedulersmpimpl.h>
> > +#include <rtems/score/assert.h>
> > +#include <rtems/malloc.h>
> > -static Scheduler_strong_APA_Context *_Scheduler_strong_APA_Get_self(
> > - Scheduler_Context *context
> > +static inline Scheduler_strong_APA_Context *
> > +_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
> > + return (Scheduler_strong_APA_Context *) _Scheduler_Get_context(
> scheduler );
> > +_Scheduler_strong_APA_Get_self( Scheduler_Context *context )
> > return (Scheduler_strong_APA_Context *) context;
> > -static Scheduler_strong_APA_Node *
> > +static inline Scheduler_strong_APA_Node *
> > _Scheduler_strong_APA_Node_downcast( Scheduler_Node *node )
> > return (Scheduler_strong_APA_Node *) node;
> > -static void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
> > +static inline void _Scheduler_strong_APA_Do_update(
> > Scheduler_Context *context,
> > - Scheduler_Node *scheduled_to_ready
> > + Priority_Control new_priority
> > - Scheduler_strong_APA_Context *self =
> > - _Scheduler_strong_APA_Get_self( context );
> > - Scheduler_strong_APA_Node *node =
> > - _Scheduler_strong_APA_Node_downcast( scheduled_to_ready );
> > - _Chain_Extract_unprotected( &node->Base.Base.Node.Chain );
> > - _Scheduler_priority_Ready_queue_enqueue_first(
> > - &node->Base.Base.Node.Chain,
> > - &node->Ready_queue,
> > - &self->Bit_map
> > + Scheduler_SMP_Node *smp_node;
> > + (void) context;
> > + smp_node = _Scheduler_SMP_Node_downcast( node );
> > + _Scheduler_SMP_Node_update_priority( smp_node, new_priority );
> Although we don't need doxygen for static (private) methods, a little
> bit of comment can be helpful to understand what the helper function
> does.
> > +static inline bool _Scheduler_strong_APA_Has_ready( Scheduler_Context
> *context )
> > + Scheduler_strong_APA_Context *self = _Scheduler_strong_APA_Get_self(
> context );
> > + bool ret;
> > + const Chain_Node *tail;
> > + Chain_Node *next;
> > + Scheduler_strong_APA_Node *node;
> > + tail = _Chain_Immutable_tail( &self->All_nodes );
> > + next = _Chain_First( &self->All_nodes );
> > + ret = false;
> > + while ( next != tail ) {
> > + node = (Scheduler_strong_APA_Node *)
> STRONG_SCHEDULER_NODE_OF_CHAIN( next );
> I see, this only works by chance. fix your macro so it works on purpose.
> > + if (
> > + _Scheduler_SMP_Node_state( &node->Base.Base ) ==
> SCHEDULER_SMP_NODE_READY
> not enough indent levels
> To break this you should use
> if (
> I know it is kind of ugly.
> > + ret = true;
> > + break;
> this is fine, but it could also be 'return true;' and then ...
> > + next = _Chain_Next( next );
> > + return ret;
> return false;
> Minor nit, but it does simplify your code
> > +static inline void _Scheduler_strong_APA_Allocate_processor(
> > + Scheduler_Context *context,
> > + Scheduler_Node *scheduled_base,
> > + Scheduler_Node *victim_base,
> > + Per_CPU_Control *victim_cpu
> > + Scheduler_strong_APA_Node *scheduled;
> > + (void) victim_base;
> I personally would like a blank line after this warning suppression to
> separate it from 'real code' in my head.
> > + scheduled = _Scheduler_strong_APA_Node_downcast( scheduled_base );
> > + _Scheduler_SMP_Allocate_processor_exact(
> > + context,
> > + &(scheduled->Base.Base),
> > + NULL,
> > + victim_cpu
> > -static void _Scheduler_strong_APA_Move_from_ready_to_scheduled(
> > +static inline Scheduler_Node * _Scheduler_strong_APA_Find_highest_ready(
> > + Scheduler_strong_APA_Context *self,
> > + uint32_t front,
> > + uint32_t rear
> > + Scheduler_Node *highest_ready;
> > + Scheduler_strong_APA_Struct *Struct;
> > + Chain_Node *next;
> > + uint32_t index_assigned_cpu;
> > + Priority_Control min_priority_num;
> > + Priority_Control curr_priority;
> > + Per_CPU_Control *assigned_cpu;
> > + Scheduler_SMP_Node_state curr_state;
> > + Per_CPU_Control *curr_CPU;
> > + bool first_task;
> > + Struct = self->Struct;
> > + //When the first task accessed has nothing to compare its priority
> against
> > + // So, it is the task with the highest priority witnessed so far!
> Use /* */
> > + first_task = true;
> > + while( front <= rear ) {
> > + curr_CPU = Struct[ front ].cpu;
> Who ensures that rear < sizeof(Struct)?
> > + front = front + 1;
> > + node = (Scheduler_strong_APA_Node*)
> > + //Check if the curr_CPU is in the affinity set of the node
> > + if (
> > + _Processor_mask_Is_set(&node->Affinity,
> _Per_CPU_Get_index(curr_CPU))
> extra ws at end of line
> you can search a regex like "\s\s*$" for that kind of problem
> > + curr_state = _Scheduler_SMP_Node_state( &node->Base.Base );
> > + if ( curr_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
> > + assigned_cpu = _Thread_Get_CPU( node->Base.Base.user );
> > + index_assigned_cpu = _Per_CPU_Get_index( assigned_cpu );
> > + if ( Struct[ index_assigned_cpu ].visited == false ) {
> > + rear = rear + 1;
> > + Struct[ rear ].cpu = assigned_cpu;
> > + Struct[ index_assigned_cpu ].visited = true;
> OK this is a little bit confusing. You are using the same 'Struct[]'
> entry to store metadata for two different CPUs. Somehow you need to
> either clarify this, or make it consistent.
> > + // The curr CPU of the queue invoked this node to add its
> CPU
> > + // that it is executing on to the queue. So this node might
> get
> > + // preempted because of the invoker curr_CPU and this
> curr_CPU
> > + // is the CPU that node should preempt in case this node
> > + // gets preempted.
> > + node->invoker = curr_CPU;
> > + else if ( curr_state == SCHEDULER_SMP_NODE_READY ) {
> > + curr_priority = _Scheduler_Node_get_priority(
> &node->Base.Base );
> > + curr_priority = SCHEDULER_PRIORITY_PURIFY( curr_priority );
> > + if ( first_task == true || curr_priority < min_priority_num )
> you can also initialize min_priority_num to the scheduler's maximum
> priority value? Then get rid of this first_task var?
> > + min_priority_num = curr_priority;
> > + highest_ready = &node->Base.Base;
> > + first_task = false;
> > + //In case this task is directly reachable from thread_CPU
> I don't know what this comment means.
> > + return highest_ready;
> > +static inline void _Scheduler_strong_APA_Move_from_ready_to_scheduled(
> > Scheduler_Node *ready_to_scheduled
> > - Scheduler_strong_APA_Context *self;
> > - Scheduler_strong_APA_Node *node;
> > - Priority_Control insert_priority;
> > + Priority_Control insert_priority;
> > - self = _Scheduler_strong_APA_Get_self( context );
> > - node = _Scheduler_strong_APA_Node_downcast( ready_to_scheduled );
> > - _Scheduler_priority_Ready_queue_extract(
> > - &self->Bit_map
> > - insert_priority = _Scheduler_SMP_Node_priority( &node->Base.Base );
> > + insert_priority = _Scheduler_SMP_Node_priority( ready_to_scheduled );
> > insert_priority = SCHEDULER_PRIORITY_APPEND( insert_priority );
> > - _Chain_Insert_ordered_unprotected(
> > - &self->Base.Scheduled,
> > - &insert_priority,
> > - _Scheduler_SMP_Priority_less_equal
> > + _Scheduler_SMP_Insert_scheduled(
> > + context,
> > + ready_to_scheduled,
> > + insert_priority
> > -static void _Scheduler_strong_APA_Insert_ready(
> > +static inline Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
> > - Scheduler_Node *node_base,
> > + Scheduler_Node *filter
> > + //Implement the BFS Algorithm for task departure
> > + //to get the highest ready task for a particular CPU
> > + //return the highest ready Scheduler_Node and Scheduler_Node filter
> here points
> > + // to the victim node that is blocked resulting which this function
> is called.
> > + Per_CPU_Control *filter_cpu;
> > - node = _Scheduler_strong_APA_Node_downcast( node_base );
> > - if ( SCHEDULER_PRIORITY_IS_APPEND( insert_priority ) ) {
> > - _Scheduler_priority_Ready_queue_enqueue(
> > - &self->Bit_map
> > - } else {
> > - &self->Bit_map
> > + Scheduler_Node *curr_node;
> > + Scheduler_Node *next_node;
> > + uint32_t front;
> > + uint32_t rear;
> > + uint32_t cpu_max;
> > + uint32_t cpu_index;
> > + self=_Scheduler_strong_APA_Get_self( context );
> ws
> > + //Denotes front and rear of the queue
> > + front = 0;
> > + rear = -1;
> > + filter_cpu = _Thread_Get_CPU( filter->user );
> > + cpu_max = _SMP_Get_processor_maximum();
> I think there is a valid scheduler at cpu_max?
> > + for ( cpu_index = 0 ; cpu_index < cpu_max ; ++cpu_index ) {
> So this should be <= not <
> Maybe?
> > + Struct[ cpu_index ].visited = false;
> > + rear = rear + 1;
> why not just init rear to 0?
> > + Struct[ rear ].cpu = filter_cpu;
> > + Struct[ _Per_CPU_Get_index( filter_cpu ) ].visited = true;
> > + highest_ready = _Scheduler_strong_APA_Find_highest_ready(
> > + self,
> > + front,
> > + rear
> wrong indents
> > + if ( highest_ready != filter ) {
> > + //Backtrack on the path from
> > + //filter_cpu to highest_ready, shifting along every task.
> > + node = _Scheduler_strong_APA_Node_downcast( highest_ready );
> > + if( node->invoker != filter_cpu ) {
> > + // Highest ready is not just directly reachable from the victim
> cpu
> > + // So there is need of task shifting
> > + curr_node = &node->Base.Base;
> > + next_node = _Thread_Scheduler_get_home_node( node->invoker->heir
> > + _Scheduler_SMP_Preempt(
> > + context,
> > + curr_node,
> > + _Thread_Scheduler_get_home_node( node->invoker->heir ),
> > + _Scheduler_strong_APA_Allocate_processor
> > + _Scheduler_strong_APA_Move_from_ready_to_scheduled(context,
> curr_node);
> > + node = _Scheduler_strong_APA_Node_downcast( next_node );
> > + while( node->invoker != filter_cpu ){
> node->invoker->heir );
> > + context,
> > + curr_node,
> This is repetitive code, can you merge the first part of the 'if'
> block into the while loop?
> > + //To save the last node so that the caller SMP_* function
> > + //can do the allocation
> > + highest_ready = curr_node;
> > -static void _Scheduler_strong_APA_Extract_from_ready(
> *_Scheduler_strong_APA_Get_lowest_scheduled(
> > - Scheduler_Node *the_thread
> > + Scheduler_Node *filter_base
> > - _Scheduler_strong_APA_Node_downcast( the_thread );
> > - &self->Bit_map
> > + //Checks the lowest scheduled directly reachable task
> put as /* */ before the function declaration
> > + uint32_t cpu_max;
> > + Thread_Control *curr_thread;
> > + Scheduler_Node *lowest_scheduled;
> > + Priority_Control max_priority_num;
> > + Scheduler_strong_APA_Node *filter_strong_node;
> > + lowest_scheduled = NULL; //To remove compiler warning.
> > + max_priority_num = 0;//Max (Lowest) priority encountered so far.
> ws
> > + filter_strong_node = _Scheduler_strong_APA_Node_downcast( filter_base
> > + //lowest_scheduled is NULL if affinty of a node is 0
> typo
> > + _Assert( !_Processor_mask_Zero( &filter_strong_node->Affinity ) );
> > + //Checks if the CPU is in the affinity set of filter_strong_node
> > + if ( _Processor_mask_Is_set( &filter_strong_node->Affinity,
> cpu_index) ) {
> > + Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
> > + if ( _Per_CPU_Is_processor_online( cpu ) ) {
> > + curr_thread = cpu->heir;
> > + curr_node = _Thread_Scheduler_get_home_node( curr_thread );
> > + curr_priority = _Scheduler_Node_get_priority( curr_node );
> > + if ( curr_priority > max_priority_num ) {
> > + lowest_scheduled = curr_node;
> > + max_priority_num = curr_priority;
> > + return lowest_scheduled;
> Is it possible this is NULL? what happens if it is?
> > -static void _Scheduler_strong_APA_Do_update(
> > +static inline void _Scheduler_strong_APA_Extract_from_scheduled(
> > - Scheduler_Node *node_to_update,
> > - Priority_Control new_priority
> > + Scheduler_Node *node_to_extract
> > - _Scheduler_strong_APA_Node_downcast( node_to_update );
> > - _Scheduler_SMP_Node_update_priority( &node->Base, new_priority );
> > - _Scheduler_priority_Ready_queue_update(
> > - SCHEDULER_PRIORITY_UNMAP( new_priority ),
> > - &self->Bit_map,
> > - &self->Ready[ 0 ]
> > + Scheduler_strong_APA_Context *self;
> > -_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
> > - return (Scheduler_strong_APA_Context *) _Scheduler_Get_context(
> scheduler );
> > + self = _Scheduler_strong_APA_Get_self( context );
> > + node = _Scheduler_strong_APA_Node_downcast( node_to_extract );
> > + _Scheduler_SMP_Extract_from_scheduled( &self->Base.Base,
> &node->Base.Base );
> > + //Not removing it from All_nodes since the node could go in the ready
> state.
> *scheduler )
> > +static inline void _Scheduler_strong_APA_Extract_from_ready(
> > - _Scheduler_strong_APA_Get_context( scheduler );
> > - _Scheduler_SMP_Initialize( &self->Base );
> > - _Priority_bit_map_Initialize( &self->Bit_map );
> > - _Scheduler_priority_Ready_queue_initialize(
> > - &self->Ready[ 0 ],
> > - scheduler->maximum_priority
> > + _Assert( !_Chain_Is_empty(self->All_nodes) );
> > + _Assert( !_Chain_Is_node_off_chain( &node->Chain ) );
> > + _Chain_Extract_unprotected( &node->Chain ); //Removed from All_nodes
> All_nodes name is now confusing me. I thought maybe it meant blocked
> nodes too, but I understand now.
> You can call the All_nodes chain 'Ready'. It should be OK to leave
> Executing tasks on a Ready structure. That is how the uniprocessor
> schedulers work as I recall.
> > + _Chain_Set_off_chain( &node->Chain );
> > - const Scheduler_Control *scheduler,
> > +static inline void _Scheduler_strong_APA_Insert_ready(
> > - Scheduler_Context *context;
> > - Scheduler_strong_APA_Node *the_node;
> > - the_node = _Scheduler_strong_APA_Node_downcast( node );
> > - _Scheduler_SMP_Node_initialize(
> > - scheduler,
> > - &the_node->Base,
> > - the_thread,
> > - priority
> > - context = _Scheduler_Get_context( scheduler );
> > - &the_node->Ready_queue,
> > - SCHEDULER_PRIORITY_UNMAP( priority ),
> > - &self->Bit_map,
> > - &self->Ready[ 0 ]
> > + node = _Scheduler_strong_APA_Node_downcast( node_base );
> > + if(_Chain_Is_node_off_chain( &node->Chain ) )
> ws after if and { } needed
> > + _Chain_Append_unprotected( &self->All_nodes, &node->Chain );
> > -static bool _Scheduler_strong_APA_Has_ready( Scheduler_Context *context
> > +static inline void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
> > + Scheduler_Node *scheduled_to_ready
> > - return !_Priority_bit_map_Is_empty( &self->Bit_map );
> > + _Scheduler_SMP_Extract_from_scheduled( context, scheduled_to_ready );
> > + insert_priority = _Scheduler_SMP_Node_priority( scheduled_to_ready );
> > + _Scheduler_strong_APA_Insert_ready(
> > + context,
> > + scheduled_to_ready,
> > + insert_priority
> > -static Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
> > +static inline Scheduler_Node*
> _Scheduler_strong_APA_Get_lowest_reachable(
> > + uint32_t front,
> > + uint32_t rear,
> > + Per_CPU_Control **cpu_to_preempt
> > + Scheduler_Node *lowest_reachable;
> > + uint32_t cpu_max;
> > + Scheduler_strong_APA_Node *curr_strong_node; //Current
> Strong_APA_Node
> > + curr_thread = curr_CPU->heir;
> > + curr_strong_node = _Scheduler_strong_APA_Node_downcast( curr_node );
> > + lowest_reachable = curr_node;
> > + *cpu_to_preempt = curr_CPU;
> > + if ( !curr_thread->is_idle ) {
> > + if ( _Processor_mask_Is_set( &curr_strong_node->Affinity,
> cpu_index ) ) {
> > + //Checks if the thread_CPU is in the affinity set of the node
> > + if ( _Per_CPU_Is_processor_online( cpu ) && Struct[ cpu_index
> > + rear = rear + 1;
> > + Struct[ rear ].cpu = cpu;
> > + Struct[ cpu_index ].visited = true;
> > + Struct[ cpu_index ].caller = curr_node;
> maybe instead of caller it should be 'ancestor' or something similar
> to denote the ordering.
> > + return lowest_reachable;
> > +static inline bool _Scheduler_strong_APA_Do_enqueue(
> > + Scheduler_Node *lowest_reachable,
> > + Priority_Control insert_priority,
> > + Per_CPU_Control *cpu_to_preempt
> > - (void) node;
> > - return (Scheduler_Node *) _Scheduler_priority_Ready_queue_first(
> > - &self->Bit_map,
> > - &self->Ready[ 0 ]
> > + bool needs_help;
> > + Priority_Control node_priority;
> > + Priority_Control lowest_priority;
> Strong_APA_Node
> > + Thread_Control *next_thread;
> > + node_priority = _Scheduler_Node_get_priority( node );
> > + node_priority = SCHEDULER_PRIORITY_PURIFY( node_priority );
> > + lowest_priority = _Scheduler_Node_get_priority( lowest_reachable );
> > + lowest_priority = SCHEDULER_PRIORITY_PURIFY( lowest_priority );
> > + if( lowest_priority > node_priority ) {
> > + //_Thread_Get_CPU(lowest_reachable->user) to lowest_reachable,
> shifting
> > + //along every task
> > + curr_node = Struct[ _Per_CPU_Get_index(cpu_to_preempt) ].caller;
> > + curr_strong_node->invoker = cpu_to_preempt;
> > + //Save which cpu to preempt in invoker value of the node
> > + while( curr_node != node ) {
> ws after while, and delete at end of line
> > + curr_CPU = _Thread_Get_CPU( curr_node->user );
> > + curr_node = Struct[ _Per_CPU_Get_index( curr_CPU ) ].caller;
> > + curr_strong_node->invoker = curr_CPU;
> > + next_thread = curr_strong_node->invoker->heir;
> > + next_node = _Thread_Scheduler_get_home_node( next_thread );
> > + node_priority = _Scheduler_Node_get_priority( curr_node );
> > + _Scheduler_SMP_Enqueue_to_scheduled(
> > + context,
> > + curr_node,
> > + node_priority,
> > + next_node,
> > + _Scheduler_SMP_Insert_scheduled,
> > + _Scheduler_strong_APA_Move_from_scheduled_to_ready,
> > + curr_node = next_node;
> > + while( curr_node != lowest_reachable) {
> ws
> > + //curr_node preempts the next_node;
> > + context,
> > + curr_node,
> > + next_node,
> > + _Scheduler_strong_APA_Move_from_scheduled_to_ready(context,
> lowest_reachable);
> > + needs_help = false;
> > + } else {
> > + needs_help = true;
> > + //Add it to All_nodes chain since it is now either scheduled or just
> ready.
> > + _Scheduler_strong_APA_Insert_ready(context,node,insert_priority);
> ws in params
> > + return needs_help;
> > -void _Scheduler_strong_APA_Block(
> > +static inline bool _Scheduler_strong_APA_Enqueue(
> > - Scheduler_Context *context = _Scheduler_Get_context( scheduler );
> > + //Idea: BFS Algorithm for task arrival
> > + //Enqueue node either in the scheduled chain or in the ready chain
> > + //node is the newly arrived node and is not scheduled.
> > + uint32_t cpu_max;
> > + Per_CPU_Control *cpu_to_preempt;
> > + Scheduler_strong_APA_Node *strong_node;
> > + uint32_t front;
> > + uint32_t rear;
> > + front = 0;
> > + rear = -1;
> > - _Scheduler_SMP_Block(
> > + strong_node = _Scheduler_strong_APA_Node_downcast( node );
> > + if ( _Processor_mask_Is_set( &strong_node->Affinity, cpu_index) ) {
> > + rear = rear + 1;
> > + Struct[ cpu_index ].caller = node;
> > + //This assert makes sure that there always exist an element in the
> > + // Queue when we start the queue traversal.
> > + _Assert( !_Processor_mask_Zero( &strong_node->Affinity ) );
> > + lowest_reachable = _Scheduler_strong_APA_Get_lowest_reachable(
> > + self,
> > + front,
> > + rear,
> > + &cpu_to_preempt
> indents
> > + return _Scheduler_strong_APA_Do_enqueue(
> > + context,
> > + lowest_reachable,
> > + node,
> > + insert_priority,
> > + cpu_to_preempt
> indents
> > +static inline bool _Scheduler_strong_APA_Enqueue_scheduled(
> > + return _Scheduler_SMP_Enqueue_scheduled(
> > context,
> > - the_thread,
> > node,
> > - _Scheduler_SMP_Extract_from_scheduled,
> > + insert_priority,
> > + _Scheduler_SMP_Priority_less_equal,
> > _Scheduler_strong_APA_Extract_from_ready,
> > _Scheduler_strong_APA_Get_highest_ready,
> > + _Scheduler_strong_APA_Insert_ready,
> > _Scheduler_strong_APA_Move_from_ready_to_scheduled,
> > - _Scheduler_SMP_Allocate_processor_exact
> > -static bool _Scheduler_strong_APA_Enqueue(
> > +static inline bool _Scheduler_strong_APA_Do_ask_for_help(
> > + Thread_Control *the_thread,
> > - return _Scheduler_SMP_Enqueue(
> > + return _Scheduler_SMP_Ask_for_help(
> > context,
> > + the_thread,
> > node,
> > - insert_priority,
> > - _Scheduler_SMP_Get_lowest_scheduled,
> > + _Scheduler_strong_APA_Get_lowest_scheduled,
> > -static bool _Scheduler_strong_APA_Enqueue_scheduled(
> > +static inline void _Scheduler_strong_APA_Register_idle(
> > + Scheduler_Node *idle_base,
> > - return _Scheduler_SMP_Enqueue_scheduled(
> > + (void) context;
> > + (void) idle_base;
> > + (void) cpu;
> > + //We do not maintain a variable to access the scheduled
> > + //node for a CPU. So this function does nothing.
> > +static inline void _Scheduler_strong_APA_Do_set_affinity(
> > + void *arg
> > + const Processor_mask *affinity;
> > + affinity = arg;
> > + node->Affinity = *affinity;
> can simplify to:
> node->Affinity = (const Processor_mask *)arg;
> > +void _Scheduler_strong_APA_Initialize( const Scheduler_Control
> *scheduler )
> > + _Scheduler_strong_APA_Get_context( scheduler );
> two more spaces, need to indent 2 levels for line break
> > + _Scheduler_SMP_Initialize( &self->Base );
> > + _Chain_Initialize_empty( &self->All_nodes );
> > + Scheduler_Context *context = _Scheduler_Get_context( scheduler );
> > + _Scheduler_SMP_Yield(
> > context,
> > + thread,
> > node,
> > - insert_priority,
> > - _Scheduler_SMP_Priority_less_equal,
> > - _Scheduler_strong_APA_Get_highest_ready,
> > - _Scheduler_strong_APA_Insert_ready,
> > - _Scheduler_SMP_Insert_scheduled,
> > - _Scheduler_strong_APA_Move_from_ready_to_scheduled,
> > + _Scheduler_strong_APA_Enqueue,
> > + _Scheduler_strong_APA_Enqueue_scheduled
> > -void _Scheduler_strong_APA_Unblock(
> > +void _Scheduler_strong_APA_Block(
> > - _Scheduler_SMP_Unblock(
> > + //The extract from ready automatically removes the node from
> All_nodes chain.
> > + _Scheduler_SMP_Block(
> > context,
> > - the_thread,
> > + thread,
> > node,
> > - _Scheduler_strong_APA_Do_update,
> > - _Scheduler_strong_APA_Enqueue
> > + _Scheduler_strong_APA_Extract_from_scheduled,
> > + _Scheduler_strong_APA_Extract_from_ready,
> > + _Scheduler_strong_APA_Get_highest_ready,
> > + _Scheduler_strong_APA_Move_from_ready_to_scheduled,
> > -static bool _Scheduler_strong_APA_Do_ask_for_help(
> > - Scheduler_Context *context,
> > +void _Scheduler_strong_APA_Unblock(
> > - return _Scheduler_SMP_Ask_for_help(
> > + _Scheduler_SMP_Unblock(
> > context,
> > - the_thread,
> > + thread,
> > node,
> > - _Scheduler_strong_APA_Move_from_scheduled_to_ready,
> > - _Scheduler_SMP_Allocate_processor_lazy
> > + _Scheduler_strong_APA_Do_update,
> > @@ -327,7 +765,7 @@ void _Scheduler_strong_APA_Update_priority(
> > _Scheduler_SMP_Update_priority(
> > context,
> > - the_thread,
> > + thread,
> > node,
> > @@ -345,7 +783,11 @@ bool _Scheduler_strong_APA_Ask_for_help(
> > - return _Scheduler_strong_APA_Do_ask_for_help( context, the_thread,
> node );
> > + return _Scheduler_strong_APA_Do_ask_for_help(
> > + context,
> > + the_thread,
> > + node
> > @@ -381,7 +823,7 @@ void _Scheduler_strong_APA_Withdraw_node(
> > @@ -397,7 +839,7 @@ void _Scheduler_strong_APA_Add_processor(
> > idle,
> > _Scheduler_strong_APA_Has_ready,
> > _Scheduler_strong_APA_Enqueue_scheduled,
> > - _Scheduler_SMP_Do_nothing_register_idle
> > + _Scheduler_strong_APA_Register_idle
> why not use the Do_nothing?
> > @@ -416,20 +858,83 @@ Thread_Control
> > + _Scheduler_SMP_Node_initialize( scheduler, smp_node, the_thread,
> priority );
> > + _Processor_mask_Assign(
> > + &strong_node->Affinity,
> > + _SMP_Get_online_processors()
> > - _Scheduler_SMP_Yield(
> > + Scheduler_Context *context;
> > + context = _Scheduler_Get_context( scheduler );
> > + _Scheduler_SMP_Do_start_idle(
> > context,
> > - the_thread,
> > - node,
> > - _Scheduler_strong_APA_Extract_from_ready,
> > - _Scheduler_strong_APA_Enqueue,
> > - _Scheduler_strong_APA_Enqueue_scheduled
> > + idle,
> > + cpu,
> > + Processor_mask local_affinity;
> > + _Processor_mask_And( &local_affinity, &context->Processors, affinity
> > + if ( _Processor_mask_Is_zero( &local_affinity ) ) {
> > + return false;
> > + if ( _Processor_mask_Is_equal( &node->Affinity, affinity ) )
> > + return true; //Nothing to do. Return true.
> > + _Processor_mask_Assign( &node->Affinity, &local_affinity );
> > + _Scheduler_SMP_Set_affinity(
> > + context,
> > + thread,
> > + node_base,
> > + &local_affinity,
> > + _Scheduler_strong_APA_Do_set_affinity,
> > + return true;
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200825/3e50826a/attachment-0001.html>
